path: root/arch/mips/sgi-ip32
2008-04-28[MIPS] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-07[MIPS] Fix IP32 breakageThomas Bogendoerfer
- suppress master aborts during config read - set io_map_base - only fixup end of iomem resource to avoid failing request_resource in serial driver - killed useless setting of crime_int bit, which caused wrong interrupts - use physcial address for serial port platform device and let 8250 driver do the ioremap Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] IP32: More interrupt renumbering fixes.Ralf Baechle
2007-11-02[MIPS] IP32: Fix address of 2nd serial interface.Ralf Baechle
Found by Giuseppe Sacco <giuseppe@eppesuigoccas.homedns.org>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] IP32: Fixes after interrupt renumbering.Ralf Baechle
And general untangling. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-18[MIPS] IP32: Retire use of plat_timer_setup.Ralf Baechle
2007-10-16[MIPS] IP32: Fix build by conversion to irq_cpu.c.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] cleanup struct irqaction initializersThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> CC: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-27[MIPS] IP32: Fix initialization of UART base addresses.Ralf Baechle
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-31[MIPS] IP32: Don't ignore request_irq's return value.Ralf Baechle
2007-07-10[MIPS] Put an end to <asm/serial.h>'s long and annyoing existenceRalf Baechle
2007-05-24meth driver renovationRalf Baechle
The meth ethernet driver for the SGI IP32 aka O2 is so far still an old style driver which does not use the device driver model. This is now causing issues with some udev based gadgetry in debian-stable. Fixed by converting the meth driver to a platform device. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> -- Fixes since previous patch: o Fixed typo in meth_exit_module() Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-19[MIPS] Misc fixes for plat_irq_dispatch functionsThiemo Seufer
o adds missing ST0_IM masks, which caused the logging of valid interrupts as spurious o stops pnx8550 to log every interrupt as spurious o adds cause register masks for ip22/ip32, which caused handling of masked interrupts o removes some superfluous parentheses in the SNI interrupt code Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-19[MIPS] A few more pt_regs fixups.Ralf Baechle
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-10-02[PATCH] replace cad_pid by a struct pidCedric Le Goater
There are a few places in the kernel where the init task is signaled. The ctrl+alt+del sequence is one them. It kills a task, usually init, using a cached pid (cad_pid). This patch replaces the pid_t by a struct pid to avoid pid wrap around problem. The struct pid is initialized at boot time in init() and can be modified through systctl with /proc/sys/kernel/cad_pid [ I haven't found any distro using it ? ] It also introduces a small helper routine kill_cad_pid() which is used where it seemed ok to use cad_pid instead of pid 1. [akpm@osdl.org: cleanups, build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] IP32: Fix wreckage caused by recent SA_* constant replacement.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26fix paniced->panicked typosLee Revell
In a testament to the utter simplicity and logic of the English language ;-), I found a single correct use - in kernel/panic.c - and 10-15 incorrect ones. Signed-Off-By: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-06[MIPS] IP32: Fix warnings.Ralf Baechle
The expressions are volatile; no need for temporary variables. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-27[MIPS] Use __ffs() instead of ffs() in ip32_irq0().Atsushi Nemoto
With recent rewrite for generic bitops, ffs() is defined the same way as the libc and compiler built-in routines (returns int instead of unsigned long). Use __ffs() for 64bit value. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-27[PATCH] mips: fixed collision of rtc function nameYoichi Yuasa
Fix the collision of rtc function name. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2006-02-08Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2006-02-07[MIPS] Rename _machine_power_off to pm_power_off so the kernel builds again.Ralf Baechle
2006-02-05[SERIAL] uart_port flags member should use UPF_*Russell King
Convert usage of ASYNC_* to UPF_*. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-17[MIPS] IP32: Fix sparse warnings.Arnaud Giersch
Add __iomem qualifier to crime and mace pointers. Signed-off-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-11-17[MIPS] IP32: Export mace symbol.Arnaud Giersch
Export mace symbol so that it can be used in modules. Signed-off-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Convert struct hw_interrupt_type initializations to ISO C99 namedRalf Baechle
initializers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29O2 doesn't have _that_ much RAM.Thiemo Seufer
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
