path: root/arch/mips/kernel/rtlx.c
2008-05-12[MIPS] MT: Functional fixes and a little reformatting of APRP supportKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Remove duplicate includes.Lucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-14[MIPS] rtlx: Fix build error.Ralf Baechle
CC arch/mips/kernel/rtlx.o cc1: warnings being treated as errors arch/mips/kernel/rtlx.c:59: warning: 'irq' defined but not used arch/mips/kernel/rtlx.c:60: warning: 'irq_num' defined but not used Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-14[MIPS] rtlx: fix int vs. long bug.Ralf Baechle
CC arch/mips/kernel/rtlx.o arch/mips/kernel/rtlx.c: In function 'rtlx_init': arch/mips/kernel/rtlx.c:114: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'long unsigned int' Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] rtlx: Fix modpost warningRalf Baechle
WARNING: vmlinux.o(.text+0x11504): Section mismatch: reference to .init.data:register_chrdev_failed (between 'rtlx_module_init' and 'rtlx_dispatch') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] MT: Enable coexistence of AP/SP with VSMP and SMTC.Ralf Baechle
2007-07-24[MIPS] Replace __attribute_used__ with __usedDavid Rientjes
Replaces the deprecated __attribute_used__ with __used. Also makes some style adjustments to abide by the kernel coding conventions. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Fix AP/SP to work in the reality of modern kernels.Ralf Baechle
2007-03-17[MIPS] RTLX: Handle copy_*_user return values.Ralf Baechle
2007-03-17[MIPS] RTLX: Protect rtlx_{read,write} with mutex.Ralf Baechle
2007-03-17[MIPS] RTLX: Harden against compiler reordering and optimization.Ralf Baechle
RTLX communication is based on lock-free shared memory buffers. It happened to be working by luck so far but relies on the optimizer doing certain optimizations but no reordering. Fixed by inserting proper barriers in rtlx_read and rtlx_write, and careful pointer dereferencing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-17[MIPS] RTLX: Don't use volatile; it's fragile.Ralf Baechle
2007-02-26[MIPS] RTLX: Delete multiple definition of ret shaddowing each other.Ralf Baechle
2007-02-26[MIPS] RTLX, VPE: Make open actually atomic.Ralf Baechle
2007-02-26[MIPS] RTLX: Handle signals when sleeping.Ralf Baechle
2007-02-12[PATCH] mark struct file_operations const 2Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@osdl.org: sparc64 fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[MIPS] RTLX: Sprinkle device model code into code to make udev happier.Ralf Baechle
2007-02-06[MIPS] Define MIPS_CPU_IRQ_BASE in generic headerAtsushi Nemoto
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all platforms and are same value on most platforms (0 or 16, depends on CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make them customizable. This will save a few cycle on each CPU interrupt. A good side effect is removing some dependencies to MALTA in generic SMTC code. Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing them might cause some header dependency problem and there seems no good reason to customize it. So currently only VR41XX is using custom MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259. Testing this patch on those platforms is greatly appreciated. Thank you. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-08[PATCH] struct path: convert mipsJosef Sipek
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-27[MIPS] Cleanup inode->r_dev usage.Ralf Baechle
imajor()/iminor() should be used instead of accessing r_dev directly. Based on patch from Eric Sesterhenn (snakebyte@gmx.de). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] kpsd and other AP/SP improvements.Ralf Baechle
2006-02-07[MIPS] RTLX compile fixes.Ralf Baechle
2005-11-07Turn rtlx upside down.Ralf Baechle
o Coding style o Race condition on open o Switch to dynamic major o Header file cleanup Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29More AP / SP bits for the 34K, the Malta bits and things. Still wantsRalf Baechle
a little polishing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
