This allows pause_on_oops and mtdoops to work.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2810/
On preempt-rt this lock needs to be raw, so it does not get converted
to a sleeping spinlock. Trying to sleep in a panic is not really
desireable.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2636/
The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
Initial patch by Yury Polyanskiy <ypolyans@princeton.edu>.
Patchwork: https://patchwork.linux-mips.org/patch/2373/
Decide at runtime to use either Context or KScratch to hold the PGD
pointer.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/1876/
We were unconditionally sending SIGBUS with an empty siginfo on FP
emulator faults. This differs from what happens when real floating
point hardware would get a fault.
For most faults we need to send SIGSEGV with the faulting address
filled in in the struct siginfo.
Reported-by: Camm Maguire <camm@maguirefamily.org>
Cc: Camm Maguire <camm@maguirefamily.org>
Patchwork: https://patchwork.linux-mips.org/patch/1727/
Some MIPS32R1 processors implement UserLocal (RDHWR $29) to accelerate
programs that make extensive use of thread-local storage. Therefore,
setting up the HWRENA register should not depend on cpu_has_mips_r2.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Software events are required as part of the measurable stuff by the
Linux performance counter subsystem. Here is the list of events added by
this patch:
PERF_COUNT_SW_PAGE_FAULTS
PERF_COUNT_SW_PAGE_FAULTS_MIN
PERF_COUNT_SW_PAGE_FAULTS_MAJ
PERF_COUNT_SW_ALIGNMENT_FAULTS
PERF_COUNT_SW_EMULATION_FAULTS
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: a.p.zijlstra@chello.nl
Cc: paulus@samba.org
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: jamie.iles@picochip.com
Acked-by: David Daney <ddaney@caviumnetworks.com>
Reviewed-by: Matt Fleming <matt@console-pimps.org>
Patchwork: https://patchwork.linux-mips.org/patch/1686/
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should
really include it. Note that this can replace #inclusions of <asm/irq.h>.
This is required for the patch to sort out irqflags handling function naming to
compile on MIPS.
The problem is that these files require access to things like setup_irq() -
which isn't available by #including <linux/interrupt.h>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
The sixth argument of notify_die() is a signal number, the fifth is a
trap number.
Instead of passing a signal number in a randomly selected argument,
pass it in the sixth. Extract the exception code from regs and pass
that as the trap number.
Get rid of redundant cast, and remove some gratuitous spaces.
Nobody actually does anything with the signal number or trap number,
but we might as well populate them with sensible values.
Patchwork: https://patchwork.linux-mips.org/patch/1532/
It is initialized to zero and only ever read. Remove it, and pass zero in
its place.
Patchwork: https://patchwork.linux-mips.org/patch/1531/
This patch is based on previous work by Sony and Himanshu Chauhan.
I have done some cleanup and implemented JProbes and KRETPROBES. The
KRETPROBES part is pretty much copied verbatim from powerpc. A possible
future enhance might be to factor out the common code.
Cc: Himanshu Chauhan <hschauhan@nulltrace.org>
To: ananth@in.ibm.com,
To: anil.s.keshavamurthy@intel.com
To: davem@davemloft.net
To: masami.hiramatsu.pt@hitachi.com
Patchwork: https://patchwork.linux-mips.org/patch/1525/
Patchwork: https://patchwork.linux-mips.org/patch/1530/
Patchwork: https://patchwork.linux-mips.org/patch/1504/
Breaking here dropped us to the default code which always sends a SIGILL
to the current process, no matter what the CU2 notifier says.
[Ralf: Currently this only hurts on Cavium and possibly some out of tree
platforms.]
Signed-off-by: Jesper Nilsson <jesper@jni.nu>
To: linux-kernel@vger.kernel.org
Patchwork: http://patchwork.linux-mips.org/patch/1391/
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (25 commits)
MIPS: Use GCC __builtin_prefetch() to implement prefetch().
MIPS: Octeon: Serial port fixes for OCTEON simulator.
MIPS: Octeon: Get rid of early serial.
MIPS: AR7: prevent race between clock initialization and devices registration
MIPS: AR7: use ar7_has_high_vlynq() to determine watchdog base address
MIPS: BCM63xx: Avoid namespace clash on GPIO_DIR_{IN,OUT}
MIPS: MTX-1: Update defconfig
MIPS: BCM47xx: Update defconfig
MIPS: RB532: Update defconfig
MIPS: AR7: Update defconfig
RTC: rtc-cmos: Fix binary mode support
MIPS: Oprofile: Loongson: Cleanup the comments
MIPS: Oprofile: Loongson: Cleanup of the macros
MIPS: Oprofile: Loongson: Remove unused variable from loongson2_cpu_setup()
MIPS: Oprofile: Loongson: Remove useless parentheses
MIPS: Oprofile: Loongson: Unify macro for setting events
MIPS: nofpu and nodsp only affect CPU0
MIPS: Clean up tables for bootmem allocation
MIPS: Coding style cleanups of access of FCSR rounding mode bits
MIPS: Loongson 2F: Add gpio/gpioilb support
Use set_cpus_allowed_ptr rather than set_cpus_allowed.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression E1,E2;
- set_cpus_allowed(E1, cpumask_of_cpu(E2))
+ set_cpus_allowed_ptr(E1, cpumask_of(E2))
expression E;
identifier I;
- set_cpus_allowed(E, I)
+ set_cpus_allowed_ptr(E, &I)
// </smpl>
To: peterz@infradead.org
To: mingo@elte.hu
To: tglx@linutronix.de
To: oleg@redhat.com
To: kernel-janitors@vger.kernel.org
Patchwork: http://patchwork.linux-mips.org/patch/1087/
The only way the debugger can handle a trap in inside rcu_lock,
notify_die, or atomic_notifier_call_chain without a recursive fault is
to have a low level "first opportunity handler" do_trap_or_bp() handler.
Generally this will be something the vast majority of folks will not
need, but for those who need it, it is added as a kernel .config
option called KGDB_LOW_LEVEL_TRAP.
Also added was a die notification for oops such that kdb can catch an
oops for analysis.
There appeared to be no obvious way to pass the struct pt_regs from
the original exception back to the stack back tracer, so a special
case was added to show_stack() for when kdb is active because you
generally desire to generally look at the back trace of the original
exception.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
"MIPS: Calculate proper ebase value for 64-bit kernels"
9af43ea080dd5d6c7b34f38261780e5dd43537bc (lmo) rsp.
f6be75d03c8870be91e6e2a195648ece04b6bb16 (kernel.org) broke some 64-bit
MIPS systems.
Before this we were using XKPHYS/cached as ebase and computed the uncached
xphsys/unchached address for that area. After that commit ebase became a
32-bit compat address and convert does not work anymore. We now should use
CKSEG1 for this. CKSEG1ADDR does just that in 32-bit and 64-bit.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
To: Ralf Baechle <ralf@linux-mips.org>
Patchwork: http://patchwork.linux-mips.org/patch/1149/
The MIPS implementation of die() forgets to call notify_die() and thus notifiers
registered via register_die_notifier() are not called. This results in kgdb not
being activated on exceptions.
The only subtlety is that notify_die declares its regs argument w/o const, so
the const had to be removed from mips die() as well.
[Ralf: Fixed build error for SGI IP22 and IP28 platforms.]
Signed-off-by: Yury Polyanskiy <ypolyans@princeton.edu>
Patchworks: http://patchwork.linux-mips.org/patch/1142/
Acked-by: Jason Wessel <jason.wessel@windriver.com>
The ebase is relative to CKSEG0 not CAC_BASE. On a 32-bit kernel they
are the same thing, for a 64-bit kernel they are not.
It happens to kind of work on a 64-bit kernel as they both reference
the same physical memory. However since the CPU uses the CKSEG0 base,
determining if a J instruction will reach always gives the wrong result
unless we use the same number the CPU uses.
Patchwork: http://patchwork.linux-mips.org/patch/1093/
AR7 has a larger physical offset than other MIPS based systems and therefore
needs to setup its handlers beyond the usual KSEG0 range. When running the
kernel in mapped mode this modification is also required. Remove function
comment which is now incorrect.
Signed-off-by: Eugene Konev <ejka@imfi.kspu.ru>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
To: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Patchwork: http://patchwork.linux-mips.org/patch/889/
Patchwork: http://patchwork.linux-mips.org/patch/932/
All call sites of set_except_vector are already annotated with __init, so
annotate that one too.
Signed-off-by: Regards, Florian Fainelli <florian@openwrt.org>
To: David Daney <ddaney@caviumnetworks.com>
Patchwork: http://patchwork.linux-mips.org/patch/888/
As reported by Maxime Bizon, the commit "MIPS: PowerTV: Fix support for
timer interrupts with > 64 external IRQs" have broken the r4k timer
since it didn't initialize the cp0_compare_irq_shift variable used in
c0_compare_int_pending() on the architectures whose cpu_has_mips_r2 is
false.
This patch fixes it via initializing the cp0_compare_irq_shift as the
cp0_compare_irq used in the old c0_compare_int_pending().
Reported-by: Maxime Bizon <mbizon@freebox.fr>
Cc: David VomLehn <dvomlehn@cisco.com>
Cc: mbizon@freebox.fr
Patchwork: http://patchwork.linux-mips.org/patch/922/
Tested-by: Shane McDonald <mcdonald.shane@gmail.com>
The MIPS processor is limited to 64 external interrupt sources. Using a
greater number without IRQ sharing requires reading platform-specific
registers. On such platforms, reading the IntCtl register to determine
which interrupt corresponds to a timer interrupt will not work.
On MIPSR2 systems there is a solution - the TI bit in the Cause register,
specifically indicates that a timer interrupt has occured. This patch uses
that bit to detect interrupts for MIPSR2 processors, which may be expected
to work regardless of how the timer interrupt may be routed in the hardware.
Signed-off-by: David VomLehn (dvomlehn@cisco.com)
Patchwork: http://patchwork.linux-mips.org/patch/804/
Patchwork: http://patchwork.linux-mips.org/patch/709/
Away with the daemons of ifdef; get ready for future COP2 users.
Patchwork: http://patchwork.linux-mips.org/patch/708/
This way it doesn't have to use CONFIG_CPU_HAS_LLSC anymore.
We had an ugly #ifdef for Cavium Octeon hwrena bits in traps.c, remove
it to mach-cavium-octeon/cpu-feature-overrides.h
Some CPUs have implementation dependent rdhwr registers. Allow them
to be enabled on a per CPU basis.
Based on original patch by Stoyan Gaydarov <stoyboyker@gmail.com> which
missed a few places.
Commit 566f74f6b2f8b85d5b8d6caaf97e5672cecd3e3e had a change that
incorrectly modified ebase. This backs out the lines that modified
ebase.
In addition, the ebase exception vector is now allocated with correct
alignment and the ebase register updated according to the architecture
specification.
Based on original patch by David VomLehn <dvomlehn@cisco.com>.
Signed-off-by: David VomLehn <dvomlehn@cisco.com>
Signed-off-by: Chris Dearman <chris@mips.com>
If a context switch occurred between the watch exception and reading the
watch registers, it would be possible for the new process to corrupt their
state. Enabling interrupts only after the watch registers are read avoids
this race.
If on Cavium, be aware of cop2 and hwrena during do_cpu().
Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com>
Signed-off-by: Paul Gortmaker <Paul.Gortmaker@windriver.com>
Arguably using the address error handler has always been ugly. But with
processors that handle unaligned loads and stores in hardware the
current mechanism ceases to work so switch it to a BREAK instruction and
allocate break code 514 to the FPU emulator.
Yoichi Yuasa provided a build fix for CONFIG_BUG=n.
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
It just so happens to be zero on all currently supported systems so this
hasn't bitten yet ...
[Ralf: Original patch from Cavium; handling of set_uncached_handler() and
de-ifdef'ed trap_init() implementation by me.]
Here we hook up the watch exception handler so that it sends SIGTRAP when
the hardware watch registers are triggered.
Signed-off-by: David Daney <ddaney@avtrex.com>
Signed-off-by: Kevin D. Kissell <kevink@paralogos.com>
If an interrupt happened between checking of NEED_RESCHED and WAIT
instruction, adjust EPC to restart from checking of NEED_RESCHED.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
trap_init issues flush_icache_range(), which uses ipi functions to
get icache flushing done on all cpus. But this is done before interrupts
are enabled and caused WARN_ON messages. This changeset introduces
a new local_flush_icache_range() and uses it before interrupts (and
additional CPUs) are enabled to avoid this problem.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
With -ffunction-section the entries in __dbe_table aren't no longer
sorted, so the lookup of exception addresses in do_be() failed for
some addresses. To avoid this we now sort __dbe_table.
The new kgdb architecture specific handler registers and unregisters
dynamically for exceptions depending on when you configure a kgdb I/O
driver.
Aside from initializing the exceptions earlier in the boot process,
kgdb should have no impact on a device when it is compiled in so long
as an I/O module is not configured for use.
There have been quite a number of contributors during the existence of
this patch (see arch/mips/kernel/kgdb.c). Most recently Jason
re-wrote the mips kgdb logic to use the die notification handlers.
It is not used anywhere in tree.
The newly added check for valid stack pointer address breaks at least for
64bit kernels. Use __get_user() for accessing stack content to avoid crashes,
when doing the backtrace.
With fixes and cleanups from Atsushi Nemoto (anemo@mba.ocn.ne.jp).
Some of these are architecturally required for R2 processors so lets try
to be bit closer to the real thing. This also provides access to the
CPU cycle timer, even on multiprocessors. In that aspect its currently
bug compatible to what would happen on a R2-based SMP.
