path: root/arch/mips/jazz
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: Jazz: Migrate to new platform makefile style.Ralf Baechle
2010-04-30MIPS: Fixup screen_info struct initializationsSebastian Andrzej Siewior
|arch/mips/sibyte/swarm/setup.c:153: | warning: large integer implicitly truncated to unsigned type The field was changed in d9b26352 aka ("x86, setup: Store the boot cursor state"). This patch changes the values back they way they were before this extra field got introduced. While here, the other two boards are also converted to C99 initializer. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1137/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-27MIPS: Jazz: Convert irq controller lock to raw spinlock.Ralf Baechle
2009-11-02MIPS: Add IRQF_TIMER flag for timer interruptsWu Zhangjin
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER flag for all timer interrupts This ensures that timer interrupts won't be disabled on suspend and not threaded for PREEMPT_RT. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Jazz: Fix read buffer overflowRoel Kluin
Check whether index is within bounds before testing the element. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: oprofile: Thou shalt not call __exit functions from __init functions cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic cpumask: remove cpumask_t from core cpumask: convert rcutorture.c cpumask: use new cpumask_ functions in core code. cpumask: remove references to struct irqaction's mask field. cpumask: use mm_cpumask() wrapper: kernel/fork.c cpumask: use set_cpu_active in init/main.c cpumask: remove node_to_first_cpu cpumask: fix seq_bitmap_*() functions. cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
2009-03-30MIPS: Use BUG_ON() where possible.Ralf Baechle
Based on original patch by Stoyan Gaydarov <stoyboyker@gmail.com> which missed a few places. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30cpumask: remove references to struct irqaction's mask field.Rusty Russell
Impact: cleanup It's unused, since about 1995. So remove all initialization of it in preparation for actually removing the field. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-08-26[MIPS] Jazz: Fix build error by header file inclusion weeding.Ralf Baechle
2008-08-05remove unneeded #include <linux/ide.h>'sAdrian Bunk
This patch remove unneeded #include <linux/ide.h>'s. It also adds a required #include <linux/interrupt.h> that was previously implicitely pulled by ide.h Signed-off-by: Adrian Bunk <bunk@kernel.org> [bart: revert change to tests/lkdtm.c (spotted by Stephen Rothwell)] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-08-05remove unnecessary <linux/hdreg.h> includesBartlomiej Zolnierkiewicz
Following files don't need <linux/hdreg.h> at all: - arch/mips/jazz/setup.c - arch/sh/boards/mach-systemh/irq.c - drivers/macintosh/mediabay.c - drivers/scsi/hptiop.c - drivers/usb/storage/freecom.c - arch/powerpc/include/asm/ide.h - init/main.c Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15[MIPS] Remove mips_machtype from ARC based machinesThomas Bogendoerfer
This is the ARC part of the mips_machtype removal. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Remove obsolete isa_slot_offsetMaciej W. Rozycki
The isa_slot_offset variable and its __ISA_IO_base macro is not used anywhere anymore. It does not look like a decent interface per today's standards either. Remove both including all places of initialization. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Cleanup pcspeaker platform device registration.Ralf Baechle
Move registration into the actual platform code instead of making a desparate attempt at sharing the hand full of likes of code in pcspeaker.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] Jazz: disable PIT; cleanup R4030 clockeventThomas Bogendoerfer
Fix ISA irq acknowledge. Make r4030 clockevent code look like other mips clockevent code. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-18[MIPS] Jazz: Retire use of plat_timer_setup.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Jazz clockevent driverRalf Baechle
2007-10-11[MIPS] JAZZ fixesThomas Bogendoerfer
- restructured irq handling - switched vdma to use memory allocated via get_free_pages - setup platform devices for serial, jazz_esp and jazzsonic - fixed cmos rtc access Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-24[MIPS] Jazz: remove unneeded reset functionsYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-24[MIPS] Jazz: Remove unused arch/mips/jazz/io.cYoichi Yuasa
2007-07-10[MIPS] Put an end to <asm/serial.h>'s long and annyoing existenceRalf Baechle
2007-06-28mips-jazz: correct flags for timer io resourceAlexey Dobriyan
arch/mips/jazz/setup.c:55:4: error: Initializer entry defined twice Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-24[MIPS] Jazz: Fix warning.Ralf Baechle
arch/mips/jazz/jazzdma.c:70: warning: assignment makes integer from pointer without a cast Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-19[MIPS] Misc fixes for plat_irq_dispatch functionsThiemo Seufer
o adds missing ST0_IM masks, which caused the logging of valid interrupts as spurious o stops pnx8550 to log every interrupt as spurious o adds cause register masks for ip22/ip32, which caused handling of masked interrupts o removes some superfluous parentheses in the SNI interrupt code Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] Compile __do_IRQ() when really neededFranck Bui-Huu
__do_IRQ() is needed only by irq handlers that can't use default handlers defined in kernel/irq/chip.c. For others platforms there's no need to compile this function since it won't be used. For those platforms this patch defines GENERIC_HARDIRQS_NO__DO_IRQ symbol which is used exactly for this purpose. Futhermore for platforms which do not use __do_IRQ(), end() method which is part of the 'irq_chip' structure is not used. This patch simply removes this method in this case. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] use generic_handle_irq, handle_level_irq, handle_percpu_irqAtsushi Nemoto
Further incorporation of generic irq framework. Replacing __do_IRQ() by proper flow handler would make the irq handling path a bit simpler and faster. * use generic_handle_irq() instead of __do_IRQ(). * use handle_level_irq for obvious level-type irq chips. * use handle_percpu_irq for irqs marked as IRQ_PER_CPU. * setup .eoi routine for irq chips possibly used with handle_percpu_irq. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-11[MIPS] Fix timer setup for JazzYoichi Yuasa
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-09[MIPS] Jazz: build fix - include <linux/screen_info.h>Ralf Baechle
2006-10-09[MIPS] Jazz: Remove warning. After 7 years probably somebody test this ;)Ralf Baechle
2006-10-09[MIPS] Jazz: Fix I/O port resources.Ralf Baechle
struct resource members were shuffeled a while ago. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Rewrite spurious_interrupt from assembler to C.Ralf Baechle
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
