path: root/arch/mips/cobalt
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-20[MIPS] Cobalt: Fix I/O port resource rangeYoichi Yuasa
LCD and buttons don't use I/O port space. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Cobalt: Register new LCD platform device.Yoichi Yuasa
2008-01-29[MIPS] add cpu_wait() to machine_halt()Yoichi Yuasa
Added cpu_wait() to machine_halt(). For the power reduction in halt. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] remove unneeded button check for resetYoichi Yuasa
Removed unneeded button check for reset. Because, the Cobalt has power switch. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-15[MIPS] Cobalt: Qube1 has no serial port so don't use itThomas Bogendoerfer
Because Qube1 doesn't have a serial chip waiting for transmit fifo empty takes forever, which isn't a good idea. No prom_putchar/early console for Qube1 fixes this. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] time: Set up Cobalt's mips_hpt_frequencyYoichi Yuasa
2007-10-22[MIPS] time: Add GT641xx timer0 clockevent driverYoichi Yuasa
And make use of it for Cobalt. A few others such as the Malta could make use of it as well. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Remove cobalt_machine_power_off()Yoichi Yuasa
It's same as cobalt_machine_halt(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Move reset port definition to arch/mips/cobalt/reset.cYoichi Yuasa
It's only used in arch/mips/cobalt/reset.c. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Move UART base definition to arch/mips/cobalt/console.cYoichi Yuasa
They're only used in arch/mips/cobalt/console.c. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Add Qube series front LED support to platform registerYoichi Yuasa
Add Cobalt Qube series front LED support to platform register. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Add Cobalt Raq LED platform register and power off triggerYoichi Yuasa
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add GT641xx IRQ routines.Yoichi Yuasa
2007-10-11[MIPS] cleanup struct irqaction initializersThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Cobalt: Enable UART on RaQ1Martin Michlmayr
Unlike the current code suggests, the RaQ1 actually has an UART. Only the Qube1 (Qube 2700) lacks one. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-06-26[MIPS] add io_map_base to pci_controller on CobaltYoichi Yuasa
2007-05-11[MIPS] Rework cobalt_board_idYoichi Yuasa
This patch has reworked cobalt_board_id. The cobalt_board_id is read from PCI config register. It should be in PCI routine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] Use RTC_CMOS for CobaltYoichi Yuasa
2007-05-11[MIPS] Use platform_device for Cobalt UARTYoichi Yuasa
2007-05-01Merge master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
Conflicts: drivers/usb/input/Makefile drivers/usb/input/gtco.c
2007-04-27[MIPS] merge GT64111 PCI routines and GT64120 PCI_0 routinesYoichi Yuasa
This patch has merged GT64111 PCI routines and GT64120 PCI_0 routines. GT64111 PCI is almost the same as GT64120's PCI_0. This patch don't change GT64120 PCI routines. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: Split PCI codes from setup.cYoichi Yuasa
It's removed #ifdef CONFIG_PCI/#endif from cobalt setup.c . Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: clean up include filesYoichi Yuasa
2007-04-12Input: cobalt buttons - separate device and driver registrationDmitry Torokhov
Create platform device for cobalt buttons as part of arch setup. This makes the driver follow current driver model more closely. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
2007-03-07[MIPS] Cobalt: Fix early printkYoichi Yuasa
2007-03-04[MIPS] Cobalt: update reserved resourcesYoichi Yuasa
This patch has removed unused timer resource. Moreover, the name of reserved resources ware changed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-22[MIPS] Cobalt: Rename "Colo" MTD partition to "firmware".Ralf Baechle
2007-02-20Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [NET] Eliminate user-selectable CONFIG_MV643XX_ETH_[012] [MIPS] Drop __init from init_8259A() [MIPS] Fix Kconfig typo bug [MIPS] Fix double signal on trap and break instruction [MIPS] sigset_32 has been made redundand by compat_sigset_t. [MIPS] emma2rh: Remove needless <asm/i8259.h> inclusion. [MIPS] Add MTD device support for Cobalt
2007-02-20[MIPS] Add MTD device support for CobaltYoichi Yuasa
This patch has added MTD device support for Cobalt. Moreover, removes old type FlashROM support. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[MIPS] Cobalt: Fix UART I/O typeYoichi Yuasa
The Cobalt UART is actually connected to memory resource area. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Rewrite GALILEO_INL/GALILEO_OUTL to GT_READ/GT_WRITEYoichi Yuasa
This patch has rewritten GALILEO_INL/GALILEO_OUTL using GT_READ/GT_WRITE. This patch tested on Cobalt Qube2. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-08[MIPS] Cobalt: Time runs too quicklyScott Ashcroft
A kernel built with HZ==250 runs about 4 four times too quickly on a Cobalt RaQ2. Signed-off-by: Scott Ashcroft <scott.ashcroft@talk21.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[SERIAL] Remove wrong asm/serial.h inclusionsRussell King
asm/serial.h is supposed to contain the definitions for the architecture specific 8250 ports for the 8250 driver. It may also define BASE_BAUD, but this is the base baud for the architecture specific ports _only_. Therefore, nothing other than the 8250 driver should be including this header file. In order to move towards this goal, here is a patch which removes some of the more obvious incorrect includes of the file. Acked-by: Paul Fulghum <paulkf@microgate.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] C99-ify struct resource initialization.Ralf Baechle
2006-06-19[MIPS] Cobalt: Fix undefined reference to disable_early_printk.Yoichi Yuasa
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] Add early console for Cobalt.Peter Horton
Signed-off-by: Peter Horton <pdh@colonel-panic.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
