path: root/arch/mips/kernel/setup.c
2011-01-18MIPS: Implement __read_mostlyDavid Daney
Just do what everyone else is doing by placing __read_mostly things in the .data.read_mostly section. mips_io_port_base can not be read-only (const) and writable (__read_mostly) at the same time. One of them has to go, so I chose to eliminate the __read_mostly. It will still get stuck in a portion of memory that is not adjacent to things that are written, and thus not be on a dirty cache line, for whatever that is worth. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1702/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-29MIPS: Add a platform hook for swiotlb setup.David Daney
This allows platforms that are using the swiotlb to initialize it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/1638/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-21of/mips: Add device tree support to MIPSDezhong Diao
Add the ability to enable CONFIG_OF on the MIPS architecture. Signed-off-by: Dezhong Diao <dediao@cisco.com> [grant.likely@secretlab.ca: cleared out obsolete hooks, removed ARCH_HAS_DEVTREE_MEM, remove __init tags from header file, removed debugfs support hunk] [ddaney@linux-mips.org: backed out over aggressive trimming of hooks] Acked-by: Ralf Baechle <ralf@linux-mips.org> Tested-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-21MIPS: nofpu and nodsp only affect CPU0Kevin Cernekee
The "nofpu" and "nodsp" kernel command line options currently do not affect CPUs that are brought online later in the boot process or hotplugged at runtime. It is desirable to apply the nofpu/nodsp options to all CPUs in the system, so that surprising results are not seen when a process migrates from one CPU to another. [Ralf: Moved definitions of mips_fpu_disabled, fpu_disable, mips_dsp_disabled and dsp_disable from setup.c to cpu-probe.c to allow making mips_fpu_disabled and mips_dsp_disabled static.] Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: http://patchwork.linux-mips.org/patch/1169/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Fix and enhance built-in kernel command lineDmitri Vorobiev
Currently, MIPS kernels silently overwrite kernel command-line parameters hardcoded in CONFIG_CMDLINE by the ones received from firmware. Therefore, using firmware remains the only reliable method to transfer the command-line parameters, which is not always desirable or convenient, and the CONFIG_CMDLINE option is thereby effectively rendered useless. This patch fixes the problem described above and introduces a more flexible scheme of handling the kernel command line, in a manner identical to what is currently used for x86. The default behavior, i.e. when CONFIG_CMDLINE_BOOL is not defined, retains the existing semantics, and firmware command-line arguments override the hardcoded ones. [Ralf: I fixed up all the defconfig files so the stay unaffected by this change.] Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/689/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Remove addinitrd and CONFIG_PROBE_INITRD_HEADERRalf Baechle
Addinitrd has been superseded by initramfs ages ago. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Replace all usages of CL_SIZE by COMMAND_LINE_SIZEDmitri Vorobiev
The MIPS-specific macro CL_SIZE is merely aliasing the macro COMMAND_LINE_SIZE. Other architectures use the latter; also, COMMAND_LINE_SIZE is documented in kernel-parameters.txt, so let's use it, and remove the alias. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Remove useless zero initializations.Ralf Baechle
2009-03-30MIPS: Stop using <asm-generic/int-l64.h>.Ralf Baechle
This fixes a few warnings - and triggers a few new ones which the rest of this patch fixes. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: Fix debugfs_create_*'s error checking method for mips/kernel/Zhaolei
debugfs_create_*() returns NULL on error. Make its callers return -ENODEV on error. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-05[MIPS] Probe initrd header only if explicitly specifiedAtsushi Nemoto
Currently init_initrd() probes initrd header at the last page of kernel image, but it is valid only if addinitrd was used. If addinitrd was not used, the area contains garbage so probing there might misdetect initrd header (magic number is not strictly robust). This patch introduces CONFIG_PROBE_INITRD_HEADER to explicitly enable this probing. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-08-26[MIPS] Convert printk statements during kernel setup to use severity levelsMike Crowe
Signed-off-by: Mike Crowe <mac@mcrowe.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] fix sparse warning about setup_early_printk()Dmitri Vorobiev
This patch fixes the following sparse warning: <<<<<<<< arch/mips/kernel/early_printk.c:35:13: warning: symbol 'setup_early_printk' was not declared. Should it be static? <<<<<<<< The fix is to define a prototype of the setup_early_printk() function and to include the appropriate header into arch/mips/kernel/early_printk.c. [Ralf: Sorted includes again] Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-15[MIPS] Remove obsolete isa_slot_offsetMaciej W. Rozycki
The isa_slot_offset variable and its __ISA_IO_base macro is not used anywhere anymore. It does not look like a decent interface per today's standards either. Remove both including all places of initialization. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Initialize max_pfn again.Ralf Baechle
This was dropped by commit a0d9e2d891e4cf54676c430da63bd4a17d1cdb80 (lmo) commit b6f1f0dea1469e0c956eb89399916d60dd2a3808 (ko) Author: Franck Bui-Huu <vagabon.xyz@gmail.com> Date: Fri Aug 11 17:51:48 2006 +0200 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-07Introduce flags for reserve_bootmem()Bernhard Walle
This patchset adds a flags variable to reserve_bootmem() and uses the BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions between crashkernel area and already used memory. This patch: Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE. If that flag is set, the function returns with -EBUSY if the memory already has been reserved in the past. This is to avoid conflicts. Because that code runs before SMP initialisation, there's no race condition inside reserve_bootmem_core(). [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: <linux-arch@vger.kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03arch/mips/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-29[MIPS] SMP: Call platform methods via ops structure.Ralf Baechle
2008-01-29[MIPS] R4000/R4400 errata workaroundsMaciej W. Rozycki
This is the gereric part of R4000/R4400 errata workarounds. They include compiler and assembler support as well as some source code modifications to address the problems with some combinations of multiply/divide+shift instructions as well as the daddi and daddiu instructions. Changes included are as follows: 1. New Kconfig options to select workarounds by platforms as necessary. 2. Arch top-level Makefile to pass necessary options to the compiler; also incompatible configurations are detected (-mno-sym32 unsupported as horribly intrusive for little gain). 3. Bug detection updated and shuffled -- the multiply/divide+shift problem is lethal enough that if not worked around it makes the kernel crash in time_init() because of a division by zero; the daddiu erratum might also trigger early potentially, though I have not observed it. On the other hand the daddi detection code requires the exception subsystem to have been initialised (and is there mainly for information). 4. r4k_daddiu_bug() added so that the existence of the erratum can be queried by code at the run time as necessary; useful for generated code like TLB fault and copy/clear page handlers. 5. __udelay() updated as it uses multiplication in inline assembly. Note that -mdaddi requires modified toolchain (which has been maintained by myself and available from my site for ~4years now -- versions covered are GCC 2.95.4 - 4.1.2 and binutils from 2.13 onwards). The -mfix-r4000 and -mfix-r4400 have been standard for a while though. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-11[MIPS] Replace 40c7869b693b18412491fdcff64682215b739f9e kludgeAtsushi Nemoto
2007-11-26[MIPS] 64-bit Sibyte kernels need DMA32.Ralf Baechle
Sibyte SOCs only have 32-bit PCI. Due to the sparse use of the address space only the first 1GB of memory is mapped at physical addresses below 1GB. If a system has more than 1GB of memory 32-bit DMA will not be able to reach all of it. For now this patch is good enough to keep Sibyte users happy but it seems eventually something like swiotlb will be needed for Sibyte. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Add some debugfs files to debug unaligned accessesAtsushi Nemoto
Currently a number of unaligned instructions is counted but not used. Add /debug/mips/unaligned_instructions file to show the value. And add /debug/mips/unaligned_action to control behavior upon an unaligned access. Possible actions are: 0: silently fixup the unaligned access. 1: send SIGBUS. 2: dump registers, process name, etc. and fixup. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[MIPS] Make some __setup functions staticAtsushi Nemoto
This fixes some sparse warnings. ("warning: symbol 'foo' was not declared. Should it be static?") Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-12[PATCH] Dynamic kernel command-line: mipsAlon Bar-Lev
Rename saved_command_line into boot_command_line. Signed-off-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-06[MIPS] Whitespace cleanups.Ralf Baechle
2007-02-06[MIPS] Move some kernel globals from asm file to C file.Atsushi Nemoto
This get rid of some undesirable hole in BSS section due to random order of placement. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] FLATMEM: introduce PHYS_OFFSET.Franck Bui-Huu
The old code was assuming that min_low_pfn was always 0. This means that platforms having a big hole at their memory start paid the price of wasting some memory for the allocation of unused entries in mem_map[]. This patch prevents this waste. It introduces PHYS_OFFSET define which is the start of the physical memory and uses it wherever needed. Specially when converting physical/virtual addresses into virtual/physical ones. Currently all platforms defines PHYS_OFFSET to 0. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Setup min_low_pfn/max_low_pfn correctlyFranck Bui-Huu
This patch makes a better usage of these two globals. 'min_low_pfn' is now correctly setup for all configs, which allow us to rely on it in boot memory code init. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] setup.c: clean up initrd related codeFranck Bui-Huu
2006-11-30[MIPS] setup.c: use __pa_symbol() where neededFranck Bui-Huu
It should fix the broken code in resource_init() too. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] setup.c: get ride of CPHYSADDR()Franck Bui-Huu
and use new __pa() implementation instead introduced by the previous patch. Indeed this macro can be used now even by the 64 bit kernels with CONFIG_BUILD_ELF64=n config. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-02[MIPS] Fix warning about init_initrd() call if !CONFIG_BLK_DEV_INITRD.Ralf Baechle
2006-09-27[MIPS] setup.c: use early_param() for early command line parsingFranck Bui-Huu
There's no point to rewrite some logic to parse command line to pass initrd parameters or to declare a user memory area. We could use instead parse_early_param() that does the same thing. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] setup.c: remove MAXMEM macroFranck Bui-Huu
It doesn't improve readability. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] setup.c: do not inline functionsFranck Bui-Huu
There's no point to inline any functions in setup.c. Let's GCC doing its job, it's good enough for that now. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] setup.c: remove useless includes.Franck Bui-Huu
2006-09-27[MIPS] setup.c: move initrd code inside dedicated functionsFranck Bui-Huu
NUMA specific code could rely on them too. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] setup.c: cleanup bootmem_init()Franck Bui-Huu
This function although doing simple thing is hard to follow. It's mainly due to: - a lot of #ifdef - bad local names - redundant tests So this patch try to address these issues. It also do not use max_pfn global which is marked as an unused exported symbol. As a bonus side, it's now really easy to see what part of the code is for no-numa system. There's also no point to make this function inline. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[MIPS] Only register RAM as resources if UNCAC_BASE != IO_BASE.Ralf Baechle
This fixes a resource collision of RAM and I/O memory on systems that use the physical address space multiple times. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix sparsemem support.Chad Reese
Move memory_present() in arch/mips/kernel/setup.c. When using sparsemem extreme, this function does an allocate for bootmem. This would always fail since init_bootmem hasn't been called yet. Move memory_present after free_bootmem. This only marks actual memory ranges as present instead of the entire address space. Signed-off-by: Chad Reese <creese@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix compiler warnings (field width, unused variable)Atsushi Nemoto
Fix following warnings: linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 2) linux/arch/mips/kernel/setup.c:432: warning: field width is not type int (arg 4) linux/arch/mips/kernel/syscall.c:279: warning: unused variable `len' linux/arch/mips/kernel/syscall.c:280: warning: unused variable `name' linux/arch/mips/math-emu/dp_fint.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/dp_flong.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/sp_fint.c:32: warning: unused variable `xc' linux/arch/mips/math-emu/sp_flong.c:32: warning: unused variable `xc' (original patch by Atsushi, slight changes to the setup.c part by me.) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] Fix sparse warnings about too big constants.Atsushi Nemoto
Fix following warnings: linux/arch/mips/kernel/setup.c:249:12: warning: constant 0xffffffff00000000 is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:209:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:227:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:283:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long linux/arch/mips/kernel/cpu-bugs64.c:299:10: warning: constant 0xffffffffffffdb9a is so big it is unsigned long Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] FPU affinity for MT ASE.Ralf Baechle
2006-03-27[PATCH] unify PFN_* macrosDave Hansen
Just about every architecture defines some macros to do operations on pfns. They're all virtually identical. This patch consolidates all of them. One minor glitch is that at least i386 uses them in a very skeletal header file. To keep away from #include dependency hell, I stuck the new definitions in a new, isolated header. Of all of the implementations, sh64 is the only one that varied by a bit. It used some masks to ensure that any sign-extension got ripped away before the arithmetic is done. This has been posted to that sh64 maintainers and the development list. Compiles on x86, x86_64, ia64 and ppc64. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21[MIPS] Remove CONFIG_BUILD_ELF64.Ralf Baechle
This option is no longer usable with supported compilers. It will be replaced by usage of -msym32 in a separate patch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
