path: root/arch/mips/sni
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] Cleanup pcspeaker platform device registration.Ralf Baechle
Move registration into the actual platform code instead of making a desparate attempt at sharing the hand full of likes of code in pcspeaker.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] SNI: s/achknowledge/acknowledge/Maciej W. Rozycki
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-02[MIPS] SNI: register a02r clockevent; don't use PIT timerThomas Bogendoerfer
Register A20R clockevent. Remove PIT timer setup because it doesn't work Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-29[MIPS] SNI: Convert a20r timer to clockevent device.Ralf Baechle
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Move ARC code into arch/mips/fw/arcAurelien Jarno
Move the ARC code to arch/mips/fw/arc from arch/mips/arc. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SNI: remove unused pcimt_scache.cYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SNI: Remove unneeded sni_machine_haltYoichi Yuasa
2007-07-31[MIPS] Use -Werror on subdirectories which build cleanly.Ralf Baechle
2007-07-24[MIPS] SNI: snipromThomas Bogendoerfer
- fix compile error due to missing #include - fix section mismatch warning Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-12[MIPS] RM: Use only phyiscal address for 82596 and 53c710Thomas Bogendoerfer
Use physical address for 82596 and 53c710 base address Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] SNI RM updatesThomas Bogendoerfer
- use RTC_CLASS instead of GEN_RTC - get rid of ds1216 in favour of a RTC_CLASS driver - use correct console device for older RM400 - use physical addresses for 82596 device - use 128 byte L1 cache line size (this is needed because most of the SNI caches are using 128 L2 cache lines) Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-06[MIPS] Fix VGA corruption on RM300CThomas Bogendoerfer
... by setting DRAM config to 2MB (SNI always used that size). This also fixes video dram size detection in cirrusfb. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-06[MIPS] RM300: Fix MMIO problems by marking the PCI INT ACK region busyThomas Bogendoerfer
2007-05-08Replace deprecated SA_xxx interrupt flagsThomas Gleixner
Fix the last users of the deprecated SA_xxx interrupt flags. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27[MIPS] Change PCI host bridge setup/resourcesThomas Bogendoerfer
PCI host bridge setup for SNI RM machines with PCI is quite broken, now that Linux does it's resource setup own its own. It will use IO addresses, which are needed by the EISA config detection and assigns PCI memory addresses, which overlap with ISA legacy addresses (video ram). Below is a patch, which changes the way how the PCI memory addresses are used and sets the minimum IO address to give enough IO space for 8 EISA slots). This patch needs the other PCI resource change, I've posted. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-19[MIPS] Misc fixes for plat_irq_dispatch functionsThiemo Seufer
o adds missing ST0_IM masks, which caused the logging of valid interrupts as spurious o stops pnx8550 to log every interrupt as spurious o adds cause register masks for ip22/ip32, which caused handling of masked interrupts o removes some superfluous parentheses in the SNI interrupt code Signed-Off-By: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] SNI: MIPS_CPU_IRQ_BASE cleanupThomas Bogendoerfer
Use MIPS_CPU_IRQ_BASE instead of own define. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] Kill redundant EXTRA_AFLAGSAtsushi Nemoto
Many Makefiles in arch/mips have EXTRA_AFLAGS := $(CFLAGS) line. This is redundant while AFLAGS contains $(cflags-y) and any options only listed in CFLAGS (not in cflags-y) should be unnecessary for asm sources. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Support for several more SNI RM models.Thomas Bogendoerfer
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Support SNI RM200C SNI in big endian mode and R5000 processors.Thomas Bogendoerfer
Added support for RM200C machines with big endian firmware Added support for RM200-C40 (R5000 support) Signed-off-by: Florian Lohoff <flo@rfc822.org> Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] C99-ify struct resource initialization.Ralf Baechle
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-27[PATCH] mips: fixed collision of rtc function nameYoichi Yuasa
Fix the collision of rtc function name. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[MIPS] Rename _machine_power_off to pm_power_off so the kernel builds again.Ralf Baechle
2005-10-29Convert struct hw_interrupt_type initializations to ISO C99 namedRalf Baechle
initializers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
