path: root/arch/parisc/kernel/parisc_ksyms.c
2013-04-25parisc: Provide __ucmpdi2 to resolve undefined references in 32 bit builds.John David Anglin
The Debian experimental linux source package (3.8.5-1) build fails with the following errors: ... MODPOST 2016 modules ERROR: "__ucmpdi2" [fs/btrfs/btrfs.ko] undefined! ERROR: "__ucmpdi2" [drivers/md/dm-verity.ko] undefined! The attached patch resolves this problem. It is based on the s390 implementation of ucmpdi2.c. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Signed-off-by: Helge Deller <deller@gmx.de>
2013-02-20parisc: fixes and cleanups in page cache flushing (1/4)John David Anglin
This is the first patch in a series of 4, with which the page cache flushing of parisc will gets fixed and enhanced. This even fixes the nasty "minifail" bug (http://wiki.parisc-linux.org/TestCases?highlight=%28minifail%29) which prevented parisc to stay an official debian port. Basically the flush in copy_user_page together with the TLB patch from commit 7139bc1579901b53db7e898789e916ee2fb52d78 is what fixes the minifail bug. This patch still uses the TMPALIAS approach. The new copy_user_page implementation calls flush_dcache_page_asm to flush the user dcache page (crucial for minifail fix) via a kernel TMPALIAS mapping. After that, it just copies the page using the kernel mapping. It does a final flush if needed. Generally it is hard to avoid doing some cache flushes using the kernel mapping (e.g., copy_to_user_page and copy_from_user_page). This patch depends on a subsequent change to pacache.S implementing clear_page_asm and copy_page_asm. These are optimized routines to clear and copy a page. The calls in clear_user_page and copy_user_page could be replaced by calls to memset and memcpy, respectively. I tested prefetch optimizations in clear_page_asm and copy_page_asm but didn't see any significant performance improvement on rp3440. I'm not sure if these are routines are significantly faster than memset and/or memcpy, but they are there for further performance evaluation. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2012-05-31[PARISC] update parisc to use generic strncpy_from_user()James Bottomley
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31parisc: add ftrace (function and graph tracer) functionalityHelge Deller
This patch adds the ftrace debugging functionality to the parisc kernel. It will currently only work with 64bit kernels, because the gcc options -pg and -ffunction-sections can't be enabled at the same time and -ffunction-sections is still needed to be able to link 32bit kernels. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13parisc: export copy_user_page_asmKyle McMartin
Needed by fuse (via copy_highpage). Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2007-12-06Revert "[PARISC] import necessary bits of libgcc.a"Kyle McMartin
This reverts commit efb80e7e097d0888e59fbbe4ded2ac5a256f556d, it turned out to cause sporadic problems with the timer interrupt on 32-bit kernels. Needs more investigation. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] import necessary bits of libgcc.aKyle McMartin
Currently we're hacking libs-y to include libgcc.a, but this has unforeseen consequences since the userspace libgcc is linked with fpregs enabled. We need the kernel to stop using fpregs in an uncontrolled manner to implement lazy fpu state saves. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-11[PATCH] remove bogus arch-specific syscall exportsAl Viro
2006-04-11[PATCH] No arch-specific strpbrk implementationsKyle McMartin
While cleaning up parisc_ksyms.c earlier, I noticed that strpbrk wasn't being exported from lib/string.c. Investigating further, I noticed a changeset that removed its export and added it to _ksyms.c on a few more architectures. The justification was that "other arches do it." I think this is wrong, since no architecture currently defines __HAVE_ARCH_STRPBRK, there's no reason for any of them to be exporting it themselves. Therefore, consolidate the export to lib/string.c. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] Kill duplicated EXPORT_SYMBOL warningsKyle McMartin
Some symbols are exported both in parisc_ksyms.c, and at their definition site. Nuke the redundant EXPORT_SYMBOL in ksyms to quiet warnings when vmlinux is linked. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Move ioremap EXPORT_SYMBOL from parisc_ksyms.cKyle McMartin
Move ioremap/iounmap EXPORT_SYMBOL to ioremap.c where they belong. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Move pm_power_off export to process.cKyle McMartin
Move the EXPORT_SYMBOL() of pm_power_off from parisc_ksyms.c to the location of its definition in process.c Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
