This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Now that device_create() has been audited, rename things back to the
original call to be sane.
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
Push the cdev lock_kernel() call into MIPS-specific drivers.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Kevin D. Kissell <kevink@mips.com>
Signed-off-by: Lucas Woods <woodzy@gmail.com>
CC arch/mips/kernel/rtlx.o
cc1: warnings being treated as errors
arch/mips/kernel/rtlx.c:59: warning: 'irq' defined but not used
arch/mips/kernel/rtlx.c:60: warning: 'irq_num' defined but not used
arch/mips/kernel/rtlx.c: In function 'rtlx_init':
arch/mips/kernel/rtlx.c:114: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'long unsigned int'
WARNING: vmlinux.o(.text+0x11504): Section mismatch: reference to .init.data:register_chrdev_failed (between 'rtlx_module_init' and 'rtlx_dispatch')
Replaces the deprecated __attribute_used__ with __used. Also makes some
style adjustments to abide by the kernel coding conventions.
Signed-off-by: David Rientjes <rientjes@google.com>
RTLX communication is based on lock-free shared memory buffers. It
happened to be working by luck so far but relies on the optimizer doing
certain optimizations but no reordering.
Fixed by inserting proper barriers in rtlx_read and rtlx_write, and careful
pointer dereferencing.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@osdl.org: sparc64 fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
The irq_base for {mips,rm7k,rm9k}_cpu_irq_init() are constant on all
platforms and are same value on most platforms (0 or 16, depends on
CONFIG_I8259). Define them in asm-mips/mach-generic/irq.h and make
them customizable. This will save a few cycle on each CPU interrupt.
A good side effect is removing some dependencies to MALTA in generic
SMTC code.
Although MIPS_CPU_IRQ_BASE is customizable, this patch changes irq
mappings on DDB5477, EMMA2RH and MIPS_SIM, since really customizing
them might cause some header dependency problem and there seems no
good reason to customize it. So currently only VR41XX is using custom
MIPS_CPU_IRQ_BASE value, which is 0 regardless of CONFIG_I8259.
Testing this patch on those platforms is greatly appreciated. Thank
you.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
Use the new IRQF_ constants and remove the SA_INTERRUPT define
imajor()/iminor() should be used instead of accessing r_dev directly.
Based on patch from Eric Sesterhenn (snakebyte@gmx.de).
o Coding style
o Race condition on open
o Switch to dynamic major
o Header file cleanup
a little polishing.
