It's more than the au1000 these days.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
Fix many errors and warnings given by checkpatch.pl:
- space after opening and before closing parentheses;
- use of C99 // comments;
- leading spaces instead of tabs;
- brace not on the same line with 'else' in the 'if' statement;
statement;
- printk() without KERN_* facility level;
- using simple_strtol() where strict_strtol() could be used.
- including <asm/gpio.h> instead of <linux/gpio.h>.
In addition to these changes, also do the following:
- insert spaces between operator and its operands;
- replace tab between the function type and name with space in
mtx1_pci_idsel() declaration;
- remove space after the type cast's closing parenthesis;
- insert missing space before closing brace in the array/structure
initializers;
- update MontaVista copyright;
- remove Pete Popov's old email address...
Go thru the Alchemy code and hunt down every unneeded #include, #define, and
extern (some of which refer to already long dead functions).
This patch adds support for the GPIO connected system button on the MTX-1
boards. Default configuration is updated accordingly.
Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu>
This patch separates the platform devices registration for the MTX-1
specific devices: GPIO leds and watchdog.
[Minor fixup and formatting change -- Ralf]
