[ Upstream commit c58734eee6a2151ba033c0dcb31902c89e310374 ]
When building with clang, the following section mismatch warning occurs:
WARNING: modpost: vmlinux.o(.text+0x24490): Section mismatch in
reference from the function r4k_cache_init() to the function
.init.text:loongson2_sc_init()
This should have been fixed with commit ad4fddef5f23 ("mips: fix Section
mismatch in reference") but it was missed. Remove the improper __init
annotation like that commit did.
Fixes: 078a55fc824c ("MIPS: Delete __cpuinit/__CPUINIT usage from MIPS code")
Link: https://github.com/ClangBuiltLinux/linux/issues/787
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Huacai Chen <chenhuacai@kernel.org>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
commit f675843ddfdfdf467d08cc922201614a149e439e upstream.
local_r4k___flush_cache_all() is missing a special check for BMIPS5000
processors, we need to blast the S-cache, just like other MTI processors
since we have an inclusive cache. We also need an additional __sync() to
make sure this is completed.
Fixes: d74b0172e4e2c ("MIPS: BMIPS: Add special cache handling in c-r4k.c")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/13012/
commit 73c4ca047f440c79f545bc6133e3033f754cd239 upstream.
BMIPS5000 and BMIPS5200 processor have no D cache aliases, and this is
properly handled by the per-CPU override added at the end of
r4k_cache_init(), the problem is that the output of probe_pcache()
disagrees with that, since this is too late:
Primary instruction cache 32kB, VIPT, 4-way, linesize 64 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
With the change moved earlier, we now have a consistent output with the
settings we are intending to have:
Primary data cache 32kB, 4-way, VIPT, no aliases, linesize 32 bytes
Patchwork: https://patchwork.linux-mips.org/patch/13011/
commit c130d2fd3d59fbd5d269f7d5827bd4ed1d94aec6 upstream.
BMIPS5000 and BMIPS52000 processors have their I-cache filling from the
D-cache. Since BMIPS_GENERIC does not provide (yet) a
cpu-feature-overrides.h file, this was not set anywhere, so make sure
the R4K cache detection takes care of that.
Patchwork: https://patchwork.linux-mips.org/patch/13010/
[ Upstream commit d4da0e97baea8768b3d66ccef3967bebd50dfc3b ]
If a driver causes DMA cache maintenance with a zero length then we
currently BUG and kill the kernel. As this is a scenario that we may
well be able to recover from, WARN & return in the condition instead.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/14623/
Add a CPU_I6400 case to various switch statements, doing the same thing
as for CPU_P5600.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10635/
The L2 cache in the I6400 core has 16 ways, so extend the way_string
array to take such caches into account.
[ralf@linux-mips.org: Other already supported CPUs are free to support
more than 8 ways of cache as well.]
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10640/
MT_SMP is not the only SMP option for MT cores. The MT_SMP option
allows more than one VPE per core to appear as a secondary CPU in the
system. Because of how CM works, it propagates the address-based
cache ops to the secondary cores but not the index-based ones.
Because of that, the code does not use IPIs to flush the L1 caches on
secondary cores because the CM would have done that already. However,
the CM functionality is independent of the type of SMP kernel so even in
non-MT kernels, IPIs are not necessary. As a result of which, we change
the conditional to depend on the CM presence. Moreover, since VPEs on
the same core share the same L1 caches, there is no need to send an
IPI on all of them so we calculate a suitable cpumask with only one
VPE per core.
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/10654/
We removed __cpuinit support (leaving no-op stubs) quite some time ago.
However a new instance was added in commit 4caa906ee949b7002cc1558bbe3744
("MIPS: mm: c-r4k: Build EVA {d,i}cache flushing functions")
Since we want to clobber the stubs soon, get this removed now.
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/9893/
Fixes a typo in arch/mips/mm/c-r4k.c's probe_scache().
Signed-off-by: Joshua Kinard <kumba@gentoo.org>
Fix the 74K D-cache alias erratum workaround so that it actually works.
Our current code sets MIPS_CACHE_VTAG for the D-cache, but that flag
only has any effect for the I-cache. Additionally MIPS_CACHE_PINDEX is
set for the D-cache if CP0.Config7.AR is also set for an affected
processor, leading to confusing information in the bootstrap log (the
flag isn't used beyond that).
So delete the setting of MIPS_CACHE_VTAG and rely on MIPS_CACHE_ALIASES,
set in a common place, removing I-cache coherency issues seen in GDB
testing with software breakpoints, gdbserver and ptrace(2), on affected
systems.
While at it add a little piece of explanation of what CP0.Config6.SYND
is so that people do not have to chase documentation.
Signed-off-by: Maciej W. Rozycki <macro@codesourcery.com>
Patchwork: https://patchwork.linux-mips.org/patch/8507/
This allows the kernel to correctly detect an R16000 MIPS CPU on systems that
have those. Otherwise, such systems will detect the CPU as an R14000, due to
similarities in the CPU PRId value.
Cc: Linux MIPS List <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/9092/
The secondary cache initialization and configuration code is processor
specific so we need to handle MIPS R6 cores as well.
The local_r4k_flush_cache_sigtramp function uses the 'cache'
instruction inside an asm block. However, MIPS R6 changed the
opcode for the cache instruction and as a result of which we
need to set the correct ISA level.
Add a CPU_QEMU_GENERIC case to various switch statements.
Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
BMIPS435x and BMIPS438x have a single shared L1 D$ and load/store unit,
so it isn't necessary to raise IPIs to keep both CPUs coherent.
BMIPS5000 has VIPT L1 caches that handle aliases in hardware, and its I$
fills from D$. But a special sequence with 2 SYNCs and 32 NOPs is needed
to ensure coherency.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Cc: f.fainelli@gmail.com
Cc: mbizon@freebox.fr
Cc: jogo@openwrt.org
Cc: jfraser@broadcom.com
Cc: devicetree@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/8165/
Code in a switch statement in probe_pcache checks the CPU type twice
unnecessarily for processor implementations that have the alias removal
feature reported by the CP0 Config7.AR and Config7.IAR bits. This change
rewrites the affected fragment avoiding the extraneous check and improving
readability.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/7221/
These are needed to boot a generic mips64r2 kernel on OCTEONIII.
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: kvm@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7003/
mips-for-linux-next
Nobody is maintaining SMTC anymore and there also seems to be no userbase.
Which is a pity - the SMTC technology primarily developed by Kevin D.
Kissell <kevink@paralogos.com> is an ingenious demonstration for the MT
ASE's power and elegance.
Based on Markos Chandras <Markos.Chandras@imgtec.com> patch
https://patchwork.linux-mips.org/patch/6719/ which while very similar did
no longer apply cleanly when I tried to merge it plus some additional
post-SMTC cleanup - SMTC was a feature as tricky to remove as it was to
merge once upon a time.
R4600_HIT_CACHEOP_WAR_IMPL is only needed on R4600 v1.6 and the R4600 has
data cache lines that are always 32 bytes so the call is pointless in
r4k_blast_dcache_page_dc64.
Implement a CPU power management callback for the r4k cache, to set up
coherency again after leaving a powered down state.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Basic Loongson-3 CPU support include CPU probing and TLB/cache
initializing.
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Signed-off-by: Hongliang Tao <taohl@lemote.com>
Signed-off-by: Hua Yan <yanh@lemote.com>
Tested-by: Alex Smith <alex.smith@imgtec.com>
Reviewed-by: Alex Smith <alex.smith@imgtec.com>
Cc: John Crispin <john@phrozen.org>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/6630
The M5150 core is a 32-bit MIPS RISC which implements the
MIPS Architecture Release-5 in a 5-stage pipeline.
In addition, it includes the MIPS Architecture Virtualization Module
that enables virtualization of operating systems,
which provides a scalable, trusted, and secure execution environment.
Patchwork: https://patchwork.linux-mips.org/patch/6596/
Setting DMA_MAYBE_COHERENT gives a platform the opportunity to select
use of cache ops at boot.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/6575/
There is a chance for the secondary cache to have memory
aliases. This can happen if the bootloader is in a non-EVA mode
(or even in EVA mode but with different mapping from the kernel)
and the kernel switching to EVA afterwards. It's best to flush
the icache to avoid having the secondary CPUs fetching stale
data from it.
Use the userspace cache flushing functions if the interrupted
process is a userspace one.
Build EVA specific cache flushing functions (ie cachee).
They will be used by a subsequent patch.
Add a CPU_P5600 case to various switch statements, doing the same thing
as for CPU_PROAPTIV.
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6408/
This patch introduces a new SMP implementation for systems implementing
the MIPS Coherent Processing System architecture. The kernel will make
use of the Coherence Manager, Cluster Power Controller & Global
Interrupt Controller in order to detect, bring up & make use of other
cores in the system. SMTC is not supported, so only a single TC per VPE
in the system is used. That is, this option enables an SMVP style setup
but across multiple cores.
Patchwork: https://patchwork.linux-mips.org/patch/6362/
Patchwork: https://patchwork.linux-mips.org/patch/6611/
Patchwork: https://patchwork.linux-mips.org/patch/6651/
Patchwork: https://patchwork.linux-mips.org/patch/6652/
The 1074K is a multiprocessing coherent processing system (CPS) based
on modified 74K cores. This patch makes the 1074K an actual unique
CPU type, instead of a 74K derivative, which it is not.
Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
Reviewed-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6389/
The *Aptiv cores can use the CONF7/IAR bit to detect if the core
has hardware support to remove instruction cache aliasing.
This also defines the CONF7/AR bit in order to avoid using
the '16' magic number.
Patchwork: https://patchwork.linux-mips.org/patch/6499/
Pull MIPS updates from Ralf Baechle:
"The most notable new addition inside this pull request is the support
for MIPS's latest and greatest core called "inter/proAptiv". The
patch series describes this core as follows.
"The interAptiv is a power-efficient multi-core microprocessor
for use in system-on-chip (SoC) applications. The interAptiv combines
a multi-threading pipeline with a coherence manager to deliver improved
computational throughput and power efficiency. The interAptiv can
contain one to four MIPS32R3 interAptiv cores, system level
coherence manager with L2 cache, optional coherent I/O port,
and optional floating point unit."
The platform specific patches touch all 3 Broadcom families. It adds
support for the new Broadcom/Netlogix XLP9xx Soc, building a common
BCM63XX SMP kernel for all BCM63XX SoCs regardless of core type/count
and full gpio button/led descriptions for BCM47xx.
The rest of the series are cleanups and bug fixes that are MIPS
generic and consist largely of changes that Imgtec/MIPS had published
in their linux-mti-3.10.git stable tree. Random other cleanups and
patches preparing code to be merged in 3.15"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits)
mips: select ARCH_MIGHT_HAVE_PC_SERIO
mips: delete non-required instances of include <linux/init.h>
MIPS: KVM: remove shadow_tlb code
MIPS: KVM: use common EHINV aware UNIQUE_ENTRYHI
mips/ide: flush dcache also if icache does not snoop dcache
MIPS: BCM47XX: fix position of cpu_wait disabling
MIPS: BCM63XX: select correct MIPS_L1_CACHE_SHIFT value
MIPS: update MIPS_L1_CACHE_SHIFT based on MIPS_L1_CACHE_SHIFT_<N>
MIPS: introduce MIPS_L1_CACHE_SHIFT_<N>
MIPS: ZBOOT: gather string functions into string.c
arch/mips/pci: don't check resource with devm_ioremap_resource
arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource
bcma: gpio: don't cast u32 to unsigned long
ssb: gpio: add own IRQ domain
MIPS: BCM47XX: fix sparse warnings in board.c
MIPS: BCM47XX: add board detection for Linksys WRT54GS V1
MIPS: BCM47XX: fix detection for some boards
MIPS: BCM47XX: Enable buttons support on SSB
MIPS: BCM47XX: Convert WNDR4500 to new syntax
MIPS: BCM47XX: Use "timer" trigger for status LEDs
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6163/
The proAptiv Multiprocessing System is a power efficient multi-core
microprocessor for use in system-on-chip (SoC) applications.
The proAptiv Multiprocessing System combines a deep pipeline
with multi-issue out of order execution for improved computational
throughput. The proAptiv Multiprocessing System can contain one to
six MIPS32r3 proAptiv cores, system level coherence
manager with L2 cache, optional coherent I/O port, and optional
Patchwork: http://patchwork.linux-mips.org/patch/6134/
According to MIPS32 and MIPS64 PRA documents,
a value of 7 in IL and DL fields is marked as "Reserved"
so panic if the core uses this value in the config1 register.
Also simplify the code a little bit.
Patchwork: http://patchwork.linux-mips.org/patch/5861/
Commit 14bd8c082016 ("MIPS: Loongson: Get rid of Loongson 2 #ifdefery
all over arch/mips") failed to add Loongson2 specific blast_icache32
functions. Fix that.
The patch fixes the following crash seen with 3.13-rc1:
Reserved instruction in kernel code[#1]:
Call Trace:
blast_icache32_page+0x8/0xb0
r4k_flush_cache_page+0x19c/0x200
do_wp_page.isra.97+0x47c/0xe08
handle_mm_fault+0x938/0x1118
__do_page_fault+0x140/0x540
resume_userspace_check+0x0/0x10
Code: 00200825 64834000 00200825 <bc900000> bc900020 bc900040 bc900060 bc900080 bc9000a0
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Reviewed-by: Aurelien Jarno <aurelien@aurel32.net>
Acked-by: John Crispin <blogic@openwrt.org>
Currently, Loongson-2 call protected_blast_icache_range() and others
call protected_loongson23_blast_icache_range(), but I think the correct
behavior should be the opposite. BTW, Loongson-3's cache-ops is
compatible with MIPS64, but not compatible with Loongson-2. So, rename
xxx_loongson23_yyy things to xxx_loongson2_yyy.
The patch fixes early boot hang with 3.13-rc1, introduced in commit
14bd8c082016 ("MIPS: Loongson: Get rid of Loongson 2 #ifdefery all over
arch/mips").
It was ugly.
[ 1.904000] BUG: scheduling while atomic: swapper/1/0x00000002
[ 1.908000] Modules linked in:
[ 1.916000] CPU: 0 PID: 1 Comm: swapper Not tainted 3.12.0-rc2-lemote-los.git-5318619-dirty #1
[ 1.920000] Stack : 0000000031aac000 ffffffff810d0000 0000000000000052 ffffffff802730a4
0000000000000000 0000000000000001 ffffffff810cdf90 ffffffff810d0000
ffffffff8068b968 ffffffff806f5537 ffffffff810cdf90 980000009f0782e8
0000000000000001 ffffffff80720000 ffffffff806b0000 980000009f078000
980000009f290000 ffffffff805f312c 980000009f05b5d8 ffffffff80233518
980000009f05b5e8 ffffffff80274b7c 980000009f078000 ffffffff8068b968
0000000000000000 0000000000000000 0000000000000000 0000000000000000
0000000000000000 980000009f05b520 0000000000000000 ffffffff805f2f6c
0000000000000000 ffffffff80700000 ffffffff80700000 ffffffff806fc758
ffffffff80700000 ffffffff8020be98 ffffffff806fceb0 ffffffff805f2f6c
[ 2.028000] Call Trace:
[ 2.032000] [<ffffffff8020be98>] show_stack+0x80/0x98
[ 2.036000] [<ffffffff805f2f6c>] __schedule_bug+0x44/0x6c
[ 2.040000] [<ffffffff805fac58>] __schedule+0x518/0x5b0
[ 2.044000] [<ffffffff805f8a58>] schedule_timeout+0x128/0x1f0
[ 2.048000] [<ffffffff80240314>] msleep+0x3c/0x60
[ 2.052000] [<ffffffff80495400>] do_probe+0x238/0x3a8
[ 2.056000] [<ffffffff804958b0>] ide_probe_port+0x340/0x7e8
[ 2.060000] [<ffffffff80496028>] ide_host_register+0x2d0/0x7a8
[ 2.064000] [<ffffffff8049c65c>] ide_pci_init_two+0x4e4/0x790
[ 2.068000] [<ffffffff8049f9b8>] amd74xx_probe+0x148/0x2c8
[ 2.072000] [<ffffffff803f571c>] pci_device_probe+0xc4/0x130
[ 2.076000] [<ffffffff80478f60>] driver_probe_device+0x98/0x270
[ 2.080000] [<ffffffff80479298>] __driver_attach+0xe0/0xe8
[ 2.084000] [<ffffffff80476ab0>] bus_for_each_dev+0x78/0xe0
[ 2.088000] [<ffffffff80478468>] bus_add_driver+0x230/0x310
[ 2.092000] [<ffffffff80479b44>] driver_register+0x84/0x158
[ 2.096000] [<ffffffff80200504>] do_one_initcall+0x104/0x160
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Linux Kernel Mailing List <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/5941/
Make sure 74K revision numbers are not applied to the 1074K. Also catch
invalid usage.
Patchwork: https://patchwork.linux-mips.org/patch/5857/
Replace hardcoded CP0 PRId and CP1 FPIR register access masks throughout.
The change does not touch places that use shifted or partial masks.
Patchwork: https://patchwork.linux-mips.org/patch/5838/
o Move current_cpu_type() to a separate header file
o #ifdefing on supported CPU types lets modern GCC know that certain
code in callers may be discarded ideally turning current_cpu_type() into
a function returning a constant.
o Use current_cpu_type() rather than direct access to struct cpuinfo_mips.
Patchwork: https://patchwork.linux-mips.org/patch/5833/
This fixes the following issue
BUG: using smp_processor_id() in preemptible [00000000] code: kjournald/1761
caller is blast_dcache32+0x30/0x254
Call Trace:
[<8047f02c>] dump_stack+0x8/0x34
[<802e7e40>] debug_smp_processor_id+0xe0/0xf0
[<80114d94>] blast_dcache32+0x30/0x254
[<80118484>] r4k_dma_cache_wback_inv+0x200/0x288
[<80110ff0>] mips_dma_map_sg+0x108/0x180
[<80355098>] ide_dma_prepare+0xf0/0x1b8
[<8034eaa4>] do_rw_taskfile+0x1e8/0x33c
[<8035951c>] ide_do_rw_disk+0x298/0x3e4
[<8034a3c4>] do_ide_request+0x2e0/0x704
[<802bb0dc>] __blk_run_queue+0x44/0x64
[<802be000>] queue_unplugged.isra.36+0x1c/0x54
[<802beb94>] blk_flush_plug_list+0x18c/0x24c
[<802bec6c>] blk_finish_plug+0x18/0x48
[<8026554c>] journal_commit_transaction+0x3b8/0x151c
[<80269648>] kjournald+0xec/0x238
[<8014ac00>] kthread+0xb8/0xc0
[<8010268c>] ret_from_kernel_thread+0x14/0x1c
Caches in most systems are identical - but not always, so we can't avoid
the use of smp_call_function() by just looking at the boot CPU's data,
have to fiddle with preemption instead.
Cc: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/5835
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
Here, we remove all the MIPS __cpuinit from C code and __CPUINIT
from asm files. MIPS is interesting in this respect, because there
are also uasm users hiding behind their own renamed versions of the
__cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
[ralf@linux-mips.org: Folded in Paul's followup fix.]
Patchwork: https://patchwork.linux-mips.org/patch/5494/
Patchwork: https://patchwork.linux-mips.org/patch/5495/
Patchwork: https://patchwork.linux-mips.org/patch/5509/
git://git.linux-mips.org/pub/scm/sjhill/linux-sjhill into mips-for-linux-next
Signed-off-by: Sanjay Lal <sanjayl@kymasys.com>
Some MIPS controllers have hardware I/O coherency. This patch
detects those and turns off software coherency. A new kernel
command line option also allows the user to manually turn
software coherency on or off.
The commit a96102be70 introduced set_isa() where compatible ISA info is
also set aside from the one gets passed in. It means, for example, 1004K
will have MIPS_CPU_ISA_M32R2/M32R1/II/I flags. This leads to things like
the following inappropriate:
if (c->isa_level == MIPS_CPU_ISA_M32R1 ||
c->isa_level == MIPS_CPU_ISA_M32R2 ||
c->isa_level == MIPS_CPU_ISA_M64R1 ||
c->isa_level == MIPS_CPU_ISA_M64R2)
This patch fixes it.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
