path: root/arch/mn10300
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12dma-mapping: mn10300: remove the obsolete and unnecessary DMA API commentsFUJITA Tomonori
pci_dma_sync_single was obsoleted long ago. All the comments are generic, not architecture specific, simply describes some of the DMA-API (and the same comments are in other files). Documentation/DMA-API.txt have more detailed descriptions. This removes the above obsolete and unnecessary DMA API comments. Let's describe the DMA API in only Documentation/DMA-API.txt. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12ptrace: move user_enable_single_step & co prototypes to linux/ptrace.hChristoph Hellwig
While in theory user_enable_single_step/user_disable_single_step/ user_enable_blockstep could also be provided as an inline or macro there's no good reason to do so, and having the prototype in one places keeps code size and confusion down. Roland said: The original thought there was that user_enable_single_step() et al might well be only an instruction or three on a sane machine (as if we have any of those!), and since there is only one call site inlining would be beneficial. But I agree that there is no strong reason to care about inlining it. As to the arch changes, there is only one thought I'd add to the record. It was always my thinking that for an arch where PTRACE_SINGLESTEP does text-modifying breakpoint insertion, user_enable_single_step() should not be provided. That is, arch_has_single_step()=>true means that there is an arch facility with "pure" semantics that does not have any unexpected side effects. Inserting a breakpoint might do very unexpected strange things in multi-threaded situations. Aside from that, it is a peculiar side effect that user_{enable,disable}_single_step() should cause COW de-sharing of text pages and so forth. For PTRACE_SINGLESTEP, all these peculiarities are the status quo ante for that arch, so having arch_ptrace() itself do those is one thing. But for building other things in the future, it is nicer to have a uniform "pure" semantics that arch-independent code can expect. OTOH, all such arch issues are really up to the arch maintainer. As of today, there is nothing but ptrace using user_enable_single_step() et al so it's a distinction without a practical difference. If/when there are other facilities that use user_enable_single_step() and might care, the affected arch's can revisit the question when someone cares about the quality of the arch support for said new facility. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_ipc wrapperChristoph Hellwig
Add a generic implementation of the ipc demultiplexer syscall. Except for s390 and sparc64 all implementations of the sys_ipc are nearly identical. There are slight differences in the types of the parameters, where mips and powerpc as the only 64-bit architectures with sys_ipc use unsigned long for the "third" argument as it gets casted to a pointer later, while it traditionally is an "int" like most other paramters. frv goes even further and uses unsigned long for all parameters execept for "ptr" which is a pointer type everywhere. The change from int to unsigned long for "third" and back to "int" for the others on frv should be fine due to the in-register calling conventions for syscalls (we already had a similar issue with the generic sys_ptrace), but I'd prefer to have the arch maintainers looks over this in details. Except for that h8300, m68k and m68knommu lack an impplementation of the semtimedop sub call which this patch adds, and various architectures have gets used - at least on i386 it seems superflous as the compat code on x86-64 and ia64 doesn't even bother to implement it. [akpm@linux-foundation.org: add sys_ipc to sys_ni.c] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-23PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refsBjorn Helgaas
No functional change; this converts loops that iterate from 0 to PCI_BUS_NUM_RESOURCES through pci_bus resource[] table to use the pci_bus_for_each_resource() iterator instead. This doesn't change the way resources are stored; it merely removes dependencies on the fact that they're in a table. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: mark struct resource as constDominik Brodowski
Now that we return the new resource start position, there is no need to update "struct resource" inside the align function. Therefore, mark the struct resource as const. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: align functions now return start of resourceDominik Brodowski
As suggested by Linus, align functions should return the start of a resource, not void. An update of "res->start" is no longer necessary. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-20MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itselfRussell King
On VIVT ARM, when we have multiple shared mappings of the same file in the same MM, we need to ensure that we have coherency across all copies. We do this via make_coherent() by making the pages uncacheable. This used to work fine, until we allowed highmem with highpte - we now have a page table which is mapped as required, and is not available for modification via update_mmu_cache(). Ralf Beache suggested getting rid of the PTE value passed to update_mmu_cache(): On MIPS update_mmu_cache() calls __update_tlb() which walks pagetables to construct a pointer to the pte again. Passing a pte_t * is much more elegant. Maybe we might even replace the pte argument with the pte_t? Ben Herrenschmidt would also like the pte pointer for PowerPC: Passing the ptep in there is exactly what I want. I want that -instead- of the PTE value, because I have issue on some ppc cases, for I$/D$ coherency, where set_pte_at() may decide to mask out the _PAGE_EXEC. So, pass in the mapped page table pointer into update_mmu_cache(), and remove the PTE value, updating all implementations and call sites to suit. Includes a fix from Stephen Rothwell: sparc: fix fallout from update_mmu_cache API change Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-11mn10300: update the ASB2303 defconfigDavid Howells
Update the defconfig for the ASB2303 platform. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: make the ASB2305's PCnet32 NIC work by using the PCI bridge's SRAMDavid Howells
Access to the ASB2305's PCnet32 NIC doesn't work correctly because when the NIC attempts to update the ring buffer flags by DMA, the change to RAM crops up about 17uS after the interrupt line is asserted. This is almost certainly due to a bug in the PCI bridge FPGA on that board. We can get around this by making dma_alloc_coherent() put the ring buffer in the SRAM attached to the PCI bridge rather than in the SDRAM. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: insert PCI root bus resources for the ASB2305 devel motherboardDavid Howells
Insert PCI root bus resources for the MN10300-based ASB2305 development kit motherboard. This is required because the CPU's window onto the PCI bus address space is considerably smaller than the CPU's full address space and non-PCI devices lie outside of the PCI window that we might want to access. Without this patch, the PCI root bus uses the platform-level bus resources, and these are then confined to the PCI window, thus making platform_device_add() reject devices outside of this window. We also add a reservation for the PCI SRAM region. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: use generic pci_enable_resources()Bjorn Helgaas
Use the generic pci_enable_resources() instead of the arch-specific code. Unlike this arch-specific code, the generic version: - checks PCI_NUM_RESOURCES (11), not 6, resources - skips resources that have neither IORESOURCE_IO nor IORESOURCE_MEM set - skips ROM resources unless IORESOURCE_ROM_ENABLE is set - checks for resource collisions with "!r->parent" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: use KERN_ERR not KERN_ERRORDavid Howells
Use KERN_ERR not KERN_ERROR in the ASB2305 platform code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: fix several bogus includes on abs2305Al Viro
asm/cpu never existed for mn10300; the files they are looking for are in asm. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: wire up missing new syscallsDavid Howells
Wire up missing new system calls for MN10300. Signed-off-by: David Howells <dhowelsl@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: add cc clobbers to asm statementsMark Salter
gcc 4.2.1 for MN10300 is more agressive than the older gcc in reordering/moving other insns between an insn that sets flags and an insn that uses those flags. This leads to trouble with asm statements which are missing an explicit "cc" clobber. This patch adds the explicit "cc" clobber to asm statements which do indeed clobber the condition flags. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: objcopy flags fixMark Salter
The gcc-4.2.1 based toolchain for MN10300 adds some new note sections which need to be stripped from the binary image. This patch takes care of that. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mn10300: signal stack fixMark Salter
This fixes a signal stack handling problem in the MN10300 arch. When new threads are cloned with CLONE_VM, they don't inherit the alternate signal stack. They do share the signal flags, though. When deciding whether to use an alternate stack, the arch code needs to check to make sure the task struct contains a valid alternate stack. This patch fixes the MN10300 arch by using the sas_ss_flags() test provided by sched.h rather than the on_sig_stack() test which is insufficient by itself. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11mm: make totalhigh_pages unsigned longAndreas Fenkart
Makes it consistent with the extern declaration, used when CONFIG_HIGHMEM is set Removes redundant casts in printout messages Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-11arch_mmap_check() on mn10300Al Viro
2009-12-09Merge branch 'bkl-arch-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'bkl-arch-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mn10300: Remove the BKL from sys_execve m68knommu: Remove the BKL from sys_execve m68k: Remove the BKL from sys_execve h83000: Remove BKL from sys_execve frv: Remove the BKL from sys_execve blackfin: Remove the BKL from sys_execve um: Remove BKL from mmapper um: Remove BKL from random s390: Remove BKL from prng
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-29percpu: make misc percpu symbols uniqueTejun Heo
This patch updates misc percpu related symbols such that percpu symbols are unique and don't clash with local symbols. This serves two purposes of decreasing the possibility of global percpu symbol collision and allowing dropping per_cpu__ prefix from percpu symbols. * drivers/crypto/padlock-aes.c: s/last_cword/paes_last_cword/ * drivers/lguest/x86/core.c: s/last_cpu/lg_last_cpu/ * drivers/s390/net/netiucv.c: rename the variable used in a macro to avoid clashing with percpu symbol * arch/mn10300/kernel/kprobes.c: replace current_ prefix with cur_ for static variables. Please note that percpu symbol current_kprobe can't be changed as it's used by generic code. Partly based on Rusty Russell's "alloc_percpu: rename percpu vars which cause name clashes" patch. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: linux390@de.ibm.com
2009-10-14mn10300: Remove the BKL from sys_execveJohn Kacur
This looks like a cut-and-paste from functionality that no-longer needs the bkl Just remove it. Also, rewrite slightly so that it looks closer to sys_execve on other architectures. Signed-off-by: John Kacur <jkacur@redhat.com> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> LKML-Reference: <alpine.LFD.2.00.0910130016540.3658@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-01mn10300: fix kernel build failures when using gcc-4.xMark Salter
Fix some build failures when using gcc-4.x for MN10300. Firstly, __get_user() fails to build because the pointer points to a const and __gu_val ends up being read-only: In file included from include/linux/mempolicy.h:62, from init/main.c:50: include/linux/pagemap.h: In function 'fault_in_pages_readable': include/linux/pagemap.h:394: error: read-only variable '__gu_val' used as 'asm' output include/linux/pagemap.h:394: error: read-only variable '__gu_val' used as 'asm' output include/linux/pagemap.h:394: error: read-only variable '__gu_val' used as 'asm' output include/linux/pagemap.h:400: error: read-only variable '__gu_val' used as 'asm' output include/linux/pagemap.h:400: error: read-only variable '__gu_val' used as 'asm' output include/linux/pagemap.h:400: error: read-only variable '__gu_val' used as 'asm' output make[1]: *** [init/main.o] Error 1 Secondly, gcc-4 doesn't allow casts of lvalues: UPD include/linux/compile.h arch/mn10300/kernel/rtc.c: In function 'calibrate_clock': arch/mn10300/kernel/rtc.c:170: error: lvalue required as left operand of assignment arch/mn10300/kernel/rtc.c:172: error: lvalue required as left operand of assignment make[1]: *** [arch/mn10300/kernel/rtc.o] Error 1 These are seen with gcc 4.2.1. Signed-off-by: Mark Salter <msalter@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24mn10300: Clean up linker script using higher-level macros.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24cpumask: use mm_cpumask() wrapper: mn10300Rusty Russell
Makes code futureproof against the impending change to mm->cpu_vm_mask (to be a pointer). It's also a chance to use the new cpumask_ ops which take a pointer (the older ones are deprecated, but there's no hurry for arch code). Also change the actual arg name here to "mm" (which it is), not "task". Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits) Use macros for .data.page_aligned section. Use macros for .bss.page_aligned section. Use new __init_task_data macro in arch init_task.c files. kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts. arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0 kbuild: add static to prototypes kbuild: fail build if recordmcount.pl fails kbuild: set -fconserve-stack option for gcc 4.5 kbuild: echo the record_mcount command gconfig: disable "typeahead find" search in treeviews kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling checkincludes.pl: add option to remove duplicates in place markup_oops: use modinfo to avoid confusion with underscored module names checkincludes.pl: provide usage helper checkincludes.pl: close file as soon as we're done with it ctags: usability fix kernel hacking: move STRIP_ASM_SYMS from General gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma kbuild: Check if linker supports the -X option kbuild: introduce ld-option ... Fix trivial conflict in scripts/basic/fixdep.c
2009-09-23MN10300: Handle removal of struct uart_infoDavid Howells
Commit ebd2c8f6d2ec4012c267ecb95e72a57b8355a705 removed struct uart_info and commit bdc04e3174e18f475289fa8f4144f66686326b7e further moved delta_msr_wait. Fix up the MN10300 on-chip serial port drivers to comply with this. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23misc: remove redundant start_kernel prototypesRusty Russell
Impact: cleanup No need for redeclaration. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23seq_file: constify seq_operationsJames Morris
Make all seq_operations structs const, to help mitigate against revectoring user-triggerable function pointers. This is derived from the grsecurity patch, although generated from scratch because it's simpler than extracting the changes from there. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22mm: remove duplicate asm/mman.h filesArnd Bergmann
A number of architectures have identical asm/mman.h files so they can all be merged by using the new generic file. The remaining asm/mman.h files are substantially different from each other. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22mm: add MAP_HUGETLB for mmaping pseudo-anonymous huge page regionsArnd Bergmann
Add a flag for mmap that will be used to request a huge page region that will look like anonymous memory to user space. This is accomplished by using a file on the internal vfsmount. MAP_HUGETLB is a modifier of MAP_ANONYMOUS and so must be specified with it. The region will behave the same as a MAP_ANONYMOUS region using small pages. The patch also adds the MAP_STACK flag, which was previously defined only on some architectures but not on others. Since MAP_STACK is meant to be a hint only, architectures can define it without assigning a specific meaning to it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: David Rientjes <rientjes@google.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: fix typos "man[ae]g?ment" -> "management"Uwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21Use new __init_task_data macro in arch init_task.c files.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
