path: root/arch/mips/au1000/db1x00/irqmap.c
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] DBAu1xx0 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - macros with complex values not enclosed in parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - initialize variable instead of assigning value later where it makes sense; - insert spaces between operator and its operands, also remove excess spaces there; - remove unneeded numeric literal type casts; - remove needless parentheses; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typos/errors, capitalize acronyms, etc. in the comments; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first/last line; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2006-06-19[MIPS] Au1xxx: board specific irq code cleanupHerbert Valerio Riedel
Convert sizeof/sizeof use to use of ARRAY_SIZE macro, and annotate irqmap structures as __initdata. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
