Running an "echo t > /proc/sysrq-trigger" crashes the parisc kernel. The
problem is, that in print_worker_info() we try to read the workqueue info via
the probe_kernel_read() functions which use pagefault_disable() to avoid
crashes like this:
probe_kernel_read(&pwq, &worker->current_pwq, sizeof(pwq));
probe_kernel_read(&wq, &pwq->wq, sizeof(wq));
probe_kernel_read(name, wq->name, sizeof(name) - 1);
The problem here is, that the first probe_kernel_read(&pwq) might return zero
in pwq and as such the following probe_kernel_reads() try to access contents of
the page zero which is read protected and generate a kernel segfault.
With this patch we fix the interruption handler to call parisc_terminate()
directly only if pagefault_disable() was not called (in which case
preempt_count()==0). Otherwise we hand over to the pagefault handler which
will try to look up the faulting address in the fixup tables.
Signed-off-by: Helge Deller <deller@gmx.de>
Cc: <stable@vger.kernel.org> # v3.0+
Signed-off-by: John David Anglin <dave.anglin@bell.net>
/proc/interrupts
Show number of floating point assistant and unaligned access fixup
handler in /proc/interrupts file.
Things like " \t" and whitespace at end of line. I'm leaving all the other
coding style errors here alone.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Fix up all callers as they were before, with make one change: an
unsigned module taints the kernel, but doesn't turn off lockdep.
Disintegrate asm/system.h for PA-RISC.
cc: linux-parisc@vger.kernel.org
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
On Tue, Aug 18, 2009 at 01:45:17PM -0400, John David Anglin wrote:
> CC arch/parisc/kernel/traps.o
> arch/parisc/kernel/traps.c: In function 'handle_interruption':
> arch/parisc/kernel/traps.c:535:18: warning: operation on 'regs->iasq[0]'
> may be undefined
Yes - Line 535 should use both [0] and [1].
Reported-by: John David Anglin <dave@hiauly1.hia.nrc.ca>
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
As pointed out by Russell in http://marc.info/?l=linux-arch&m=118208089204630&w=2
This patch adds the ftrace debugging functionality to the parisc kernel.
It will currently only work with 64bit kernels, because the gcc options -pg
and -ffunction-sections can't be enabled at the same time and -ffunction-sections
is still needed to be able to link 32bit kernels.
and use this instead of dealing with exporting start/end and
toying with function descriptors.
On Wed, Dec 17, 2008 at 11:46:05PM +0100, Helge Deller wrote:
Honestly, I can't decide whether to apply this. It really should never
happen in the kernel, since the kernel can guarantee it won't get the
access rights failure (highest privilege level, and can set %sr and
%protid to whatever it wants.)
It really genuinely is a bug that probably should panic the kernel. The
only precedent I can easily see is x86 fixing up a bad iret with a
general protection fault, which is more or less analogous to code 27
here.
On the other hand, taking the exception on a userspace access really
isn't all that critical, and there's fundamentally little reason for the
kernel not to SIGSEGV the process, and continue...
Argh.
(btw, I've instrumented my do_sys_poll with a pile of assertions that
%cr8 << 1 == %sr3 == current->mm.context... let's see if where we're
getting corrupted is deterministic, though, I would guess that it won't
be.)
Any user on existing parisc 32- and 64bit-kernels can easily crash
the kernel and as such enforce a DSO.
A simple testcase is available here:
http://gsyprf10.external.hp.com/~deller/crash.tgz
The problem is introduced by the fact, that the handle_interruption()
crash handler calls the show_regs() function, which in turn tries to
unwind the stack by calling parisc_show_stack(). Since the stack contains
userspace addresses, a try to unwind the stack is dangerous and useless
and leads to the crash.
The fix is trivial: For userspace processes
a) avoid to unwind the stack, and
b) avoid to resolve userspace addresses to kernel symbol names.
While touching this code, I converted print_symbol() to %pS
printk formats and made parisc_show_stack() static.
An initial patch for this was written by Kyle McMartin back in August:
http://marc.info/?l=linux-parisc&m=121805168830283&w=2
Compile and run-tested with a 64bit parisc kernel.
Cc: Grant Grundler <grundler@parisc-linux.org>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, earlier...]
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Matthew Wilcox <willy@debian.org>
When we show_regs, we obviously have a struct pt_regs of the calling
frame. Use these in show_stack so we don't have the entire bogus call trace
up to the show_stack call.
Originally, show_stack was used in BUG() output. However, a recent commit
changed it to print register state (no idea what that's supposed to help,
really...) and parisc was missing a backtrace because of it.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
One of the easiest things to isolate is the pid printed in kernel log.
There was a patch, that made this for arch-independent code, this one makes
so for arch/xxx files.
It took some time to cross-compile it, but hopefully these are all the
printks in arch code.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: <linux-arch@vger.kernel.org>
If the kernel OOPSed or BUGed then it probably should be considered as
tainted. Thus, all subsequent OOPSes and SysRq dumps will report the
tainted kernel. This saves a lot of time explaining oddities in the
calltraces.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
[ Added parisc patch from Matthew Wilson -Linus ]
The current generic bug implementation has a call to dump_stack() in case a
WARN_ON(whatever) gets hit. Since report_bug(), which calls dump_stack(),
gets called from an exception handler we can do better: just pass the
pt_regs structure to report_bug() and pass it to show_regs() in case of a
warning. This will give more debug informations like register contents,
etc... In addition this avoids some pointless lines that dump_stack()
emits, since it includes a stack backtrace of the exception handler which
is of no interest in case of a warning. E.g. on s390 the following lines
are currently always present in a stack backtrace if dump_stack() gets
called from report_bug():
[<000000000001517a>] show_trace+0x92/0xe8)
[<0000000000015270>] show_stack+0xa0/0xd0
[<00000000000152ce>] dump_stack+0x2e/0x3c
[<0000000000195450>] report_bug+0x98/0xf8
[<0000000000016cc8>] illegal_op+0x1fc/0x21c
[<00000000000227d6>] sysc_return+0x0/0x10
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Kyle McMartin <kyle@parisc-linux.org>
check_ivt had some seriously broken code wrt function pointers on
parisc64. Instead of referencing the hpmc code via a function pointer,
export symbols and reference it as a const array.
Thanks to jda for pointing out the broken 64-bit func ptr handling.
Spelling fixes in arch/parisc/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Acked-by: Grant Grundler <grundler@parisc-linux.org>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
- additionally update my copyright timestamps
And clean up 32/64bit branch assembler statements
show_stack() was calling kzalloc() to allocate a struct pt_regs.
This meant that *really* early stack dumps would cause a null pointer
dereference. x86_64 allocates its pt_regs on the stack, so do the same.
Kyle actually committed this exact patch to CVS on
Wed Jul 26 14:32:39 2006 UTC, and never moved it across to git.
Bad Kyle.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
No changes in functionality.
Signed-off-by: Randolph Chung <tausq@debian.org>
Signed-off-by: Helge Deller <deller@parisc-linux.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
show_regs() was one bloaty function. Split it into a few cleaner
functions and define a clean macro to print a line of registers.
[And from Thibaut, only print fprs on a usermode trap.]
Helge,
o Convert a bunch of kmalloc/memset uses to kzalloc.
o pci.c: Add some __read_mostly annotations.
o pci.c: Move constant pci_post_reset_delay to asm/pci.h
o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG.
o Add some consts to perf.c/perf_images.h
Matthew,
o sticore.c: Add some consts to suppress compile warnings.
Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
We're using fp regs now in the kernel, so we want to print them
on stack dump
Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org>
infrastructure for it.
Let it rip!
