path: root/arch/mn10300/kernel/setup.c
2009-04-15MN10300: Discard duplicate PFN_xxx() macrosDavid Howells
Discard duplicate PFN_xxx() macros from arch code as they're now in the general headers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10Separate out the proc- and unit-specific header directories from the generalDavid Howells
MN10300 arch headers and place them instead in the same directories as contain the .c files for the processor and unit implementations. This permits the symlinks include/asm/proc and include/asm/unit to be dispensed with. This does, however, require that #include <asm/proc/xxx.h> be converted to #include <proc/xxx.h> and similarly for asm/unit -> unit. Signed-off-by: David Howells <dhowells@redhat.com>
2008-12-10MN10300: Give correct size when reserving interrupt vector tableAkira Takeuchi
Give the correct size when reserving the interrupt vector table. It should be a page not a single byte. Signed-off-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-16MN10300: Kill linux/a.out.h inclusionsDavid Howells
Kill linux/a.out.h inclusions in the MN10300 arch code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mn10300: add the MN10300/AM33 architecture to the kernelDavid Howells
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the kernel. This patch also adds board support for the ASB2303 with the ASB2308 daughter board, and the ASB2305. The only processor supported is the MN103E010, which is an AM33v2 core plus on-chip devices. [akpm@linux-foundation.org: nuke cvs control strings] Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com> Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
