path: root/arch/mips/au1000/pb1500/irqmap.c
2008-10-11MIPS: Alchemy: rename directoryRalf Baechle
It's more than the au1000 these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Pb1500 code style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - use of C99 // comments; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - using simple_strtol() where strict_strtol() could be used. In addition to these changes, also do the following: - replace numeric literals/expressions with the matching macros; - insert spaces between operator and its operands; - properly indent the code and the array initializers; - remove useless #if dirctive from board_setup(); - remove needless parentheses; - remove unneeded type casts; - remove excess new lines; - make hexadecimal literals all lower case; - remove space after the type cast's closing parenthesis; - insert missing space before closing brace in the array initializers; - replace spaces after the macro name with tabs in the #define directives, also sometimes insert space there for better looks; - fix typos/errors, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2006-06-19[MIPS] Au1xxx: board specific irq code cleanupHerbert Valerio Riedel
Convert sizeof/sizeof use to use of ARRAY_SIZE macro, and annotate irqmap structures as __initdata. Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
