This commit rearranges the HUB interrupt code by using MIPS_IRQ_CPU
interrupt handling code and modern Linux IRQ framework features to get
rid of global arrays. It also adds support for irq affinity setting.
Signed-off-by: Thomas Bogendoerfer <tbogendoerfer@suse.de>
Signed-off-by: Paul Burton <paul.burton@mips.com>
Cc: James Hogan <jhogan@kernel.org>
Cc: linux-mips@vger.kernel.org
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In preparation for making the clockevents core NTP correction aware,
all clockevent device drivers must set ->min_delta_ticks and
->max_delta_ticks rather than ->min_delta_ns and ->max_delta_ns: a
clockevent device's rate is going to change dynamically and thus, the
ratio of ns to ticks ceases to stay invariant.
Make the MIPS arch's clockevent drivers initialize these fields properly.
This patch alone doesn't introduce any change in functionality as the
clockevents core still looks exclusively at the (untouched) ->min_delta_ns
and ->max_delta_ns. As soon as this has changed, a followup patch will
purge the initialization of ->min_delta_ns and ->max_delta_ns from these
drivers.
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Cc: Keguang Zhang <keguang.zhang@gmail.com>
Cc: John Crispin <john@phrozen.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
There is no point in having an extra type for extra confusion. u64 is
unambiguous.
Conversion was done with the following coccinelle script:
@rem@
-typedef u64 cycle_t;
@fix@
typedef cycle_t;
-cycle_t
+u64
Cc: John Stultz <john.stultz@linaro.org>
Migrate sgidriver to the new 'set-state' interface provided by
clockevents core, the earlier 'set-mode' interface is marked obsolete
now.
This also enables us to implement callbacks for new states of clockevent
devices, for example: ONESHOT_STOPPED.
We weren't doing anything in the ->set_mode() callback. So, this patch
doesn't provide any set-state callbacks.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: linux-mips@linux-mips.org
Cc: linaro-kernel@lists.linaro.org
Patchwork: https://patchwork.linux-mips.org/patch/10611/
Use ip27 hub real time counter for sched_clock source. This implementation
will give high resolution cputime accounting.
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: macro@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/9483/
commit 3747069b25e419f6b51395f48127e9812abc3596 upstream.
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
and are flagged as __cpuinit -- so if we remove the __cpuinit from
the arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
related content into no-ops as early as possible, since that will get
rid of these warnings. In any case, they are temporary and harmless.
Here, we remove all the MIPS __cpuinit from C code and __CPUINIT
from asm files. MIPS is interesting in this respect, because there
are also uasm users hiding behind their own renamed versions of the
__cpuinit macros.
[1] https://lkml.org/lkml/2013/5/20/589
[ralf@linux-mips.org: Folded in Paul's followup fix.]
Patchwork: https://patchwork.linux-mips.org/patch/5494/
Patchwork: https://patchwork.linux-mips.org/patch/5495/
Patchwork: https://patchwork.linux-mips.org/patch/5509/
Without, the LTO compiler will complain:
LD init/built-in.o
LDFINAL vmlinux.o
arch/mips/sgi-ip27/ip27-irq.c:379:22: warning: type of ‘rt_timer_irq’ does not match original declaration [enabled by default]
extern unsigned int rt_timer_irq;
arch/mips/sgi-ip27/ip27-timer.c:72:5: note: previously declared here
int rt_timer_irq;
MODPOST vmlinux.o
And without LTO, it's still good stile to things match.
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled],
We run all interrupt handlers with interrupts disabled and we even check
and yell when an interrupt handler returns with interrupts enabled (see
commit [b738a50a: genirq: Warn when handler enables interrupts]).
So now this flag is a NOOP and can be removed.
[ralf@linux-mips.org: Fixed up conflicts in
arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and
arch/mips/kernel/perf_event.c.]
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
To: linux-kernel@vger.kernel.org
Cc: tglx@linutronix.de
Patchwork: https://patchwork.linux-mips.org/patch/2835/
* 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: convert mips to generic i8253 clocksource
clocksource: convert x86 to generic i8253 clocksource
clocksource: convert footbridge to generic i8253 clocksource
clocksource: add common i8253 PIT clocksource
blackfin: convert to clocksource_register_hz
mips: convert to clocksource_register_hz/khz
sparc: convert to clocksource_register_hz/khz
alpha: convert to clocksource_register_hz
microblaze: convert to clocksource_register_hz/khz
ia64: convert to clocksource_register_hz/khz
x86: Convert remaining x86 clocksources to clocksource_register_hz/khz
Make clocksource name const
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource
arch/ia64/kernel/cyclone.c
arch/mips/kernel/i8253.c
arch/x86/kernel/i8253.c
Reason: Resolve conflicts so further cleanups do not conflict further
Scripted with coccinelle.
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2203/
This converts the mips clocksources to use clocksource_register_hz/khz
CC: Ralf Baechle <ralf@linux-mips.org>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Along the lines of d6c585a4342a2ff627a29f9aea77c5ed4cd76023, add IRQF_TIMER
flag for all timer interrupts This ensures that timer interrupts won't be
disabled on suspend and not threaded for PREEMPT_RT.
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com>
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
Pass clocksource pointer to the read() callback for clocksources. This
allows us to share the callback between multiple instances.
[hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods]
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Impact: change calling convention of existing clock_event APIs
struct clock_event_timer's cpumask field gets changed to take pointer,
as does the ->broadcast function.
Another single-patch change. For safety, we BUG_ON() in
clockevents_register_device() if it's not set.
This patchset removes some dead code and creates a platform device
for the RTC class driver.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Fix breakage introduced by converting hub_rt to clockevent.
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Acked-By: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
This separates the tick timer stuff from the generic MIPS time.c.
Hard to follow who is pointing what to where and why so it's simply getting
in the way of the time code renovation.
The "typename" field was obsoleted by the "name" field.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
__do_IRQ() is needed only by irq handlers that can't use
default handlers defined in kernel/irq/chip.c.
For others platforms there's no need to compile this function
since it won't be used. For those platforms this patch defines
GENERIC_HARDIRQS_NO__DO_IRQ symbol which is used exactly for
this purpose.
Futhermore for platforms which do not use __do_IRQ(), end()
method which is part of the 'irq_chip' structure is not used.
This patch simply removes this method in this case.
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
Make clocksource_mips public and get rid of mips_hpt_read,
mips_hpt_mask.
Further incorporation of generic irq framework. Replacing __do_IRQ()
by proper flow handler would make the irq handling path a bit simpler
and faster.
* use generic_handle_irq() instead of __do_IRQ().
* use handle_level_irq for obvious level-type irq chips.
* use handle_percpu_irq for irqs marked as IRQ_PER_CPU.
* setup .eoi routine for irq chips possibly used with handle_percpu_irq.
This is a big irq cleanup patch.
* Use set_irq_chip() to register irq_chip.
* Initialize .mask, .unmask, .mask_ack field. Functions for these
method are already exist in most case.
* Do not initialize .startup, .shutdown, .enable, .disable fields if
default routines provided by irq_chip_set_defaults() were suitable.
* Remove redundant irq_desc initializations.
* Remove unnecessary local_irq_save/local_irq_restore, spin_lock.
With this cleanup, it would be easy to switch to slightly lightwait
irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ().
Though whole this patch is quite large, changes in each irq_chip are
not quite simple. Please review and test on your platform. Thanks.
Since we already moved to GENERIC_TIME, we should implement alternatives
of old do_gettimeoffset routines to get sub-jiffies resolution from
gettimeofday(). This patch includes:
* MIPS clocksource support (based on works by Manish Lachwani).
* remove unused gettimeoffset routines and related codes.
* remove unised 64bit do_div64_32().
* simplify mips_hpt_init. (no argument needed, __init tag)
* simplify c0_hpt_timer_init. (no need to write to c0_count)
* remove some hpt_init routines.
* mips_hpt_mask variable to specify bitmask of hpt value.
* convert jmr3927_do_gettimeoffset to jmr3927_hpt_read.
* convert ip27_do_gettimeoffset to ip27_hpt_read.
* convert bcm1480_do_gettimeoffset to bcm1480_hpt_read.
* simplify sb1250 hpt functions. (no need to subtract and shift)
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies.
So we can kill wall_jiffies completely.
This is just a cleanup and logically should not change any real behavior
except for one thing: RTC updating code in (old) ppc and xtensa use a
condition "jiffies - wall_jiffies == 1". This condition is never met so I
suppose it is just a bug. I just remove that condition only instead of
kill the whole "if" block.
[heiko.carstens@de.ibm.com: s390 build fix and cleanup]
Cc: Andi Kleen <ak@muc.de>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata.hirokazu@renesas.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp>
Cc: Richard Curnow <rc@rc0.org.uk>
Cc: William Lee Irwin III <wli@holomorphy.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
Cc: Chris Zankel <chris@zankel.net>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390
timer interrupt handler with this change.
Currently update_times() calculates ticks by "jiffies - wall_jiffies", but
callers of do_timer() should know how many ticks to update. Passing ticks
get rid of this redundant calculation. Also there are another redundancy
pointed out by Martin Schwidefsky.
This cleanup make a barrier added by
5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes
it.
As a bonus, this cleanup make wall_jiffies can be removed easily, since now
wall_jiffies is always synced with jiffies. (This patch does not really
remove wall_jiffies. It would be another cleanup patch)
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: john stultz <johnstul@us.ibm.com>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
> #define hw_interrupt_type irq_chip
> typedef struct irq_chip hw_irq_controller;
> #define no_irq_type no_irq_chip
> typedef struct irq_desc irq_desc_t;
Use the new IRQF_ constants and remove the SA_INTERRUPT define
