path: root/arch/parisc/kernel/traps.c
2008-05-15parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] clean up show_stackKyle McMartin
When we show_regs, we obviously have a struct pt_regs of the calling frame. Use these in show_stack so we don't have the entire bogus call trace up to the show_stack call. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-03-15[PARISC] dump_stack in show_regsKyle McMartin
Originally, show_stack was used in BUG() output. However, a recent commit changed it to print register state (no idea what that's supposed to help, really...) and parisc was missing a backtrace because of it. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-10-19Use helpers to obtain task pid in printks (arch code)Alexey Dobriyan
One of the easiest things to isolate is the pid printed in kernel log. There was a patch, that made this for arch-independent code, this one makes so for arch/xxx files. It took some time to cross-compile it, but hopefully these are all the printks in arch code. Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Report that kernel is tainted if there was an OOPSPavel Emelianov
If the kernel OOPSed or BUGed then it probably should be considered as tainted. Thus, all subsequent OOPSes and SysRq dumps will report the tainted kernel. This saves a lot of time explaining oddities in the calltraces. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Added parisc patch from Matthew Wilson -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16generic bug: use show_regs() instead of dump_stack()Heiko Carstens
The current generic bug implementation has a call to dump_stack() in case a WARN_ON(whatever) gets hit. Since report_bug(), which calls dump_stack(), gets called from an exception handler we can do better: just pass the pt_regs structure to report_bug() and pass it to show_regs() in case of a warning. This will give more debug informations like register contents, etc... In addition this avoids some pointless lines that dump_stack() emits, since it includes a stack backtrace of the exception handler which is of no interest in case of a warning. E.g. on s390 the following lines are currently always present in a stack backtrace if dump_stack() gets called from report_bug(): [<000000000001517a>] show_trace+0x92/0xe8) [<0000000000015270>] show_stack+0xa0/0xd0 [<00000000000152ce>] dump_stack+0x2e/0x3c [<0000000000195450>] report_bug+0x98/0xf8 [<0000000000016cc8>] illegal_op+0x1fc/0x21c [<00000000000227d6>] sysc_return+0x0/0x10 Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andi Kleen <ak@suse.de> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-04[PARISC] Fix kernel panic in check_ivtKyle McMartin
check_ivt had some seriously broken code wrt function pointers on parisc64. Instead of referencing the hpmc code via a function pointer, export symbols and reference it as a const array. Thanks to jda for pointing out the broken 64-bit func ptr handling. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-05-22[PARISC] spelling fixes: arch/parisc/Simon Arlott
Spelling fixes in arch/parisc/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] detect recursive kernel crash earlierHelge Deller
2007-02-17[PARISC] a and b in "break a,b" message were swappedHelge Deller
And clean up 32/64bit branch assembler statements Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] dump stack backtrace on BUG() and add syslog-levels to printk()sHelge Deller
2007-02-17[PARISC] Generic BUGHelge Deller
2007-02-17[PARISC] Fix show_stack() when we can't kmallocMatthew Wilcox
show_stack() was calling kzalloc() to allocate a struct pt_regs. This meant that *really* early stack dumps would cause a null pointer dereference. x86_64 allocates its pt_regs on the stack, so do the same. Kyle actually committed this exact patch to CVS on Wed Jul 26 14:32:39 2006 UTC, and never moved it across to git. Bad Kyle. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] Clean up the cache and tlb headersRandolph Chung
No changes in functionality. Signed-off-by: Randolph Chung <tausq@debian.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Honour "panic_on_oops" sysctlHelge Deller
Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] Refactor show_regs in traps.cKyle McMartin
show_regs() was one bloaty function. Split it into a few cleaner functions and define a clean macro to print a line of registers. [And from Thibaut, only print fprs on a usermode trap.] Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Add printing of fpregs state to stack dumpThibaut Varene
We're using fp regs now in the kernel, so we want to print them on stack dump Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
