path: root/arch/mips/pci/fixup-au1000.c
2008-05-12[MIPS] Alchemy PCI code style cleanupSergei Shtylyov
Fix 15 errors and 4 warnings given by checkpatch.pl: - space between the asterisk and variable name; - space after opening and before closing parentheses; - leading spaces instead of tabs; - printk() without KERN_* facility level; - unnecessary braces for single-statement block; - line over 80 characters. In addition to these changes, also do the following: - combine the nested 'if' statements into one when possible; - remove needless parentheses; - add missing and remove excess spaces between operator and its operands; - fix printk() format specifiers mismatching the argument types; - put the function's result type and name/parameters on the same line; - insert missing and remove excess new lines; - properly indent multi-line expressions; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line; - fix typos, capitalize acronyms, etc. in the comments; - update MontaVista copyright; - remove Pete Popov's old email address... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill useless #include's, #define's and extern'sSergei Shtylyov
Go thru the Alchemy code and hunt down every unneeded #include, #define, and extern (some of which refer to already long dead functions). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] PCI: Make dev pointer argument of pcibios_map_irq const.Ralf Baechle
This is to break the code of people who think they are supposed to scribble into the pci device structure - it's off limits. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
