path: root/arch/mips/au1000/mtx-1/board_setup.c
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MTX-1 code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - use of C99 // comments; - leading spaces instead of tabs; - brace not on the same line with 'else' in the 'if' statement; statement; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used. - including <asm/gpio.h> instead of <linux/gpio.h>. In addition to these changes, also do the following: - insert spaces between operator and its operands; - replace tab between the function type and name with space in mtx1_pci_idsel() declaration; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array/structure initializers; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-03arch/mips/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-09[MIPS] Alchemy: Fix USB initialization.Florian Fainelli
This patch fixes a wrong ifdef in the board setup code, leading to the GPIO pin not being pulled high, and thus the USB switch not being powered at all. This finishes the rename of CONFIG_USB_OHCI to CONFIG_USB_OHCI_HCD, which started in 2005 (before 2.6.12-rc2), then probably because things were working anyway for most people got forgotten. [Ralf: Paolo's original patch didn't fix the module case, Florian's patch only fixed MTX1 etc. so this is a combined patch plus some cleanups.] Cc: Giuseppe Patanè <giuseppe.patane@tvblob.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] MTX1: add idsel cardbus ressourcesFlorian Fainelli
Adds cardbus ressources for MTX1 boards which have a PCMCIA controller. Signed-off-by: Florian Fainelli <florian.fainelli@int-evry.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] MTX1: remove unneeded settingsFlorian Fainelli
This patch removes unnecessary settings at setup time. Signed-off-by: Florian Fainelli <florian.fainelli@int-evry.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Alchemy: nuke usbdev; it's useless as is ...Ralf Baechle
