path: root/arch/parisc/kernel/entry.S
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: use conditional macro for 64-bit wide opsKyle McMartin
This work enables us to remove -traditional from $AFLAGS on parisc. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Kill off broken irqstack codeKyle McMartin
It's been unfinished and broken long enough, and I have some ideas on how to do it more cleanly. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Remove hardcoded uses of PAGE_SIZEKyle McMartin
2007-05-30[PARISC] fix "reduce size of task_struct on 64-bit machines" falloutKyle McMartin
Amazingly, parisc was the only arch effected by this... Convert register-sized loads/stores to always be 32-bit for these fields. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-05-30[PARISC] remove remnants of parisc-specific softirq codeGrant Grundler
Kyle, This patch removes remnants of softirq support that we no longer need. I suspect this was just overlooked when willy convert parisc to generic IRQ support. Tested on c3600 32-bit UP. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> [and tested on a c8000 64-bit SMP --kyle] Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] do not export get_register/set_registerHelge Deller
- noticed by Randolph Chung (tausq) Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] implement standard ENTRY(), END() and ENDPROC()Helge Deller
Use the macros in entry.S Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] use less assembler statements in syscall pathHelge Deller
2007-02-17[PARISC] Add TIF_RESTORE_SIGMASK supportKyle McMartin
And unmask the pselect6/ppoll system calls. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] a and b in "break a,b" message were swappedHelge Deller
And clean up 32/64bit branch assembler statements Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] [BUGFIX] nullify branch delay slot of the jump back toKyle McMartin
intr_restore in intr_do_preempt. This prevents the execution of an unwanted insn... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Abstract shift register left in .SKyle McMartin
Abstract existing shift register left macros as shift register right are. This lends itself to a nice clean up of some #ifdef blocks in entry.S Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-03Attack of "the the"s in archMatt LaPlante
The patch below corrects multiple occurances of "the the" typos across several files, both in source comments and KConfig files. There is no actual code changed, only text. Note this only affects the /arch directory, and I believe I could find many more elsewhere. :) Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-27[PARISC] Ensure all ldcw uses are ldcw,co on pa2.0Kyle McMartin
ldcw,co should always be used on pa2.0, otherwise the strict cache width alignment requirement is not relaxed. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-21[PARISC] Further work for multiple page sizesHelge Deller
More work towards supporing multiple page sizes on 64-bit. Convert some assumptions that 64bit uses 3 level page tables into testing PT_NLEVELS. Also some BUG() to BUG_ON() conversions and some cleanups to assembler. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Add PREEMPT supportKyle McMartin
2006-03-30[PARISC] Fix IOREMAP with a 64-bit kernelHelge Deller
We were only copying 32-bits of the PTE/PFN, not the full 52-bits. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Document some register usages in assembly filesCarlos O'Donell
Document clobbers and args in entry.S and syscall.S. entry.S: Add comment to indicate that cr27 may recycle and EDEADLOCK detection is not 100% correct. Since this is only enabled when using ENABLE_LWS_DEBUG, the user is warned by the comment. Signed-off-by: Carlos O'Donell <carlos@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Remove the spurious do_softirq calls from entry.SJames Bottomley
remove the spurious do_softirq calls from entry.S With these in we were calling do_softirq twice; plus the calls in entry.S took no account of nesting. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix the alloc_slabmgmt panicJames Bottomley
Fix the alloc_slabmgmt panic Hopefully this should also fix a lot of other intermittent kernel bugs. The problem has been around since 2.6.9-rc2-pa6 when we allowed floating point registers to be used in kernel code. The essence of the problem is that gcc prefers to use floating point for integer divides and multiples. Further, it can rely on the values in the no clobber fp regs being correct across a function call. Unfortunately, our task switch function only saves the integer no clobber registers, not the fp ones, so if gcc makes a function call to any function in the kernel which could sleep, the values it is relying on in any no clobber floating point register may be lost. In the case of alloc_slabmgmt, the value of the page offset is being stored in %fr12 across a call to kmem_getpages(), which sleeps if no pages are available. Thus, the offset can be trashed and the slab code can end up with a completely bogus address leading to corruption. Kudos to Randolph who came up with the program to trip this problem at will and thus allowed it to be tracked and fixed. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Replace uses of __LP64__ with CONFIG_64BITGrant Grundler
2.6.12-rc4-pa3 s/__LP64__/CONFIG_64BIT/ and fixup config.h usage Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Replace some calls to bl with b,l or bv to use longer offsetsRandolph Chung
convert some bl calls to b,l or bv to use longer offsets Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Make sure use of RFI conforms to PA 2.0 and 1.1 arch docsGrant Grundler
2.6.12-rc4-pa3 : first pass at making sure use of RFI conforms to PA 2.0 arch pages F-4 and F-5, PA 1.1 Arch page 3-19 and 3-20. The discussion revolves around all the rules for clearing PSW Q-bit. The hard part is meeting all the rules for "relied upon translation". .align directive is used to guarantee the critical sequence ends more than 8 instructions (32 bytes) from the end of page. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
