path: root/arch/mips/kernel/rtlx.c
2014-11-24MIPS: rtlx: Remove KERN_DEBUG from pr_debug() arguments in rtlx.cMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7938/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-01-22MIPS: APRP: Code formatting clean-ups.Steven J. Hill
Clean-up code according to the 'checkpatch.pl' script. Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Reviewed-by: Qais Yousef <Qais.Yousef@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/6097/ Reviewed-by: John Crispin <blogic@openwrt.org>
2014-01-22MIPS: APRP: Split RTLX support into separate files.Deng-Cheng Zhu
Split the RTLX functionality in preparation for adding support for CMP platforms. Common functions remain in the original file and a new file contains code specific to platforms that do not have a CMP. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Reviewed-by: Qais Yousef <Qais.Yousef@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/6093/ Reviewed-by: John Crispin <blogic@openwrt.org>
2013-10-04sched/wait: Make the __wait_event*() interface more friendlyPeter Zijlstra
Change all __wait_event*() implementations to match the corresponding wait_event*() signature for convenience. In particular this does away with the weird 'ret' logic. Since there are __wait_event*() users this requires we update them too. Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131002092529.042563462@infradead.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-21MIPS: Fix rtlx build error.Ralf Baechle
CC arch/mips/kernel/rtlx.o /home/ralf/src/linux/upstream-sfr/arch/mips/kernel/rtlx.c: In function ‘file_write’: /home/ralf/src/linux/upstream-sfr/arch/mips/kernel/rtlx.c:439:23: error: unused variable ‘rt’ [-Werror=unused-variable] /home/ralf/src/linux/upstream-sfr/arch/mips/kernel/rtlx.c: In function ‘rtlx_module_init’: /home/ralf/src/linux/upstream-sfr/arch/mips/kernel/rtlx.c:523:3: error: implicit declaration of function ‘set_vi_handler’ [-Werror=implicit-function-declaration] cc1: all warnings being treated as errors Caused by 496ad9aa8ef448058e36ca7a787c61f2e63f0f54 [new helper: file_inode(file)]. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-06MIPS: rtlx: Fix implicit declaration of function set_vi_handler()Yoichi Yuasa
arch/mips/kernel/rtlx.c: In function 'rtlx_module_init': arch/mips/kernel/rtlx.c:523:3: error: implicit declaration of function 'set_vi_handler' [-Werror=implicit-function-declaration] Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5340/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-03-02Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: o Add basic support for the Mediatek/Ralink Wireless SoC family. o The Qualcomm Atheros platform is extended by support for the new QCA955X SoC series as well as a bunch of patches that get the code ready for OF support. o Lantiq and BCM47XX platform have a few improvements and bug fixes. o MIPS has sent a few patches that get the kernel ready for the upcoming microMIPS support. o The rest of the series is made up of small bug fixes and cleanups that relate to various parts of the MIPS code. The biggy in there is a whitespace cleanup. After I was sent another set of whitespace cleanup patches I decided it was the time to clean the whitespace "issues" for once and and that touches many files below arch/mips/. Fix up silly conflicts, mostly due to whitespace cleanups. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (105 commits) MIPS: Quit exporting kernel internel break codes to uapi/asm/break.h MIPS: remove broken conditional inside vpe loader code MIPS: SMTC: fix implicit declaration of set_vi_handler MIPS: early_printk: drop __init annotations MIPS: Probe for and report hardware virtualization support. MIPS: ath79: add support for the Qualcomm Atheros AP136-010 board MIPS: ath79: add USB controller registration code for the QCA955X SoCs MIPS: ath79: add PCI controller registration code for the QCA955X SoCs MIPS: ath79: add WMAC registration code for the QCA955X SoCs MIPS: ath79: register UART for the QCA955X SoCs MIPS: ath79: add QCA955X specific glue to ath79_device_reset_{set, clear} MIPS: ath79: add GPIO setup code for the QCA955X SoCs MIPS: ath79: add IRQ handling code for the QCA955X SoCs MIPS: ath79: add clock setup code for the QCA955X SoCs MIPS: ath79: add SoC detection code for the QCA955X SoCs MIPS: ath79: add early printk support for the QCA955X SoCs MIPS: ath79: fix WMAC IRQ resource assignment mips: reserve elfcorehdr mips: Make sure kernel memory is in iomem MIPS: ath79: use dynamically allocated USB platform devices ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-31mips: remove needless include of module.h from core kernel files.Paul Gortmaker
None of these files are using modular infrastructure, and build tests reveal that none of these files are really relying on any implicit inclusions via. module.h either. So delete them. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-27MIPS: Don't include <linux/smp_lock.h> unnecessarily.Ralf Baechle
2009-09-30MIPS: VPE: Get rid of BKL.Ralf Baechle
2009-09-17MIPS: Remove useless zero initializations.Ralf Baechle
2008-10-16device create: misc: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21device create: mips: convert device_create to device_create_drvdataGreg Kroah-Hartman
device_create() is race-prone, so use the race-free device_create_drvdata() instead as device_create() is going away. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-18mips: cdev lock_kernel() pushdownJonathan Corbet
Push the cdev lock_kernel() call into MIPS-specific drivers. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-12[MIPS] MT: Functional fixes and a little reformatting of APRP supportKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Remove duplicate includes.Lucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-14[MIPS] rtlx: Fix build error.Ralf Baechle
CC arch/mips/kernel/rtlx.o cc1: warnings being treated as errors arch/mips/kernel/rtlx.c:59: warning: 'irq' defined but not used arch/mips/kernel/rtlx.c:60: warning: 'irq_num' defined but not used Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-14[MIPS] rtlx: fix int vs. long bug.Ralf Baechle
CC arch/mips/kernel/rtlx.o arch/mips/kernel/rtlx.c: In function 'rtlx_init': arch/mips/kernel/rtlx.c:114: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'long unsigned int' Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] rtlx: Fix modpost warningRalf Baechle
WARNING: vmlinux.o(.text+0x11504): Section mismatch: reference to .init.data:register_chrdev_failed (between 'rtlx_module_init' and 'rtlx_dispatch') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] MT: Enable coexistence of AP/SP with VSMP and SMTC.Ralf Baechle
2007-07-24[MIPS] Replace __attribute_used__ with __usedDavid Rientjes
Replaces the deprecated __attribute_used__ with __used. Also makes some style adjustments to abide by the kernel coding conventions. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Fix AP/SP to work in the reality of modern kernels.Ralf Baechle
2007-03-17[MIPS] RTLX: Handle copy_*_user return values.Ralf Baechle
2007-03-17[MIPS] RTLX: Protect rtlx_{read,write} with mutex.Ralf Baechle
2007-03-17[MIPS] RTLX: Harden against compiler reordering and optimization.Ralf Baechle
RTLX communication is based on lock-free shared memory buffers. It happened to be working by luck so far but relies on the optimizer doing certain optimizations but no reordering. Fixed by inserting proper barriers in rtlx_read and rtlx_write, and careful pointer dereferencing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-17[MIPS] RTLX: Don't use volatile; it's fragile.Ralf Baechle
2007-02-26[MIPS] RTLX: Delete multiple definition of ret shaddowing each other.Ralf Baechle
2007-02-26[MIPS] RTLX, VPE: Make open actually atomic.Ralf Baechle
2007-02-26[MIPS] RTLX: Handle signals when sleeping.Ralf Baechle
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[MIPS] RTLX: Sprinkle device model code into code to make udev happier.Ralf Baechle
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-08[PATCH] struct path: convert mipsJosef Sipek
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-27[MIPS] Cleanup inode->r_dev usage.Ralf Baechle
imajor()/iminor() should be used instead of accessing r_dev directly. Based on patch from Eric Sesterhenn (snakebyte@gmx.de). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] kpsd and other AP/SP improvements.Ralf Baechle
2006-02-07[MIPS] RTLX compile fixes.Ralf Baechle
2005-11-07Turn rtlx upside down.Ralf Baechle
o Coding style o Race condition on open o Switch to dynamic major o Header file cleanup Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29More AP / SP bits for the 34K, the Malta bits and things. Still wantsRalf Baechle
a little polishing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
