The commit ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
caused building a 64 bit kernel with support for n32 and not o32
to produce a build error:
arch/mips/kernel/signal32.c:415:11: error: ‘vdso_image_o32’ undeclared here (not in a function)
.vdso = &vdso_image_o32,
Fix this by moving the o32 specific code into signal_o32.c and
updating the Makefile accordingly.
Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Alex Smith <alex@alex-smith.me.uk>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/13690/
arch/mips/kernel/relocate.c contains the functions necessary to relocate
the kernel elsewhere in memory
The kernel makes a copy of itself at the new address. It uses the
relocation table inserted by the relocs tool to fix symbol references
within the new image.
If copy/relocation is sucessful then the entry point of the new kernel
is returned, otherwise fall back to starting the kernel in place.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: kernel-hardening@lists.openwall.com
Patchwork: https://patchwork.linux-mips.org/patch/12985/
Import bmips_5xxx_init.S from the stblinux-3.3 tree, and to make sure that this
would work nicely with a BMIPS multiplatform kernel (with BMIPS330, BMIPS43XX
and BMIPS5000 enabled), update soft_reset to check for the BMIPS5200 processor
id (PRID_IMP_BMIPS5200) and execute bmips_5xxx_init for these processors to
bring them online.
Tested on 7425, 7429 and 7435 with CPU hotplug. 7435 SMP still needs some
additional changes in the L1 interrupt area to work properly with interrupt
affinity.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: john@phrozen.org
Cc: cernekee@gmail.com
Cc: jon.fraser@broadcom.com
Cc: jaedon.shin@gmail.com
Cc: dragan.stancevic@gmail.com
Cc: jogo@openwrt.org
Patchwork: https://patchwork.linux-mips.org/patch/12377/
We now have a generic IPI layer that will use GIC automatically
if it's compiled in.
Signed-off-by: Qais Yousef <qais.yousef@imgtec.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: <jason@lakedaemon.net>
Cc: <marc.zyngier@arm.com>
Cc: <jiang.liu@linux.intel.com>
Cc: <linux-mips@linux-mips.org>
Cc: <lisa.parratt@imgtec.com>
Cc: Qais Yousef <qsyousef@gmail.com>
Link: http://lkml.kernel.org/r/1449580830-23652-19-git-send-email-qais.yousef@imgtec.com
Provide support for outputting early debug information, in the form of
various register values should an exception occur, during the early
bringup of secondary cores. This code requires an ns16550-compatible
UART accessible from the secondary core, and is written in assembly due
to the environment in which such early exceptions occur where way may
not have a stack, be coherent or even have initialised caches.
[ralf@linux-mips.org: Fix merge conflict.]
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/11202/
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 4.3 for MIPS. Here's the summary:
Three fixes that didn't make 4.2-stable:
- a -Os build might compile the kernel using the MIPS16 instruction
set but the R2 optimized inline functions in <uapi/asm/swab.h> are
implemented using 32-bit wide instructions which is invalid.
- a build error in pgtable-bits.h for a particular kernel
configuration.
- accessing registers of the CM GCR might have been compiled to use
64 bit accesses but these registers are onl 32 bit wide.
And also a few new bits:
- move the ATH79 GPIO driver to drivers/gpio
- the definition of IRQCHIP_DECLARE has moved to linux/irqchip.h,
change ATH79 accordingly.
- fix definition of pgprot_writecombine
- add an implementation of dma_map_ops.mmap
- fix alignment of quiet build output for vmlinuz link
- BCM47xx: Use kmemdup rather than duplicating its implementation
- Netlogic: Fix 0x0x prefixes of constants.
- merge Bjorn Helgaas' series to remove most of the weak keywords
from function declarations.
- CP0 and CP1 registers are best considered treated as unsigned
values to avoid large values from becoming negative values.
- improve support for the MIPS GIC timer.
- enable common clock framework for Malta and SEAD3.
- a number of improvments and fixes to dump_tlb().
- document the MIPS TLB dump functionality in Magic SysRq.
- Cavium Octeon CN68XX improvments.
- NetLogic improvments.
- irq: Use access helper irq_data_get_affinity_mask.
- handle MSA unaligned accesses.
- a number of R6-related math-emu fixes.
- support for I6400.
- improvments to MSA support.
- add uprobes support.
- move from deprecated __initcall to arch_initcall.
- remove finish_arch_switch().
- IRQ cleanups by Thomas Gleixner.
- migrate to new 'set-state' interface.
- random small cleanups"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (148 commits)
MIPS: UAPI: Fix unrecognized opcode WSBH/DSBH/DSHD when using MIPS16.
MIPS: Fix alignment of quiet build output for vmlinuz link
MIPS: math-emu: Remove unused handle_dsemul function declaration
MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction
MIPS: math-emu: Add support for the MIPS R6 RINT FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELNEZ FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELEQZ FPU instruction
MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction
MIPS: inst.h: Add new MIPS R6 FPU opcodes
MIPS: Octeon: Fix management port MII address on Kontron S1901
MIPS: BCM47xx: Use kmemdup rather than duplicating its implementation
STAGING: Octeon: Use common helpers for determining interface and port
MIPS: Octeon: Support interfaces 4 and 5
MIPS: Octeon: Set up 1:1 mapping between CN68XX PKO queues and ports
MIPS: Octeon: Initialize CN68XX PKO
STAGING: Octeon: Support CN68XX style WQE
While at it, rename it because in drivers/irqchip no longer every CPU is
a MIPS.
Add a MIPS specific SysRq operation to dump the TLB entries on all CPUs,
using the 'x' trigger key.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10072/
MIPS R6 removed quite a few R2 instructions. However, there
is plenty of <R6 userland code so we add an in-kernel emulator
so we can still be able to execute all R2 userland out there.
The emulator comes with a handy debugfs under /mips/ directory
(r2-emul-stats) to provide some basic statistics of the
instructions that are being emulated.
Below are some statistics from booting a minimal buildroot image:
Instruction Total BDslot
movs 236969 0
hilo 56686 0
muls 55279 0
divs 10941 0
dsps 0 0
bops 1 0
traps 0 0
fpus 0 0
loads 214981 17
stores 103364 0
llsc 56898 0
dsemul 150418 0
jr 370158
bltzl 43
bgezl 1594
bltzll 0
bgezll 0
bltzal 39
bgezal 39
beql 14503
bnel 138741
blezl 0
bgtzl 3988
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
MIPS R6, just like MIPS R2, have scratch pad storage, so add a new
symbol which is selected by MIPS R2 and R6.
Link: http://www.linux-mips.org/archives/linux-mips/2015-01/msg00389.html
Combine the GIC clocksource driver with the GIC clockevent driver from
arch/mips/kernel/cevt-gic.c and remove the clockevent driver's separate
Kconfig symbol.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: John Crispin <blogic@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/8132/
Move the GIC clocksource driver to drivers/clocksource/mips-gic-timer.c.
Patchwork: https://patchwork.linux-mips.org/patch/8133/
This patch reads the .MIPS.abiflags section when it is present, and sets
the FP mode of the task accordingly. Any loaded ELF files which do not
contain a .MIPS.abiflags section will continue to observe the previous
behaviour, that is FR=1 if EF_MIPS_FP64 is set else FR=0.
Cc: linux-fsdevel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7681/
Move GIC irqchip support to drivers/irqchip/ and rename the Kconfig
option from IRQ_GIC to MIPS_GIC to avoid confusion with the ARM GIC.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Reviewed-by: Qais Yousef <qais.yousef@imgtec.com>
Tested-by: Qais Yousef <qais.yousef@imgtec.com>
Cc: Jeffrey Deans <jeffrey.deans@imgtec.com>
Cc: Jonas Gorski <jogo@openwrt.org>
Cc: David Daney <ddaney.cavm@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/7812/
Some versions of the assembler will not assemble CFC1 for OCTEON, so
override the ISA for these.
Add r4k_fpu.o to handle low level FPU initialization.
Modify octeon_switch.S to save the FPU registers. And include
r4k_switch.S to pick up more FPU support.
Get rid of "#define cpu_has_fpu 0"
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Cc: kvm@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7006/
mips-for-linux-next
This patch adds code to generate entry & exit code for various low power
states available on systems based around the MIPS Coherent Processing
System architecture (ie. those with a Coherence Manager, Global
Interrupt Controller & for >=CM2 a Cluster Power Controller). States
supported are:
- Non-coherent wait. This state first leaves the coherent domain and
then executes a regular MIPS wait instruction. Power savings are
found from the elimination of coherency interventions between the
core and any other coherent requestors in the system.
- Clock gated. This state leaves the coherent domain and then gates
the clock input to the core. This removes all dynamic power from the
core but leaves the core at the mercy of another to restart its
clock. Register state is preserved, but the core can not service
interrupts whilst its clock is gated.
- Power gated. This deepest state removes all power input to the core.
All register state is lost and the core will restart execution from
its BEV when another core powers it back up. Because register state
is lost this state requires cooperation with the CONFIG_MIPS_CPS SMP
implementation in order for the core to exit the state successfully.
The code will detect which states are available on the current system
during boot & generate the entry/exit code for those states. This will
be used by cpuidle & hotplug implementations.
Nobody is maintaining SMTC anymore and there also seems to be no userbase.
Which is a pity - the SMTC technology primarily developed by Kevin D.
Kissell <kevink@paralogos.com> is an ingenious demonstration for the MT
ASE's power and elegance.
Based on Markos Chandras <Markos.Chandras@imgtec.com> patch
https://patchwork.linux-mips.org/patch/6719/ which while very similar did
no longer apply cleanly when I tried to merge it plus some additional
post-SMTC cleanup - SMTC was a feature as tricky to remove as it was to
merge once upon a time.
Add a CPU power management notifier callback for preserving general CPU
context. The CPU PM callbacks will be triggered by the powering down of
CPU cores, for example by cpuidle drivers & in the future by suspend to
RAM implementations.
The current state preserved is mostly related to the process context:
- FPU
- DSP
- ASID
- UserLocal
- Watch registers
This patch introduces a new SMP implementation for systems implementing
the MIPS Coherent Processing System architecture. The kernel will make
use of the Coherence Manager, Cluster Power Controller & Global
Interrupt Controller in order to detect, bring up & make use of other
cores in the system. SMTC is not supported, so only a single TC per VPE
in the system is used. That is, this option enables an SMVP style setup
but across multiple cores.
Patchwork: https://patchwork.linux-mips.org/patch/6362/
Patchwork: https://patchwork.linux-mips.org/patch/6611/
Patchwork: https://patchwork.linux-mips.org/patch/6651/
Patchwork: https://patchwork.linux-mips.org/patch/6652/
This patch introduces code to probe for a MIPS Cluster Power Controller
& accessor functions to allow for easy register access. This support
code will be used by a subsequent patch.
Patchwork: https://patchwork.linux-mips.org/patch/6361/
The kernel currently only probes for a MIPS Coherence Manager in the
Malta interrupt code in order to detect & enable the GIC. However CM is
not Malta-specific, so this should really be more generic. This patch
introduces some non-Malta-specific code which probes for a CM and
performs some basic initialisation.
A new header, with temporarily duplicated register definitions, is
introduced in order to:
1) Allow the new definitions to be correct with regards to the
CM documentation, as many of those in gcmpregs.h aren't.
2) Allow switching away from the REG() macro used via a few layers of
nested macros in order to access registers in gcmpregs.h. This
patch instead introduced accessor functions akin to the
{read,write}_c0_* functions used for cop0 registers.
3) Allow users of the CM to be migrated one by one.
4) Switch from the name 'GCMP' to 'CM' since the Coherence Manager is
what this code is actually dealing with.
Patchwork: https://patchwork.linux-mips.org/patch/6360/
The GIC IPI functions aren't necessarily specific to the "CMP
framework" SMP implementation, and will be used elsewhere in a
subsequent commit. This patch adds cleaned up GIC IPI functions to a
separate file which is compiled when a new CONFIG_MIPS_GIC_IPI Kconfig
symbol is selected, and selects that symbol for CONFIG_MIPS_CMP.
Patchwork: https://patchwork.linux-mips.org/patch/6359/
This patch adds RTLX API support for platforms having a CMP.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Reviewed-by: Qais Yousef <Qais.Yousef@imgtec.com>
Patchwork: http://patchwork.linux-mips.org/patch/6095/
Reviewed-by: John Crispin <blogic@openwrt.org>
Split the RTLX functionality in preparation for adding support for CMP
platforms. Common functions remain in the original file and a new file
contains code specific to platforms that do not have a CMP.
Patchwork: http://patchwork.linux-mips.org/patch/6093/
This patch adds VPE loader support for platforms having a CMP.
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6092/
Split the VPE functionality in preparation for adding support
for CMP platforms. Common functions remain in the original file
and a new file contains code specific to platforms that do not
have a CMP present.
Patchwork: http://patchwork.linux-mips.org/patch/6094/
Add a new mips/segments debugfs file to print the 6 segmentation
control registers for supported cores. A sample from a proAptiv core
is given below:
Patchwork: http://patchwork.linux-mips.org/patch/6137/
Segment Virtual Size Access Mode Physical Caching EU
0 e0000000 512M MK UND U 0
1 c0000000 512M MSK UND U 0
2 a0000000 512M UK 000 2 0
3 80000000 512M UK 000 3 0
4 40000000 1G MUSK UND U 1
5 00000000 1G MUSK UND U 1
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Nobody seems to care about this platform anymore and my attempts to find
somebody willing to provide some tlc for PowerTV have failed so far.
So let's nuke the bloody thing.
Patchwork: https://patchwork.linux-mips.org/patch/5910/
The generic version is wrong for MIPS.
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Cc: linux-mips <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/947/
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
git://git.linux-mips.org/pub/scm/sjhill/linux-sjhill into mips-for-linux-next
Add new clockevent driver that uses the counter present on the MIPS
Global Interrupt Controller.
Signed-off-by: Raghu Gandham <Raghu.Gandham@imgtec.com>
Reorganize some of the GIC clocksource driver code. Below is a list of
the various changes.
* No longer select CSRC_GIC by default for Malta platform.
* Limit choice for either the GIC or R4K clocksource, not both.
* Change location in Makefile.
* Created new 'gic_read_count' function in common 'irq-gic.c' file.
* Change 'git_hpt_read' function in 'csrc-gic.c' to use new function.
* Surround GIC specific code in Malta platform code with #ifdef's.
* Only initialize the GIC clocksource if it was selected. Original
code called it unconditionally if a GIC was found.
Previously this functionality was only available to users of the mips_machine
api. Moving the code to prom.c allows us to also add a OF wrapper.
Patchwork: http://patchwork.linux-mips.org/patch/5164/
* pm-cpufreq: (57 commits)
cpufreq: MAINTAINERS: Add co-maintainer
cpufreq: pxa2xx: initialize variables
ARM: S5pv210: compiling issue, ARM_S5PV210_CPUFREQ needs CONFIG_CPU_FREQ_TABLE=y
cpufreq: cpu0: Put cpu parent node after using it
cpufreq: ARM big LITTLE: Adapt to latest cpufreq updates
cpufreq: ARM big LITTLE: put DT nodes after using them
cpufreq: Don't call __cpufreq_governor() for drivers without target()
cpufreq: exynos5440: Protect OPP search calls with RCU lock
cpufreq: dbx500: Round to closest available freq
cpufreq: Call __cpufreq_governor() with correct policy->cpus mask
cpufreq / intel_pstate: Optimize intel_pstate_set_policy
cpufreq: OMAP: instantiate omap-cpufreq as a platform_driver
arm: exynos: Enable OPP library support for exynos5440
cpufreq: exynos: Remove error return even if no soc is found
cpufreq: exynos: Add cpufreq driver for exynos5440
cpufreq: AMD "frequency sensitivity feedback" powersave bias for ondemand governor
cpufreq: ondemand: allow custom powersave_bias_target handler to be registered
cpufreq: convert cpufreq_driver to using RCU
cpufreq: powerpc/platforms/cell: move cpufreq driver to drivers/cpufreq
cpufreq: sparc: move cpufreq driver to drivers/cpufreq
MAINTAINERS (with commit a8e39c3 from pm-cpuidle)
drivers/cpufreq/cpufreq_governor.h (with commit beb0ff3)
This patch moves cpufreq driver of MIPS architecture to drivers/cpufreq.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: John Crispin <blogic@openwrt.org>
Commit 32a7ede (MIPS: dsp: Add assembler support for DSP ASEs) has
enabled the use of DSP ASE specific instructions such as rddsp and wrdsp
under the idea that all code path that will make use of these two
instructions are properly checking for cpu_has_dsp to ensure that the
particular CPU we are running on *actually* supports DSP ASE.
This commit actually causes the following oops on QEMU Malta emulating a
MIPS 24Kc without the DSP ASE implemented:
[ 7.960000] Reserved instruction in kernel
[ 7.960000] Cpu 0
[ 7.960000] $ 0 : 00000000 00000000 00000014 00000005
[ 7.960000] $ 4 : 8fc2de48 00000001 00000000 8f59ddb0
[ 7.960000] $ 8 : 8f5ceec4 00000018 00000c00 00800000
[ 7.960000] $12 : 00000100 00000200 00000000 00457b84
[ 7.960000] $16 : 00000000 8fc2ba78 8f4ec980 00000001
[ 7.960000] $20 : 80418f90 00000000 00000000 000002dd
[ 7.960000] $24 : 0000009c 7730d7b8
[ 7.960000] $28 : 8f59c000 8f59dd38 00000001 80104248
[ 7.960000] Hi : 0000001d
[ 7.960000] Lo : 0000000b
[ 7.960000] epc : 801041ec thread_saved_pc+0x2c/0x38
[ 7.960000] Not tainted
[ 7.960000] ra : 80104248 get_wchan+0x48/0xac
[ 7.960000] Status: 1000b703 KERNEL EXL IE
[ 7.960000] Cause : 10800028
[ 7.960000] PrId : 00019300 (MIPS 24Kc)
[ 7.960000] Modules linked in:
[ 7.960000] Process killall (pid: 1574, threadinfo=8f59c000,
task=8fd14558, tls=773aa440)
[ 7.960000] Stack : 8fc2ba78 8012b008 0000000c 0000001d 00000000
00000000 8f58a380
8f58a380 8fc2ba78 80202668 8f59de78 8f468600 8f59de28
801b2a3c 8f59df00 8f98ba20 74696e69
8f468600 8f59de28 801b7308 0081c007 00000000 00000000
00000000 00000000 00000000 00000000
00000000 8fc2bbb4 00000001 0000001d 0000000b 77f038cc
7fe80648 ffffffff ffffffff 00000000
00000001 0016e000 00000000 ...
[ 7.960000] Call Trace:
[ 7.960000] [<801041ec>] thread_saved_pc+0x2c/0x38
[ 7.960000] [<80104248>] get_wchan+0x48/0xac
The disassembly of thread_saved_pc points to the following:
000006d0 <thread_saved_pc>:
6d0: 8c820208 lw v0,520(a0)
6d4: 3c030000 lui v1,0x0
6d8: 24630000 addiu v1,v1,0
6dc: 10430008 beq v0,v1,700 <thread_saved_pc+0x30>
6e0: 00000000 nop
6e4: 3c020000 lui v0,0x0
6e8: 8c43000c lw v1,12(v0)
6ec: 04620004 bltzl v1,700 <thread_saved_pc+0x30>
6f0: 00001021 move v0,zero
6f4: 8c840200 lw a0,512(a0)
6f8: 00031080 sll v0,v1,0x2
6fc: 7c44100a lwx v0,a0(v0) <------------
700: 03e00008 jr ra
704: 00000000 nop
If we specifically disable -mdsp/-mdspr2 for arch/mips/kernel/process.o,
we get the following (non-crashing) assembly:
00000708 <thread_saved_pc>:
708: 8c820208 lw v0,520(a0)
70c: 3c030000 lui v1,0x0
710: 24630000 addiu v1,v1,0
714: 10430009 beq v0,v1,73c <thread_saved_pc+0x34>
718: 00000000 nop
71c: 3c020000 lui v0,0x0
720: 8c42000c lw v0,12(v0)
724: 04420005 bltzl v0,73c <thread_saved_pc+0x34>
728: 00001021 move v0,zero
72c: 8c830200 lw v1,512(a0)
730: 00021080 sll v0,v0,0x2
734: 00431021 addu v0,v0,v1
738: 8c420000 lw v0,0(v0)
73c: 03e00008 jr ra
740: 00000000 nop
The specific line that leads a different assembly being produced is:
unsigned long thread_saved_pc(struct task_struct *tsk)
return ((unsigned long *)t->reg29)[schedule_mfi.pc_offset]; <---
The problem here is that the compiler was given the right to use DSP
instructions with the -mdsp / -mdspr2 command-line switches and
performed some optimization for us and used DSP ASE instructions where
we are not checking that the running CPU actually supports DSP ASE.
This patch fixes the issue by partially reverting commit 32a7ede for
arch/mips/kernel/Makefile in order to remove the -mdsp / -mdspr2
compiler command-line switches such that we are now guaranteed that the
compiler will not optimize using DSP ASE reserved instructions. We also
need to fixup the rddsp/wrdsp and m{t,h}{hi,lo}{0,1,2,3} macros in
arch/mips/include/asm/mipsregs.h to tell the assembler that we are going
to explicitely use DSP ASE reserved instructions. The comment in
arch/mips/kernel/Makefile is also updated to reflect that.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Acked-by: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: blogic@openwrt.org
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
Add new clocksource that uses the counter present on the MIPS
Signed-off-by: Steven J. Hill <sjhill@mips.com>
Patchwork: http://patchwork.linux-mips.org/patch/4681/
Newer toolchains support the DSP and DSP Rev2 instructions. This patch
performs a check for that support and adds compiler and assembler
flags for only the files that need use those instructions.
Acked-by: Florian Fainelli <florian@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/4752/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Nobody seems to be interested anymore and upstream also never had an
ethernet driver.
Manuel Lauss <manuel.lauss@gmail.com> writes:
I introduced it as a fallback because early revisions of Alchemy hardware
we shipped had a non-functional 32kHz timer and had to rely on the r4k
timer instead. Previously the r4k timer was initialized regardless, but
it's useless with the "wait" instruction.
So long story short: I need either the on-chip 32kHz timer OR the r4k
timer if the 32kHz one is unusable, but not both, and r4k timer is useless
when au1k_idle is in use.
The current in-kernel Alchemy boards all work with the 32kHz timer, so I'm
not against removing R4K_LIB symbols.
[ralf@linux-mips.org: Original patch by Maxim Uvarov <muvarov@gmail.com>
with plenty of further shining, polishing, debugging and testing by me.]
Signed-off-by: Maxim Uvarov <muvarov@gmail.com>
Cc: kexec@lists.infradead.org
Cc: horms@verge.net.au
Patchwork: https://patchwork.linux-mips.org/patch/1025/
