path: root/arch/mn10300/boot
2010-10-27MN10300: And Panasonic AM34 subarch and implement SMPAkira Takeuchi
Implement the Panasonic MN10300 AM34 CPU subarch and implement SMP support for MN10300. Also implement support for the MN2WS0060 processor and the ASB2364 evaluation board which are AM34 based. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-10-27MN10300: Make the boot wrapper able to use writeback cachingAkira Takeuchi
Make the boot wrapper able to use writeback caching, including flushing the cache before jumping to the main kernel. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: Kiyoshi Owada <owada.kiyoshi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com>
2010-08-12MN10300: Don't try and #include <linux/slab.h> in lib/inflate.c from bootloaderDavid Howells
Don't try and #include <linux/slab.h> in lib/inflate.c from the bootloader code as linux/slab.h hauls in function defs that aren't available in the bootloader code and may also haul in conflicting functions. To fix this, make the inclusion of linux/slab.h contingent on NO_INFLATE_MALLOC as are the usages of kmalloc() and kfree(). In MN10300, this causes the following errors: In file included from include/linux/string.h:21, from include/linux/bitmap.h:8, from include/linux/nodemask.h:93, from include/linux/mmzone.h:16, from include/linux/gfp.h:4, from include/linux/slab.h:12, from arch/mn10300/boot/compressed/../../../../lib/inflate.c:106, from arch/mn10300/boot/compressed/misc.c:170: /warthog/am33/linux-2.6-mn10300/arch/mn10300/include/asm/string.h:19: error: conflicting types for 'memset' arch/mn10300/boot/compressed/misc.c:59: error: previous definition of 'memset' was here Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25inflate: refactor inflate malloc codeThomas Petazzoni
Inflate requires some dynamic memory allocation very early in the boot process and this is provided with a set of four functions: malloc/free/gzip_mark/gzip_release. The old inflate code used a mark/release strategy rather than implement free. This new version instead keeps a count on the number of outstanding allocations and when it hits zero, it resets the malloc arena. This allows removing all the mark and release implementations and unifying all the malloc/free implementations. The architecture-dependent code must define two addresses: - free_mem_ptr, the address of the beginning of the area in which allocations should be made - free_mem_end_ptr, the address of the end of the area in which allocations should be made. If set to 0, then no check is made on the number of allocations, it just grows as much as needed The architecture-dependent code can also provide an arch_decomp_wdog() function call. This function will be called several times during the decompression process, and allow to notify the watchdog that the system is still running. If an architecture provides such a call, then it must define ARCH_HAS_DECOMP_WDOG so that the generic inflate code calls arch_decomp_wdog(). Work initially done by Matt Mackall, updated to a recent version of the kernel and improved by me. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <mikael.starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13mn10300: replace deprecated "TOPDIR" with newer "srctree"Robert P. J. Day
This would appear to be the last reference to TOPDIR in the entire tree, after which i'm guessing that variable can be dropped. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
