path: root/arch/mips/rb532
2015-09-03MIPS: Remove all the uses of custom gpio.hAlban Bedel
Currently CONFIG_ARCH_HAVE_CUSTOM_GPIO_H is defined for all MIPS machines, and each machine type provides its own gpio.h. However only a handful really implement the GPIO API, most just forward everythings to gpiolib. The Alchemy machine is notable as it provides a system to allow implementing the GPIO API at the board level. But it is not used by any board currently supported, so it can also be removed. For most machine types we can just remove the custom gpio.h, as well as the custom wrappers if some exists. Some of the code found in the wrappers must be moved to the respective GPIO driver. A few more fixes are need in some drivers as they rely on linux/gpio.h to provides some machine specific definitions, or used asm/gpio.h instead of linux/gpio.h for the gpio API. Signed-off-by: Alban Bedel <albeu@free.fr> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: linux-mips@linux-mips.org Cc: Hauke Mehrtens <hauke@hauke-m.de> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Tejun Heo <tj@kernel.org> Cc: Alexandre Courbot <gnurou@gmail.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Florian Fainelli <florian@openwrt.org> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: Daniel Walter <dwalter@google.com> Cc: Sergey Ryazanov <ryazanov.s.a@gmail.com> Cc: Huacai Chen <chenhc@lemote.com> Cc: James Hartley <james.hartley@imgtec.com> Cc: Andrew Bresticker <abrestic@chromium.org> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Wolfram Sang <wsa@the-dreams.de> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Varka Bhadram <varkabhadram@gmail.com> Cc: Masanari Iida <standby24x7@gmail.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Michael Buesch <m@bues.ch> Cc: abdoulaye berthe <berthe.ab@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-ide@vger.kernel.org Cc: linux-gpio@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: netdev@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/10828/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-11-24MIPS: Replace use of phys_t with phys_addr_t.Ralf Baechle
2014-11-24MIPS: Remove useless parenthesesRalf Baechle
Based on the spatch @@ expression e; @@ - return (e); + return e; with heavy hand editing because some of the changes are either whitespace or identation only or result in excessivly long lines. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-08-02Merge branch '3.16-fixes' into mips-for-linux-nextRalf Baechle
2014-07-30MIPS: RB532: Replace parse_mac_addr() with mac_pton().Daniel Walter
Signed-off-by: Daniel Walter <dwalter@google.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7150/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-07-30MIPS: RB532: Fix reregistering of serial consoleWaldemar Brodkorb
Runtime tested on Mikrotik RB532 board. Thanks goes to Geert Uytterhoeven for the explanation of the problem. "I'm afraid this is not gonna help. When the port is unregistered, its type will be reset to PORT_UNKNOWN. So before registering it again, its type must be set again the actual serial driver, cfr. the change to of_serial.c." Signed-off-by: Waldemar Brodkorb <wbx@openadk.org> Reviewed-by: Florian Fainelli <florian@openwrt.org> Cc: Linux MIPS Mailing List <linux-mips@linux-mips.org> Cc: geert@linux-m68k.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7241/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-12-13MIPS: RB532: Fix build of prom code.Ralf Baechle
CC arch/mips/rb532/prom.o /home/ralf/src/linux/linux-mips/arch/mips/rb532/prom.c: In function ‘prom_setup_cmdline’: /home/ralf/src/linux/linux-mips/arch/mips/rb532/prom.c:75:22: error: variable ‘prom_envp’ set but not used [-Werror=unused-but-set-variable] This warning exists in gcc 4.6.0 and newer. Kernels 2.6.40 and newer use -Wunused-but-set-variable to suppress it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-06-01Merge tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull mtd update from David Woodhouse: - More robust parsing especially of xattr data in JFFS2 - Updates to mxc_nand and gpmi drivers to support new boards and device tree - Improve consistency of information about ECC strength in NAND devices - Clean up partition handling of plat_nand - Support NAND drivers without dedicated access to OOB area - BCH hardware ECC support for OMAP - Other fixes and cleanups, and a few new device IDs Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to added include files next to each other. * tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits) mtd: mxc_nand: move ecc strengh setup before nand_scan_tail mtd: block2mtd: fix recursive call of mtd_writev mtd: gpmi-nand: define ecc.strength mtd: of_parts: fix breakage in Kconfig mtd: nand: fix scan_read_raw_oob mtd: docg3 fix in-middle of blocks reads mtd: cfi_cmdset_0002: Slight cleanup of fixup messages mtd: add fixup for S29NS512P NOR flash. jffs2: allow to complete xattr integrity check on first GC scan jffs2: allow to discriminate between recoverable and non-recoverable errors mtd: nand: omap: add support for hardware BCH ecc ARM: OMAP3: gpmc: add BCH ecc api and modes mtd: nand: check the return code of 'read_oob/read_oob_raw' mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw' mtd: m25p80: Add support for Winbond W25Q80BW jffs2: get rid of jffs2_sync_super jffs2: remove unnecessary GC pass on sync jffs2: remove unnecessary GC pass on umount jffs2: remove lock_super mtd: gpmi: add gpmi support for mx6q ...
2012-05-15MIPS: Fix several implicit uses of export.h/module.hPaul Gortmaker
These will show up as a build failure once we clean up a misuse of module.h in the mips termios header. Uses export.h: (EXPORT_SYMBOL) arch/mips/cavium-octeon/setup.c arch/mips/pmc-sierra/yosemite/setup.c arch/mips/rb532/devices.c arch/mips/sni/setup.c Uses module.h: (symbol_get/put) arch/mips/alchemy/devboards/db1200.c Uses module.h: (print_modules) arch/mips/kernel/traps.c Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3448/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-13mtd: nand: kill NAND_NO_AUTOINCR optionBrian Norris
No drivers use auto-increment NAND, so kill the NO_AUTOINCR option entirely. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2011-10-31mips: add export.h to files using EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
Or else we get lots of variations on this: arch/mips/pci/pci.c:330: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL' scattered throughout the build. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-25MIPS: RB532: Use hex_to_bin()Andy Shevchenko
Remove custom implementation of hex_to_bin(). Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org To: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1580/ Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18MIPS: RB532: Fix iomap resource size miscalculation.Ralf Baechle
This is the MIPS portion of Joe Perches <joe@perches.com>'s https://patchwork.linux-mips.org/patch/2172/ which seems to have been lost in time and space. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: RB532: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2201/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-07MIPS: Add missing #inclusions of <linux/irq.h>David Howells
Add missing #inclusions of <linux/irq.h> to a whole bunch of files that should really include it. Note that this can replace #inclusions of <asm/irq.h>. This is required for the patch to sort out irqflags handling function naming to compile on MIPS. The problem is that these files require access to things like setup_irq() - which isn't available by #including <linux/interrupt.h> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: RB532: Migrate to new platform makefile style.Ralf Baechle
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17MIPS: Replace all usages of CL_SIZE by COMMAND_LINE_SIZEDmitri Vorobiev
The MIPS-specific macro CL_SIZE is merely aliasing the macro COMMAND_LINE_SIZE. Other architectures use the latter; also, COMMAND_LINE_SIZE is documented in kernel-parameters.txt, so let's use it, and remove the alias. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-02MIPS: RB532: Fix devices.c compilation.Florian Fainelli
We should now use dev_set_drvdata to set the driver driver_data field. Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/747/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-13MIPS: Make local arrays with CL_SIZE static __initdataAtsushi Nemoto
Since commit 22242681cff52bfb7cba5d2a37b91802be7a4e4c ("MIPS: Extend COMMAND_LINE_SIZE"), CL_SIZE is 4096 and local array variables with this size will cause an build failure with default CONFIG_FRAME_WARN settings. Although current users of such array variables are all early bootstrap code and not likely to cause real stack overflow (thread_info corruption), it is preferable to to declare these arrays static with __initdata. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: RB532: Check irq number when handling GPIO interruptsFlorian Fainelli
This patch makes sure that we are not going to clear or change the interrupt status of a GPIO interrupt superior to 13 as this is the maximum number of GPIO interrupt source (p.232 of the RC32434 reference manual). Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-09Input: add driver for S1 button of rb532Phil Sutter
Mikrotik's Routerboard 532 has two builtin buttons, from which one triggers a hardware reset. The other one is accessible through GPIO pin 1. Sadly, this pin is being multiplexed with UART0 input, so enabling it as interrupt source (as implied by the gpio-keys driver) is not possible unless UART0 has been turned off. The later one though is a rather bad idea as the Routerboard is an embedded device with only a single serial port, so it's almost always used as serial console device. This patch adds a driver based on INPUT_POLLDEV, which disables the UART and reconfigures GPIO pin 1 temporarily while reading the button state. This procedure works fine and has been tested as part of another, unpublished driver for this device. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-01-30MIPS: RB532: Export rb532_gpio_set_func()Phil Sutter
This kernel symbol provides a way for drivers to switch on alternate function for a certain GPIO pin. Turning it off is done implicitly when changing the GPIO direction, as that would be fixed when using the given pin als alternate function. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Simplify dev3 initPhil Sutter
As rb532_dev3_ctl_res is not used by any platform device, it can be dropped when not used for holding the physical address of the device 3 controller. Also a size of one byte should suffice when ioremapping the physical address mentioned above, as only a single byte is being read from and written to it. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Remove {get,set}_434_reg()Phil Sutter
These kernel symbols are unused. Also, since dev3 init has been moved to devices.c, set_434_reg() breaks compiling as it uses dev3. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Move dev3 init code to devices.cPhil Sutter
This code doesn't belong to gpio.c, as it's completely unrelated to GPIO. As dev1 and dev2 init code is in devices.c, it seems to be a more adequate place. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Fix set_latch_u5()Phil Sutter
The data to be written is just a byte, so use writeb instead of writel. Also, dev3.base contains the address, not the data so referencing here is wrong. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Fix init of rb532_dev3_ctl_resPhil Sutter
This register just contains the address of the actual resource, so initialisation has to be the same as cf_slot0_res and nand_slot0_res. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Use driver_data instead of platform_dataPhil Sutter
As the korina ethernet driver uses platform_get_drvdata() to extract the driver specific data from the platform device, driver_data has to be used here. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Detect uart type, add platform devicePhil Sutter
Auto-detection works just fine, so use it instead of specifying the type manually. Also define a platform device for the uart, as suggested by David Daney. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: remove useless CF GPIO initialisationPhil Sutter
As the pata-rb532-cf driver calls gpio_direction_input(), the calls to rb532_gpio_set_func() and rb532_gpio_direction_input() are not needed since the alternate function is automatically being disabled when changing the GPIO pin direction. The later two calls to rb532_gpio_set_{ilevel,istat}() are implicitly being done by the IRQ initialisation of pata-rb532-cf. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Auto disable GPIO alternate functionPhil Sutter
When a driver calls gpio_set_direction_{input,output}(), it obviously doesn't want the alternate function for that pin to be active (as the direction would not matter in that case). This patch ensures alternate function is disabled when the direction is being changed. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Add set_type() function to IRQ struct.Phil Sutter
Interrupt Group 4 mapps the GPIO pins enabled as interrupt sources; add defines to make this clear when addressing them later in code. The mapped GPIOs support triggering on either level high or low. To achieve this, the set_type() function calls rb532_gpio_set_ilevel() for interrupts of the above mentioned group. As there is no way to alter the triggering characteristics of the other interrupts, accept level triggering on status high only. (This is just a guess; but as the system boots fine and interrupt-driven devices (e.g. serial console) work with no implications, it seems to be right.) To clear a GPIO mapped IRQ, the source has to be cleared (i.e., the interrupt status bit of the corresponding GPIO pin). This is done inside rb532_disable_irq(). After applying these changes I could undo most of my former "fixes" to pata-rb532-cf. Particularly all interrupt handling can be done generically via set_irq_type() as it was before. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-30MIPS: RB532: Fix bit swapping in rb532_set_bit()Phil Sutter
The algorithm works unconditionally. If bitval is one, the first line is a no op and the second line sets the bit at offset position. Vice versa, if bitval is zero, the first line clears the bit at offset position and the second line is a no op. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-11-20MIPS: RB532: Provide functions for gpio configurationPhil Sutter
As gpiolib doesn't support pin multiplexing, it provides no way to access the GPIOFUNC register. Also there is no support for setting interrupt status and level. These functions provide access to them and are needed by the CompactFlash driver. Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-11-20MIPS: RB532: GPIO register offsets are relative to GPIOBASEFlorian Fainelli
This patch fixes the wrong use of GPIO register offsets in devices.c. To avoid further problems, use gpio_get_value to return the NAND status instead of our own expanded code. Also define the zero offset of the alternate function register to allow consistent access. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Phil Sutter <n0-1@freewrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-27MIPS: RB532: Disable the right devicePhil Sutter
2008-10-27MIPS: RB532: Set gpio interrupt status and level for CompactFlashFlorian Fainelli
This patch sets the correct interrupt status and level in order to get the CompactFlash adapter working. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: Kill unused <asm/debug.h> inclusionsShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Convert to GPIO libFlorian Fainelli
This patch converts the rb532 code to use gpio library and register its gpio chip. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Cleanup the headers againFlorian Fainelli
This patch cleans up headers and regroups informations to where they should reside. While moving, try to have a consistant naming for defines. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Remove obsolute reference to setup_serial_portFlorian Fainelli
We are no longer using setup_serial_port. So just remove it from the prom code. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Fix id usage in platform devicesFlorian Fainelli
When there is only platform device of the same type, id = -1 should be used, fix this. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: replace raw volatile read with a readlFlorian Fainelli
This patch replaces a raw read using volatiles with a readl. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Remove gpio bootup stateFlorian Fainelli
We are no longer using gpio bootup state, so do not export it and do not parse the kernel command line tag for it. Instead we provide gpio-keys for the button the gpio bootup state was checking. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Use physical addresses for gpio and device controller registersFlorian Fainelli
This patch fixes the misuse of virtual addresses for the GPIO and third device controller which would lead to problems while accessing ioremap'd registers. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: RB532: Cleanup and group definitions to their right placesFlorian Fainelli
This patch moves GPIO related definitions to gpio.h and IRQ related to irq.h Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
