virtio has been so far used only in the context of virtualization,
and the virtio Kconfig was sourced directly by the relevant arch
Kconfigs when VIRTUALIZATION was selected.
Now that we start using virtio for inter-processor communications,
we need to source the virtio Kconfig outside of the virtualization
scope too.
Moreover, some architectures might use virtio for both virtualization
and inter-processor communications, so directly sourcing virtio
might yield unexpected results due to conflicting selections.
The simple solution offered by this patch is to always source virtio's
Kconfig in drivers/Kconfig, and remove it from the appropriate arch
Kconfigs. Additionally, a virtio menu entry has been added so virtio
drivers don't show up in the general drivers menu.
This way anyone can use virtio, though it's arguably less accessible
(and neat!) for virtualization users now.
Note: some architectures (mips and sh) seem to have a VIRTUALIZATION
menu merely for sourcing virtio's Kconfig, so that menu is removed too.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
* 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
mips: Fix i8253 clockevent fallout
i8253: Cleanup outb/inb magic
arm: Footbridge: Use common i8253 clockevent
mips: Use common i8253 clockevent
x86: Use common i8253 clockevent
i8253: Create common clockevent implementation
i8253: Export i8253_lock unconditionally
pcpskr: MIPS: Make config dependencies finer grained
pcspkr: Cleanup Kconfig dependencies
i8253: Move remaining content and delete asm/i8253.h
i8253: Consolidate definitions of PIT_LATCH
x86: i8253: Consolidate definitions of global_clock_event
i8253: Alpha, PowerPC: Remove unused asm/8253pit.h
alpha: i8253: Cleanup remaining users of i8253pit.h
i8253: Remove I8253_LOCK config
i8253: Make pcsp sound driver use the shared i8253_lock
i8253: Make pcspkr input driver use the shared i8253_lock
i8253: Consolidate all kernel definitions of i8253_lock
i8253: Unify all kernel declarations of i8253_lock
i8253: Create linux/i8253.h and use it in all 8253 related files
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (123 commits)
perf: Remove the nmi parameter from the oprofile_perf backend
x86, perf: Make copy_from_user_nmi() a library function
perf: Remove perf_event_attr::type check
x86, perf: P4 PMU - Fix typos in comments and style cleanup
perf tools: Make test use the preset debugfs path
perf tools: Add automated tests for events parsing
perf tools: De-opt the parse_events function
perf script: Fix display of IP address for non-callchain path
perf tools: Fix endian conversion reading event attr from file header
perf tools: Add missing 'node' alias to the hw_cache[] array
perf probe: Support adding probes on offline kernel modules
perf probe: Add probed module in front of function
perf probe: Introduce debuginfo to encapsulate dwarf information
perf-probe: Move dwarf library routines to dwarf-aux.{c, h}
perf probe: Remove redundant dwarf functions
perf probe: Move strtailcmp to string.c
perf probe: Rename DIE_FIND_CB_FOUND to DIE_FIND_CB_END
tracing/kprobe: Update symbol reference when loading module
tracing/kprobes: Support module init function probing
kprobes: Return -ENOENT if probe point doesn't exist
pit_clockevent wants to replaced in the argument of the callback
function as well.
Reported-by; Ingo Molnar <mingo@elte.hu>
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Signed-of-by: John Crispin <blogic@openwrt.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2465/
Signed-off-by: Florian Fainelli <florian@openwrt.org>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2489/
Signed-off-by: Jonas Gorski <jonas.gorski@gmail.com>
Acked-by: Florian Fainelli <florian@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/2461/
Fix few issues in the Netlogic code:
- Use handle_percpu_irq to handle per-cpu interrupts
- Remove unused function nlm_common_ipi_handler()
- Call scheduler_ipi() on SMP_RESCHEDULE_YOURSELF
- Enable interrupts in nlm_smp_finish()
Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com>
Patchwork: https://patchwork.linux-mips.org/patch/2460/
Commit d6d5d5c4a (MIPS: Sibyte: Convert to new irq_chip functions)
removed the mask function which breaks irq_shutdown(). Restore it.
Reported-by: Matt Turner <mattst88@gmail.com>
Tested-by: Matt Turner <mattst88@gmail.com>
This patch combines linux-mips.org patches
637d69600fb1773da56487271ec2a79c33d237ed [MIPS: Netlogic: Yank out crap.]
and 5e3c263b9658a4b1c6c5577793e9347efb44854e [MIPS: XLR, XLS: Add Kbuild
files for platform.]
Patchwork: https://patchwork.linux-mips.org/patch/2415/
Since 6be63bbbdab66b9185dc6f67c8b1bacb6f37f946 (lmo) rsp.
af3a1f6f4813907e143f87030cde67a9971db533 (kernel.org) the Malta code does
no longer probe for presence of GCMP if CMP is not configured. This means
that the variable gcmp_present well be left at its default value of -1
which normally is meant to indicate that GCMP has not yet been mmapped.
This non-zero value is now interpreted as GCMP being present resulting
in a write attempt to a GCMP register resulting in a crash.
Reported and a build fix on top of my fix by Rob Landley <rob@landley.net>.
Reported-by: Rob Landley <rob@landley.net>
Patchwork: https://patchwork.linux-mips.org/patch/2413/
Renumbering was necessary because I had already wired up setns(2) in the
linux-mips.org tree in commit c3fce54644cabbb90700cc3acc040718a377f609
[MIPS: Wire up new sendmmsg syscall.] but the same syscall numbers were
used by 7b21fddd087678a70ad64afc0f632e0f1071b092 [ns: Wire up the setns
system call] resulting in a conflict.
Commit ee6114202e48dc282c6d04741e9c5d7171eb8bb8 (lmo) rsp.
1685f3b158a244d4f6e205e67c84483fffcb2d9f (kernel.org) ["MIPS: SMTC: Move
declaration of smtc_init_secondary to <asm/smtc.h>."] didn't quite do
that - it rather lost the declaration of smtc_init_secondary resulting in
a build error.
Commit a561b02a2577aec51277ba39c82bd192a79c0267 (lmo) rsp.
7c8d948f1633da5ff81e4f5b31ef237d74c40127 (kernel.org) ["MIPS: i8259: Convert
to new irq_chip functions"] missed one location to modify resulting in
build breakage.
The code in arch/mips/kernel/i8259.c still hasn't been converted to
using struct syscore_ops instead of a sysdev for resume and shutdown.
As a result, this code doesn't build any more after suspend, resume
and shutdown callbacks have been removed from struct sysdev_class.
Fix this problem by converting i8259.c to using syscore_ops.
Reported-and-tested-by: Roland Vossen <rvossen@broadcom.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Make sure that the 'static' keywork is at the beginning of declaration
for arch/mips/include/asm/mach-jz4740/gpio.h
This gets rid of warnings like
warning: ‘static’ is not at beginning of declaration
when building with -Wold-style-declaration (and/or -Wextra which also
enables it).
Also a few tiny whitespace changes.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Signed-off-by: Michael Buesch <m@bues.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core
Add a NODE level to the generic cache events which is used to measure
local vs remote memory accesses. Like all other cache events, an
ACCESS is HIT+MISS, if there is no way to distinguish between reads
and writes do reads only etc..
The below needs filling out for !x86 (which I filled out with
unsupported events).
I'm fairly sure ARM can leave it like that since it doesn't strike me as
an architecture that even has NUMA support. SH might have something since
it does appear to have some NUMA bits.
Sparc64, PowerPC and MIPS certainly want a good look there since they
clearly are NUMA capable.
Cc: David Daney <ddaney@caviumnetworks.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop
The nmi parameter indicated if we could do wakeups from the current
context, if not, we would set some state and self-IPI and let the
resulting interrupt do the wakeup.
For the various event classes:
- hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from
the PMI-tail (ARM etc.)
- tracepoint: nmi=0; since tracepoint could be from NMI context.
- software: nmi=[0,1]; some, like the schedule thing cannot
perform wakeups, and hence need 0.
As one can see, there is very little nmi=1 usage, and the down-side of
not using it is that on some platforms some software events can have a
jiffy delay in wakeup (when arch_irq_work_raise isn't implemented).
The up-side however is that we can remove the nmi parameter and save a
bunch of conditionals in fast paths.
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/20110609130622.133068765@linutronix.de
Many stupid corrections of duplicated includes based on the output of
scripts/checkincludes.pl.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
RTC_CLASS is changed to bool, so 'm' is invalid.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Stack unwinding is done by code examination. For kernelspace, the
already existing unwind function is utilized that uses kallsyms to
quickly find the beginning of functions. For userspace a new function
was added that examines code at and before the pc.
Signed-off-by: Daniel Kalmar <kalmard@homejinni.com>
Signed-off-by: Gergely Kis <gergely@homejinni.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
The unwind_stack_by_address variant supports unwinding based
on any kernel code address.
This symbol is also exported so it can be called from modules.
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
Only the Siemens-Nixdorf RM series workstations and the Jazz family
workstations have PC speakers built in; Malta can connect one via the
infamous AMR connector with an AMR sound card or a little creativity.
So we don't want to offer the PC speaker driver on all MIPS systems.
Link: http://lkml.kernel.org/r/20110601180611.061710714@duck.linux-mips.net
Lenghty lists of the kind "depends on ARCH1 || ARCH2 ... || ARCH123" are
usually either wrong or too coarse grained. Or plain an ugly sin.
[ tglx: Fixed up amigaone ]
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: Gerhard Pircher <gerhard_pircher@gmx.net>
Link: http://lkml.kernel.org/r/20110601180610.984881988@duck.linux-mips.net
Move setup_pit_timer() declaration to the common header file and
remove the arch specific ones.
[ tglx: Move it to linux/i8253.h instead of asm/mips and asm/x86 ]
Cc: Sergei Shtylyov <sshtylyov@mvista.com
Link: http://lkml.kernel.org/r/20110601180610.913463093@duck.linux-mips.net
x86 defines PIT_LATCH as LATCH which in <linux/timex.h> is defined as
((CLOCK_TICK_RATE + HZ/2) / HZ) and <asm/timex.h> again defines
CLOCK_TICK_RATE as PIT_TICK_RATE.
MIPS defines PIT_LATCH as LATCH which in <linux/timex.h> is defined as
CLOCK_TICK_RATE as 1193182.
ARM defines PITCH_LATCH as ((PIT_TICK_RATE + HZ / 2) / HZ) - and that's
the sanest thing and equivalent to above definitions so use that as the
new definition in <linux/i8253.h>.
Link: http://lkml.kernel.org/r/20110601180610.832810002@duck.linux-mips.net
Move them to drivers/clocksource/i8253.c and remove the
implementations in arch/
[ tglx: Avoid the extra file in lib - folded arch patches in. The
export will become conditional in a later step ]
Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net
Link: http://lkml.kernel.org/r/20110601180610.134151920@duck.linux-mips.net
Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net
arch/arm/mach-footbridge/isa-timer.c | 2 +-
arch/mips/cobalt/time.c | 2 +-
arch/mips/jazz/irq.c | 2 +-
arch/mips/kernel/i8253.c | 2 +-
arch/mips/mti-malta/malta-time.c | 2 +-
arch/mips/sgi-ip22/ip22-time.c | 2 +-
arch/mips/sni/time.c | 2 +-
arch/x86/kernel/apic/apic.c | 2 +-
arch/x86/kernel/apm_32.c | 2 +-
arch/x86/kernel/hpet.c | 2 +-
arch/x86/kernel/i8253.c | 2 +-
arch/x86/kernel/time.c | 2 +-
drivers/block/hd.c | 2 +-
drivers/clocksource/i8253.c | 2 +-
drivers/input/gameport/gameport.c | 2 +-
drivers/input/joystick/analog.c | 2 +-
drivers/input/misc/pcspkr.c | 2 +-
include/linux/i8253.h | 11 +++++++++++
sound/drivers/pcsp/pcsp.h | 2 +-
19 files changed, 29 insertions(+), 18 deletions(-)
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
* git://git.infradead.org/mtd-2.6: (97 commits)
mtd: kill CONFIG_MTD_PARTITIONS
mtd: remove add_mtd_partitions, add_mtd_device and friends
mtd: convert remaining users to mtd_device_register()
mtd: samsung onenand: convert to mtd_device_register()
mtd: omap2 onenand: convert to mtd_device_register()
mtd: txx9ndfmc: convert to mtd_device_register()
mtd: tmio_nand: convert to mtd_device_register()
mtd: socrates_nand: convert to mtd_device_register()
mtd: sharpsl: convert to mtd_device_register()
mtd: s3c2410 nand: convert to mtd_device_register()
mtd: ppchameleonevb: convert to mtd_device_register()
mtd: orion_nand: convert to mtd_device_register()
mtd: omap2: convert to mtd_device_register()
mtd: nomadik_nand: convert to mtd_device_register()
mtd: ndfc: convert to mtd_device_register()
mtd: mxc_nand: convert to mtd_device_register()
mtd: mpc5121_nfc: convert to mtd_device_register()
mtd: jz4740_nand: convert to mtd_device_register()
mtd: h1910: convert to mtd_device_register()
mtd: fsmc_nand: convert to mtd_device_register()
Fixed up trivial conflicts in
- drivers/mtd/maps/integrator-flash.c: removed in ARM tree
- drivers/mtd/maps/physmap.c: addition of afs partition probe type
clashing with removal of CONFIG_MTD_PARTITIONS
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (45 commits)
ARM: 6945/1: Add unwinding support for division functions
ARM: kill pmd_off()
ARM: 6944/1: mm: allow ASID 0 to be allocated to tasks
ARM: 6943/1: mm: use TTBR1 instead of reserved context ID
ARM: 6942/1: mm: make TTBR1 always point to swapper_pg_dir on ARMv6/7
ARM: 6941/1: cache: ensure MVA is cacheline aligned in flush_kern_dcache_area
ARM: add sendmmsg syscall
ARM: 6863/1: allow hotplug on msm
ARM: 6832/1: mmci: support for ST-Ericsson db8500v2
ARM: 6830/1: mach-ux500: force PrimeCell revisions
ARM: 6829/1: amba: make hardcoded periphid override hardware
ARM: 6828/1: mach-ux500: delete SSP PrimeCell ID
ARM: 6827/1: mach-netx: delete hardcoded periphid
ARM: 6940/1: fiq: Briefly document driver responsibilities for suspend/resume
ARM: 6938/1: fiq: Refactor {get,set}_fiq_regs() for Thumb-2
ARM: 6914/1: sparsemem: fix highmem detection when using SPARSEMEM
ARM: 6913/1: sparsemem: allow pfn_valid to be overridden when using SPARSEMEM
at91: drop at572d940hf support
at91rm9200: introduce at91rm9200_set_type to specficy cpu package
at91: drop boot_params and PLAT_PHYS_OFFSET
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Fix PM QOS's user mode interface to work with ASCII input
PM / Hibernate: Update kerneldoc comments in hibernate.c
PM / Hibernate: Remove arch_prepare_suspend()
PM / Hibernate: Update some comments in core hibernate code
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT,
CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used
to test for existence of find bitops anymore.
Acked-by: Greg Ungerer <gerg@uclinux.org>
The ns_cgroup is an annoying cgroup at the namespace / cgroup frontier and
leads to some problems:
* cgroup creation is out-of-control
* cgroup name can conflict when pids are looping
* it is not possible to have a single process handling a lot of
namespaces without falling in a exponential creation time
* we may want to create a namespace without creating a cgroup
The ns_cgroup was replaced by a compatibility flag 'clone_children',
where a newly created cgroup will copy the parent cgroup values.
The userspace has to manually create a cgroup and add a task to
the 'tasks' file.
This patch removes the ns_cgroup as suggested in the following thread:
https://lists.linux-foundation.org/pipermail/containers/2009-June/018616.html
The 'cgroup_clone' function is removed because it is no longer used.
This is a userspace-visible change. Commit 45531757b45c ("cgroup: notify
ns_cgroup deprecated") (merged into 2.6.27) caused the kernel to emit a
printk warning users that the feature is planned for removal. Since that
time we have heard from XXX users who were affected by this.
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Jamal Hadi Salim <hadi@cyberus.ca>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Paul Menage <menage@google.com>
Acked-by: Matt Helsley <matthltc@us.ibm.com>
devel-stable
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it
to lib/Kconfig.debug so each arch doesn't have to define it. This
obviously makes the option generic, but that's fine because the config is
already used in generic code.
It's not obvious to me that sysrq-P actually does anything caution by
keeping the most inclusive wording.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Fold all the mmu_gather rework patches into one for submission
Reported-by: Hugh Dickins <hughd@google.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
