For the case PM_DEFAULT_MASK == 0, we were placing a branch in the
delay slot of another branch. This leads to undefined behavior.
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2775/
Only some GCC versions such as gcc 4.2 notice that the variable wr in
build_r3000_tlb_modify_handler is used uninitialized. When using one
of those GCCs the build will fail due to -Werror. GCC 4.6 does not
warn about the uninitialized use of wr.
This issue was introduced by 7211f4d7a3dcbe57c5d396c334dca525315dceb2
[MIPS: Close races in TLB modify handlers.]
Reported-by: Ganesan Ramalingam <ganesan18@gmail.com>
Page table entries are made invalid by writing a zero into the the PTE
slot in a page table. This creates a race condition with the TLB
modify handlers when they are updating the PTE.
CPU0 CPU1
Test for _PAGE_PRESENT
. set to not _PAGE_PRESENT (zero)
Set to _PAGE_VALID
So now the page not present value (zero) is suddenly valid and user
space programs have access to physical page zero.
We close the race by putting the test for _PAGE_PRESENT and setting of
_PAGE_VALID into an atomic LL/SC section. This requires more registers
than just K0 and K1 in the handlers, so we need to save some registers
to a save area and then restore them when we are done.
The save area is an array of cacheline aligned structures that should
not suffer cache line bouncing as they are CPU private.
[ralf@linux-mips.org: Fix !defined(CONFIG_MIPS_PGD_C0_CONTEXT) build error.]
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2577/
CPU_XLR case added to mm/tlbex.c
CPU_XLR case added to mm/c-r4k.c for PINDEX attribute
Feature overrides for XLR cpu.
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
Patchwork: https://patchwork.linux-mips.org/patch/2333/
CC arch/mips/mm/tlbex.o
arch/mips/mm/tlbex.c: In function 'build_r4000_tlb_refill_handler':
arch/mips/mm/tlbex.c:1155:22: error: variable 'vmalloc_mode' set but not used [-Werror=unused-but-set-variable]
arch/mips/mm/tlbex.c:1154:28: error: variable 'htlb_info' set but not used [-Werror=unused-but-set-variable]
cc1: all warnings being treated as errors
It was reported that GCC-4.3.3 (with CodeSourcery extensions) fails
without this.
Reported-by: Jonas Gorski <jonas.gorski@gmail.com>
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/2010/
Octeon can use scratch registers in the TLB handlers. Octeon II can
use LDX instructions.
Patchwork: https://patchwork.linux-mips.org/patch/1904/
If the CPU supports BBIT0 and BBIT1, use them in TLB handlers as they
are more efficient than an AND followed by an branch and then
restoring the clobbered register.
Patchwork: https://patchwork.linux-mips.org/patch/1873/
Decide at runtime to use either Context or KScratch to hold the PGD
pointer.
Patchwork: https://patchwork.linux-mips.org/patch/1876/
BMIPS processor cores are used in 50+ different chipsets spread across
5+ product lines. In many cases the chipsets do not share the same
peripheral register layouts, the same register blocks, the same
interrupt controllers, the same memory maps, or much of anything else.
But, across radically different SoCs that share nothing more than the
same BMIPS CPU, a few things are still mostly constant:
SMP operations
Access to performance counters
DMA cache coherency quirks
Cache and memory bus configuration
So, it makes sense to treat each BMIPS processor type as a generic
"building block," rather than tying it to a specific SoC. This makes it
easier to support a large number of BMIPS-based chipsets without
unnecessary duplication of code, and provides the infrastructure needed
to support BMIPS-proprietary features.
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
Cc: mbizon@freebox.fr
Tested-by: Florian Fainelli <ffainelli@freebox.fr>
Patchwork: https://patchwork.linux-mips.org/patch/1706/
Adds a new cpu type for the JZ4740 to the Linux MIPS architecture code.
It also adds the iomem addresses for the different components found on
a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1464/
For some combinations of PAGE_SIZE and vmbits, it is possible to have
userspace access that are beyond what is covered by the PGD, but within
vmbits. Such an access would cause the TLB refill handler to load garbage
values for PMD and PTE potentially giving userspace access to parts of the
physical address space to which it is not entitled.
In the TLB refill hot path, we add a single dsrl instruction so we can
check if any bits outside of the range covered by the PGD are set. In
the vmalloc side we then separate the bad case from the normal vmalloc
case and call tlb_do_page_fault_0 if warranted. This slows us down a
bit, but has the benefit of yielding deterministic behavior.
[Ralf: Fixed build error for 32-bit kernels.]
[Ralf: Folded lmo commit c8c0e22b2aa3982852b44279638ef37f9aa31b7d into this
commit.]
Patchwork: http://patchwork.linux-mips.org/patch/1152/
This makes the code somewhat cleaner while reducing the risk of shift
amount overflows when various page table related options are changed.
Patchwork: http://patchwork.linux-mips.org/patch/1154/
The M3 workaround needs to cmpare the region and VPN2 fields only.
The SmartMIPS ASE specifies how Read Inhibit (RI) and eXecute Inhibit
(XI) bits in the page tables work. The upper two bits of EntryLo{0,1}
are RI and XI when the feature is enabled in the PageGrain register.
SmartMIPS only covers 32-bit systems. Cavium Octeon+ extends this to
64-bit systems by continuing to place the RI and XI bits in the top of
EntryLo even when EntryLo is 64-bits wide.
Because we need to carry the RI and XI bits in the PTE, the layout of
the PTE is changed. There is a two instruction overhead in the TLB
refill hot path to get the EntryLo bits into the proper position.
Also the TLB load exception has to probe the TLB to check if RI or XI
caused the exception.
Also of note is that the layout of the PTE bits is done at compile and
runtime rather than statically. In the 32-bit case this allows for
the same number of PFN bits as before the patch as the _PAGE_HUGE is
not supported in 32-bit kernels (we have _PAGE_NO_EXEC and
_PAGE_NO_READ instead of _PAGE_READ and _PAGE_HUGE).
The patch is tested on Cavium Octeon+, but should also work on 32-bit
systems with the Smart-MIPS ASE.
Patchwork: http://patchwork.linux-mips.org/patch/952/
Patchwork: http://patchwork.linux-mips.org/patch/956/
Patchwork: http://patchwork.linux-mips.org/patch/962/
64-bit CPUs have 64-bit c0_entrylo{0,1} registers. We should use the
64-bit dmtc0 instruction to set them. This becomes important if we
want to set the RI and XI bits present in some processors.
Patchwork: http://patchwork.linux-mips.org/patch/954/
Signed-off-by: Florian Fainelli <florian@openwrt.org>
To: David Daney <ddaney@caviumnetworks.com>
Patchwork: http://patchwork.linux-mips.org/patch/887/
For 64-bit kernels with 64KB pages and two level page tables, there are
42 bits worth of virtual address space This is larger than the 40 bits of
virtual address space obtained with the default 4KB Page size and three
levels, so there are no draw backs for using two level tables with this
configuration.
Patchwork: http://patchwork.linux-mips.org/patch/761/
commit c8af165342e83a4eb078c9607d29a7c399d30a53 (lmo) rsp.
e0cc87f59490d7d62a8ab2a76498dc8a2b64927a (kernel.org) left
label_module_alloc unused. Remove it now.
Patchwork: http://patchwork.linux-mips.org/patch/752/
Processors that support the mips64r2 ISA can in four instructions
convert a shifted PGD pointer stored in the upper bits of c0_context
into a usable pointer. By doing this we save a memory load and
associated potential cache miss in the TLB exception handlers.
Since the upper bits of c0_context were holding the CPU number, we
move this to the upper bits of c0_xcontext which doesn't have enough
bits to hold the PGD pointer, but has plenty for the CPU number.
Todo: Nothing ever detects CPU_BCM6338 but the code tests for it anyway.
Signed-off-by: Maxime Bizon <mbizon@freebox.fr>
By combining swapper_pg_dir and module_pg_dir, several if conditions
can be eliminated from the tlb exception handler. The reason they
can be combined is that, the effective virtual address of vmalloc
returned is at the bottom, and of module_alloc returned is at the
top. It also fixes the bug in vmalloc(), which happens when its
return address is not covered by the first pgd.
Signed-off-by: Wu Fei <at.wufei@gmail.com>
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
The TLB handlers need to check for huge pages and give them special
handling. Huge pages consist of two contiguous sub-pages of physical
memory.
* Loading entrylo0 and entrylo1 need to be handled specially.
* The page mask must be set for huge pages and then restored after
writing the TLB entries.
* The PTE for huge pages resides in the PMD, we halt traversal of the
tables there.
The l parameter to iPTE_LW() is unused. Remove it and from some of its
callers as well.
CPU_CAVIUM_OCTEON is mips_r2 which is handled before the switch. This
label in the switch statement is dead code, so we remove it.
Reviewed by: David VomLehn <dvomlehn@cisco.com>
Some CPUs do not need ehb instructions after writing CP0 registers.
By allowing ehb generation to be overridden in
cpu-feature-overrides.h, we can save a few instructions in the TLB
handler hot paths.
Try to fold the 64-bit TLB refill handler opportunistically at the
beginning of the vmalloc path so as to avoid splitting execution flow in
half and wasting cycles for a branch required at that point then. Resort
to doing the split if either of the newly created parts would not fit into
its designated slot.
Original-patch-by: Maciej W. Rozycki <macro@linux-mips.org>
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
The logic used to split the r4000 refill handler is liberally
sprinkled with magic numbers. We attempt to explain what they are and
normalize them against a new symbolic value (MIPS64_REFILL_INSNS).
CC: David VomLehn <dvomlehn@cisco.com>
Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com>
The Alchemy manuals state:
"All pipeline hazards and dependencies are enforced by hardware interlocks
so that any sequence of instructions is guaranteed to execute correctly.
Therefore, it is not necessary to pad legacy MIPS hazards (such as
load delay slots and coprocessor accesses) with NOPs."
Run-tested on Au12x0, without any ill effects.
Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net>
This patch removes the various CPU_AU1??? model constants in favor of
a single CPU_ALCHEMY one.
All currently existing Alchemy models are identical in terms of cpu
core and cache size/organization. The parts of the mips kernel which
need to know the exact CPU revision extract it from the c0_prid register
already; and finally nothing else in-tree depends on those any more.
Should a new variant with slightly different "company options" and/or
"processor revision" bits in c0_prid appear, it will be supported
immediately (minus an exact model string in cpuinfo).
Current VR5500 processor support lacks of some functions which are
expected to be configured/synthesized on arch initialization.
Here're some VR5500A spec notes:
* All execution hazards are handled in hardware.
* Once VR5500A stops the operation of the pipeline by WAIT instruction,
it could return from the standby mode only when either a reset, NMI
request, or all enabled interrupts is/are detected. In other words,
if interrupts are disabled by Status.IE=0, it keeps in standby mode
even when interrupts are internally asserted.
Notes on WAIT: The operation of the processor is undefined if WAIT
insn is in the branch delay slot. The operation is also undefined
if WAIT insn is executed when Status.EXL and Status.ERL are set to 1.
* VR5500A core only implements the Load prefetch.
With these changes, it boots fine.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Expand the case statement for build_tlb_write_entry so that it does
the right thing on Cavium CPU variants.
Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com>
Signed-off-by: Paul Gortmaker <Paul.Gortmaker@windriver.com>
trap_init issues flush_icache_range(), which uses ipi functions to
get icache flushing done on all cpus. But this is done before interrupts
are enabled and caused WARN_ON messages. This changeset introduces
a new local_flush_icache_range() and uses it before interrupts (and
additional CPUs) are enabled to avoid this problem.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Treat R4700 like R4600 in build_tlb_probe_entry. Without this fix kernel
will lock up.
Early 4KEc were MIPS32r1 and therefore need some love to get a TLB
refill handler.
This patch moves the micro-assembler in a separate implementation, as
it is useful for further run-time optimizations. The only change in
behaviour is cutting down printk noise at kernel startup time.
Checkpatch complains about macro parameters which aren't protected by
parentheses. I believe this is a flaw in checkpatch, the paste operator
used in those macros won't work with parenthesised parameters.
Signed-off-by: Thiemo Seufer <ths@networkno.de>
This patch adds IDs for new Au1200 variants: Au1210 and Au1250.
They are essentially identical to the Au1200 except for the Au1210
which has a different SoC-ID in the PRId register [bits 31:24].
The Au1250 is a "Au1200 V0.2".
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
This complements the generic R4000/R4400 errata workaround code and adds
bits for the daddiu problem. In most places it just modifies handwritten
assembly code so that the assembler is allowed to use a temporary register
as daddiu may now be treated as a macro that expands to a sequence of li
and daddu. It is the AT register or, where AT is unavailable or used
explicitly for another purpose, an explicitly-named register is selected,
using the .set at=<reg> feature added recently to gas. This feature is
only used if CONFIG_CPU_DADDI_WORKAROUNDS has been set, so if the
workaround remains disabled, the required version of binutils stays
unchanged.
Similarly, daddiu instructions put in branch delay slots in noreorder
fragments are now taken out of them and the assembler is allowed to
reorder them itself as possible (which it does making the whole idea of
scheduling them into delay slots manually questionable).
Also in the very few places where such a simple conversion was not
possible, a handcoded longer sequence is implemented.
Other than that there are changes to code responsible for building the
TLB fault and page clear/copy handlers to avoid daddiu as appropriate.
These are only effective if the erratum is verified to be present at the
run time.
Finally there is a trivial update to __delay(), because it uses daddiu in
a branch delay slot.
This reverts commit aaf76a3245c02faba51c96b9a340c14d6bb0dcc0.
As requested by ranck Bui-Huu <fbuihuu@gmail.com>.
This saves a few k on systems which only ever ship with a single CPU type.
