path: root/arch/mips/bcm47xx
2008-02-19[MIPS] BCM47XX: Use new SSB SPROM data structureAurelien Jarno
Switch the BCM47XX code to the new SPROM data structure now that the old one has been removed. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-19[MIPS] WGT634U: Register MTD as platform device.Aurelien Jarno
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] GPIO LED driver for the WGT634U machineAurelien Jarno
Add LED support to the WGT634U machine. It uses the new gpio-led driver and a platform driver for the pin definitions. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add gpio support to the BCM47XX platformAurelien Jarno
Add GPIO support to the BCM47XX platform. It will be used by a GPIO LED driver. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add CFE support to BCM47XXAurelien Jarno
Add CFE support to the BCM47XX code. That includes querying CFE environment variables as well as using CFE to print messages before the serial port is initialized (early printk). Signed-off-by: Aurelien Jarno <aurel32@farad.aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add support for BCM47XX CPUs.Aurelien Jarno
Note that the BCM4710 does not support the wait instruction, this is not a mistake in the code. It originally comes from the OpenWrt patches. Cc: Michael Buesch <mb@bu3sch.de> Cc: Felix Fietkau <nbd@openwrt.org> Cc: Florian Schirmer <jolt@tuxbox.org> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
