path: root/arch/mips/au1000/pb1200/board_setup.c
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1200/DBAu1200 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - initialization of a 'static' variable to 0; - space after opening and before closing parentheses; - missing space between 'for' and opening parenthesis; - macros with complex values not enclosed in parentheses; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used; - line over 80 characters. In addition to these changes, also do the following: - mention DBAu1200 board in the Makefile; - replace the group of #include/#ifdef directives by a single #include <au1xxx.h> since this header contains the needed stuff; - properly indent the blocks; - insert spaces between operator and its operands, remove excess spaces there; - remove needless parentheses and add some for clarity; - replace numeric literals/expressions with the matching macros; - remove space after the type cast's closing parenthesis; - reduce pb1200_setup_cascade() to the single 'return' statement; - reduce the number of printed empty lines in the so-called CPLD workaround; - remove #undef AU1X00_EXTERNAL_INT since that macro is not defined anywhere; - replace spaces after the macro name with tabs in the #define directives; - remove excess tabs after the macro name in the #define directives; - fix typo in the BCSR_RESETS_PWMR1mUX macro's name; - group all Pb1200 PCMCIA definitions together; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - fix typos/errors, capitalize acronyms, etc. in the comments; - combine some comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] Pb1200: Fix warning.Ralf Baechle
arch/mips/au1000/pb1200/board_setup.c:71: warning: unused variable 'pin_func' Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-15add new prom.h for AU1x00Yoichi Yuasa
Add new prom.h for AU1x00. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-13[MIPS] Alchemy: Remove code wrapped by dead symbol CONFIG_AU1XXX_PSC_SPIRalf Baechle
Noticed by Robert P. J. Day (rpjday@mindspring.com). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] PB1200: Remove duplicate definitionsYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Misc au1200 updates.Pete Popov
2005-10-29Int controller fixes.Pete Popov
2005-10-29Base Au1200 2.6 support.Pete Popov
