path: root/arch/mips/pci/pci-ip27.c
2014-01-24mips: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6320/
2013-07-14MIPS: Delete __cpuinit/__CPUINIT usage from MIPS codePaul Gortmaker
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream. The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. Note that some harmless section mismatch warnings may result, since notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c) and are flagged as __cpuinit -- so if we remove the __cpuinit from the arch specific callers, we will also get section mismatch warnings. As an intermediate step, we intend to turn the linux/init.h cpuinit related content into no-ops as early as possible, since that will get rid of these warnings. In any case, they are temporary and harmless. Here, we remove all the MIPS __cpuinit from C code and __CPUINIT from asm files. MIPS is interesting in this respect, because there are also uasm users hiding behind their own renamed versions of the __cpuinit macros. [1] https://lkml.org/lkml/2013/5/20/589 [ralf@linux-mips.org: Folded in Paul's followup fix.] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5494/ Patchwork: https://patchwork.linux-mips.org/patch/5495/ Patchwork: https://patchwork.linux-mips.org/patch/5509/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-06-21MIPS: IP27: Fix build error if CONFIG_PCI=y and CONFIG_NUMA disabled.Ralf Baechle
Then <asm-generic/topology.h> will define cpp macro as default definition for pcibus_to_node resulting in: CC arch/mips/pci/pci-ip27.o arch/mips/pci/pci-ip27.c:220:7: error: expected identifier or ‘(’ before ‘void’ arch/mips/pci/pci-ip27.c:220:12: error: expected ‘)’ before ‘(’ token make[1]: *** [arch/mips/pci/pci-ip27.o] Error 1 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-01-03MIPS: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19MIPS: PCI: Move fixups from __init to __devinit.Sebastian Andrzej Siewior
Fixups are executed once the pci-device is found which is during boot process so __init seems fine as long as the platform does not support hotplug. However it is possible to remove the PCI bus at run time and have it rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call the fixups again. [ralf@linux-mips.org: Made piixirqmap[] in malta_piix_func0_fixup() __initdata.] Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-02-23mips/PCI: replace pci_probe_only with pci_flagsBjorn Helgaas
Some architectures (alpha, mips, powerpc) have an arch-specific "pci_probe_only" flag. Others use PCI_PROBE_ONLY in pci_flags for the same purpose. This moves mips to the pci_flags approach so generic code can use the same test across all architectures. CC: Ralf Baechle <ralf@linux-mips.org> CC: linux-mips@linux-mips.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2011-10-31mips: add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or else we get lots of variations on this: arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' scattered throughout the build. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-07PCI: mips: use generic pci_swizzle_interrupt_pin()Bjorn Helgaas
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code. Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-09-27[MIPS] IP27: Switch to dynamic interrupt routing avoding panic on error.Ralf Baechle
pcibios_map_irq is no way of returning an error but on IP27 an interrupt is possibly not routable when running out of resources. So do the interrupt routing at pcibios_enable_device time. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-08-26[MIPS] IP27: Export symbol pcibus_to_node to modules.Ralf Baechle
2008-07-15[MIPS] Declare some pci variables in header fileAtsushi Nemoto
Declare pci_probe_only, etc. in asm-mips/pci.h file. This will fix some sparse warnings. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-05[MIPS] IP27: misc fixesThomas Bogendoerfer
- fix PCI interrupt assignment by emulating ioc3 interrupt pin register - use pci_probe_only mode - select correct page size in bridge - remove no longer needed ioc3_sio_init() code [Ralf: Fix for 64kB or larger pagesizes] Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Fix loads of section missmatchesRalf Baechle
2007-07-10[MIPS] PCI: Make dev pointer argument of pcibios_map_irq const.Ralf Baechle
This is to break the code of people who think they are supposed to scribble into the pci device structure - it's off limits. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] IP27: Delete useless declaration of allocate_irqno().Ralf Baechle
2006-06-19[MIPS] IP27: Extract pci_ops into separate file.Ralf Baechle
2006-06-19[MIPS] IP27: Use symbolic constants instead of magic numbers.Ralf Baechle
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2005-10-29Define pcibus_to_node() for IP27.Ralf Baechle
