git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
Pull x86 seccomp changes from Ingo Molnar:
"This tree includes x86 seccomp filter speedups and related preparatory
work, which touches core seccomp facilities as well.
The main idea is to split seccomp into two phases, to be able to enter
a simple fast path for syscalls with ptrace side effects.
There's no substantial user-visible (and ABI) effects expected from
this, except a change in how we emit a better audit record for
SECCOMP_RET_TRACE events"
* 'x86-seccomp-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86_64, entry: Use split-phase syscall_trace_enter for 64-bit syscalls
x86_64, entry: Treat regs->ax the same in fastpath and slowpath syscalls
x86: Split syscall_trace_enter into two phases
x86, entry: Only call user_exit if TIF_NOHZ
x86, x32, audit: Fix x32's AUDIT_ARCH wrt audit
seccomp: Document two-phase seccomp and arch-provided seccomp_data
seccomp: Allow arch code to provide seccomp_data
seccomp: Refactor the filter callback and the API
seccomp,x86,arm,mips,s390: Remove nr parameter from secure_computing
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave
Hansen)
- Various sched/idle refinements for better idle handling (Nicolas
Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot)
- sched/numa updates and optimizations (Rik van Riel)
- sysbench speedup (Vincent Guittot)
- capacity calculation cleanups/refactoring (Vincent Guittot)
- Various cleanups to thread group iteration (Oleg Nesterov)
- Double-rq-lock removal optimization and various refactorings
(Kirill Tkhai)
- various sched/deadline fixes
... and lots of other changes"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits)
sched/dl: Use dl_bw_of() under rcu_read_lock_sched()
sched/fair: Delete resched_cpu() from idle_balance()
sched, time: Fix build error with 64 bit cputime_t on 32 bit systems
sched: Improve sysbench performance by fixing spurious active migration
sched/x86: Fix up typo in topology detection
x86, sched: Add new topology for multi-NUMA-node CPUs
sched/rt: Use resched_curr() in task_tick_rt()
sched: Use rq->rd in sched_setaffinity() under RCU read lock
sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask'
sched: Use dl_bw_of() under RCU read lock
sched/fair: Remove duplicate code from can_migrate_task()
sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW
sched: print_rq(): Don't use tasklist_lock
sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock()
sched: Fix the task-group check in tg_has_rt_tasks()
sched/fair: Leverage the idle state info when choosing the "idlest" cpu
sched: Let the scheduler see CPU idle states
sched/deadline: Fix inter- exclusive cpusets migrations
sched/deadline: Clear dl_entity params when setscheduling to different class
sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault()
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
Merge patch-bomb from Andrew Morton:
- part of OCFS2 (review is laggy again)
- procfs
- slab
- all of MM
- zram, zbud
- various other random things: arch, filesystems.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (164 commits)
nosave: consolidate __nosave_{begin,end} in <asm/sections.h>
include/linux/screen_info.h: remove unused ORIG_* macros
kernel/sys.c: compat sysinfo syscall: fix undefined behavior
kernel/sys.c: whitespace fixes
acct: eliminate compile warning
kernel/async.c: switch to pr_foo()
include/linux/blkdev.h: use NULL instead of zero
include/linux/kernel.h: deduplicate code implementing clamp* macros
include/linux/kernel.h: rewrite min3, max3 and clamp using min and max
alpha: use Kbuild logic to include <asm-generic/sections.h>
frv: remove deprecated IRQF_DISABLED
frv: remove unused cpuinfo_frv and friends to fix future build error
zbud: avoid accessing last unused freelist
zsmalloc: simplify init_zspage free obj linking
mm/zsmalloc.c: correct comment for fullness group computation
zram: use notify_free to account all free notifications
zram: report maximum used memory
zram: zram memory size limitation
zsmalloc: change return value unit of zs_get_total_size_bytes
zsmalloc: move pages_allocated to zs_pool
The different architectures used their own (and different) declarations:
extern __visible const void __nosave_begin, __nosave_end;
extern const void __nosave_begin, __nosave_end;
extern long __nosave_begin, __nosave_end;
Consolidate them using the first variant in <asm/sections.h>.
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"The interesting things here are:
- Turn on Config Request Retry Status Software Visibility. This
caused hangs last time, but we included a fix this time.
- Rework PCI device configuration to use _HPP/_HPX more aggressively
- Allow PCI devices to be put into D3cold during system suspend
- Add arm64 PCI support
- Add APM X-Gene host bridge driver
- Add TI Keystone host bridge driver
- Add Xilinx AXI host bridge driver
More detailed summary:
Enumeration
- Check Vendor ID only for Config Request Retry Status (Rajat Jain)
- Enable Config Request Retry Status when supported (Rajat Jain)
- Add generic domain handling (Catalin Marinas)
- Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado)
Resource management
- Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu)
- Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr)
PCI device hotplug
- Prevent NULL dereference during pciehp probe (Andreas Noever)
- Move _HPP & _HPX handling into core (Bjorn Helgaas)
- Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas)
- Apply _HPP/_HPX to display devices (Bjorn Helgaas)
- Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas)
- Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas)
- Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas)
- Fix wait time in pciehp timeout message (Yinghai Lu)
- Add more pciehp Slot Control debug output (Yinghai Lu)
- Stop disabling pciehp notifications during init (Yinghai Lu)
MSI
- Remove arch_msi_check_device() (Alexander Gordeev)
- Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev)
- Move D0 check into pci_msi_check_device() (Alexander Gordeev)
- Remove unused kobject from struct msi_desc (Yijing Wang)
- Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang)
- Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang)
- Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang)
- Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang)
- Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang)
Power management
- Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki)
- Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki)
AER
- Add additional AER error strings (Gong Chen)
- Make <linux/aer.h> standalone includable (Thierry Reding)
Virtualization
- Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson)
- Add ACS quirk for Intel 10G NICs (Alex Williamson)
- Add ACS quirk for AMD A88X southbridge (Marti Raudsepp)
- Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson)
- Add device flag helpers (Ethan Zhao)
- Assume all Mellanox devices have broken INTx masking (Gavin Shan)
Generic host bridge driver
- Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau)
- Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau)
- Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau)
- Fix the conversion of IO ranges into IO resources (Liviu Dudau)
- Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau)
- Add support for parsing PCI host bridge resources from DT (Liviu Dudau)
- Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau)
- Add arm64 architectural support for PCI (Liviu Dudau)
APM X-Gene
- Add APM X-Gene PCIe driver (Tanmay Inamdar)
- Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar)
Freescale i.MX6
- Probe in module_init(), not fs_initcall() (Lucas Stach)
- Delay enabling reference clock for SS until it stabilizes (Tim Harvey)
Marvell MVEBU
- Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni)
NVIDIA Tegra
- Make sure the PCIe PLL is really reset (Eric Yuen)
- Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang)
- Fix extended configuration space mapping (Peter Daifuku)
- Implement resource hierarchy (Thierry Reding)
- Clear CLKREQ# enable on port disable (Thierry Reding)
- Add Tegra124 support (Thierry Reding)
ST Microelectronics SPEAr13xx
- Pass config resource through reg property (Pratyush Anand)
Synopsys DesignWare
- Use NULL instead of false (Fabio Estevam)
- Parse bus-range property from devicetree (Lucas Stach)
- Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach)
- Remove pci_assign_unassigned_resources() (Lucas Stach)
- Check private_data validity in single place (Lucas Stach)
- Setup and clear exactly one MSI at a time (Lucas Stach)
- Remove open-coded bitmap operations (Lucas Stach)
- Fix configuration base address when using 'reg' (Minghuan Lian)
- Fix IO resource end address calculation (Minghuan Lian)
- Rename get_msi_data() to get_msi_addr() (Minghuan Lian)
- Add get_msi_data() to pcie_host_ops (Minghuan Lian)
- Add support for v3.65 hardware (Murali Karicheri)
- Fold struct pcie_port_info into struct pcie_port (Pratyush Anand)
TI Keystone
- Add TI Keystone PCIe driver (Murali Karicheri)
- Limit MRSS for all downstream devices (Murali Karicheri)
- Assume controller is already in RC mode (Murali Karicheri)
- Set device ID based on SoC to support multiple ports (Murali Karicheri)
Xilinx AXI
- Add Xilinx AXI PCIe driver (Srikanth Thokala)
- Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter)
Miscellaneous
- Clean up whitespace (Quentin Lambert)
- Remove assignments from "if" conditions (Quentin Lambert)
- Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri)
- x86: Mark DMI tables as initialization data (Mathias Krause)
- x86: Move __init annotation to the correct place (Mathias Krause)
- x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause)
- x86: Constify pci_mmcfg_probes[] array (Mathias Krause)
- x86: Mark PCI BIOS initialization code as such (Mathias Krause)
- Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya)
- Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)"
* tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits)
arm64: dts: Add APM X-Gene PCIe device tree nodes
PCI: Add ACS quirk for AMD A88X southbridge devices
PCI: xgene: Add APM X-Gene PCIe driver
PCI: designware: Remove open-coded bitmap operations
PCI/MSI: Remove unnecessary temporary variable
PCI/MSI: Use __write_msi_msg() instead of write_msi_msg()
MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg()
PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg()
PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints
PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib
PCI/MSI: Remove unused kobject from struct msi_desc
PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported()
PCI/MSI: Move D0 check into pci_msi_check_device()
PCI/MSI: Remove arch_msi_check_device()
irqchip: armada-370-xp: Remove arch_msi_check_device()
PCI/MSI/PPC: Remove arch_msi_check_device()
arm64: Add architectural support for PCI
PCI: Add pci_remap_iospace() to map bus I/O resources
of/pci: Add support for parsing PCI host bridge resources from DT
of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()
arch/arm64/boot/dts/apm-storm.dtsi
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
Pull timer fixes from Ingo Molnar:
"Main changes:
- Fix the deadlock reported by Dave Jones et al
- Clean up and fix nohz_full interaction with arch abilities
- nohz init code consolidation/cleanup"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: nohz full depends on irq work self IPI support
nohz: Consolidate nohz full init code
arm64: Tell irq work about self IPI support
arm: Tell irq work about self IPI support
x86: Tell irq work about self IPI support
irq_work: Force raised irq work to run on irq work interrupt
irq_work: Introduce arch_irq_work_has_interrupt()
nohz: Move nohz full init call to tick init
Pull networking updates from David Miller:
"Most notable changes in here:
1) By far the biggest accomplishment, thanks to a large range of
contributors, is the addition of multi-send for transmit. This is
the result of discussions back in Chicago, and the hard work of
several individuals.
Now, when the ->ndo_start_xmit() method of a driver sees
skb->xmit_more as true, it can choose to defer the doorbell
telling the driver to start processing the new TX queue entires.
skb->xmit_more means that the generic networking is guaranteed to
call the driver immediately with another SKB to send.
There is logic added to the qdisc layer to dequeue multiple
packets at a time, and the handling mis-predicted offloads in
software is now done with no locks held.
Finally, pktgen is extended to have a "burst" parameter that can
be used to test a multi-send implementation.
Several drivers have xmit_more support: i40e, igb, ixgbe, mlx4,
virtio_net
Adding support is almost trivial, so export more drivers to
support this optimization soon.
I want to thank, in no particular or implied order, Jesper
Dangaard Brouer, Eric Dumazet, Alexander Duyck, Tom Herbert, Jamal
Hadi Salim, John Fastabend, Florian Westphal, Daniel Borkmann,
David Tat, Hannes Frederic Sowa, and Rusty Russell.
2) PTP and timestamping support in bnx2x, from Michal Kalderon.
3) Allow adjusting the rx_copybreak threshold for a driver via
ethtool, and add rx_copybreak support to enic driver. From
Govindarajulu Varadarajan.
4) Significant enhancements to the generic PHY layer and the bcm7xxx
driver in particular (EEE support, auto power down, etc.) from
Florian Fainelli.
5) Allow raw buffers to be used for flow dissection, allowing drivers
to determine the optimal "linear pull" size for devices that DMA
into pools of pages. The objective is to get exactly the
necessary amount of headers into the linear SKB area pre-pulled,
but no more. The new interface drivers use is eth_get_headlen().
From WANG Cong, with driver conversions (several had their own
by-hand duplicated implementations) by Alexander Duyck and Eric
Dumazet.
6) Support checksumming more smoothly and efficiently for
encapsulations, and add "foo over UDP" facility. From Tom
Herbert.
7) Add Broadcom SF2 switch driver to DSA layer, from Florian
Fainelli.
8) eBPF now can load programs via a system call and has an extensive
testsuite. Alexei Starovoitov and Daniel Borkmann.
9) Major overhaul of the packet scheduler to use RCU in several major
areas such as the classifiers and rate estimators. From John
Fastabend.
10) Add driver for Intel FM10000 Ethernet Switch, from Alexander
Duyck.
11) Rearrange TCP_SKB_CB() to reduce cache line misses, from Eric
Dumazet.
12) Add Datacenter TCP congestion control algorithm support, From
Florian Westphal.
13) Reorganize sk_buff so that __copy_skb_header() is significantly
faster. From Eric Dumazet"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1558 commits)
netlabel: directly return netlbl_unlabel_genl_init()
net: add netdev_txq_bql_{enqueue, complete}_prefetchw() helpers
net: description of dma_cookie cause make xmldocs warning
cxgb4: clean up a type issue
cxgb4: potential shift wrapping bug
i40e: skb->xmit_more support
net: fs_enet: Add NAPI TX
net: fs_enet: Remove non NAPI RX
r8169:add support for RTL8168EP
net_sched: copy exts->type in tcf_exts_change()
wimax: convert printk to pr_foo()
af_unix: remove 0 assignment on static
ipv6: Do not warn for informational ICMP messages, regardless of type.
Update Intel Ethernet Driver maintainers list
bridge: Save frag_max_size between PRE_ROUTING and POST_ROUTING
tipc: fix bug in multicast congestion handling
net: better IFF_XMIT_DST_RELEASE support
net/mlx4_en: remove NETDEV_TX_BUSY
3c59x: fix bad split of cpu_to_le32(pci_map_single())
net: bcmgenet: fix Tx ring priority programming
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the big tty/serial driver patchset for 3.18-rc1.
Lots of little things in here, some good work from Peter Hurley on the
tty core, and in lots of drivers. There are also lots of other driver
updates in here as well, full details in the changelogs.
All have been in the linux-next tree for a while"
* tag 'tty-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (99 commits)
Revert "serial/core: Initialize the console pm state"
tty: serial: 8250: use 32bit variable for rpm_tx_active
tty: serial: msm: Add earlycon support
serial: asc: Conditionally use readl_relaxed (COMPILE_TEST)
serial: of-serial: add PM suspend/resume support
m68k: AMIGA_BUILTIN_SERIAL should depend on TTY
asm/uapi: Add definition of TIOC[SG]RS485
tty/metag_da: Add console_poll module parameter
serial: 8250_pci: remove rts_n override from Baytrail quirk
serial: cadence: Add generic earlycon support
serial: imx: change the wait even to interruptiable
serial: imx: terminate the RX DMA when the UART is suspending
serial: imx: fix throttle/unthrottle callbacks for hardware assisted flow control
serial: 8250: Add Quark X1000 to 8250_pci.c
tty: omap-serial: pull out calculation from baud_is_mode16
tty: omap-serial: fix division by zero
xen_hvc: no reason to write the type key on xenstore
tty: serial: 8250_core: remove UART_IER_RDI in serial8250_stop_rx()
tty: serial: 8250_core: use the ->line argument as a hint in serial8250_find_match_or_unused()
Pull KVM updates from Paolo Bonzini:
"Fixes and features for 3.18.
Apart from the usual cleanups, here is the summary of new features:
- s390 moves closer towards host large page support
- PowerPC has improved support for debugging (both inside the guest
and via gdbstub) and support for e6500 processors
- ARM/ARM64 support read-only memory (which is necessary to put
firmware in emulated NOR flash)
- x86 has the usual emulator fixes and nested virtualization
improvements (including improved Windows support on Intel and
Jailhouse hypervisor support on AMD), adaptive PLE which helps
overcommitting of huge guests. Also included are some patches that
make KVM more friendly to memory hot-unplug, and fixes for rare
caching bugs.
Two patches have trivial mm/ parts that were acked by Rik and Andrew.
Note: I will soon switch to a subkey for signing purposes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits)
kvm: do not handle APIC access page if in-kernel irqchip is not in use
KVM: s390: count vcpu wakeups in stat.halt_wakeup
KVM: s390/facilities: allow TOD-CLOCK steering facility bit
KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode
arm/arm64: KVM: Report correct FSC for unsupported fault types
arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc
kvm: Fix kvm_get_page_retry_io __gup retval check
arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset
kvm: x86: Unpin and remove kvm_arch->apic_access_page
kvm: vmx: Implement set_apic_access_page_addr
kvm: x86: Add request bit to reload APIC access page address
kvm: Add arch specific mmu notifier for page invalidation
kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static
kvm: Fix page ageing bugs
kvm/x86/mmu: Pass gfn and level to rmapp callback.
x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only
kvm: x86: use macros to compute bank MSRs
KVM: x86: Remove debug assertion of non-PAE reserved bits
kvm: don't take vcpu mutex for obviously invalid vcpu ioctls
kvm: Faults which trigger IO release the mmap_sem
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
Use the much more reader friendly ACCESS_ONCE() instead of the cast to volatile.
This is purely a stylistic change.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Link: http://lkml.kernel.org/r/1411482607-20948-1-git-send-email-bobby.prani@gmail.com
drivers/net/usb/r8152.c
net/netfilter/nfnetlink.c
Both r8152 and nfnetlink conflicts were simple overlapping changes.
"msi_attrib.pos" is only used for MSI (not MSI-X), and we already cache the
MSI capability offset in "dev->msi_cap".
Remove "pos" from the struct msi_attrib and use "dev->msi_cap" directly.
[bhelgaas: changelog, fix whitespace]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Fix:
arch/mips/net/bpf_jit.c: In function 'build_body':
arch/mips/net/bpf_jit.c:762:6: error: unused variable 'tmp'
cc1: all warnings being treated as errors
make[2]: *** [arch/mips/net/bpf_jit.o] Error 1
Seen when building mips:allmodconfig in -next since next-20140924.
Pull MIPS fixes from Ralf Baechle:
"The final round of fixes. One corner case in the math emulator and
another one in the mcount function for ftrace"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: mcount: Adjust stack pointer for static trace in MIPS32
MIPS: Fix MFC1 & MFHC1 emulation for 64-bit MIPS systems
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
John W. Linville says:
pull request: wireless-next 2014-09-22
Please pull this batch of updates intended for the 3.18 stream...
For the mac80211 bits, Johannes says:
"This time, I have some rate minstrel improvements, support for a very
small feature from CCX that Steinar reverse-engineered, dynamic ACK
timeout support, a number of changes for TDLS, early support for radio
resource measurement and many fixes. Also, I'm changing a number of
places to clear key memory when it's freed and Intel claims copyright
for code they developed."
For the bluetooth bits, Johan says:
"Here are some more patches intended for 3.18. Most of them are cleanups
or fixes for SMP. The only exception is a fix for BR/EDR L2CAP fixed
channels which should now work better together with the L2CAP
information request procedure."
For the iwlwifi bits, Emmanuel says:
"I fix here dvm which was broken by my last pull request. Arik
continues to work on TDLS and Luca solved a few issues in CT-Kill. Eyal
keeps digging into rate scaling code, more to come soon. Besides this,
nothing really special here."
Beyond that, there are the usual big batches of updates to ath9k, b43,
mwifiex, and wil6210 as well as a handful of other bits here and there.
Also, rtlwifi gets some btcoexist attention from Larry.
Please let me know if there are problems!
Had to adjust the wil6210 code to comply with Joe Perches's recent
change in net-next to make the netdev_*() routines return void instead
of 'int'.
Every mcount() call in the MIPS 32-bit kernel is done as follows:
move at, ra
jal _mcount
addiu sp, sp, -8
but upon returning from the mcount() function, the stack pointer
is not adjusted properly. This is explained in details in 58b69401c797
(MIPS: Function tracer: Fix broken function tracing).
Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.)
fixed the stack manipulation for 64-bit but it didn't fix it completely
for MIPS32.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: <stable@vger.kernel.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/7792/
Commit bbd426f542cb "MIPS: Simplify FP context access" modified the
SIFROMREG & SIFROMHREG macros such that they return unsigned rather
than signed 32b integers. I had believed that to be fine, but
inadvertently missed the MFC1 & MFHC1 cases which write to a struct
pt_regs regs element. On MIPS32 this is fine, but on 64 bit those
saved regs' fields are 64 bit wide. Using unsigned values caused the
32 bit value from the FP register to be zero rather than sign extended
as the architecture specifies, causing incorrect emulation of the
MFC1 & MFHc1 instructions. Fix by reintroducing the casts to signed
integers, and therefore the sign extension.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: stable@vger.kernel.org # v3.15+
Patchwork: https://patchwork.linux-mips.org/patch/7848/
This patch fix spelling typos found in Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Commit df568d8e ("scsi: Use 'depends' with LIBFC instead of
'select'.") removed what happened to be the only instance of 'select
NET'. Defconfigs that were relying on the select now lack networking
support.
Commit 5d6be6a5 ("scsi_netlink : Make SCSI_NETLINK dependent on NET
instead of selecting NET") removed what happened to be the only instance
of 'select NET'. Defconfigs that were relying on the select now lack
networking support.
Kirill found that there's a subtle race in the
__ARCH_WANT_UNLOCKED_CTXSW code, and instead of fixing it, remove the
entire exception because neither arch that uses it seems to actually
still require it.
Boot tested on mips64el (qemu) only.
Reviewed-by: Kirill Tkhai <tkhai@yandex.ru>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: oleg@redhat.com
Cc: linux@roeck-us.net
Cc: linux-ia64@vger.kernel.org
Link: http://lkml.kernel.org/r/20140923150641.GH3312@worktop.programming.kicks-ass.net
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
Pull KVM fixes from Paolo Bonzini:
"Two very simple bugfixes, affecting all supported architectures"
[ Two? There's three commits in here. Oh well, I guess Paolo didn't
count the preparatory symbol export ]
KVM: correct null pid check in kvm_vcpu_yield_to()
KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn()
mm: export symbol dependencies of is_zero_pfn()
"A fair number of build fixes for various configurations.
Fixes to BPF, and the BCM47xx platform code, a preemption fix for the
Loongson core, a syscall auditing fix, wire up the new getrandom and
memfd_create. Several patches for EVA"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (30 commits)
MIPS: SmartMIPS: Disable assembler warnings
MIPS: Move CPU topology macros to topology.h
MIPS: Wire up new syscalls getrandom and memfd_create.
MIPS: Fix a warning for virt_to_page
arch/mips/net/bpf_jit.c: fix failure check
MIPS: COP2: CPP macro safety fixes.
MIPS: Kconfig: Select SMP symbols for CMP
MIPS: ZBOOT: add missing <linux/string.h> include
MIPS: IP28: Fix/clean spaces.h
MIPS: IP28: Select correct L1_CACHE_SHIFT
MIPS: BCM63xx: delete double assignment
MIPS: Spelling s/confugrations/configurations/
MIPS: OCTEON: make get_system_type() thread-safe
MIPS: CPS: Initialize EVA before bringing up VPEs from secondary cores
MIPS: Malta: EVA: Rename 'eva_entry' to 'platform_eva_init'
MIPS: EVA: Add new EVA header
MIPS: scall64-o32: Fix indirect syscall detection
MIPS: syscall: Fix AUDIT value for O32 processes on MIPS64
MIPS: Loongson: Fix COP2 usage for preemptible kernel
MIPS: NL: Fix nlm_xlp_defconfig build error
this remove all reference to gpio_remove retval in all driver
except pinctrl and gpio. the same thing is done for gpio and
pinctrl in two different patches.
Signed-off-by: Abdoulaye Berthe <berthe.ab@gmail.com>
Acked-by: Michael Büsch <m@bues.ch>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
The kernel code overrides the default ISA as passed by the compiler
in quite a few places. This has unfortunate side effects when smartmips
is enabled leading to hundreds of warnings during build such as:
{standard input}: Assembler messages:
{standard input}:411: Warning: the `smartmips' extension requires MIPS32
revision 1 or greater
{standard input}:43: Warning: the 64-bit MIPS architecture does not support the
Until the kernel code is fixed properly (if possible), disable all the
assembler warning messages to make the build logs readable again.
This has no runtime side effects but it makes it easier to spot
more critical warnings and problems during build.
Patchwork: https://patchwork.linux-mips.org/patch/7356/
In order to make the static inline function is_zero_pfn() callable by
modules, export its symbol dependencies 'zero_pfn' and (for s390 and
mips) 'zero_page_mask'.
We need this for KVM, as CONFIG_KVM is a tristate for all supported
architectures except ARM and arm64, and testing a pfn whether it refers
to the zero page is required to correctly distinguish the zero page
from other special RAM ranges that may also have the PG_reserved bit
set, but need to be treated as MMIO memory.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Currently we have 2 pkt_type_offset functions doing the same thing and
spread across the architecture files. Remove those and replace them
with a PKT_TYPE_OFFSET macro helper which gets the constant value from a
zero sized sk_buff member right in front of the bitfield with offsetof.
This new offset marker does not change size of struct sk_buff.
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Daniel Borkmann <dborkman@redhat.com>
Cc: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Signed-off-by: Denis Kirjanov <kda@linux-powerpc.org>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Commit: e676253b19b2d269cccf67fdb1592120a0cd0676 (serial/8250: Add
support for RS485 IOCTLs), adds support for RS485 ioctls for 825_core on
all the archs. Unfortunaltely the definition of TIOCSRS485 and
TIOCGRS485 was missing on the ioctls.h file
Reported-by: Markos Chandras <markos.chandras@imgtec.com>
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
The patch folding the atomic ops had two silly fails in the _return
primitives.
Fixes: ef31563e950c ("locking,arch,mips: Fold atomic_ops")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Cc: Bart Van Assche <bvanassche@acm.org>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Maciej W. Rozycki <macro@codesourcery.com>
Link: http://lkml.kernel.org/r/20140902202126.GA3190@worktop.ger.corp.intel.com
Reported by Mikulas Patocka, kmemcheck currently barks out a
false positive since we don't have special kmemcheck annotation
for bitfields used in bpf_prog structure.
We currently have jited:1, len:31 and thus when accessing len
while CONFIG_KMEMCHECK enabled, kmemcheck throws a warning that
we're reading uninitialized memory.
As we don't need the whole bit universe for pages member, we
can just split it to u16 and use a bool flag for jited instead
of a bitfield.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
This is required to split SoC bus init into two phases. The later one
(which includes scanning) should be called when kalloc is available.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
With eBPF getting more extended and exposure to user space is on it's way,
hardening the memory range the interpreter uses to steer its command flow
seems appropriate. This patch moves the to be interpreted bytecode to
read-only pages.
In case we execute a corrupted BPF interpreter image for some reason e.g.
caused by an attacker which got past a verifier stage, it would not only
provide arbitrary read/write memory access but arbitrary function calls
as well. After setting up the BPF interpreter image, its contents do not
change until destruction time, thus we can setup the image on immutable
made pages in order to mitigate modifications to that code. The idea
is derived from commit 314beb9bcabf ("x86: bpf_jit_comp: secure bpf jit
against spraying attacks").
This is possible because bpf_prog is not part of sk_filter anymore.
After setup bpf_prog cannot be altered during its life-time. This prevents
any modifications to the entire bpf_prog structure (incl. function/JIT
image pointer).
Every eBPF program (including classic BPF that are migrated) have to call
bpf_prog_select_runtime() to select either interpreter or a JIT image
as a last setup step, and they all are being freed via bpf_prog_free(),
including non-JIT. Therefore, we can easily integrate this into the
eBPF life-time, plus since we directly allocate a bpf_prog, we have no
performance penalty.
Tested with seccomp and test_bpf testsuite in JIT/non-JIT mode and manual
inspection of kernel_page_tables. Brad Spengler proposed the same idea
via Twitter during development of this patch.
Joint work with Hannes Frederic Sowa.
Suggested-by: Brad Spengler <spender@grsecurity.net>
Cc: Alexei Starovoitov <ast@plumgrid.com>
The secure_computing function took a syscall number parameter, but
it only paid any attention to that parameter if seccomp mode 1 was
enabled. Rather than coming up with a kludge to get the parameter
to work in mode 2, just remove the parameter.
To avoid churn in arches that don't have seccomp filters (and may
not even support syscall_get_nr right now), this leaves the
parameter in secure_computing_strict, which is now a real function.
For ARM, this is a bit ugly due to the fact that ARM conditionally
supports seccomp filters. Fixing that would probably only be a
couple of lines of code, but it should be coordinated with the audit
maintainers.
This will be a slight slowdown on some arches. The right fix is to
pass in all of seccomp_data instead of trying to make just the
syscall nr part be fast.
This is a prerequisite for making two-phase seccomp work cleanly.
Cc: linux-s390@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
This patch fix spelling typo in printk.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
New system call depends on crypto. As it did not have a separate config
option, CONFIG_KEXEC was modified to select CRYPTO and CRYPTO_SHA256.
But now previous patch introduced a new config option for new syscall.
So CONFIG_KEXEC does not require crypto. Remove that dependency.
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Shaun Ruffell <sruffell@digium.com>
In the beggining was on_each_cpu(), which required an unused argument to
kvm_arch_ops.hardware_{en,dis}able, but this was soon forgotten.
Remove unnecessary arguments that stem from this.
Signed-off-by: Radim KrÄmář <rkrcmar@redhat.com>
Using static inline is going to save few bytes and cycles.
For example on powerpc, the difference is 700 B after stripping.
(5 kB before)
This patch also deals with two overlooked empty functions:
kvm_arch_flush_shadow was not removed from arch/mips/kvm/mips.c
2df72e9bc KVM: split kvm_arch_flush_shadow
and kvm_arch_sched_in never made it into arch/ia64/kvm/kvm-ia64.c.
e790d9ef6 KVM: add kvm_arch_sched_in
Opaque KVM structs are useful for prototypes in asm/kvm_host.h, to avoid
"'struct foo' declared inside parameter list" warnings (and consequent
breakage due to conflicting types).
Move them from individual files to a generic place in linux/kvm_types.h.
The correct position is topology.h, and this fix macros redefinition
problems for Netlogic.
[ralf@linux-mips.org: Fix build - the original patch broke most
configurations.]
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Jayachandran C. <jchandra@broadcom.com>
Cc: John Crispin <john@phrozen.org>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/7575/
__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
#define __get_cpu_var(var) (*this_cpu_ptr(&(var)))
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
At the end of the patch set all uses of __get_cpu_var have been removed so
the macro is removed too.
The patch set includes passes over all arches as well. Once these operations
are used throughout then specialized macros can be defined in non -x86
arches as well in order to optimize per cpu access by f.e. using a global
register that may be set to the per cpu base.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
__this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
__this_cpu_inc(y)
Signed-off-by: Christoph Lameter <cl@linux.com>
The use of __this_cpu_inc() requires a fundamental integer type, so
change the type of all the counters to unsigned long, which is the
same width they were before, but not wrapped in local_t.
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
