[ Upstream commit ae7cc577ec2a4a6151c9e928fd1f595d953ecef1 ]
Cc: stable@vger.kernel.org
[ Upstream commit 43403eabf558d2800b429cd886e996fd555aa542 ]
commit c86576ea114a9a881cf7328dc7181052070ca311 upstream.
mn10300 builds fail with
fs/stat.c: In function 'cp_old_stat':
fs/stat.c:163:2: error: 'old_uid_t' undeclared
ipc/util.c: In function 'ipc64_perm_to_ipc_perm':
ipc/util.c:540:2: error: 'old_uid_t' undeclared
Select CONFIG_HAVE_UID16 and remove local definition of CONFIG_UID16
to fix the problem.
Fixes: fbc416ff8618 ("arm64: fix building without CONFIG_UID16")
Acked-by: Acked-by: David Howells <dhowells@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull second batch of devicetree updates from Rob Herring:
"As Grant mentioned in the first devicetree pull request, here is the
2nd batch of DT changes for 4.1. The main remaining item here is the
endianness bindings and related 8250 driver support.
- DT endianness specification bindings
- big-endian 8250 serial support
- DT overlay unittest updates
- various DT doc updates
- compile fixes for OF_IRQ=n"
* tag 'devicetree-for-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
frv: add io{read,write}{16,32}be functions
mn10300: add io{read,write}{16,32}be functions
Documentation: DT bindings: add doc for Altera's SoCFPGA platform
of: base: improve of_get_next_child() kernel-doc
Doc: dt: arch_timer: discourage clock-frequency use
of: unittest: overlay: Keep track of created overlays
of/fdt: fix allocation size for device node path
serial: of_serial: Support big-endian register accesses
serial: 8250: Add support for big-endian MMIO accesses
of: Document {little,big,native}-endian bindings
of/fdt: Add endianness helper function for early init code
of: Add helper function to check MMIO register endianness
of/fdt: Remove "reg" data prints from early_init_dt_scan_memory
of: add vendor prefix for Artesyn
of: Add dummy of_irq_to_resource_table() for IRQ_OF=n
of: OF_IRQ should depend on IRQ_DOMAIN
These functions are used in various drivers, including the latest
version of the 8250 driver. The latter causes the following build failure.
drivers/tty/serial/8250/8250_core.c: In function 'mem32be_serial_out':
drivers/tty/serial/8250/8250_core.c:456:2: error:
implicit declaration of function 'iowrite32be'
drivers/tty/serial/8250/8250_core.c: In function 'mem32be_serial_in':
drivers/tty/serial/8250/8250_core.c:462:2: error:
implicit declaration of function 'ioread32be'
Cc: Kevin Cernekee <cernekee@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Fixes: c627f2ceb692 ("serial: 8250: Add support for big-endian MMIO
accesses")
Signed-off-by: Rob Herring <robh@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
As execution domain support is gone we can remove
signal translation from the signal code and remove
exec_domain from thread_info.
Signed-off-by: Richard Weinberger <richard@nod.at>
* pci/enumeration:
PCI: Cleanup control flow
sparc/PCI: Claim bus resources before pci_bus_add_devices()
PCI: Assign resources before drivers claim devices (pci_scan_root_bus())
PCI: Assign resources before drivers claim devices (pci_scan_bus())
* pci/virtualization:
PCI: Add ACS quirks for Intel 1G NICs
Previously, pci_scan_root_bus() created a root PCI bus, enumerated the
devices on it, and called pci_bus_add_devices(), which made the devices
available for drivers to claim them.
Most callers assigned resources to devices after pci_scan_root_bus()
returns, which may be after drivers have claimed the devices. This is
incorrect; the PCI core should not change device resources while a driver
is managing the device.
Remove pci_bus_add_devices() from pci_scan_root_bus() and do it after any
resource assignment in the callers.
Note that ARM's pci_common_init_dev() already called pci_bus_add_devices()
after pci_scan_root_bus(), so we only need to remove the first call:
pci_common_init_dev
pcibios_init_hw
pci_scan_root_bus
pci_bus_add_devices # first call
pci_bus_assign_resources
pci_bus_add_devices # second call
[bhelgaas: changelog, drop "root_bus" var in alpha common_init_pci(),
return failure earlier in mn10300, add "return" in x86 pcibios_scan_root(),
return early if xtensa platform_pcibios_fixup() fails]
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Richard Henderson <rth@twiddle.net>
CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
CC: Matt Turner <mattst88@gmail.com>
CC: David Howells <dhowells@redhat.com>
CC: Tony Luck <tony.luck@intel.com>
CC: Michal Simek <monstr@monstr.eu>
CC: Ralf Baechle <ralf@linux-mips.org>
CC: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
CC: Sebastian Ott <sebott@linux.vnet.ibm.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Chris Metcalf <cmetcalf@ezchip.com>
CC: Chris Zankel <chris@zankel.net>
CC: Max Filippov <jcmvbkbc@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded. Usually, these defines are provided by
<asm-generic/pgtable-nopmd.h> and <asm-generic/pgtable-nopud.h>.
But some architectures fold page table levels in a custom way. They
need to define these macros themself. This patch adds missing defines.
The patch fixes mm->nr_pmds underflow and eliminates dead __pmd_alloc()
and __pud_alloc() on architectures without these page table levels.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"OK, this has the big virtio 1.0 implementation, as specified by OASIS.
On top of tht is the major rework of lguest, to use PCI and virtio
1.0, to double-check the implementation.
Then comes the inevitable fixes and cleanups from that work"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (80 commits)
virtio: don't set VIRTIO_CONFIG_S_DRIVER_OK twice.
virtio_net: unconditionally define struct virtio_net_hdr_v1.
tools/lguest: don't use legacy definitions for net device in example launcher.
virtio: Don't expose legacy net features when VIRTIO_NET_NO_LEGACY defined.
tools/lguest: use common error macros in the example launcher.
tools/lguest: give virtqueues names for better error messages
tools/lguest: more documentation and checking of virtio 1.0 compliance.
lguest: don't look in console features to find emerg_wr.
tools/lguest: don't start devices until DRIVER_OK status set.
tools/lguest: handle indirect partway through chain.
tools/lguest: insert driver references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: insert device references from the 1.0 spec (4.1 Virtio Over PCI)
tools/lguest: rename virtio_pci_cfg_cap field to match spec.
tools/lguest: fix features_accepted logic in example launcher.
tools/lguest: handle device reset correctly in example launcher.
virtual: Documentation: simplify and generalize paravirt_ops.txt
lguest: remove NOTIFY call and eventfd facility.
lguest: remove NOTIFY facility from demonstration launcher.
lguest: use the PCI console device's emerg_wr for early boot messages.
lguest: always put console in PCI slot #1.
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
Merge misc updates from Andrew Morton:
"Bite-sized chunks this time, to avoid the MTA ratelimiting woes.
- fs/notify updates
- ocfs2
- some of MM"
That laconic "some MM" is mainly the removal of remap_file_pages(),
which is a big simplification of the VM, and which gets rid of a *lot*
of random cruft and special cases because we no longer support the
non-linear mappings that it used.
From a user interface perspective, nothing has changed, because the
remap_file_pages() syscall still exists, it's just done by emulating the
old behavior by creating a lot of individual small mappings instead of
one non-linear one.
The emulation is slower than the old "native" non-linear mappings, but
nobody really uses or cares about remap_file_pages(), and simplifying
the VM is a big advantage.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (78 commits)
memcg: zap memcg_slab_caches and memcg_slab_mutex
memcg: zap memcg_name argument of memcg_create_kmem_cache
memcg: zap __memcg_{charge,uncharge}_slab
mm/page_alloc.c: place zone_id check before VM_BUG_ON_PAGE check
mm: hugetlb: fix type of hugetlb_treat_as_movable variable
mm, hugetlb: remove unnecessary lower bound on sysctl handlers"?
mm: memory: merge shared-writable dirtying branches in do_wp_page()
mm: memory: remove ->vm_file check on shared writable vmas
xtensa: drop _PAGE_FILE and pte_file()-related helpers
x86: drop _PAGE_FILE and pte_file()-related helpers
unicore32: drop pte_file()-related helpers
um: drop _PAGE_FILE and pte_file()-related helpers
tile: drop pte_file()-related helpers
sparc: drop pte_file()-related helpers
sh: drop _PAGE_FILE and pte_file()-related helpers
score: drop _PAGE_FILE and pte_file()-related helpers
s390: drop pte_file()-related helpers
parisc: drop _PAGE_FILE and pte_file()-related helpers
openrisc: drop _PAGE_FILE and pte_file()-related helpers
nios2: drop _PAGE_FILE and pte_file()-related helpers
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Move domain assignment from arm64 to generic code (Lorenzo Pieralisi)
- ARM: Remove artificial dependency on pci_sys_data domain (Lorenzo Pieralisi)
- ARM: Move to generic PCI domains (Lorenzo Pieralisi)
- Generate uppercase hex for modalias var in uevent (Ricardo Ribalda Delgado)
- Add and use generic config accessors on ARM, PowerPC (Rob Herring)
Resource management
- Free resources on failure in of_pci_get_host_bridge_resources() (Lorenzo Pieralisi)
- Fix infinite loop with ROM image of size 0 (Michel Dänzer)
PCI device hotplug
- Handle surprise add even if surprise removal isn't supported (Bjorn Helgaas)
Virtualization
- Mark AMD/ATI VGA devices that don't reset on D3hot->D0 transition (Alex Williamson)
- Add DMA alias quirk for Adaptec 3405 (Alex Williamson)
- Add Wellsburg (X99) to Intel PCH root port ACS quirk (Alex Williamson)
- Add ACS quirk for Emulex NICs (Vasundhara Volam)
MSI
- Fail MSI-X mappings if there's no space assigned to MSI-X BAR (Yijing Wang)
Freescale Layerscape host bridge driver
- Fix platform_no_drv_owner.cocci warnings (Julia Lawall)
NVIDIA Tegra host bridge driver
- Remove unnecessary tegra_pcie_fixup_bridge() (Lucas Stach)
Renesas R-Car host bridge driver
- Fix error handling of irq_of_parse_and_map() (Dmitry Torokhov)
TI Keystone host bridge driver
- Fix misspelling of current function in debug output (Julia Lawall)
Xilinx AXI host bridge driver
- Fix harmless format string warning (Arnd Bergmann)
Miscellaneous
- Use standard parsing functions for ASPM sysfs setters (Chris J Arges)
- Add pci_device_to_OF_node() stub for !CONFIG_OF (Kevin Hao)
- Delete unnecessary NULL pointer checks (Markus Elfring)
- Add and use defines for PCIe Max_Read_Request_Size (Rafał Miłecki)
- Include clk.h instead of clk-private.h (Stephen Boyd)"
* tag 'pci-v3.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits)
PCI: Add pci_device_to_OF_node() stub for !CONFIG_OF
PCI: xilinx: Convert to use generic config accessors
PCI: xgene: Convert to use generic config accessors
PCI: tegra: Convert to use generic config accessors
PCI: rcar: Convert to use generic config accessors
PCI: generic: Convert to use generic config accessors
powerpc/powermac: Convert PCI to use generic config accessors
powerpc/fsl_pci: Convert PCI to use generic config accessors
ARM: ks8695: Convert PCI to use generic config accessors
ARM: sa1100: Convert PCI to use generic config accessors
ARM: integrator: Convert PCI to use generic config accessors
PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver
ARM: dts: versatile: add PCI controller binding
of/pci: Free resources on failure in of_pci_get_host_bridge_resources()
PCI: versatile: Add DT docs for ARM Versatile PB PCIe driver
PCI: Fail MSI-X mappings if there's no space assigned to MSI-X BAR
r8169: use PCI define for Max_Read_Request_Size
[SCSI] esas2r: use PCI define for Max_Read_Request_Size
tile: use PCI define for Max_Read_Request_Size
rapidio/tsi721: use PCI define for Max_Read_Request_Size
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
This patch also increases the number of bits availble for swap offset.
Kim Phillips reported following build failure.
LD init/built-in.o
mm/built-in.o: In function `free_pages_prepare':
mm/page_alloc.c:770: undefined reference to `.kernel_map_pages'
mm/built-in.o: In function `prep_new_page':
mm/page_alloc.c:933: undefined reference to `.kernel_map_pages'
mm/built-in.o: In function `map_pages':
mm/compaction.c:61: undefined reference to `.kernel_map_pages'
make: *** [vmlinux] Error 1
Reason for this problem is that commit 031bc5743f15
("mm/debug-pagealloc: make debug-pagealloc boottime configurable")
forgot to remove the old declaration of kernel_map_pages() for some
architectures. This patch removes them to fix build failure.
Reported-by: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Some instances of pci_ops initialization rely on the read/write members'
location in the struct. This is fragile and may break when adding new
members to the beginning of the struct.
No functional change.
CC: linux-am33-list@redhat.com
pci-iomap.c was (apparently, mistakenly) reintroduced as part of
commit 83c2dc15ce824450e7044b9f90cd529c25747ae0
MN10300: Handle cacheable PCI regions in pci_iomap()
probably as side-effect of forward-porting the patch
from an old kernel.
It's not really needed: the generic pci_iomap does the right thing here.
The new file isn't compiled so it's safe to drop.
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: linux-pci@vger.kernel.org
Cc: trivial@kernel.org
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Every PCI-PCI bridge window should fit inside an upstream bridge window
because orphaned address space is unreachable from the primary side of the
upstream bridge. If we inherit invalid bridge windows that overlap an
upstream window from firmware, clip them to fit and update the bridge
accordingly.
[bhelgaas: changelog]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=85491
Reported-by: Marek Kordik <kordikmarek@gmail.com>
Fixes: 5b28541552ef ("PCI: Restrict 64-bit prefetchable bridge windows to 64-bit resources")
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
introduce new setsockopt() command:
setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd))
where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...)
and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER
setsockopt() calls bpf_prog_get() which increments refcnt of the program,
so it doesn't get unloaded while socket is using the program.
The same eBPF program can be attached to multiple sockets.
User task exit automatically closes socket which calls sk_filter_uncharge()
which decrements refcnt of eBPF program
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
write{b,w,l}_relaxed are implemented by some architectures in order to
permit memory-mapped I/O accesses with weaker barrier semantics than the
non-relaxed variants.
This patch adds dummy macros for the write accessors to mn10300, in the
same vein as the dummy definitions for the relaxed read accessors.
Pull arch atomic cleanups from Ingo Molnar:
"This is a series kept separate from the main locking tree, which
cleans up and improves various details in the atomics type handling:
- Remove the unused atomic_or_long() method
- Consolidate and compress atomic ops implementations between
architectures, to reduce linecount and to make it easier to add new
ops.
- Rewrite generic atomic support to only require cmpxchg() from an
architecture - generate all other methods from that"
* 'locking-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
locking,arch: Use ACCESS_ONCE() instead of cast to volatile in atomic_read()
locking, mips: Fix atomics
locking, sparc64: Fix atomics
locking,arch: Rewrite generic atomic support
locking,arch,xtensa: Fold atomic_ops
locking,arch,sparc: Fold atomic_ops
locking,arch,sh: Fold atomic_ops
locking,arch,powerpc: Fold atomic_ops
locking,arch,parisc: Fold atomic_ops
locking,arch,mn10300: Fold atomic_ops
locking,arch,mips: Fold atomic_ops
locking,arch,metag: Fold atomic_ops
locking,arch,m68k: Fold atomic_ops
locking,arch,m32r: Fold atomic_ops
locking,arch,ia64: Fold atomic_ops
locking,arch,hexagon: Fold atomic_ops
locking,arch,cris: Fold atomic_ops
locking,arch,avr32: Fold atomic_ops
locking,arch,arm64: Fold atomic_ops
locking,arch,arm: Fold atomic_ops
Pull timer fixes from Ingo Molnar:
"Main changes:
- Fix the deadlock reported by Dave Jones et al
- Clean up and fix nohz_full interaction with arch abilities
- nohz init code consolidation/cleanup"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
nohz: nohz full depends on irq work self IPI support
nohz: Consolidate nohz full init code
arm64: Tell irq work about self IPI support
arm: Tell irq work about self IPI support
x86: Tell irq work about self IPI support
irq_work: Force raised irq work to run on irq work interrupt
irq_work: Introduce arch_irq_work_has_interrupt()
nohz: Move nohz full init call to tick init
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
The symbol is an orphan, get rid of it.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The nohz full code needs irq work to trigger its own interrupt so that
the subsystem can work even when the tick is stopped.
Lets introduce arch_irq_work_has_interrupt() that archs can override to
tell about their support for this ability.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Many of the atomic op implementations are the same except for one
instruction; fold the lot into a few CPP macros and reduce LoC.
This also prepares for easy addition of new ops.
Cc: linux-am33-list@redhat.com
Link: http://lkml.kernel.org/r/20140508135852.605324173@infradead.org
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
There's no need to have an architecture version of scatterlist.h if the
only thing the file does is include asm-generic/scatterlist.h. Switch to
the asm-generic versions directly.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Cc: Chen Liqin <liqin.linux@gmail.com>,
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Use sigsp() instead of the open coded variant.
Use the more generic functions get_signal() signal_setup_done()
for signal delivery.
The arch_mutex_cpu_relax() function, introduced by 34b133f, is
hacky and ugly. It was added a few years ago to address the fact
that common cpu_relax() calls include yielding on s390, and thus
impact the optimistic spinning functionality of mutexes. Nowadays
we use this function well beyond mutexes: rwsem, qrwlock, mcs and
lockref. Since the macro that defines the call is in the mutex header,
any users must include mutex.h and the naming is misleading as well.
This patch (i) renames the call to cpu_relax_lowlatency ("relax, but
only if you can do it with very low latency") and (ii) defines it in
each arch's asm/processor.h local header, just like for regular cpu_relax
functions. On all archs, except s390, cpu_relax_lowlatency is simply cpu_relax,
and thus we can take it out of mutex.h. While this can seem redundant,
I believe it is a good choice as it allows us to move out arch specific
logic from generic locking primitives and enables future(?) archs to
transparently define it, similarly to System Z.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Cc: Bharat Bhushan <r65777@freescale.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Cc: Dominik Dingel <dingel@linux.vnet.ibm.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Joe Perches <joe@perches.com>
Cc: Joseph Myers <joseph@codesourcery.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Qais Yousef <qais.yousef@imgtec.com>
Cc: Qiaowei Ren <qiaowei.ren@intel.com>
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Stratos Karafotis <stratosk@semaphore.gr>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Vasily Kulikov <segoon@openwall.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wolfram Sang <wsa@the-dreams.de>
Cc: adi-buildroot-devel@lists.sourceforge.net
Cc: linux390@de.ibm.com
Cc: linux-alpha@vger.kernel.org
Cc: linux-c6x-dev@linux-c6x.org
Cc: linux-cris-kernel@axis.com
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux@lists.openrisc.net
Cc: linux-m32r-ja@ml.linux-m32r.org
Cc: linux-m32r@ml.linux-m32r.org
Cc: linux-m68k@lists.linux-m68k.org
Cc: linux-metag@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-parisc@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/1404079773.2619.4.camel@buesod1.americas.hpqcorp.net
sys_sgetmask and sys_ssetmask are obsolete system calls no longer
supported in libc.
This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert
mode configuration.That option is enabled by default for those
architectures.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Greg Ungerer <gerg@uclinux.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull core locking updates from Ingo Molnar:
"The main changes in this cycle were:
- reduced/streamlined smp_mb__*() interface that allows more usecases
and makes the existing ones less buggy, especially in rarer
architectures
- add rwsem implementation comments
- bump up lockdep limits"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (33 commits)
rwsem: Add comments to explain the meaning of the rwsem's count field
lockdep: Increase static allocations
arch: Mass conversion of smp_mb__*()
arch,doc: Convert smp_mb__*()
arch,xtensa: Convert smp_mb__*()
arch,x86: Convert smp_mb__*()
arch,tile: Convert smp_mb__*()
arch,sparc: Convert smp_mb__*()
arch,sh: Convert smp_mb__*()
arch,score: Convert smp_mb__*()
arch,s390: Convert smp_mb__*()
arch,powerpc: Convert smp_mb__*()
arch,parisc: Convert smp_mb__*()
arch,openrisc: Convert smp_mb__*()
arch,mn10300: Convert smp_mb__*()
arch,mips: Convert smp_mb__*()
arch,metag: Convert smp_mb__*()
arch,m68k: Convert smp_mb__*()
arch,m32r: Convert smp_mb__*()
arch,ia64: Convert smp_mb__*()
pcibios_penalize_isa_irq() is only implemented by x86 now, and legacy ISA
is not used by some architectures. Make pcibios_penalize_isa_irq() a
__weak function to simplify the code. This removes the need for new
platforms to add stub implementations of pcibios_penalize_isa_irq().
[bhelgaas: changelog, comments]
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
mn10300 fully relies on asm-generic/barrier.h and therefore its
smp_mb() is barrier(). We can use the default implementation.
Link: http://lkml.kernel.org/n/tip-wotyeoj99h1dpojjeest2jbk@git.kernel.org
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull irq code updates from Thomas Gleixner:
"The irq department proudly presents:
- Another tree wide sweep of irq infrastructure abuse. Clear winner
of the trainwreck engineering contest was:
#include "../../../kernel/irq/settings.h"
- Tree wide update of irq_set_affinity() callbacks which miss a cpu
online check when picking a single cpu out of the affinity mask.
- Tree wide consolidation of interrupt statistics.
- Updates to the threaded interrupt infrastructure to allow explicit
wakeup of the interrupt thread and a variant of synchronize_irq()
which synchronizes only the hard interrupt handler. Both are
needed to replace the homebrewn thread handling in the mmc/sdhci
code.
- New irq chip callbacks to allow proper support for GPIO based irqs.
The GPIO based interrupts need to request/release GPIO resources
from request/free_irq.
- A few new ARM interrupt chips. No revolutionary new hardware, just
differently wreckaged variations of the scheme.
- Small improvments, cleanups and updates all over the place"
I was hoping that that trainwreck engineering contest was a April Fools'
joke. But no.
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits)
irqchip: sun7i/sun6i: Disable NMI before registering the handler
ARM: sun7i/sun6i: dts: Fix IRQ number for sun6i NMI controller
ARM: sun7i/sun6i: irqchip: Update the documentation
ARM: sun7i/sun6i: dts: Add NMI irqchip support
ARM: sun7i/sun6i: irqchip: Add irqchip driver for NMI controller
genirq: Export symbol no_action()
arm: omap: Fix typo in ams-delta-fiq.c
m68k: atari: Fix the last kernel_stat.h fallout
irqchip: sun4i: Simplify sun4i_irq_ack
irqchip: sun4i: Use handle_fasteoi_irq for all interrupts
genirq: procfs: Make smp_affinity values go+r
softirq: Add linux/irq.h to make it compile again
m68k: amiga: Add linux/irq.h to make it compile again
irqchip: sun4i: Don't ack IRQs > 0, fix acking of IRQ 0
irqchip: sun4i: Fix a comment about mask register initialization
irqchip: sun4i: Fix irq 0 not working
genirq: Add a new IRQCHIP_EOI_THREADED flag
genirq: Document IRQCHIP_ONESHOT_SAFE flag
ARM: sunxi: dt: Convert to the new irq controller compatibles
irqchip: sunxi: Change compatibles
Many architectures have a stub cputime.h that only include the default
cputime.h
Lets remove the useless headers, we only need to mention that we want
the default headers on the Kbuild files.
Cc: Archs <linux-arch@vger.kernel.org>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
This patch removes the IRQF_DISABLED flag from mn10300 architecture
code. It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Cc: srivatsa.bhat@linux.vnet.ibm.com
Cc: dhowells@redhat.com
Cc: yasutake.koichi@jp.panasonic.com
Link: http://lkml.kernel.org/r/1393965111-17092-1-git-send-email-michael.opdenacker@free-electrons.com
Let the core do the irq_desc resolution.
Cc: mn10300 <linux-am33-list@redhat.com>
Link: http://lkml.kernel.org/r/20140223212737.751487689@linutronix.de
This patch allows each architecture to add its specific assembly optimized
arch_mcs_spin_lock_contended and arch_mcs_spinlock_uncontended for
MCS lock and unlock functions.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Scott J Norton <scott.norton@hp.com>
Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: AswinChandramouleeswaran <aswin@hp.com>
Cc: George Spelvin <linux@horizon.com>
Cc: Rik vanRiel <riel@redhat.com>
Cc: MichelLespinasse <walken@google.com>
Cc: Peter Hurley <peter@hurleysoftware.com>
Cc: Alex Shi <alex.shi@linaro.org>
Cc: "Figo.zhang" <figo1802@gmail.com>
Cc: "Paul E.McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: Matthew R Wilcox <matthew.r.wilcox@intel.com>
Link: http://lkml.kernel.org/r/1390347382.3138.67.camel@schen9-DESK
alphabetical order
We perform a clean up of the Kbuid files in each architecture.
We order the files in each Kbuild in alphabetical order
by running the below script.
for i in arch/*/include/asm/Kbuild
do
cat $i | gawk '/^generic-y/ {
i = 3;
do {
for (; i <= NF; i++) {
if ($i == "\\") {
getline;
i = 1;
continue;
if ($i != "")
hdr[$i] = $i;
break;
} while (1);
next;
print $0;
END {
n = asort(hdr);
for (i = 1; i <= n; i++)
print "generic-y += " hdr[i];
}' > ${i}.sorted;
mv ${i}.sorted $i;
done
[ Fixed build bug. ]
