Like x86 did in arch/x86/kernel/{process_32.c,process_64.c}, also don't
trace irqsoff for idle.
If there's no useful work to be done, we don't care about the irqsoff
duration. If we trace the idle process, the max duration of irqsoff will
be the idle time and make the irqsoff tracer useless.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: http://patchwork.linux-mips.org/patch/1044/
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The resume() implementation octeon_switch.S examines the saved cp0_status
register. We were clobbering the entire pt_regs structure in kernel
threads leading to random crashes.
When switching away from a kernel thread, the saved cp0_status is examined
and if bit 30 is set it is cleared and the CP2 state saved into the pt_regs
structure. Since the kernel thread stack overlaid the pt_regs structure
this resulted in a corrupt stack. When the kthread with the corrupt stack
was resumed, it could crash if it used any of the data in the stack that was
clobbered.
We fix it by moving the kernel thread stack down so it doesn't overlay
pt_regs.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Each platform has to add support for CPU hotplugging itself by providing
suitable definitions for the cpu_disable and cpu_die of the smp_ops
methods and setting SYS_SUPPORTS_HOTPLUG_CPU. A platform should only set
SYS_SUPPORTS_HOTPLUG_CPU once all it's smp_ops definitions have the
necessary changes. This patch contains the changes to the dummy smp_ops
definition for uni-processor systems.
Parts of the code contributed by Cavium Inc.
First argument unused since 2.3.11.
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/asm-x86/statfs.h
Signed-off-by: Kevin D. Kissell <kevink@paralogos.com>
This patch also includes the required removal of (unused) inclusion of
<asm/a.out.h> <linux/a.out.h>'s in the arch/ code for these
architectures.
[dwmw2: updated for 2.6.27-rc]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Jack Ren and Eric Miao tracked down the following long standing
problem in the NOHZ code:
scheduler switch to idle task
enable interrupts
Window starts here
----> interrupt happens (does not set NEED_RESCHED)
irq_exit() stops the tick
----> interrupt happens (does set NEED_RESCHED)
return from schedule()
cpu_idle(): preempt_disable();
Window ends here
The interrupts can happen at any point inside the race window. The
first interrupt stops the tick, the second one causes the scheduler to
rerun and switch away from idle again and we end up with the tick
disabled.
The fact that it needs two interrupts where the first one does not set
NEED_RESCHED and the second one does made the bug obscure and extremly
hard to reproduce and analyse. Kudos to Jack and Eric.
Solution: Limit the NOHZ functionality to the idle loop to make sure
that we can not run into such a situation ever again.
cpu_idle()
preempt_disable();
while(1) {
tick_nohz_stop_sched_tick(1); <- tell NOHZ code that we
are in the idle loop
while (!need_resched())
halt();
tick_nohz_restart_sched_tick(); <- disables NOHZ mode
preempt_enable_no_resched();
schedule();
preempt_disable();
In hindsight we should have done this forever, but ...
/me grabs a large brown paperbag.
Debugged-by: Jack Ren <jack.ren@marvell.com>,
Debugged-by: eric miao <eric.y.miao@gmail.com>
Never terribly functional or popular, plagued by hard to fix bugs the time
to say goodbye has more than arrived.
Signed-off-by: Chris Dearman <chris@mips.com>
Match the R4000 semantics for the initial state of interrupt/kernel
status register flags for the R3000 in kernel_thread().
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
Convert old/obsolete NORET_TYPE and ATTRIB_NORET macros to use the
newer standard of "__noreturn" as defined in compiler-gcc.h.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
native and compat do_signal and handle_signal are identical and can easily
be unified.
This new routine doesn't lookup for symbol names. So we needn't
to pass any char buffers or pointer since we don't care about
names.
Make sure cpu_has_fpu (which uses smp_processor_id()) is used only in
atomic context.
If the PC was ret_from_irq or ret_from_exception, there will be no
more normal stackframe. Instead of stopping the unwinding, use PC and
RA saved by an exception handler to continue unwinding into the
interrupted context. This also simplifies the CONFIG_STACKTRACE code.
Implement stacktrace interface by using unwind_stack() and enable lockdep
support in Kconfig.
This array was used to 'cache' some frame info about scheduler
functions to speed up get_wchan(). This array was 1Ko size and
was only used when CONFIG_KALLSYMS was set but declared for all
configs.
Rather than make the array statement conditional, this patches
removes this array and its uses. Indeed the common case doesn't
seem to use this array and get_wchan() is not a critical path
anyways.
It results in a smaller bss and a smaller/cleaner code:
2543808 254148 139296 2937252 2cd1a4 vmlinux-new-get-wchan
2544080 254148 143392 2941620 2ce2b4 vmlinux~old
Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com>
This patch adds 2 sanity checks.
The first one test that the start address of the function to analyze has been
set by the caller. If not return an error since nothing usefull can be done
without.
The second one checks that the function's size has been set. A null size can
happen if CONFIG_KALLSYMS is not set and it means that we don't know the size
of the function to analyze. In this case, we make it equal to 128 instructions
by default.
instruction
This patch allows unwind_stack() to return ra for leaf function.
But it tries to detects cases where get_frame_info() wrongly
consider nested function as a leaf one.
It also pass 'unsinged long *sp' instead of 'unsigned long **sp'
as second parameter. The code looks cleaner.
Now get_frame_info() wants to detect move sp instruction first. It
assumes that the save ra in the stack instruction can't happen
before allocating frame size space into the stack.
Instead of dump all possible address in the stack, unwind the stack frame
based on prologue code analysis, as like as get_wchan() does. While the
code analysis might fail for some reason, there is a new kernel option
"raw_show_trace" to disable this feature.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
The only user of get_wchan is the proc fs - and proc can't be built modular.
Move function prototypes to asm/signal.h to detect trivial errors and
add some __user tags to get rid of sparse warnings. Generated code
should not be changed.
Implement get_wchan() and frame_info_init() using kallsyms_lookup().
This fixes problem with static sched/lock functions and mfinfo[]
maintenance issue. If CONFIG_KALLSYMS was disabled, get_wchan() just
returns thread_saved_pc() value.
Also unwind stackframe based on "addiu sp,-imm" analysis instead of
frame pointer. This fixes problem with functions compiled without
-fomit-frame-pointer.
It's return value is ignored everywhere.
dump_regs() is used by a bunch of drivers for their internal stuff;
renamed mips instance (one that is seen in system-wide headers)
to elf_dump_regs()
Run idle threads with preempt disabled.
Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()).
How did it ever work before?
Might fix the CPU hotplugging hang which Nigel Cunningham noted.
We think the bug hits if the idle thread is preempted after checking
need_resched() and before going to sleep, then the CPU offlined.
After calling stop_machine_run, the CPU eventually returns from preemption and
into the idle thread and goes to sleep. The CPU will continue executing
previous idle and have no chance to call play_dead.
By disabling preemption until we are ready to explicitly schedule, this bug is
fixed and the idle threads generally become more robust.
PPC build fix
MIPS build fix
Signed-off-by: Nick Piggin <npiggin@suse.de>
Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp>
