This reverts the following patch, which shouldn't have been applied
to the .32 stable tree as it causes problems.
commit 5fd4514bb351b5ecb0da3692fff70741e5ed200c upstream.
Set the PCI CLS early in the boot process to prevent
device failures. In pcibios_set_master use the new
pci_cache_line_size instead of a hard-coded value.
Signed-off-by: Carlos O'Donell <carlos@codesourcery.com>
Reviewed-by: Grant Grundler <grundler@google.com>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Use the generic pci_enable_resources() instead of the arch-specific code.
Unlike this arch-specific code, the generic version:
- checks PCI_NUM_RESOURCES (11), not DEVICE_COUNT_RESOURCE (12), resources
- skips resources that have neither IORESOURCE_IO nor IORESOURCE_MEM set
- skips ROM resources unless IORESOURCE_ROM_ENABLE is set
- checks for resource collisions with "!r->parent"
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
'bus' was basically useless and 'hba' is only applicable on
64bit. Sigh, there's got to be a cleaner way to do this...
pcibios_link_hba_resources() could corrupt the resource tree by inserting
resources in the wrong place. Fix this by calling pci_claim_resource()
for PCI-PCI bridges. Delete pcibios_link_hba_resources as we shouldn't
need it any more. Also get rid of lba_claim_dev_resources() and just
call pci_claim_resource() directly.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
max() doesn't like comparing an unsigned long and a resource_size_t,
so make the local variables resource_size_t too.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Avoid compiler warning for unused variables on 32bit kernels by
conditionalizing the local variables on CONFIG_64BIT. PCI_HOST_ADDR()
only uses the hba argument on 64bit compiles.
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Remove two unnecessary extern declarations from asm/pci.h.
They collide with what gcc4.0 assumed was static (and should be static).
Found by Joel Soete.
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Helge,
o Convert a bunch of kmalloc/memset uses to kzalloc.
o pci.c: Add some __read_mostly annotations.
o pci.c: Move constant pci_post_reset_delay to asm/pci.h
o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG.
o Add some consts to perf.c/perf_images.h
Matthew,
o sticore.c: Add some consts to suppress compile warnings.
Generate a more informative message when a resource does not have
a parent.
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
infrastructure for it.
Let it rip!
