path: root/arch/parisc/lib
2012-03-28Disintegrate asm/system.h for PA-RISCDavid Howells
Disintegrate asm/system.h for PA-RISC. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-parisc@vger.kernel.org
2011-11-28parisc: switch to GENERIC_PCI_IOMAPMichael S. Tsirkin
parisc copied pci_iomap from generic code, probably to avoid pulling the rest of iomap.c in. Since that's in a separate file now, we can reuse the common implementation. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2011-10-31parisc: Add export.h to files needing EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These guys were getting it implicitly via module.h before, when module.h was everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06parisc: add strict copy size checks (v2)Helge Deller
Add CONFIG_DEBUG_STRICT_USER_COPY_CHECKS, copied from the x86 implementation. Tested with 32 and 64bit kernel. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-01-05Merge branch 'master' into percpuTejun Heo
Conflicts: arch/powerpc/platforms/pseries/hvCall.S include/linux/percpu.h
2009-12-14locking: Rename __RAW_SPIN_LOCK_UNLOCKED to __ARCH_SPIN_LOCK_UNLOCKEDThomas Gleixner
Further name space cleanup. No functional change Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_spinlock to arch_spinlockThomas Gleixner
The raw_spin* namespace was taken by lockdep for the architecture specific implementations. raw_spin_* would be the ideal name space for the spinlocks which are not converted to sleeping locks in preempt-rt. Linus suggested to convert the raw_ to arch_ locks and cleanup the name space instead of using an artifical name like core_spin, atomic_spin or whatever No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-10-29percpu: remove per_cpu__ prefix.Rusty Russell
Now that the return from alloc_percpu is compatible with the address of per-cpu vars, it makes sense to hand around the address of per-cpu variables. To make this sane, we remove the per_cpu__ prefix we used created to stop people accidentally using these vars directly. Now we have sparse, we can use that (next patch). tj: * Updated to convert stuff which were missed by or added after the original patch. * Kill per_cpu_var() macro. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
2009-07-03parisc: fix mismatched parenthesis in memcpy.cRandolph Chung
>>>> I think this is what was intended? Note that this patch may affect >>>> profiling. >>> it really should be >>> >>> - if (likely(t1 & (sizeof(unsigned int)-1)) == 0) { >>> + if (likely((t1 & (sizeof(unsigned int)-1)) == 0)) { >>> >>> randolph Reported-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: remove CVS keywordsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: lib/: make code staticAdrian Bunk
Make the following needlessly global code static: - iomap.c: struct iomap_ops[] - memcpy.c: pa_memcpy() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-06-13Revert "parisc: fix trivial section name warnings"Kyle McMartin
This reverts commit bd3bb8c15b9a80dbddfb7905b237a4a11a4725b4. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-05-15parisc: fix trivial section name warningsHelge Deller
This trivial patch fixes the following section warnings on PARISC: > WARNING: vmlinux.o (.text.1): unexpected section name. >The (.[number]+) following section name are ld generated and not expected. > Did you forget to use "ax"/"aw" in a .S file? > Note that for example <linux/init.h> contains > section definitions for use in .S files. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-04-29iomap: fix 64 bits resources on 32 bitsBenjamin Herrenschmidt
Almost all implementations of pci_iomap() in the kernel, including the generic lib/iomap.c one, copies the content of a struct resource into unsigned long's which will break on 32 bits platforms with 64 bits resources. This fixes all definitions of pci_iomap() to use resource_size_t. I also "fixed" the 64bits arch for consistency. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06Revert "[PARISC] import necessary bits of libgcc.a"Kyle McMartin
This reverts commit efb80e7e097d0888e59fbbe4ded2ac5a256f556d, it turned out to cause sporadic problems with the timer interrupt on 32-bit kernels. Needs more investigation. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] import necessary bits of libgcc.aKyle McMartin
Currently we're hacking libs-y to include libgcc.a, but this has unforeseen consequences since the userspace libgcc is linked with fpregs enabled. We need the kernel to stop using fpregs in an uncontrolled manner to implement lazy fpu state saves. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] parisc: "extern inline" -> "static inline"Adrian Bunk
"extern inline" will have different semantics with gcc 4.3, and "static inline" is correct here. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macroHelge Deller
- this macro unifies the code to add exception table entries - additionally use ENTRY()/ENDPROC() at more places Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-12-02[NET]: PARISC checksum annotations and cleanups.Al Viro
* sanitized prototypes, annotated * kill shift-by-16 in checksum calculation Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-30[PARISC] Remove obsolete CONFIG_DEBUG_IOREMAPHelge Deller
Remove CONFIG_DEBUG_IOREMAP, it's now obsolete and won't work anyway. Remove it from lib/KConfig since it was only available on parisc. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Specify level to fix binutils level promotion bugGrant Grundler
fixup.S needs to specify .level and use correct LDREG macro. New binutils has a bug where it doesn't "promote" from PA1.0 to PA1.1 correctly when using ",s" completer. remove use of __LP64__ in assembly.h and add some white space. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Disable use of fpregs in pa_memcpyRandolph Chung
Disable use of fpregs in pa_memcpy, and turn on the -mdisable-fpregs flag. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-04-16[PATCH] add Big Endian variants of ioread/iowriteJames Bottomley
In the new io infrastructure, all of our operators are expecting the underlying device to be little endian (because the PCI bus, their main consumer, is LE). However, there are a fair few devices and busses in the world that are actually Big Endian. There's even evidence that some of these BE bus and chip types are attached to LE systems. Thus, there's a need for a BE equivalent of our io{read,write}{16,32} operations. The attached patch adds this as io{read,write}{16,32}be. When it's in, I'll add the first consume (the 53c700 SCSI chip driver). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
