path: root/arch/mips
2014-12-06MIPS: Loongson: Make platform serial setup always built-in.Aaro Koskinen
commit 26927f76499849e095714452b8a4e09350f6a3b9 upstream. If SERIAL_8250 is compiled as a module, the platform specific setup for Loongson will be a module too, and it will not work very well. At least on Loongson 3 it will trigger a build failure, since loongson_sysconf is not exported to modules. Fix by making the platform specific serial code always built-in. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Reported-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Huacai Chen <chenhc@lemote.com> Cc: Markos Chandras <Markos.Chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/8533/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06MIPS: oprofile: Fix backtrace on 64-bit kernelAaro Koskinen
commit bbaf113a481b6ce32444c125807ad3618643ce57 upstream. Fix incorrect cast that always results in wrong address for the new frame on 64-bit kernels. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8110/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14MIPS: tlbex: Properly fix HUGE TLB Refill exception handlerDavid Daney
commit 9e0f162a36914937a937358fcb45e0609ef2bfc4 upstream. In commit 8393c524a25609 (MIPS: tlbex: Fix a missing statement for HUGETLB), the TLB Refill handler was fixed so that non-OCTEON targets would work properly with huge pages. The change was incorrect in that it broke the OCTEON case. The problem is shown here: xxx0: df7a0000 ld k0,0(k1) . . . xxxc0: df610000 ld at,0(k1) xxxc4: 335a0ff0 andi k0,k0,0xff0 xxxc8: e825ffcd bbit1 at,0x5,0x0 xxxcc: 003ad82d daddu k1,at,k0 . . . In the non-octeon case there is a destructive test for the huge PTE bit, and then at 0, $k0 is reloaded (that is what the 8393c524a25609 patch added). In the octeon case, we modify k1 in the branch delay slot, but we never need k0 again, so the new load is not needed, but since k1 is modified, if we do the load, we load from a garbage location and then get a nested TLB Refill, which is seen in userspace as either SIGBUS or SIGSEGV (depending on the garbage). The real fix is to only do this reloading if it is needed, and never where it is harmful. Signed-off-by: David Daney <david.daney@cavium.com> Cc: Huacai Chen <chenhc@lemote.com> Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8151/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14MIPS: ftrace: Fix a microMIPS build problemMarkos Chandras
commit aedd153f5bb5b1f1d6d9142014f521ae2ec294cc upstream. Code before the .fixup section needs to have the .insn directive. This has no side effects on MIPS32/64 but it affects the way microMIPS loads the address for the return label. Fixes the following build problem: mips-linux-gnu-ld: arch/mips/built-in.o: .fixup+0x4a0: Unsupported jump between ISA modes; consider recompiling with interlinking enabled. mips-linux-gnu-ld: final link failed: Bad value Makefile:819: recipe for target 'vmlinux' failed The fix is similar to 1658f914ff91c3bf ("MIPS: microMIPS: Disable LL/SC and fix linker bug.") Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8117/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05MIPS: mcount: Adjust stack pointer for static trace in MIPS32Markos Chandras
commit 8a574cfa2652545eb95595d38ac2a0bb501af0ae upstream. Every mcount() call in the MIPS 32-bit kernel is done as follows: [...] move at, ra jal _mcount addiu sp, sp, -8 [...] but upon returning from the mcount() function, the stack pointer is not adjusted properly. This is explained in details in 58b69401c797 (MIPS: Function tracer: Fix broken function tracing). Commit ad8c396936e3 ("MIPS: Unbreak function tracer for 64-bit kernel.) fixed the stack manipulation for 64-bit but it didn't fix it completely for MIPS32. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7792/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05MIPS: ZBOOT: add missing <linux/string.h> includeAurelien Jarno
commit 29593fd5a8149462ed6fad0d522234facdaee6c8 upstream. Commit dc4d7b37 (MIPS: ZBOOT: gather string functions into string.c) moved the string related functions into a separate file, which might cause the following build error, depending on the configuration: | CC arch/mips/boot/compressed/decompress.o | In file included from linux/arch/mips/boot/compressed/../../../../lib/decompress_unxz.c:234:0, | from linux/arch/mips/boot/compressed/decompress.c:67: | linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c: In function 'fill_temp': | linux/arch/mips/boot/compressed/../../../../lib/xz/xz_dec_stream.c:162:2: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration] | cc1: some warnings being treated as errors | linux/scripts/Makefile.build:308: recipe for target 'arch/mips/boot/compressed/decompress.o' failed | make[6]: *** [arch/mips/boot/compressed/decompress.o] Error 1 | linux/arch/mips/Makefile:308: recipe for target 'vmlinuz' failed It does not fail with the standard configuration, as when CONFIG_DYNAMIC_DEBUG is not enabled <linux/string.h> gets included in include/linux/dynamic_debug.h. There might be other ways for it to get indirectly included. We can't add the include directly in xz_dec_stream.c as some architectures might want to use a different version for the boot/ directory (see for example arch/x86/boot/string.h). Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7420/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: OCTEON: make get_system_type() thread-safeAaro Koskinen
commit 608308682addfdc7b8e2aee88f0e028331d88e4d upstream. get_system_type() is not thread-safe on OCTEON. It uses static data, also more dangerous issue is that it's calling cvmx_fuse_read_byte() every time without any synchronization. Currently it's possible to get processes stuck looping forever in kernel simply by launching multiple readers of /proc/cpuinfo: (while true; do cat /proc/cpuinfo > /dev/null; done) & (while true; do cat /proc/cpuinfo > /dev/null; done) & ... Fix by initializing the system type string only once during the early boot. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Reviewed-by: Markos Chandras <markos.chandras@imgtec.com> Patchwork: http://patchwork.linux-mips.org/patch/7437/ Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: asm/reg.h: Make 32- and 64-bit definitions available at the same timeAlex Smith
commit bcec7c8da6b092b1ff3327fd83c2193adb12f684 upstream. Get rid of the WANT_COMPAT_REG_H test and instead define both the 32- and 64-bit register offset definitions at the same time with MIPS{32,64}_ prefixes, then define the existing EF_* names to the correct definitions for the kernel's bitness. This patch is a prerequisite of the following bug fix patch. Signed-off-by: Alex Smith <alex@alex-smith.me.uk> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7451/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: Remove BUG_ON(!is_fpu_owner()) in do_ade()Huacai Chen
commit 2e5767a27337812f6850b3fa362419e2f085e5c3 upstream. In do_ade(), is_fpu_owner() isn't preempt-safe. For example, when an unaligned ldc1 is executed, do_cpu() is called and then FPU will be enabled (and TIF_USEDFPU will be set for the current process). Then, do_ade() is called because the access is unaligned. If the current process is preempted at this time, TIF_USEDFPU will be cleard. So when the process is scheduled again, BUG_ON(!is_fpu_owner()) is triggered. This small program can trigger this BUG in a preemptible kernel: int main (int argc, char *argv[]) { double u64[2]; while (1) { asm volatile ( ".set push \n\t" ".set noreorder \n\t" "ldc1 $f3, 4(%0) \n\t" ".set pop \n\t" ::"r"(u64): ); } return 0; } V2: Remove the BUG_ON() unconditionally due to Paul's suggestion. Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Jie Chen <chenj@lemote.com> Signed-off-by: Rui Wang <wangr@lemote.com> Cc: John Crispin <john@phrozen.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: tlbex: Fix a missing statement for HUGETLBHuacai Chen
commit 8393c524a25609a30129e4a8975cf3b91f6c16a5 upstream. In commit 2c8c53e28f1 (MIPS: Optimize TLB handlers for Octeon CPUs) build_r4000_tlb_refill_handler() is modified. But it doesn't compatible with the original code in HUGETLB case. Because there is a copy & paste error and one line of code is missing. It is very easy to produce a bug with LTP's hugemmap05 test. Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Binbin Zhou <zhoubb@lemote.com> Cc: John Crispin <john@phrozen.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/7496/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: Prevent user from setting FCSR cause bitsPaul Burton
commit b1442d39fac2fcfbe6a4814979020e993ca59c9e upstream. If one or more matching FCSR cause & enable bits are set in saved thread context then when that context is restored the kernel will take an FP exception. This is of course undesirable and considered an oops, leading to the kernel writing a backtrace to the console and potentially rebooting depending upon the configuration. Thus the kernel avoids this situation by clearing the cause bits of the FCSR register when handling FP exceptions and after emulating FP instructions. However the kernel does not prevent userland from setting arbitrary FCSR cause & enable bits via ptrace, using either the PTRACE_POKEUSR or PTRACE_SETFPREGS requests. This means userland can trivially cause the kernel to oops on any system with an FPU. Prevent this from happening by clearing the cause bits when writing to the saved FCSR context via ptrace. This problem appears to exist at least back to the beginning of the git era in the PTRACE_POKEUSR case. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Paul Burton <paul.burton@imgtec.com> Cc: stable@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7438/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: ptrace: Change GP regset to use correct core dump register layoutAlex Smith
commit c23b3d1a53119849dc3c23c417124deb067aa33d upstream. Commit 6a9c001b7ec3 ("MIPS: Switch ELF core dumper to use regsets.") switched the core dumper to use regsets, however the GP regset code simply makes a direct copy of the kernel's pt_regs, which does not match the original core dump register layout as defined in asm/reg.h. Furthermore, the definition of pt_regs can vary with certain Kconfig variables, therefore the GP regset can never be relied upon to return registers in the same layout. Therefore, this patch changes the GP regset to match the original core dump layout. The layout differs for 32- and 64-bit processes, so separate implementations of the get/set functions are added for the 32- and 64-bit regsets. Signed-off-by: Alex Smith <alex@alex-smith.me.uk> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7452/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: ptrace: Test correct task's flags in task_user_regset_view()Alex Smith
commit 65768a1a92cb12cbba87588927cf597a65d560aa upstream. task_user_regset_view() should test for TIF_32BIT_REGS in the flags of the specified task, not of the current task. Signed-off-by: Alex Smith <alex@alex-smith.me.uk> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7450/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: O32/32-bit: Fix bug which can cause incorrect system call restartsAlex Smith
commit e90e6fddc57055c4c6b57f92787fea1c065d440b upstream. On 32-bit/O32, pt_regs has a padding area at the beginning into which the syscall arguments passed via the user stack are copied. 4 arguments totalling 16 bytes are copied to offset 16 bytes into this area, however the area is only 24 bytes long. This means the last 2 arguments overwrite pt_regs->regs[{0,1}]. If a syscall function returns an error, handle_sys stores the original syscall number in pt_regs->regs[0] for syscall restart. signal.c checks whether regs[0] is non-zero, if it is it will check whether the syscall return value is one of the ERESTART* codes to see if it must be restarted. Should a syscall be made that results in a non-zero value being copied off the user stack into regs[0], and then returns a positive (non-error) value that matches one of the ERESTART* error codes, this can be mistaken for requiring a syscall restart. While the possibility for this to occur has always existed, it is made much more likely to occur by commit 46e12c07b3b9 ("MIPS: O32 / 32-bit: Always copy 4 stack arguments."), since now every syscall will copy 4 arguments and overwrite regs[0], rather than just those with 7 or 8 arguments. Since that commit, booting Debian under a 32-bit MIPS kernel almost always results in a hang early in boot, due to a wait4 syscall returning a PID that matches one of the ERESTART* codes, which then causes an incorrect restart of the syscall. The problem is fixed by increasing the size of the padding area so that arguments copied off the stack will not overwrite pt_regs->regs[{0,1}]. Signed-off-by: Alex Smith <alex.smith@imgtec.com> Reviewed-by: Aurelien Jarno <aurelien@aurel32.net> Tested-by: Aurelien Jarno <aurelien@aurel32.net> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7454/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17MIPS: GIC: Prevent array overrunJeffrey Deans
commit ffc8415afab20bd97754efae6aad1f67b531132b upstream. A GIC interrupt which is declared as having a GIC_MAP_TO_NMI_MSK mapping causes the cpu parameter to gic_setup_intr() to be increased to 32, causing memory corruption when pcpu_masks[] is written to again later in the function. Signed-off-by: Jeffrey Deans <jeffrey.deans@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7375/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: KVM: Fix memory leak on VCPUDeng-Cheng Zhu
commit 8c9eb041cf76038eb3b62ee259607eec9b89f48d upstream. kvm_arch_vcpu_free() is called in 2 code paths: 1) kvm_vm_ioctl() kvm_vm_ioctl_create_vcpu() kvm_arch_vcpu_destroy() kvm_arch_vcpu_free() 2) kvm_put_kvm() kvm_destroy_vm() kvm_arch_destroy_vm() kvm_mips_free_vcpus() kvm_arch_vcpu_free() Neither of the paths handles VCPU free. We need to do it in kvm_arch_vcpu_free() corresponding to the memory allocation in kvm_arch_vcpu_create(). Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: KVM: Remove redundant NULL checks before kfree()James Hogan
commit c6c0a6637f9da54f9472144d44f71cf847f92e20 upstream. The kfree() function already NULL checks the parameter so remove the redundant NULL checks before kfree() calls in arch/mips/kvm/. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: kvm@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Sanjay Lal <sanjayl@kymasys.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06MIPS: MSC: Prevent out-of-bounds writes to MIPS SC ioremap'd regionMarkos Chandras
commit ab6c15bc6620ebe220970cc040b29bcb2757f373 upstream. Previously, the lower limit for the MIPS SC initialization loop was set incorrectly allowing one extra loop leading to writes beyond the MSC ioremap'd space. More precisely, the value of the 'imp' in the last loop increased beyond the msc_irqmap_t boundaries and as a result of which, the 'n' variable was loaded with an incorrect value. This value was used later on to calculate the offset in the MSC01_IC_SUP which led to random crashes like the following one: CPU 0 Unable to handle kernel paging request at virtual address e75c0200, epc == 8058dba4, ra == 8058db90 [...] Call Trace: [<8058dba4>] init_msc_irqs+0x104/0x154 [<8058b5bc>] arch_init_irq+0xd8/0x154 [<805897b0>] start_kernel+0x220/0x36c Kernel panic - not syncing: Attempted to kill the idle task! This patch fixes the problem Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/7118/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-30hugetlb: restrict hugepage_migration_support() to x86_64Naoya Horiguchi
commit c177c81e09e517bbf75b67762cdab1b83aba6976 upstream. Currently hugepage migration is available for all archs which support pmd-level hugepage, but testing is done only for x86_64 and there're bugs for other archs. So to avoid breaking such archs, this patch limits the availability strictly to x86_64 until developers of other archs get interested in enabling this feature. Simply disabling hugepage migration on non-x86_64 archs is not enough to fix the reported problem where sys_move_pages() hits the BUG_ON() in follow_page(FOLL_GET), so let's fix this by checking if hugepage migration is supported in vma_migratable(). Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reported-by: Michael Ellerman <mpe@ellerman.id.au> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-26MIPS: KVM: Allocate at least 16KB for exception handlersJames Hogan
commit 7006e2dfda9adfa40251093604db76d7e44263b3 upstream. Each MIPS KVM guest has its own copy of the KVM exception vector. This contains the TLB refill exception handler at offset 0x000, the general exception handler at offset 0x180, and interrupt exception handlers at offset 0x200 in case Cause_IV=1. A common handler is copied to offset 0x2000 and offset 0x3000 is used for temporarily storing k1 during entry from guest. However the amount of memory allocated for this purpose is calculated as 0x200 rounded up to the next page boundary, which is insufficient if 4KB pages are in use. This can lead to the common handler at offset 0x2000 being overwritten and infinitely recursive exceptions on the next exit from the guest. Increase the minimum size from 0x200 to 0x4000 to cover the full use of the page. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: kvm@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Sanjay Lal <sanjayl@kymasys.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16MIPS: asm: thread_info: Add _TIF_SECCOMP flagMarkos Chandras
commit 137f7df8cead00688524c82360930845396b8a21 upstream. Add _TIF_SECCOMP flag to _TIF_WORK_SYSCALL_ENTRY to indicate that the system call needs to be checked against a seccomp filter. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6405/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11MIPS: Fix typo when reporting cache and ftlb errors for ImgTec coresMarkos Chandras
commit 721a9205396c4ef2a811dd665ec2a232163b583d upstream. Introduced by the following two commits: 75b5b5e0a262790fa11043fe45700499c7e3d818 "MIPS: Add support for FTLBs" 6de20451857ed14a4eecc28d08f6de5925d1cf96 "MIPS: Add printing of ES bit for Imgtec cores when cache error occurs" Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reported-by: Matheus Almeida <Matheus.Almeida@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/6980/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07genirq: Allow forcing cpu affinity of interruptsThomas Gleixner
commit 01f8fa4f01d8362358eb90e412bd7ae18a3ec1ad upstream. The current implementation of irq_set_affinity() refuses rightfully to route an interrupt to an offline cpu. But there is a special case, where this is actually desired. Some of the ARM SoCs have per cpu timers which require setting the affinity during cpu startup where the cpu is not yet in the online mask. If we can't do that, then the local timer interrupt for the about to become online cpu is routed to some random online cpu. The developers of the affected machines tried to work around that issue, but that results in a massive mess in that timer code. We have a yet unused argument in the set_affinity callbacks of the irq chips, which I added back then for a similar reason. It was never required so it got not used. But I'm happy that I never removed it. That allows us to implement a sane handling of the above scenario. So the affected SoC drivers can add the required force handling to their interrupt chip, switch the timer code to irq_force_affinity() and things just work. This does not affect any existing user of irq_set_affinity(). Tagged for stable to allow a simple fix of the affected SoC clock event drivers. Reported-and-tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Tomasz Figa <t.figa@samsung.com>, Cc: Daniel Lezcano <daniel.lezcano@linaro.org>, Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-arm-kernel@lists.infradead.org, Link: http://lkml.kernel.org/r/20140416143315.717251504@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07mips: dts: Fix missing device_type="memory" property in memory nodesLeif Lindholm
commit dfc44f8030653b345fc6fb337558c3a07536823f upstream. A few platforms lack a 'device_type = "memory"' for their memory nodes, relying on an old ppc quirk in order to discover its memory. Add the missing data so that all parsing code can find memory nodes correctly. Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org> Cc: linux-mips@linux-mips.org Cc: devicetree@vger.kernel.org Cc: Mark Rutland <mark.rutland@arm.com> Acked-by: John Crispin <blogic@openwrt.org> Signed-off-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-07MIPS/loongson2_cpufreq: Fix CPU clock rate settingAaro Koskinen
commit 8e8acb32960f42c81b1d50deac56a2c07bb6a18a upstream. Loongson2 has been using (incorrectly) kHz for cpu_clk rate. This has been unnoticed, as loongson2_cpufreq was the only place where the rate was set/get. After commit 652ed95d5fa6074b3c4ea245deb0691f1acb6656 (cpufreq: introduce cpufreq_generic_get() routine) things however broke, and now loops_per_jiffy adjustments are incorrect (1000 times too long). The patch fixes this by changing cpu_clk rate to Hz. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: cpufreq@vger.kernel.org Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Patchwork: https://patchwork.linux-mips.org/patch/6678/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13MIPS: Hibernate: Flush TLB entries in swsusp_arch_resume()Huacai Chen
commit c14af233fbe279d0e561ecf84f1208b1bae087ef upstream. The original MIPS hibernate code flushes cache and TLB entries in swsusp_arch_resume(). But they are removed in Commit 44eeab67416711 (MIPS: Hibernation: Remove SMP TLB and cacheflushing code.). A cross- CPU flush is surely unnecessary because all but the local CPU have already been disabled. But a local flush (at least the TLB flush) is needed. When we do hibernation on Loongson-3 with an E1000E NIC, it is very easy to produce a kernel panic (kernel page fault, or unaligned access). The root cause is E1000E driver use vzalloc_node() to allocate pages, the stale TLB entries of the booting kernel will be misused by the resumed target kernel. Signed-off-by: Huacai Chen <chenhc@lemote.com> Cc: John Crispin <john@phrozen.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: Aurelien Jarno <aurelien@aurel32.net> Cc: linux-mips@linux-mips.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/6643/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13MIPS: KVM: Pass reserved instruction exceptions to guestJames Hogan
commit 15505679362270d02c449626385cb74af8905514 upstream. Previously a reserved instruction exception while in guest code would cause a KVM internal error if kvm_mips_handle_ri() didn't recognise the instruction (including a RDHWR from an unrecognised hardware register). However the guest OS should really have the opportunity to catch the exception so that it can take the appropriate actions such as sending a SIGILL to the guest user process or emulating the instruction itself. Therefore in these cases emulate a guest RI exception and only return EMULATE_FAIL if that fails, being careful to revert the PC first in case the exception occurred in a branch delay slot in which case the PC will already point to the branch target. Also turn the printk messages relating to these cases into kvm_debug messages so that they aren't usually visible. This allows crashme to run in the guest without killing the entire VM. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Sanjay Lal <sanjayl@kymasys.com> Cc: linux-mips@linux-mips.org Cc: kvm@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-20MIPS: Make local_irq_disable macro safe for non-Mipsr2Jim Quinlan
For non-mipsr2 processors, the local_irq_disable contains an mfc0-mtc0 pair with instructions inbetween. With preemption enabled, this sequence may get preempted and effect a stale value of CP0_STATUS when executing the mtc0 instruction. This commit avoids this scenario by incrementing the preempt count before the mfc0 and decrementing it after the mtc9. [ralf@linux-mips.org: This patch is sorting out the part that were missed by e97c5b6098 [MIPS: Make irqflags.h functions preempt-safe for non-mipsr2 cpus.] I also re-enabled the inclusion of <asm/asm-offsets.h> at the top of <asm/asmmacro.h>]. Signed-off-by: Jim Quinlan <jim2101024@gmail.com> Cc: linux-mips@linux-mips.org Cc: cernekee@gmail.com Patchwork: https://patchwork.linux-mips.org/patch/6164/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-19MIPS: Octeon: Fix warning in of_device_alloc on cn3xxxAndreas Herrmann
Starting with commit 3da5278727a895d49a601f67fd49dffa0b80f9a5 (of/irq: Rework of_irq_count()) the following warning is triggered on octeon cn3xxx: [ 0.887281] WARNING: CPU: 0 PID: 1 at drivers/of/platform.c:171 of_device_alloc+0x228/0x230() [ 0.895642] Modules linked in: [ 0.898689] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.0-rc7-00012-g9ae51f2-dirty #41 [ 0.906860] Stack : c8b439581166d96e ffffffff816b0000 0000000040808000 ffffffff81185ddc [ 0.906860] 0000000000000000 0000000000000000 0000000000000000 000000000000000b [ 0.906860] 000000000000000a 000000000000000a 0000000000000000 0000000000000000 [ 0.906860] ffffffff81740000 ffffffff81720000 ffffffff81615900 ffffffff816b0177 [ 0.906860] ffffffff81727d10 800000041f868fb0 0000000000000001 0000000000000000 [ 0.906860] 0000000000000000 0000000000000038 0000000000000001 ffffffff81568484 [ 0.906860] 800000041f86faa8 ffffffff81145ddc 0000000000000000 ffffffff811873f4 [ 0.906860] 800000041f868b88 800000041f86f9c0 0000000000000000 ffffffff81569c9c [ 0.906860] 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 0.906860] 0000000000000000 ffffffff811205e0 0000000000000000 0000000000000000 [ 0.906860] ... [ 0.971695] Call Trace: [ 0.974139] [<ffffffff811205e0>] show_stack+0x68/0x80 [ 0.979183] [<ffffffff81569c9c>] dump_stack+0x8c/0xe0 [ 0.984196] [<ffffffff81145efc>] warn_slowpath_common+0x84/0xb8 [ 0.990110] [<ffffffff81436888>] of_device_alloc+0x228/0x230 [ 0.995726] [<ffffffff814368d8>] of_platform_device_create_pdata+0x48/0xd0 [ 1.002593] [<ffffffff81436a94>] of_platform_bus_create+0x134/0x1e8 [ 1.008837] [<ffffffff81436af8>] of_platform_bus_create+0x198/0x1e8 [ 1.015064] [<ffffffff81436cc4>] of_platform_bus_probe+0xa4/0x100 [ 1.021149] [<ffffffff81100570>] do_one_initcall+0xd8/0x128 [ 1.026701] [<ffffffff816e2a10>] kernel_init_freeable+0x144/0x210 [ 1.032753] [<ffffffff81564bc4>] kernel_init+0x14/0x110 [ 1.037973] [<ffffffff8111bb44>] ret_from_kernel_thread+0x14/0x1c With this commit the kernel starts mapping the interrupts listed for gpio-controller node. irq_domain_ops for CIU (octeon_irq_ciu_map and octeon_irq_ciu_xlat) refuse to handle the GPIO lines (returning -EINVAL) and this is causing above warning in of_device_alloc(). Modify irq_domain_ops for CIU and CIU2 to "gracefully handle" GPIO lines (neither return error code nor call octeon_irq_set_ciu_mapping for it). This should avoid the warning. (As before the real setup for GPIO lines will happen using irq_domain_ops of gpio-controller.) This patch is based on Wei's patch v2 (see http://marc.info/?l=linux-mips&m=139511814813247). Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com> Reported-by: Yang Wei <wei.yang@windriver.com> Acked-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6624/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-19MIPS: ftrace: Tweak safe_load()/safe_store() macrosViller Hsiao
Due to name collision in ftrace safe_load and safe_store macros, these macros cannot take expressions as operands. For example, compiler will complain for a macro call like the following: safe_store_code(new_code2, ip + 4, faulted); arch/mips/include/asm/ftrace.h:61:6: note: in definition of macro 'safe_store' : [dst] "r" (dst), [src] "r" (src)\ ^ arch/mips/kernel/ftrace.c:118:2: note: in expansion of macro 'safe_store_code' safe_store_code(new_code2, ip + 4, faulted); ^ arch/mips/kernel/ftrace.c:118:32: error: undefined named operand 'ip + 4' safe_store_code(new_code2, ip + 4, faulted); ^ arch/mips/include/asm/ftrace.h:61:6: note: in definition of macro 'safe_store' : [dst] "r" (dst), [src] "r" (src)\ ^ arch/mips/kernel/ftrace.c:118:2: note: in expansion of macro 'safe_store_code' safe_store_code(new_code2, ip + 4, faulted); ^ This build error is triggered by a4671094 [MIPS: ftrace: Fix icache flush range error]. Tweak variable naming in those macros to allow flexible operands. Signed-off-by: Viller Hsiao <villerhsiao@gmail.com> Cc: linux-mips@linux-mips.org Cc: rostedt@goodmis.org Cc: fweisbec@gmail.com Cc: mingo@redhat.com Cc: Qais.Yousef@imgtec.com Patchwork: https://patchwork.linux-mips.org/patch/6622/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-19MIPS: BCM47XX: Check all (32) GPIOs when looking for a pinRafał Miłecki
Broadcom boards support 32 GPIOs and NVRAM may have entires for higher ones too. Example: gpio23=wombo_reset Signed-off-by: Rafa? Mi?ecki <zajec5@gmail.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: linux-mips@linux-mips.org Cc: Rafał Miłecki <zajec5@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/6547/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-18MIPS: Fix possible build error with transparent hugepages enabledAlex Smith
If CONFIG_TRANSPARENT_HUGEPAGE is enabled, but CONFIG_HUGETLB_PAGE is not, it is possible to end up with a configuration that fails to build with the following error: include/linux/huge_mm.h:125:2: error: #error "hugepages can't be allocated by the buddy allocator" This is due to CONFIG_FORCE_MAX_ZONEORDER defaulting to 11. It already has ranges that change the valid values when HUGETLB_PAGE is enabled, but this is not done for TRANSPARENT_HUGEPAGE. Fix by changing the HUGETLB_PAGE dependencies to MIPS_HUGE_TLB_SUPPORT, which includes both TRANSPARENT_HUGEPAGE and HUGETLB_PAGE. Signed-off-by: Alex Smith <alex.smith@imgtec.com> Reviewed-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6391/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-17MIPS: mark O32+FP64 experimental for nowPaul Burton
Commit 597ce1723e0f "MIPS: Support for 64-bit FP with O32 binaries" introduced support for setting Status.FR=1 for O32 binaries with the EF_MIPS_FP64 ELF header flag set. Whilst this flag is currently supported by binutils it does introduce an ABI break within userland. Objects built with EF_MIPS_FP64 cannot be safely linked with those built without it since code in either object may assume behaviour specific to a value of FR. More recently there has been discussion around avoiding further fragmentation of the O32 ABI whilst still allowing the use of FR=1 and features such as MSA which depend upon it. Details of the plan to allow this are still being worked on, and whilst the kernel will need the ability to handle FR=1 with O32 tasks it is unclear what else it may need to provide to a userland which seeks to avoid another ABI break. In order to prevent the proliferation of userland which may rely upon the current EF_MIPS_FP64 behaviour this patch marks the kernel support for it experimental & disables it by default. Under current proposals it is likely that this support can simply be enabled again later, but possibly after the introduction of further interfaces with userland and support for the MIPS R5 UFR feature. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Matthew Fortune <matthew.fortune@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Paul Burton <paul.burton@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/6549/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-17MIPS: ftrace: Fix icache flush range errorViller Hsiao
In 32-bit mode, the start address passed to flush_icache_range is shifted by 4 bytes before the second safe_store_code() call. This causes system crash from time to time because the first 4 bytes might not be flushed properly. This bug exists since linux-3.8. Also remove obsoleted comment while at it. Signed-off-by: Viller Hsiao <villerhsiao@gmail.com> Cc: linux-mips@linux-mips.org Cc: rostedt@goodmis.org Cc: fweisbec@gmail.com Cc: mingo@redhat.com Cc: Qais.Yousef@imgtec.com Patchwork: https://patchwork.linux-mips.org/patch/6586/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-17MIPS: Fix syscall tracing interfaceLars Persson
Fix pointer computation for stack-based arguments. Signed-off-by: Lars Persson <larper@axis.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6620/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-17MIPS: asm: syscall: Fix copying system call argumentsMarkos Chandras
The syscall_get_arguments function expects the arguments to be copied to the '*args' argument but instead a local variable was used to hold the system call argument. As a result of which, this variable was never passed to the filter and any filter testing the system call arguments would fail. This is fixed by passing the '*args' variable as the destination memory for the system call arguments. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: James Hogan <james.hogan@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6402/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-15MIPS: Octeon: Fix fall through on bar type OCTEON_DMA_BAR_TYPE_SMALLColin Ian King
Bar type OCTEON_DMA_BAR_TYPE_SMALL assigns lo and hi addresses and then falls through to OCTEON_DMA_BAR_TYPE_BIG that re-assignes lo and hi addresses with totally different values. Add a break so we don't fall through. Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/6529/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-14MIPS: FPU: Fix conflict of register usageHuacai Chen
In _restore_fp_context/_restore_fp_context32, t0 is used for both CP0_Status and CP1_FCSR. This is a mistake and cause FP exeception on boot, so fix it. Signed-off-by: Huacai Chen <chenhc@lemote.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Tested-by: Andreas Barth <aba@ayous.org> Cc: John Crispin <john@phrozen.org> Cc: Steven J. Hill <Steven.Hill@imgtec.com> Cc: Aurelien Jarno <aurelien@aurel32.net> Cc: linux-mips@linux-mips.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/6507/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-14MIPS: Replace CONFIG_MIPS64 and CONFIG_MIPS32_R2Paul Bolle
Commit 597ce1723e0f ("MIPS: Support for 64-bit FP with O32 binaries") introduced references to two undefined Kconfig macros. CONFIG_MIPS32_R2 should clearly be replaced with CONFIG_CPU_MIPS32_R2. And CONFIG_MIPS64 should be replaced with CONFIG_64BIT. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/6522/ Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-11MIPS: math-emu: Fix prefx detection and COP1X function field definitionDeng-Cheng Zhu
When running applications which contain the instruction "prefx" on FPU-less CPUs, a message "Illegal instruction" will be seen. This instruction is supposed to be ignored by the FPU emulator. However, its current detection and function field encoding are incorrect. This patch fix the issue. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Reviewed-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Acked-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Cc: Steven.Hill@imgtec.com Patchwork: https://patchwork.linux-mips.org/patch/6608/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: APRP: Choose the correct VPE loader by fixing the linkingDeng-Cheng Zhu
Now we have CONFIG_MIPS_VPE_LOADER and CONFIG_MIPS_VPE_LOADER_[CMP|MT]. The latter two are used by the 2 exclusive flavors. The vpe_run in malta-amon.c is for CMP APRP. Without the fix, this vpe_run will be used in MT APRP. Reviewed-by: Steven J. Hill <Steven.Hill@imgtec.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Cc: linux-mips@linux-mips.org Cc: john@phrozen.org Patchwork: https://patchwork.linux-mips.org/patch/6589/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: APRP: Unregister rtlx interrupt hook at module exitDeng-Cheng Zhu
If the aprp_hook is not assigned back to NULL, it will still be called after module exits. This is not wanted. Reviewed-by: Steven J. Hill <Steven.Hill@imgtec.com> Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Cc: linux-mips@linux-mips.org Cc: john@phrozen.org Patchwork: https://patchwork.linux-mips.org/patch/6590/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: APRP: Fix the linking of rtlx interrupt hookDeng-Cheng Zhu
There are 2 errors with the existing aprp_hook linking: - The prefix CONFIG_ is missing; - The hook should be linked exclusively in the cases of MT and CMP. Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com> Reviewed-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Cc: john@phrozen.org Patchwork: https://patchwork.linux-mips.org/patch/6588/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: bcm47xx: Include missing errno.h for ENXIOMarkos Chandras
Fixes the following build problen on allmodconfig: arch/mips/bcm47xx/board.c: In function 'bcm47xx_board_detect': arch/mips/bcm47xx/board.c:291:14: error: 'ENXIO' undeclared (first use in this function) Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6571/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: Alchemy: Fix unchecked kstrtoul return valueManuel Lauss
enabled __must_check logic triggers a build error for mtx1 and gpr in the prom init code. Fix by checking the kstrtoul() return value. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/6574/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-06MIPS: Fix randconfig build error.Ralf Baechle
CC arch/mips/kernel/ptrace.o In file included from arch/mips/kernel/ptrace.c:42:0: arch/mips/kernel/ptrace.c: In function ‘mips_get_syscall_arg’: /home/ralf/src/linux/linux-mips/arch/mips/include/asm/syscall.h:60:1: error: control reaches end of non-void function [-Werror=return-type] cc1: all warnings being treated as errors make[2]: *** [arch/mips/kernel/ptrace.o] Error 1 make[1]: *** [arch/mips/kernel] Error 2 make: *** [arch/mips] Error 2 Fixed by marking the end of mips_get_syscall_arg() as unreachable. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-02-06MIPS: fpu.h: Fix build when CONFIG_BUG is not setAaro Koskinen
__enable_fpu produces a build failure when CONFIG_BUG is not set: In file included from arch/mips/kernel/cpu-probe.c:24:0: arch/mips/include/asm/fpu.h: In function '__enable_fpu': arch/mips/include/asm/fpu.h:77:1: error: control reaches end of non-void function [-Werror=return-type] This is regression introduced in 3.14-rc1. Fix that. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Acked-by: Paul Burton <paul.burton@imgtec.com> Cc: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6504/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-02-04MIPS: Wire up sched_setattr/sched_getattr syscallsJames Hogan
Wire up for MIPS the new sched_setattr and sched_getattr system calls added in commit d50dde5a10f3 (sched: Add new scheduler syscalls to support an extended scheduling parameters ABI) merged in v3.14-rc1. Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Markos Chandras <markos.chandras@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6502/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-02-04MIPS: Alchemy: Fix DB1100 GPIO registrationManuel Lauss
With CONFIG_GPIOLIB=y gpios need to be requested before they can be modified. Request the SD carddetect pins, and drop the SPI direction setup, as the driver does that for us anyway. This gets rid of a lot of WARN_ON()s triggered by GPIO core, and restores functionality of the touschreen controller. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/6497/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-01-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "The most notable new addition inside this pull request is the support for MIPS's latest and greatest core called "inter/proAptiv". The patch series describes this core as follows. "The interAptiv is a power-efficient multi-core microprocessor for use in system-on-chip (SoC) applications. The interAptiv combines a multi-threading pipeline with a coherence manager to deliver improved computational throughput and power efficiency. The interAptiv can contain one to four MIPS32R3 interAptiv cores, system level coherence manager with L2 cache, optional coherent I/O port, and optional floating point unit." The platform specific patches touch all 3 Broadcom families. It adds support for the new Broadcom/Netlogix XLP9xx Soc, building a common BCM63XX SMP kernel for all BCM63XX SoCs regardless of core type/count and full gpio button/led descriptions for BCM47xx. The rest of the series are cleanups and bug fixes that are MIPS generic and consist largely of changes that Imgtec/MIPS had published in their linux-mti-3.10.git stable tree. Random other cleanups and patches preparing code to be merged in 3.15" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) mips: select ARCH_MIGHT_HAVE_PC_SERIO mips: delete non-required instances of include <linux/init.h> MIPS: KVM: remove shadow_tlb code MIPS: KVM: use common EHINV aware UNIQUE_ENTRYHI mips/ide: flush dcache also if icache does not snoop dcache MIPS: BCM47XX: fix position of cpu_wait disabling MIPS: BCM63XX: select correct MIPS_L1_CACHE_SHIFT value MIPS: update MIPS_L1_CACHE_SHIFT based on MIPS_L1_CACHE_SHIFT_<N> MIPS: introduce MIPS_L1_CACHE_SHIFT_<N> MIPS: ZBOOT: gather string functions into string.c arch/mips/pci: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource bcma: gpio: don't cast u32 to unsigned long ssb: gpio: add own IRQ domain MIPS: BCM47XX: fix sparse warnings in board.c MIPS: BCM47XX: add board detection for Linksys WRT54GS V1 MIPS: BCM47XX: fix detection for some boards MIPS: BCM47XX: Enable buttons support on SSB MIPS: BCM47XX: Convert WNDR4500 to new syntax MIPS: BCM47XX: Use "timer" trigger for status LEDs ...
