It's more than the au1000 these days.
Fix several errors and warnings given by checkpatch.pl:
- space between asterisk and variable name;
- use of C99 // comments;
- using simple_strtol() where strict_strtol() could be used.
In addition to these changes, also do the following:
- properly indent the code;
- remove space after the type cast's closing parenthesis;
- replace numeric literals/expressions with the matching macros;
- replace spaces after the macro name with tabs in the #define directives,
and sometimes insert spaces there;
- fix typos/errors, capitalize acronyms, etc. in the comments;
- make the multi-line comment style consistent with the kernel style
elsewhere by adding empty first line;
- update MontaVista copyright;
- remove Pete Popov's old email address...
infrastructure for it.
Let it rip!
