path: root/arch/mips/mm/tlbex.c
2010-08-05MIPS: JZ4740: Add base support for Ingenic JZ4740 System-on-a-ChipLars-Peter Clausen
Adds a new cpu type for the JZ4740 to the Linux MIPS architecture code. It also adds the iomem addresses for the different components found on a JZ4740 SoC. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1464/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-30MIPS: Check for accesses beyond the end of the PGD.David Daney
For some combinations of PAGE_SIZE and vmbits, it is possible to have userspace access that are beyond what is covered by the PGD, but within vmbits. Such an access would cause the TLB refill handler to load garbage values for PMD and PTE potentially giving userspace access to parts of the physical address space to which it is not entitled. In the TLB refill hot path, we add a single dsrl instruction so we can check if any bits outside of the range covered by the PGD are set. In the vmalloc side we then separate the bad case from the normal vmalloc case and call tlb_do_page_fault_0 if warranted. This slows us down a bit, but has the benefit of yielding deterministic behavior. [Ralf: Fixed build error for 32-bit kernels.] [Ralf: Folded lmo commit c8c0e22b2aa3982852b44279638ef37f9aa31b7d into this commit.] Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1152/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2010-04-30MIPS: Use uasm_i_ds{r,l}l_safe() instead of uasm_i_ds{r,l}l() in tlbex.cDavid Daney
This makes the code somewhat cleaner while reducing the risk of shift amount overflows when various page table related options are changed. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1154/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Sibyte: Fix M3 TLB exception handler workaround.Ralf Baechle
The M3 workaround needs to cmpare the region and VPN2 fields only. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Implement Read Inhibit/eXecute InhibitDavid Daney
The SmartMIPS ASE specifies how Read Inhibit (RI) and eXecute Inhibit (XI) bits in the page tables work. The upper two bits of EntryLo{0,1} are RI and XI when the feature is enabled in the PageGrain register. SmartMIPS only covers 32-bit systems. Cavium Octeon+ extends this to 64-bit systems by continuing to place the RI and XI bits in the top of EntryLo even when EntryLo is 64-bits wide. Because we need to carry the RI and XI bits in the PTE, the layout of the PTE is changed. There is a two instruction overhead in the TLB refill hot path to get the EntryLo bits into the proper position. Also the TLB load exception has to probe the TLB to check if RI or XI caused the exception. Also of note is that the layout of the PTE bits is done at compile and runtime rather than statically. In the 32-bit case this allows for the same number of PFN bits as before the patch as the _PAGE_HUGE is not supported in 32-bit kernels (we have _PAGE_NO_EXEC and _PAGE_NO_READ instead of _PAGE_READ and _PAGE_HUGE). The patch is tested on Cavium Octeon+, but should also work on 32-bit systems with the Smart-MIPS ASE. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/952/ Patchwork: http://patchwork.linux-mips.org/patch/956/ Patchwork: http://patchwork.linux-mips.org/patch/962/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Use 64-bit stores to c0_entrylo on 64-bit kernels.David Daney
64-bit CPUs have 64-bit c0_entrylo{0,1} registers. We should use the 64-bit dmtc0 instruction to set them. This becomes important if we want to set the RI and XI bits present in some processors. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/954/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Move arch/mips/mm/uasm.h to arch/mips/include/asm/uasm.hFlorian Fainelli
Signed-off-by: Florian Fainelli <florian@openwrt.org> To: linux-mips@linux-mips.org To: David Daney <ddaney@caviumnetworks.com> Patchwork: http://patchwork.linux-mips.org/patch/887/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Two-level pagetables for 64-bit kernels with 64KB pages.David Daney
For 64-bit kernels with 64KB pages and two level page tables, there are 42 bits worth of virtual address space This is larger than the 40 bits of virtual address space obtained with the default 4KB Page size and three levels, so there are no draw backs for using two level tables with this configuration. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/761/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-01-12MIPS: Cleanup forgotten label_module_alloc in tlbex.cDavid Daney
commit c8af165342e83a4eb078c9607d29a7c399d30a53 (lmo) rsp. e0cc87f59490d7d62a8ab2a76498dc8a2b64927a (kernel.org) left label_module_alloc unused. Remove it now. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/752/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Put PGD in C0_CONTEXT for 64-bit R2 processors.David Daney
Processors that support the mips64r2 ISA can in four instructions convert a shifted PGD pointer stored in the upper bits of c0_context into a usable pointer. By doing this we save a memory load and associated potential cache miss in the TLB exception handlers. Since the upper bits of c0_context were holding the CPU number, we move this to the upper bits of c0_xcontext which doesn't have enough bits to hold the PGD pointer, but has plenty for the CPU number. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: BCM63xx: Add Broadcom 63xx CPU definitions.Maxime Bizon
Todo: Nothing ever detects CPU_BCM6338 but the code tests for it anyway. Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Shrink the size of tlb handlerWu Fei
By combining swapper_pg_dir and module_pg_dir, several if conditions can be eliminated from the tlb exception handler. The reason they can be combined is that, the effective virtual address of vmalloc returned is at the bottom, and of module_alloc returned is at the top. It also fixes the bug in vmalloc(), which happens when its return address is not covered by the first pgd. Signed-off-by: Wu Fei <at.wufei@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: TLB support for hugetlbfs.David Daney
The TLB handlers need to check for huge pages and give them special handling. Huge pages consist of two contiguous sub-pages of physical memory. * Loading entrylo0 and entrylo1 need to be handled specially. * The page mask must be set for huge pages and then restored after writing the TLB entries. * The PTE for huge pages resides in the PMD, we halt traversal of the tables there. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Remove unused parameters from iPTE_LW.David Daney
The l parameter to iPTE_LW() is unused. Remove it and from some of its callers as well. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Remove dead case label.David Daney
CPU_CAVIUM_OCTEON is mips_r2 which is handled before the switch. This label in the switch statement is dead code, so we remove it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Reviewed by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Allow R2 CPUs to turn off generation of 'ehb' instructions.David Daney
Some CPUs do not need ehb instructions after writing CP0 registers. By allowing ehb generation to be overridden in cpu-feature-overrides.h, we can save a few instructions in the TLB handler hot paths. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Fold the TLB refill at the vmalloc path if possible.David Daney
Try to fold the 64-bit TLB refill handler opportunistically at the beginning of the vmalloc path so as to avoid splitting execution flow in half and wasting cycles for a branch required at that point then. Resort to doing the split if either of the newly created parts would not fit into its designated slot. Original-patch-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Replace some magic numbers with symbolic values in tlbex.cDavid Daney
The logic used to split the r4000 refill handler is liberally sprinkled with magic numbers. We attempt to explain what they are and normalize them against a new symbolic value (MIPS64_REFILL_INSNS). CC: David VomLehn <dvomlehn@cisco.com> Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30MIPS: Alchemy: MIPS hazard workarounds are not required.Manuel Lauss
The Alchemy manuals state: "All pipeline hazards and dependencies are enforced by hardware interlocks so that any sequence of instructions is guaranteed to execute correctly. Therefore, it is not necessary to pad legacy MIPS hazards (such as load delay slots and coprocessor accesses) with NOPs." Run-tested on Au12x0, without any ill effects. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30MIPS: Alchemy: unify CPU model constants.Manuel Lauss
This patch removes the various CPU_AU1??? model constants in favor of a single CPU_ALCHEMY one. All currently existing Alchemy models are identical in terms of cpu core and cache size/organization. The parts of the mips kernel which need to know the exact CPU revision extract it from the c0_prid register already; and finally nothing else in-tree depends on those any more. Should a new variant with slightly different "company options" and/or "processor revision" bits in c0_prid appear, it will be supported immediately (minus an exact model string in cpuinfo). Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-11MIPS: NEC VR5500 processor support fixupShinya Kuribayashi
Current VR5500 processor support lacks of some functions which are expected to be configured/synthesized on arch initialization. Here're some VR5500A spec notes: * All execution hazards are handled in hardware. * Once VR5500A stops the operation of the pipeline by WAIT instruction, it could return from the standby mode only when either a reset, NMI request, or all enabled interrupts is/are detected. In other words, if interrupts are disabled by Status.IE=0, it keeps in standby mode even when interrupts are internally asserted. Notes on WAIT: The operation of the processor is undefined if WAIT insn is in the branch delay slot. The operation is also undefined if WAIT insn is executed when Status.EXL and Status.ERL are set to 1. * VR5500A core only implements the Load prefetch. With these changes, it boots fine. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-11MIPS: Add Cavium OCTEON slot into proper tlb category.David Daney
Expand the case statement for build_tlb_write_entry so that it does the right thing on Cavium CPU variants. Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Paul Gortmaker <Paul.Gortmaker@windriver.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-05[MIPS] Fix WARNING: at kernel/smp.c:290Thomas Bogendoerfer
trap_init issues flush_icache_range(), which uses ipi functions to get icache flushing done on all cpus. But this is done before interrupts are enabled and caused WARN_ON messages. This changeset introduces a new local_flush_icache_range() and uses it before interrupts (and additional CPUs) are enabled to avoid this problem. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] R4700: Fix build_tlb_probe_entryThomas Bogendoerfer
Treat R4700 like R4600 in build_tlb_probe_entry. Without this fix kernel will lock up. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-01[MIPS] Add missing 4KEC TLB refill handlerThomas Bogendoerfer
Early 4KEc were MIPS32r1 and therefore need some love to get a TLB refill handler. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Fix loads of section missmatchesRalf Baechle
2008-02-01[MIPS] Split the micro-assembler from tlbex.c.Thiemo Seufer
This patch moves the micro-assembler in a separate implementation, as it is useful for further run-time optimizations. The only change in behaviour is cutting down printk noise at kernel startup time. Checkpatch complains about macro parameters which aren't protected by parentheses. I believe this is a flaw in checkpatch, the paste operator used in those macros won't work with parenthesised parameters. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Alchemy: Au1210/Au1250 CPU supportManuel Lauss
This patch adds IDs for new Au1200 variants: Au1210 and Au1250. They are essentially identical to the Au1200 except for the Au1210 which has a different SoC-ID in the PRId register [bits 31:24]. The Au1250 is a "Au1200 V0.2". Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] tlbex.c: cleanup debug codeFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] tlbex.c: use __cacheline_aligned instead of __tlb_handler_align Franck Bui-Huu
2008-01-29[MIPS] tlbex.c: cleanup include filesFranck Bui-Huu
2008-01-29[MIPS] tlbex.c: Cleanup __init usages.Franck Bui-Huu
2008-01-29[MIPS] R4000/R4400 daddiu erratum workaroundMaciej W. Rozycki
This complements the generic R4000/R4400 errata workaround code and adds bits for the daddiu problem. In most places it just modifies handwritten assembly code so that the assembler is allowed to use a temporary register as daddiu may now be treated as a macro that expands to a sequence of li and daddu. It is the AT register or, where AT is unavailable or used explicitly for another purpose, an explicitly-named register is selected, using the .set at=<reg> feature added recently to gas. This feature is only used if CONFIG_CPU_DADDI_WORKAROUNDS has been set, so if the workaround remains disabled, the required version of binutils stays unchanged. Similarly, daddiu instructions put in branch delay slots in noreorder fragments are now taken out of them and the assembler is allowed to reorder them itself as possible (which it does making the whole idea of scheduling them into delay slots manually questionable). Also in the very few places where such a simple conversion was not possible, a handcoded longer sequence is implemented. Other than that there are changes to code responsible for building the TLB fault and page clear/copy handlers to avoid daddiu as appropriate. These are only effective if the erratum is verified to be present at the run time. Finally there is a trivial update to __delay(), because it uses daddiu in a branch delay slot. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] tlbex: Cleanup handling of R2 hazards in TLB handlers.Ralf Baechle
2007-10-13[MIPS] Revert "[MIPS] tlbex.c: Cleanup __init usage."Ralf Baechle
This reverts commit aaf76a3245c02faba51c96b9a340c14d6bb0dcc0. As requested by ranck Bui-Huu <fbuihuu@gmail.com>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] tlbex.c: Cleanup __init usage.Franck Bui-Huu
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Allow hardwiring of the CPU type to a single type for optimization.Ralf Baechle
This saves a few k on systems which only ever ship with a single CPU type. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] tlbex: Size optimize code by declaring a few functions inline.Ralf Baechle
2007-10-11[MIPS] Add support for BCM47XX CPUs.Aurelien Jarno
Note that the BCM4710 does not support the wait instruction, this is not a mistake in the code. It originally comes from the OpenWrt patches. Cc: Michael Buesch <mb@bu3sch.de> Cc: Felix Fietkau <nbd@openwrt.org> Cc: Florian Schirmer <jolt@tuxbox.org> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-14[MIPS] Workaround for 4Kc machine check exceptionMaciej W. Rozycki
2007-09-10[MIPS] TLB: Fix instruction bitmasksThiemo Seufer
Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] define Hit_Invalidate_I to Index_Invalidate_I for loongson2Fuxin Zhang
Signed-off-by: Fuxin Zhang <zhangfx@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] tlbex: use __maybe_unusedDavid Rientjes
Replace function instances of __attribute__((unused)) with __maybe_unused. Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Load modules to CKSEG0 if CONFIG_BUILD_ELF64=nAtsushi Nemoto
This is a patch to load 64-bit modules to CKSEG0 so that can be compiled with -msym32 option. This makes each module ~10% smaller. * introduce MODULE_START and MODULE_END * custom module_alloc() * PGD for modules * change XTLB refill handler synthesizer * enable -msym32 for modules again (revert ca78b1a5c6a6e70e052d3ea253828e49b5d07c8a) New XTLB refill handler looks like this: 80000080 dmfc0 k0,C0_BADVADDR 80000084 bltz k0,800000e4 # goto l_module_alloc 80000088 lui k1,0x8046 # %high(pgd_current) 8000008c ld k1,24600(k1) # %low(pgd_current) 80000090 dsrl k0,k0,0x1b # l_vmalloc_done: 80000094 andi k0,k0,0x1ff8 80000098 daddu k1,k1,k0 8000009c dmfc0 k0,C0_BADVADDR 800000a0 ld k1,0(k1) 800000a4 dsrl k0,k0,0x12 800000a8 andi k0,k0,0xff8 800000ac daddu k1,k1,k0 800000b0 dmfc0 k0,C0_XCONTEXT 800000b4 ld k1,0(k1) 800000b8 andi k0,k0,0xff0 800000bc daddu k1,k1,k0 800000c0 ld k0,0(k1) 800000c4 ld k1,8(k1) 800000c8 dsrl k0,k0,0x6 800000cc mtc0 k0,C0_ENTRYLO0 800000d0 dsrl k1,k1,0x6 800000d4 mtc0 k1,C0_ENTRYL01 800000d8 nop 800000dc tlbwr 800000e0 eret 800000e4 dsll k1,k0,0x2 # l_module_alloc: 800000e8 bgez k1,80000008 # goto l_vmalloc 800000ec lui k1,0xc000 800000f0 dsubu k0,k0,k1 800000f4 lui k1,0x8046 # %high(module_pg_dir) 800000f8 beq zero,zero,80000000 800000fc nop 80000000 beq zero,zero,80000090 # goto l_vmalloc_done 80000004 daddiu k1,k1,0x4000 80000008 dsll32 k1,k1,0x0 # l_vmalloc: 8000000c dsubu k0,k0,k1 80000010 beq zero,zero,80000090 # goto l_vmalloc_done 80000014 lui k1,0x8046 # %high(swapper_pg_dir) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-01[MIPS] 16K & 64K page size fixesRalf Baechle
Derived from Peter Watkins <treestem@gmail.com>'s work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-03Attack of "the the"s in archMatt LaPlante
The patch below corrects multiple occurances of "the the" typos across several files, both in source comments and KConfig files. There is no actual code changed, only text. Note this only affects the /arch directory, and I believe I could find many more elsewhere. :) Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-07-13[MIPS] Print out TLB handler assembly for debugging.Thiemo Seufer
Small update, using pr_debug and pr_info. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
