path: root/arch/mips/kernel/vpe.c
2014-01-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The most notable new addition inside this pull request is the support for MIPS's latest and greatest core called "inter/proAptiv". The patch series describes this core as follows. "The interAptiv is a power-efficient multi-core microprocessor for use in system-on-chip (SoC) applications. The interAptiv combines a multi-threading pipeline with a coherence manager to deliver improved computational throughput and power efficiency. The interAptiv can contain one to four MIPS32R3 interAptiv cores, system level coherence manager with L2 cache, optional coherent I/O port, and optional floating point unit." The platform specific patches touch all 3 Broadcom families. It adds support for the new Broadcom/Netlogix XLP9xx Soc, building a common BCM63XX SMP kernel for all BCM63XX SoCs regardless of core type/count and full gpio button/led descriptions for BCM47xx. The rest of the series are cleanups and bug fixes that are MIPS generic and consist largely of changes that Imgtec/MIPS had published in their linux-mti-3.10.git stable tree. Random other cleanups and patches preparing code to be merged in 3.15" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) mips: select ARCH_MIGHT_HAVE_PC_SERIO mips: delete non-required instances of include <linux/init.h> MIPS: KVM: remove shadow_tlb code MIPS: KVM: use common EHINV aware UNIQUE_ENTRYHI mips/ide: flush dcache also if icache does not snoop dcache MIPS: BCM47XX: fix position of cpu_wait disabling MIPS: BCM63XX: select correct MIPS_L1_CACHE_SHIFT value MIPS: update MIPS_L1_CACHE_SHIFT based on MIPS_L1_CACHE_SHIFT_<N> MIPS: introduce MIPS_L1_CACHE_SHIFT_<N> MIPS: ZBOOT: gather string functions into string.c arch/mips/pci: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource bcma: gpio: don't cast u32 to unsigned long ssb: gpio: add own IRQ domain MIPS: BCM47XX: fix sparse warnings in board.c MIPS: BCM47XX: add board detection for Linksys WRT54GS V1 MIPS: BCM47XX: fix detection for some boards MIPS: BCM47XX: Enable buttons support on SSB MIPS: BCM47XX: Convert WNDR4500 to new syntax MIPS: BCM47XX: Use "timer" trigger for status LEDs ...
2014-01-22MIPS: VPE: Remove vpe_getuid and vpe_getgidEric W. Biederman
The linux build-bot recently reported a build error in arch/mips/kernel/vpe.c tree: git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git for-linus head: 261000a56b6382f597bcb12000f55c9ff26a1efb commit: 261000a56b6382f597bcb12000f55c9ff26a1efb [4/4] userns: userns: Remove UIDGID_STRICT_TYPE_CHECKS config: make ARCH=mips maltaaprp_defconfig All error/warnings: arch/mips/kernel/vpe.c: In function 'vpe_open': >> arch/mips/kernel/vpe.c:1086:9: error: incompatible types when assigning to type 'unsigned int' from type 'kuid_t' >> arch/mips/kernel/vpe.c:1087:9: error: incompatible types when assigning to type 'unsigned int' from type 'kgid_t' vim +1086 arch/mips/kernel/vpe.c 863abad4 Jesper Juhl 2010-10-30 1080 return -ENOMEM; 863abad4 Jesper Juhl 2010-10-30 1081 } e01402b1 Ralf Baechle 2005-07-14 1082 v->plen = P_SIZE; e01402b1 Ralf Baechle 2005-07-14 1083 v->load_addr = NULL; e01402b1 Ralf Baechle 2005-07-14 1084 v->len = 0; e01402b1 Ralf Baechle 2005-07-14 1085 d76b0d9b David Howells 2008-11-14 @1086 v->uid = filp->f_cred->fsuid; d76b0d9b David Howells 2008-11-14 @1087 v->gid = filp->f_cred->fsgid; 2600990e Ralf Baechle 2006-04-05 1088 2600990e Ralf Baechle 2006-04-05 1089 v->cwd[0] = 0; 2600990e Ralf Baechle 2006-04-05 1090 ret = getcwd(v->cwd, VPE_PATH_MAX); When examining the code to see what v->uid and v->gid were used for I discovered that the only users in the kernel are vpe_getuid and vpe_getgid, and that vpe_getuid and vpe_getgid are never called. So instead of proposing a conversion to use kuid_t and kgid_t instead of unsigned int/int as I normally would let's just kill this dead code so no one has to worry about it further. Deng-Cheng Zhu said: This is a good catch. vpe_get[u|g]id was originally used by KSPD which has been removed. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Reviewed-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-01-22MIPS: APRP: Code formatting clean-ups.Steven J. Hill
Clean-up code according to the 'checkpatch.pl' script. Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Reviewed-by: Qais Yousef <Qais.Yousef@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/6097/ Reviewed-by: John Crispin <blogic@openwrt.org>
2014-01-22MIPS: APRP: Split VPE loader into separate files.Deng-Cheng Zhu
Split the VPE functionality in preparation for adding support for CMP platforms. Common functions remain in the original file and a new file contains code specific to platforms that do not have a CMP present. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Reviewed-by: Qais Yousef <Qais.Yousef@imgtec.com> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6094/
2013-09-13MIPS: kernel: vpe: Make vpe_attrs an array of pointers.Markos Chandras
Commit 567b21e973ccf5b0d13776e408d7c67099749eb8 "mips: convert vpe_class to use dev_groups" broke the build on MIPS since vpe_attrs should be an array of 'struct device_attribute' pointers. Fixes the following build problem: arch/mips/kernel/vpe.c:1372:2: error: missing braces around initializer [-Werror=missing-braces] arch/mips/kernel/vpe.c:1372:2: error: (near initialization for 'vpe_attrs[0]') [-Werror=missing-braces] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Crispin <blogic@openwrt.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5819/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-08-19mips: convert vpe_class to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the MIPS vpe_class code to use the correct field. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Crispin <blogic@openwrt.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-02Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: o Add basic support for the Mediatek/Ralink Wireless SoC family. o The Qualcomm Atheros platform is extended by support for the new QCA955X SoC series as well as a bunch of patches that get the code ready for OF support. o Lantiq and BCM47XX platform have a few improvements and bug fixes. o MIPS has sent a few patches that get the kernel ready for the upcoming microMIPS support. o The rest of the series is made up of small bug fixes and cleanups that relate to various parts of the MIPS code. The biggy in there is a whitespace cleanup. After I was sent another set of whitespace cleanup patches I decided it was the time to clean the whitespace "issues" for once and and that touches many files below arch/mips/. Fix up silly conflicts, mostly due to whitespace cleanups. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (105 commits) MIPS: Quit exporting kernel internel break codes to uapi/asm/break.h MIPS: remove broken conditional inside vpe loader code MIPS: SMTC: fix implicit declaration of set_vi_handler MIPS: early_printk: drop __init annotations MIPS: Probe for and report hardware virtualization support. MIPS: ath79: add support for the Qualcomm Atheros AP136-010 board MIPS: ath79: add USB controller registration code for the QCA955X SoCs MIPS: ath79: add PCI controller registration code for the QCA955X SoCs MIPS: ath79: add WMAC registration code for the QCA955X SoCs MIPS: ath79: register UART for the QCA955X SoCs MIPS: ath79: add QCA955X specific glue to ath79_device_reset_{set, clear} MIPS: ath79: add GPIO setup code for the QCA955X SoCs MIPS: ath79: add IRQ handling code for the QCA955X SoCs MIPS: ath79: add clock setup code for the QCA955X SoCs MIPS: ath79: add SoC detection code for the QCA955X SoCs MIPS: ath79: add early printk support for the QCA955X SoCs MIPS: ath79: fix WMAC IRQ resource assignment mips: reserve elfcorehdr mips: Make sure kernel memory is in iomem MIPS: ath79: use dynamically allocated USB platform devices ...
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21Merge branch 'mips-next-3.9' of ↵Ralf Baechle
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
2013-02-19MIPS: remove broken conditional inside vpe loader codeJohn Crispin
The commit [1] breaks builds and results in the following error arch/mips/kernel/vpe.c: In function 'vpe_run': arch/mips/kernel/vpe.c:708:16: error: invalid type argument of '->' (have 'struct list_head') Taking a closer look at the conditional we notice that list_first_entry wont ever return NULL. The easiest fix is to just drop the dead code. [1] commit 3d2d03247632920aa21b42a0b032a4ffd44ce15e MIPS: vpe.c: Fix null pointer dereference in print arguments. Signed-off-by: John Crispin <blogic@openwrt.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-01-16MIPS: vpe.c: Fix null pointer dereference in print arguments.Cong Ding
In the printk, the variable t euqals to NULL, so there is no t->index. Use v->tc->index instead. [ralf@linux-mips.org: Use opportunity of changing this line anyway to make this line whitespacely correct.] Signed-off-by: Cong Ding <dinggnu@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/4792/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-11MIPS: MT: Remove kspd.Ralf Baechle
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2011-10-31mips: remove needless include of module.h from core kernel files.Paul Gortmaker
None of these files are using modular infrastructure, and build tests reveal that none of these files are really relying on any implicit inclusions via. module.h either. So delete them. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-17MIPS: VPE: Select correct tcHillf Danton
If we could find tc on the tc list for @index, the found tc should be returned. Signed-off-by: Hillf Danton <dhillf@gmail.com> To: LKML <linux-kernel@vger.kernel.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2692/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-14MIPS: Replace deprecated spinlock initializationThomas Gleixner
SPIN_LOCK_UNLOCK is deprecated. Use the lockdep capable variant instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2025/ Signed-off-by: Ralf Baechle <ralf@duck.linux-mips.net>
2010-12-16MIPS: VPE loader: Check vmalloc return value in vpe_openJesper Juhl
The return value of the vmalloc() call in arch/mips/kernel/vpe.c::vpe_open() is not checked, so we potentially store a null pointer in v->pbuffer. Add a check for a null return and then return -ENOMEM in that case. [Ralf: The check added by Jesper's original patch is where it logically should be. Adding it eleminated the need for the checks in a few other places, so I removed them. There still is a zillion of other things that need to be fixed in this file / API.] Signed-off-by: Jesper Juhl <jj@chaosbits.net> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1747/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-02-27MIPS: Don't include <linux/smp_lock.h> unnecessarily.Ralf Baechle
2009-11-02MIPS: VPE: Remove stray unlock_kernel.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Josip Rodin <joy@entuzijast.net>
2009-09-30MIPS: VPE: Get rid of BKL.Ralf Baechle
2009-09-17MIPS: Remove useless zero initializations.Ralf Baechle
2009-08-03MIPS: VPE: Delete unused function get_tc_unused().Ralf Baechle
2009-08-03MIPS: VPE: Fix bogus indentation.Ralf Baechle
2009-08-03MIPS: VPE: Make various functions static.Ralf Baechle
None of these is used outside the VPE loader. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: VPE: Free relocation chain on error.Ralf Baechle
This may happen if a bad sequence of relocations is being encountered. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: VPE: Fix compiler warning.Raghu Gandham
Signed-off-by: Raghu Gandham <raghu@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-03MIPS: MT: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-06mips: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-05MIPS: Fix incorrect use of loose in vpe.cNick Andrew
It should be 'lose', not 'loose'. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-11-14CRED: Use creds in file structsDavid Howells
Attach creds to file structs and discard f_uid/f_gid. file_operations::open() methods (such as hppfs_open()) should use file->f_cred rather than current_cred(). At the moment file->f_cred will be current_cred() at this point. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-05-18mips: cdev lock_kernel() pushdownJonathan Corbet
Push the cdev lock_kernel() call into MIPS-specific drivers. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-12[MIPS] ELF handling - use SELFMAG instead of numeric constantCyrill Gorcunov
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Don't use max_pfn which is no longer initialized these days.Ralf Baechle
Still won't play nicely with esotheric configurations such as discontig memory ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-12[MIPS] Fixes necessary for non-SMP kernels and non-relocatable binariesKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-01[MIPS] VPE loader: Check result of memory allocation.Ralf Baechle
And while at it, make it a little cleaner. Issue originally reported by Tiejun Chen (tiejun.chen@windriver.com). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Remove duplicate includes.Lucas Woods
Signed-off-by: Lucas Woods <woodzy@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] vpe: Add missing "space"Joe Perches
2007-11-15[MIPS] vpe: handle halting TCs in an errata safe way.Nigel Stephens
Adds a JR.HB after halting a TC, to ensure that the TC has really halted. only modifies the TCSTATUS register when the TC is safely halted. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] vpe: Use p_paddr instead of p_vaddr loader.Ralf Baechle
This subtle difference makes ELF overlays work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] VPE loader: convert from struct class_ device to struct deviceKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] VPE: reimplement ELF loader.Ralf Baechle
Loading ELF binaries based on the section table is totally wrong. This still leaves the other fat bug of referencing symbols in an executable unfixed, so people better don't run strip on their binaries ... As added bonus the new loader is also 23 lines shorter. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-07-31[MIPS] RP: Sysfs interface for stopping RP programRalf Baechle
The old method of attempting to load a invalid program was just too icky. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] RP: Pass number of TCs available to RP program in $2.Ralf Baechle
