path: root/arch/mips/au1000/common/dbdma.c
2006-10-19[MIPS] A few more pt_regs fixups.Ralf Baechle
2006-09-26[PATCH] Alchemy: Delete unused pt_regs * argument from au1xxx_dbdma_chan_allocRalf Baechle
The third argument of au1xxx_dbdma_chan_alloc's callback function is not used anywhere. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[MIPS] au1xxx: export dbdma functionsDomen Puncer
These are needed for au1550_ac97 module. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[MIPS] au1xxx: dbdma, no sleeping under spin_lockDomen Puncer
kmalloc under spin_lock can't sleep. Signed-off-by: Domen Puncer <domen.puncer@ultra.si> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2005-10-29Remove useless casts of kmalloc return values.Ralf Baechle
2005-10-29Convert the remaining SPIN_LOCK_UNLOCKED instances to DEFINE_SPINLOCK.Ralf Baechle
2005-10-29Fix a cache snooping issue.Pete Popov
2005-10-29Cleaned up AMD Au1200 IDE driver:Pete Popov
- converted to platform bus - removed pci dependencies - removed virt_to_phys/phys_to_virt calls System now can root off of a disk. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> diff --git a/Documentation/mips/AU1xxx_IDE.README b/Documentation/mips/AU1xxx_IDE.README new file mode 100644
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Base Au1200 2.6 support.Pete Popov
