path: root/arch/mips/au1000/mtx-1
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-30[MIPS] Initialization of Alchemy boardsKevin Hickey
An earlier update changed some calls from simple_strotl to strict_strtol but did not account for the differences in the syntax between the calls. simple_strotl returns the integer; strict_strtol returns an error code and takes a pointer to the result. As it was, NULL was being passed in place of the result, which led to failures during kernel initialization when using YAMON. Signed-off-by: Kevin Hickey <khickey@rmicorp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] MTX-1 flash partition setup move to platform devices registrationYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] MTX-1 code style cleanupSergei Shtylyov
Fix many errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - use of C99 // comments; - leading spaces instead of tabs; - brace not on the same line with 'else' in the 'if' statement; statement; - printk() without KERN_* facility level; - using simple_strtol() where strict_strtol() could be used. - including <asm/gpio.h> instead of <linux/gpio.h>. In addition to these changes, also do the following: - insert spaces between operator and its operands; - replace tab between the function type and name with space in mtx1_pci_idsel() declaration; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array/structure initializers; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-03arch/mips/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-29[MIPS] MTX-1: Add GPIO system buttonFlorian Fainelli
This patch adds support for the GPIO connected system button on the MTX-1 boards. Default configuration is updated accordingly. Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unused mips_machtypeYoichi Yuasa
Removed unused mips_machtype. These are only set but not used. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] mtx-1: Enable -Werror.Ralf Baechle
2007-11-02[MIPS] mtx-1: Remove unused mtx1_sys_btn.Ralf Baechle
2007-10-29[MIPS] Alchemy: Register platform devicesFlorian Fainelli
This patch separates the platform devices registration for the MTX-1 specific devices: GPIO leds and watchdog. [Minor fixup and formatting change -- Ralf] Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-09[MIPS] Alchemy: Fix USB initialization.Florian Fainelli
This patch fixes a wrong ifdef in the board setup code, leading to the GPIO pin not being pulled high, and thus the USB switch not being powered at all. This finishes the rename of CONFIG_USB_OHCI to CONFIG_USB_OHCI_HCD, which started in 2005 (before 2.6.12-rc2), then probably because things were working anyway for most people got forgotten. [Ralf: Paolo's original patch didn't fix the module case, Florian's patch only fixed MTX1 etc. so this is a combined patch plus some cleanups.] Cc: Giuseppe Patanè <giuseppe.patane@tvblob.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Florian Fainelli <florian.fainelli@telecomint.eu> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] MTX1: add idsel cardbus ressourcesFlorian Fainelli
Adds cardbus ressources for MTX1 boards which have a PCMCIA controller. Signed-off-by: Florian Fainelli <florian.fainelli@int-evry.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] MTX1: remove unneeded settingsFlorian Fainelli
This patch removes unnecessary settings at setup time. Signed-off-by: Florian Fainelli <florian.fainelli@int-evry.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Alchemy: nuke usbdev; it's useless as is ...Ralf Baechle
2006-06-19[MIPS] Au1xxx: board specific irq code cleanupHerbert Valerio Riedel
Convert sizeof/sizeof use to use of ARRAY_SIZE macro, and annotate irqmap structures as __initdata. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Arrested for multiple offences of header file inclusion.Ralf Baechle
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
