path: root/arch/mips/kernel/cpu-bugs64.c
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-09-19[MIPS] cpu-bugs64.c: GCC 3.3 constraint workaroundMaciej W. Rozycki
Add a workaround to address warnings generated on the "n" constraint by GCC 3.3 and below. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Fix gcc 3.3 warning.Ralf Baechle
CC arch/mips/kernel/cpu-bugs64.o arch/mips/kernel/cpu-bugs64.c: In function 'align_mod': arch/mips/kernel/cpu-bugs64.c:23: warning: asm operand 0 probably doesn't match constraints arch/mips/kernel/cpu-bugs64.c:23: warning: asm operand 1 probably doesn't match constraints Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix sparse warnings about too big constants.Atsushi Nemoto
Fix following warnings: linux/arch/mips/kernel/setup.c:249:12: warning: constant 0xffffffff00000000 is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:209:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:227:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:283:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:299:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
