commit 3f0a53bc6482fb09770982a8447981260ea258dc upstream.
This fixes booting with the combination of CONFIG_RELOCATABLE=y
and CONFIG_MIPS_ELF_APPENDED_DTB=y.
Sections that appear after the relocation table are not relocated
on system boot (except .bss, which has special handling).
With CONFIG_MIPS_ELF_APPENDED_DTB, the dtb is part of the
vmlinux ELF, so it must be relocated together with everything else.
Fixes: 069fd766271d ("MIPS: Reserve space for relocation table")
Signed-off-by: Yasha Cherikovsky <yasha.che3@gmail.com>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: stable@vger.kernel.org # v4.7+
[ Upstream commit 3f00f4d8f083bc61005d0a1ef592b149f5c88bbd ]
When clearing the .bss section in kernel_entry we do so using LONG_S
instructions, and branch whilst the current write address doesn't equal
the end of the .bss section minus the size of a long integer. The .bss
section always begins at a long-aligned address and we always increment
the write pointer by the size of a long integer - we therefore rely upon
the .bss section ending at a long-aligned address. If this is not the
case then the long-aligned write address can never be equal to the
non-long-aligned end address & we will continue to increment past the
end of the .bss section, attempting to zero the rest of memory.
Despite this requirement that .bss end at a long-aligned address we pass
0 as the end alignment requirement to the BSS_SECTION macro and thus
don't guarantee any particular alignment, allowing us to hit the error
condition described above.
Fix this by instead passing 8 bytes as the end alignment argument to
the BSS_SECTION macro, ensuring that the end of the .bss section is
always at least long-aligned.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/14526/
When doing an nmi backtrace of many cores, most of which are idle, the
output is a little overwhelming and very uninformative. Suppress
messages for cpus that are idling when they are interrupted and just
emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN".
We do this by grouping all the cpuidle code together into a new
.cpuidle.text section, and then checking the address of the interrupted
PC to see if it lies within that section.
This commit suitably tags x86 and tile idle routines, and only adds in
the minimal framework for other architectures.
Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com
Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm]
Tested-by: Petr Mladek <pmladek@suse.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
When CONFIG_RELOCATABLE is enabled, add a new section in the memory map
to be filled with relocation data.
CONFIG_RELOCATION_TABLE_SIZE allows the amount of space reserved to be
adjusted if necessary.
The relocs tool will populate this reserved space with relocation
information. The space is reserved within the elf by filling it with
0's, and an invalid entry is left at the start of the space such that
kernel relocation will be aborted if the table is empty.
Signed-off-by: Matt Redfearn <matt.redfearn@imgtec.com>
Cc: Aaro Koskinen <aaro.koskinen@nokia.com>
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Jonas Gorski <jogo@openwrt.org>
Cc: kernel-hardening@lists.openwall.com
Patchwork: https://patchwork.linux-mips.org/patch/12982/
KASAN needs to know whether the allocation happens in an IRQ handler.
This lets us strip everything below the IRQ entry point to reduce the
number of unique stack traces needed to be stored.
Move the definition of __irq_entry to <linux/interrupt.h> so that the
users don't need to pull in <linux/ftrace.h>. Also introduce the
__softirq_entry macro which is similar to __irq_entry, but puts the
corresponding functions to the .softirqentry.text section.
Signed-off-by: Alexander Potapenko <glider@google.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
For bootloaders that support booting only ELF kernels and load only ELF
segments to memory there is no easy way to supply DTB without kernel
recompilation. For that purpose, create a section called .appended_dtb
that can be later updated with board-specific DTB using binutils e.g. at
kernel installation time.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Patchwork: https://patchwork.linux-mips.org/patch/11114/
OCTEON Pre-SDK-1.8.1 bootloaders can not handle PT_NOTE program headers,
so do not emit them.
Before the patch:
$ readelf --program-headers octeon-vmlinux
Elf file type is EXEC (Executable file)
Entry point 0xffffffff815d09d0
There are 2 program headers, starting at offset 64
Program Headers:
Type Offset VirtAddr PhysAddr
FileSiz MemSiz Flags Align
LOAD 0x0000000000001000 0xffffffff81100000 0xffffffff81100000
0x0000000000b57f80 0x0000000001b86360 RWE 1000
NOTE 0x00000000004e02e0 0xffffffff815df2e0 0xffffffff815df2e0
0x0000000000000024 0x0000000000000024 R 4
After the patch:
There are 1 program headers, starting at offset 64
Program Headers:
The patch was tested on DSR-1000N router.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Matthew Fortune <Matthew.Fortune@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/11403/
Discard .MIPS.abiflags from vmlinux. It's not needed and will cause
issues e.g. with old OCTEON bootloaders that cannot tolerate
additional program headers.
Before the patch:
There are 3 program headers, starting at offset 64
Program Headers:
ABIFLAGS 0x00000000005e77f0 0xffffffff816e67f0 0xffffffff816e67f0
0x0000000000000018 0x0000000000000018 R 8
After the patch:
Program Headers:
Suggested-by: Matthew Fortune <matthew.fortune@imgtec.com>
Suggested-by: Ralf Baechle <ralf@linux-mips.org>
Cc: David Daney <ddaney.cavm@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/11402/
Add support for detecting a vmlinux.bin appended dtb and overriding
the boot arguments to match the UHI interface.
Due to the PERCPU section being empty for !SMP, but still modifying
the current address by aligning it to the page size, do not define
it for !SMP builds to allow __appended_dtb to still point to
the actual end of the data.
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
Cc: devicetree@vger.kernel.org
Cc: John Crispin <blogic@openwrt.org>
Cc: Kevin Cernekee <cernekee@gmail.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: James Hartley <James.Hartley@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9739/
Some toolchains (including Cavium OCTEON SDK) are emitting .eh_frame
sections by default. Discard them as they are useless in the kernel.
Signed-off-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5684/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
We can save an instruction in the TLB Refill path for kernel mappings
by aligning swapper_pg_dir on a 64K boundary. The address of
swapper_pg_dir can be generated with a single LUI instead of
LUI/{D}ADDUI.
The alignment of __init_end is bumped up to 64K so there are no holes
between it and swapper_pg_dir, which is placed at the very beginning
of .bss.
The alignment of invalid_pmd_table and invalid_pte_table can be
relaxed to PAGE_SIZE. We do this by using __page_aligned_bss, which
has the added benefit of eliminating alignment holes in .bss.
Cc: linux-arch@vger.kernel.org,
Patchwork: https://patchwork.linux-mips.org/patch/4220/
Improper alignment can lead to unbootable systems and/or random
crashes.
[ralf@linux-mips.org: This is a lond standing bug since
6eb10bc9e2deab06630261cd05c4cb1e9a60e980 (kernel.org) rsp.
c422a10917f75fd19fa7fe070aaaa23e384dae6f (lmo) [MIPS: Clean up linker script
using new linker script macros.] so dates back to 2.6.32.]
Cc: <stable@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/3881/
_sdata is defined twice in vmlinux.lds.S. According to vmlinux.ld.h
in asm-generic, _sdata should be marked at the beginning RO_DATA_SECTION.
* _sdata = .;
* RO_DATA_SECTION(PAGE_SIZE)
* RW_DATA_SECTION(...)
* _edata = .;
Remove the one that is marked at RW_DATA_SECTION.
Signed-off-by: Tony Wu <tung7970@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/3215/
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
A new utility function (core_kernel_data()) is used to determine if a
passed in address is part of core kernel data or not. It may or may not
return true for RO data, but this utility must work for RW data.
Thus both _sdata and _edata must be defined and continuous,
without .init sections that may later be freed and replaced by
volatile memory (memory that can be freed).
This utility function is used to determine if data is safe from
ever being freed. Thus it should return true for all RW global
data that is not in a module or has been allocated, or false
otherwise.
Also change core_kernel_data() back to the more precise _sdata condition
and document the function.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Hirokazu Takata <takata@linux-m32r.org>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: linux-m68k@lists.linux-m68k.org
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: JamesE.J.Bottomley <jejb@parisc-linux.org>
Link: http://lkml.kernel.org/r/1305855298.1465.19.camel@gandalf.stny.rr.com
arch/alpha/kernel/vmlinux.lds.S | 1 +
arch/m32r/kernel/vmlinux.lds.S | 1 +
arch/m68k/kernel/vmlinux-std.lds | 2 ++
arch/m68k/kernel/vmlinux-sun3.lds | 1 +
arch/mips/kernel/vmlinux.lds.S | 1 +
arch/parisc/kernel/vmlinux.lds.S | 3 +++
kernel/extable.c | 12 +++++++++++-
7 files changed, 20 insertions(+), 1 deletion(-)
Signed-off-by: Maxin B. John <maxin.john@gmail.com>
To: Catalin Marinas <catalin.marinas@arm.com>
Cc: Daniel Baluta <dbaluta@ixiacom.com>
Cc: naveen yadav <yad.naveen@gmail.com>
Cc: linux-mm@kvack.org
Patchwork: https://patchwork.linux-mips.org/patch/2244/
Percpu allocator honors alignment request upto PAGE_SIZE and both the
percpu addresses in the percpu address space and the translated kernel
addresses should be aligned accordingly. The calculation of the
former depends on the alignment of percpu output section in the kernel
image.
The linker script macros PERCPU_VADDR() and PERCPU() are used to
define this output section and the latter takes @align parameter.
Several architectures are using @align smaller than PAGE_SIZE breaking
percpu memory alignment.
This patch removes @align parameter from PERCPU(), renames it to
PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it,
add PCPU_SETUP_BUG_ON() checks such that alignment problems are
reliably detected and remove percpu alignment comment recently added
in workqueue.c as the condition would trigger BUG way before reaching
there.
For um, this patch raises the alignment of percpu area. As the area
is in .init, there shouldn't be any noticeable difference.
This problem was discovered by David Howells while debugging boot
failure on mn10300.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: Jeff Dike <jdike@addtoit.com>
Cc: user-mode-linux-devel@lists.sourceforge.net
Currently percpu readmostly subsection may share cachelines with other
percpu subsections which may result in unnecessary cacheline bounce
and performance degradation.
This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR()
linker macros, makes each arch linker scripts specify its cacheline
size and use it to align percpu subsections.
This is based on Shaohua's x86 only patch.
Cc: Shaohua Li <shaohua.li@intel.com>
This patch adds a generic solution to support multiple machines based on
a given SoC within a single kernel image. It is implemented already for
several other architectures but MIPS has no generic support for that yet.
[Ralf: This competes with DT but DT is a much more complex solution and this
code has been used by OpenWRT for a long time so for now DT is a bad reason
to stop the merge but longer term this should be migrated to DT.]
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: kaloz@openwrt.org
Cc: Luis R. Rodriguez <lrodriguez@atheros.com>
Cc: Cliff Holden <Cliff.Holden@Atheros.com>
Patchwork: https://patchwork.linux-mips.org/patch/1814/
This patch add a new section for MIPS to record the block of the hardirq
handling for function graph tracer(print_graph_irq) via adding the
__irq_entry annotation to the the entrypoints of the hardirqs(the block
with irq_enter()...irq_exit()).
Thanks goes to Steven & Frederic Weisbecker for their feedbacks.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Cc: Nicholas Mc Guire <der.herr@hofr.at>
Cc: zhangfx@lemote.com
Cc: Wu Zhangjin <wuzhangjin@gmail.com>
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Patchwork: http://patchwork.linux-mips.org/patch/676/
Commit 51b563fc93c8cb5bff1d67a0a71c374e4a4ea049 ("arm, cris, mips,
sparc, powerpc, um, xtensa: fix build with bash 4.0") removed a few
CPPFLAGS with vital include paths necessary to build vmlinux.lds
on MIPS, and moved the calculation of the 'jiffies' symbol
directly to vmlinux.lds.S but forgot to change make ifdef/... to
cpp macros.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
[sam: moved assignment of CPPFLAGS arch/mips/kernel/Makefile]
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported:
Bash 4 filters out variables which contain a dot in them.
This happends to be the case of CPPFLAGS_vmlinux.lds.
This is rather unfortunate, as it now causes
build failures when using SHELL=/bin/bash to compile,
or when bash happens to be used by make (eg when it's /bin/sh)
Remove the common definition of CPPFLAGS_vmlinux.lds by
pushing relevant stuff to either Makefile.build or the
arch specific kernel/Makefile where we build the linker script.
This is also nice cleanup as we move the information out where
it is used.
Notes for the different architectures touched:
arm - we use an already exported symbol
cris - we use a config symbol aleady available
[Not build tested]
mips - the jiffies complexity has moved to vmlinux.lds.S where we need it.
Added a few variables to CPPFLAGS - they are only used by
the linker script.
[Not build tested]
powerpc - removed assignment that is not needed
[not build tested]
sparc - simplified it using $(BITS)
um - introduced a few new exported variables to deal with this
xtensa - added options to CPP invocation
[not build tested]
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Chris Zankel <chris@zankel.net>
This patch results in fewer output sections and in some data being
reordered, but should have no functional impact.
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
Now that PAGE_SIZE is available to assembly directly, there is no need
to separately expose it as _PAGE_SIZE through asm-offsets.
In addition, remove _PAGE_SHIFT from asm-offsets, since it was never
needed, and is not used anywhere.
Discarded sections in different archs share some commonality but have
considerable differences. This led to linker script for each arch
implementing its own /DISCARD/ definition, which makes maintaining
tedious and adding new entries error-prone.
This patch makes all linker scripts to move discard definitions to the
end of the linker script and use the common DISCARDS macro. As ld
uses the first matching section definition, archs can include default
discarded sections by including them earlier in the linker script.
ia64 is notable because it first throws away some ia64 specific
subsections and then include the rest of the sections into the final
image, so those sections must be discarded before the inclusion.
defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64,
alpha, sparc, sparc64 and s390. Michal Simek tested microblaze.
Acked-by: Paul Mundt <lethal@linux-sh.org>
Tested-by: Michal Simek <monstr@monstr.eu>
Cc: microblaze-uclinux@itee.uq.edu.au
x86 throws away .discard section but no other archs do. Also,
.discard is not thrown away while linking modules. Make every arch
and module linking throw it away. This will be used to define dummy
variables for percpu declarations and definitions.
This patch is based on Ivan Kokshaysky's alpha percpu patch.
[ Impact: always throw away everything in .discard ]
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Bryan Wu <cooloney@kernel.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com>
The -ffunction-sections puts each text in .text.function_name section.
Without this patch, most functions are placed outside _text..._etext
area and it breaks show_stacktrace(), etc.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
This patch consolidate all definitions of .init.text, .init.data
and .exit.text, .exit.data section definitions in
the generic vmlinux.lds.h.
This is a preparational patch - alone it does not buy
us much good.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
This style will be consitent with all other arch's - soon.
In addition:
- Moved a few labels inside brackets for the sections they specify
to prevent that linker alignmnet made them point before the section start
Store any note sections after the exception tables like the other
architectures do. This is required for .note.gnu.build-id emitted from
binutils 2.18 onwards if nothing else.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Leaving these sections is useful to some tools that look at the image, and
none of them are loaded into memory. The .mdebug.abi64 section, in
particular, lets GDB recognize vmlinux.32 as an N64 program instead of
guessing that it is O32.
Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com>
per cpu data section contains two types of data. One set which is
exclusively accessed by the local cpu and the other set which is per cpu,
but also shared by remote cpus. In the current kernel, these two sets are
not clearely separated out. This can potentially cause the same data
cacheline shared between the two sets of data, which will result in
unnecessary bouncing of the cacheline between cpus.
One way to fix the problem is to cacheline align the remotely accessed per
cpu data, both at the beginning and at the end. Because of the padding at
both ends, this will likely cause some memory wastage and also the
interface to achieve this is not clean.
This patch:
Moves the remotely accessed per cpu data (which is currently marked
as ____cacheline_aligned_in_smp) into a different section, where all the data
elements are cacheline aligned. And as such, this differentiates the local
only data and remotely accessed data cleanly.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: <linux-arch@vger.kernel.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@suse.de>
With this consolidation we can now modify the .data
section definition in one spot for all archs.
Move definition of .text section to asm-generic.
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and
Ingo suggested KVM as well).
Because larger alignments can use more room, we increase the max per-cpu
memory to 64k rather than 32k: it's getting a little tight.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs
when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes
on most platfoms (some reserve PAGE_SIZE for initramfs).
Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com>
While the recent cset 86384d544157db23879064cde36061cdcafc6794 did improve
things it didn't resolve all the problems. So bite the bullet and discard
.exit.text and .exit.data at runtime. Which of course sucks because it
bloats binaries with code that will never ever be used but it's the only
thing that will work reliable as demonstrated by the function sd_major() in
drivers/scsi/sd.c.
Gcc may compile sd_major() using a jump table which it will put into
.rodata. If it also inlines sd_major's function body into exit_sd() which
gcc > 3.4.x does. If CONFIG_BLK_DEV_SD has been set to y we would like ld
to discard exit_sd's code at link time. However sd_major happens to
contain a switch statement which gcc will compile using a jump table in
.rodata on the architectures I checked. So, when ld later discards
.exit.text only the jump table in .rodata with its stale references to
the discard .exit.text will be left which any no antique ld will honor
with a link error.
This fixes fairly unobvious breakage of various drivers.
Derived from Peter Watkins <treestem@gmail.com>'s work.
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table,
teach all the architectures to use it.
This is a prerequisite for a patch which performs initcall synchronisation for
multithreaded-probing.
Cc: Greg KH <greg@kroah.com>
[ Added AVR32 as well ]
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
