path: root/arch/parisc/include
2011-08-04Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] wire up sendmmsg syscall [PARISC] fix return type of __atomic64_add_return [PARISC] Fix futex support
2011-07-31[PARISC] wire up sendmmsg syscallJames Bottomley
Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-29[PARISC] fix return type of __atomic64_add_returnJohn David Anglin
The return type of __atomic64_add_return of should be s64 or long, not int. This fixes the atomic64 test failure that I previously reported. Signed-off-by: John David Anglin <dave.anglin@nrc-cnrc.gc.ca> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21treewide: fix potentially dangerous trailing ';' in #defined values/expressionsPhil Carmody
All these are instances of #define NAME value; or #define NAME(params_opt) value; These of course fail to build when used in contexts like if(foo $OP NAME) while(bar $OP NAME) and may silently generate the wrong code in contexts such as foo = NAME + 1; /* foo = value; + 1; */ bar = NAME - 1; /* bar = value; - 1; */ baz = NAME & quux; /* baz = value; & quux; */ Reported on comp.lang.c, Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com> Initial analysis of the dangers provided by Keith Thompson in that thread. There are many more instances of more complicated macros having unnecessary trailing semicolons, but this pile seems to be all of the cases of simple values suffering from the problem. (Thus things that are likely to be found in one of the contexts above, more complicated ones aren't.) Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-18[PARISC] Fix futex supportCarlos O'Donell
Implements futex op support and makes futex cmpxchg atomic. Tested on 64-bit SMP kernel running on 2 x PA8700s. [jejb: checkpatch fixes] Signed-off-by: Carlos O'Donell <carlos@systemhalted.org> Tested-by: John David Anglin <dave.anglin@bell.net> Cc: stable@kernel.org Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25Remove unused PROC_CHANGE_PENALTY constantStephen Boyd
This constant hasn't been used since before the git era (2.6.12) and thus can be dropped. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Richard Weinberger <richard@nod.at> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-22Merge branch 'flushing' into for-linusJames Bottomley
2011-04-15[PARISC] wire up syncfs syscallJames Bottomley
Cc: stable@kernel.org Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2011-04-15[PARISC] wire up the fhandle syscallsJames Bottomley
2011-04-15[PARISC] wire up clock_adjtime syscallJames Bottomley
2011-04-15[PARISC] wire up fanotify syscallsJames Bottomley
2011-04-15[PARISC] prevent speculative re-read on cache flushJames Bottomley
According to Appendix F, the TLB is the primary arbiter of speculation. Thus, if a page has a TLB entry, it may be speculatively read into the cache. On linux, this can cause us incoherencies because if we're about to do a disk read, we call get_user_pages() to do the flush/invalidate in user space, but we still potentially have the user TLB entries, and the cache could speculate the lines back into userspace (thus causing stale data to be used). This is fixed by purging the TLB entries before we flush through the tmpalias space. Now, the only way the line could be re-speculated is if the user actually tries to touch it (which is not allowed). Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-04-15[PARISC] only make executable areas executableJames Bottomley
Currently parisc has the whole kernel marked as RWX, meaning any kernel page at all is eligible to be executed. This can cause a theoretical problem on systems with combined I/D TLB because the act of referencing a page causes a TLB insertion with an executable bit. This TLB entry may be used by the CPU as the basis for speculating the page into the I-Cache. If this speculated page is subsequently used for a user process, there is the possibility we will get a stale I-cache line picked up as the binary executes. As a point of good practise, only mark actual kernel text pages as executable. The same has to be done for init_text pages, but they're converted to data pages (and the I-Cache flushed) when the init memory is released. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23remove dma64_addr_tFUJITA Tomonori
There is no user now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: David Miller <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] Convert to new irq_chip functions [PARISC] fix per-cpu flag problem in the cpu affinity checkers [PARISC] fix vmap flush/invalidate eliminate special FLUSH flag from page table parisc: flush pages through tmpalias space
2011-03-17mm: make __get_user_pages return -EHWPOISON for HWPOISON page optionallyHuang Ying
Make __get_user_pages return -EHWPOISON for HWPOISON page only if FOLL_HWPOISON is specified. With this patch, the interested callers can distinguish HWPOISON pages from general FAULT pages, while other callers will still get -EFAULT for all these pages, so the user space interface need not to be changed. This feature is needed by KVM, where UCR MCE should be relayed to guest for HWPOISON page, while instruction emulation and MMIO will be tried for general FAULT page. The idea comes from Andrew Morton. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-03-16vfs: add nonconflicting values for O_PATHStephen Rothwell
[AV: on architectures where default conflicts with existing flags, that is] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-11futex: Sanitize futex ops argument typesMichel Lespinasse
Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic prototypes to use u32 types for the futex as this is the data type the futex core code uses all over the place. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311025058.GD26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-11futex: Sanitize cmpxchg_futex_value_locked APIMichel Lespinasse
The cmpxchg_futex_value_locked API was funny in that it returned either the original, user-exposed futex value OR an error code such as -EFAULT. This was confusing at best, and could be a source of livelocks in places that retry the cmpxchg_futex_value_locked after trying to fix the issue by running fault_in_user_writeable(). This change makes the cmpxchg_futex_value_locked API more similar to the get_futex_value_locked one, returning an error code and updating the original value through a reference argument. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile] Acked-by: Tony Luck <tony.luck@intel.com> [ia64] Acked-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Michal Simek <monstr@monstr.eu> [microblaze] Acked-by: David Howells <dhowells@redhat.com> [frv] Cc: Darren Hart <darren@dvhart.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110311024851.GC26122@google.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17tty: add TIOCVHANGUP to allow clean tty shutdown of all ttysKay Sievers
This is useful for system management software so that it can kick off things like gettys and everything that's started from a tty, before we reuse it from/for something else or shut it down. Without this ioctl it would have to temporarily become the owner of the tty, then call vhangup() and then give it up again. Cc: Lennart Poettering <lennart@poettering.net> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-10Merge branch 'irq' into for-nextJames Bottomley
2011-02-10Merge branch 'fixes' into for-nextJames Bottomley
2011-02-10Merge branch 'tmpalias-flush' into for-nextJames Bottomley
2011-02-10[PARISC] Convert to new irq_chip functionsThomas Gleixner
Convert all the parisc driver interrupt handlers (dino, eisa, gsc, iosapic and superio) as well as the cpu interrupts. Prepare show_interrupts for GENERIC_HARDIRQS_NO_DEPRECATED and finally selects that Kconfig option [jejb: compile and testing fixes] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-09[PARISC] fix vmap flush/invalidateJames Bottomley
On parisc, we never implemented invalidate_kernel_vmap_range() because it was unnecessary for the xfs use case. However, we do need to implement an invalidate for the opposite use case (which occurred in a recent NFS change) where the user wants to read through the vmap range and write via the kernel address. There's an additional complexity to this in that if the page has no userspace mappings, it might have dirty cache lines in the kernel (indicated by the PG_dcache_dirty bit). In order to get full coherency, we need to flush these pages through the kernel mapping before invalidating the vmap range. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-16parisc: fix compile breakage caused by inlining maybe_mkwriteJames Bottomley
On PARISC, we have an include of linux/mm.h inside our asm/pgtable.h, so this patch commit 14fd403f2146f740942d78af4e0ee59396ad8eab Author: Andrea Arcangeli <aarcange@redhat.com> Date: Thu Jan 13 15:46:37 2011 -0800 thp: export maybe_mkwrite causes us an unsatisfiable use of pte_mkwrite in linux/mm.h. The fix is to avoid including linux/mm.h in our pgtable.h, which unbreaks the build. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-15eliminate special FLUSH flag from page tableJames Bottomley
This was used to flush a region even if the page table entry had been cleared. In theory this was never necessary, but now we've switched to alias based flushing, the whole set of code associated with it can be dumped. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-15parisc: flush pages through tmpalias spaceJames Bottomley
The kernel has an 8M tmpailas space (originally designed for copying and clearing pages but now only used for clearing). The idea is to place zeros into the cache above a physical page rather than into the physical page and flush the cache, because often the zeros end up being replaced quickly anyway. We can also use the tmpalias space for flushing a page. The difference here is that we have to do tmpalias processing in the non access data and instruction traps. The principle is the same: as long as we know the physical address and have a virtual address congruent to the real one, the flush will be effective. In order to use the tmpalias space, the icache miss path has to be enhanced to check for the alias region to make the fic instruction effective. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-13thp: mm: define MADV_NOHUGEPAGEAndrea Arcangeli
Define MADV_NOHUGEPAGE. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mm: define MADV_HUGEPAGEAndrea Arcangeli
Define MADV_HUGEPAGE. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-16TTY: Add tty ioctl to figure device node of the system console.Werner Fink
This has been in the SuSE kernels for a very long time. Signed-off-by: Werner Fink <werner@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-28Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: add tty driver to PDC console drivers/parisc/iosapic.c: Remove unnecessary kzalloc cast parisc: remove homegrown L1_CACHE_ALIGN macro arch/parisc: Removing undead ifdef CONFIG_PA20 parisc: unwind - optimise linked-list searches for modules parisc: change to new flag variable drivers/char/agp/parisc-agp.c: eliminate memory leak parisc: kill __do_IRQ parisc: convert eisa interrupts to flow handlers parisc: convert gsc and dino pci interrupts to flow handlers parisc: convert suckyio interrupts to flow handlers parisc: convert iosapic interrupts to proper flow handlers parisc: convert cpu interrupts to proper flow handlers parisc: lay groundwork for killing __do_IRQ parisc: add prlimit64 syscall parisc: squelch warning when using dev_get_stats
2010-10-28parisc: fix compile failure with kmap_atomic changesJames Bottomley
Commit 3e4d3af501cc ("mm: stack based kmap_atomic()") overlooked the fact that parisc uses kmap as a coherence mechanism, so even though we have no highmem, we do need to supply our own versions of kmap (and atomic). This patch converts the parisc kmap to the form which is needed to keep it compiling (it's a simple prototype and name change). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Acked-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-21parisc: remove homegrown L1_CACHE_ALIGN macroFUJITA Tomonori
Let's use the standard L1_CACHE_ALIGN macro instead. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflagsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-irqflags: Fix IRQ flag handling naming MIPS: Add missing #inclusions of <linux/irq.h> smc91x: Add missing #inclusion of <linux/irq.h> Drop a couple of unnecessary asm/system.h inclusions SH: Add missing consts to sys_execve() declaration Blackfin: Rename IRQ flags handling functions Blackfin: Add missing dep to asm/irqflags.h Blackfin: Rename DES PC2() symbol to avoid collision Blackfin: Split the BF532 BFIN_*_FIO_FLAG() functions to their own header Blackfin: Split PLL code from mach-specific cdef headers
2010-10-18irq_work: Add generic hardirq context callbacksPeter Zijlstra
Provide a mechanism that allows running code in IRQ context. It is most useful for NMI code that needs to interact with the rest of the system -- like wakeup a task to drain buffers. Perf currently has such a mechanism, so extract that and provide it as a generic feature, independent of perf so that others may also benefit. The IRQ context callback is generated through self-IPIs where possible, or on architectures like powerpc the decrementer (the built-in timer facility) is set to generate an interrupt immediately. Architectures that don't have anything like this get to do with a callback from the timer tick. These architectures can call irq_work_run() at the tail of any IRQ handlers that might enqueue such work (like the perf IRQ handler) to avoid undue latencies in processing the work. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [ various fixes ] Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1287036094.7768.291.camel@yhuang-dev> Signed-off-by: Ingo Molnar <mingo@elte.hu>
