path: root/arch/parisc/kernel/Makefile
2013-11-07parisc: add kernel audit featureHelge Deller
Implement missing functions for parisc to provide kernel audit feature. Signed-off-by: Helge Deller <deller@gmx.de>
2012-05-07parisc: Fix init_task falloutThomas Gleixner
Forgot to remove the objects from the Makefiles. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-31parisc: add ftrace (function and graph tracer) functionalityHelge Deller
This patch adds the ftrace debugging functionality to the parisc kernel. It will currently only work with 64bit kernels, because the gcc options -pg and -ffunction-sections can't be enabled at the same time and -ffunction-sections is still needed to be able to link 32bit kernels. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-31parisc: add LATENCYTOP_SUPPORT and CONFIG_STACKTRACE_SUPPORTHelge Deller
2008-05-15parisc: remove -traditional from assembler flagsKyle McMartin
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
