path: root/arch/parisc
2014-02-06parisc: fix cache-flushingHelge Deller
commit 57737c49dd72c96cfbcd4f66559f3ffc399aeb4f upstream. This commit: f8dae00684d678afa13041ef170cecfd1297ed40: parisc: Ensure full cache coherency for kmap/kunmap caused negative caching side-effects, e.g. hanging processes with expect and too many inequivalent alias messages from flush_dcache_page() on Debian 5 systems. This patch now partly reverts it and has been in production use on our debian buildd makeservers since a week without any major problems. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-15parisc: Ensure full cache coherency for kmap/kunmapJohn David Anglin
commit f8dae00684d678afa13041ef170cecfd1297ed40 upstream. Helge Deller noted a few weeks ago problems with the AIO support on parisc. This change is the result of numerous iterations on how best to deal with this problem. The solution adopted here is to provide full cache coherency in a uniform manner on all parisc systems. This involves calling flush_dcache_page() on kmap operations and flush_kernel_dcache_page() on kunmap operations. As a result, the copy_user_page() and clear_user_page() functions can be removed and the overall code is simpler. The change ensures that both userspace and kernel aliases to a mapped page are invalidated and flushed. This is necessary for the correct operation of PA8800 and PA8900 based systems which do not support inequivalent aliases. With this change, I have observed no cache related issues on c8000 and rp3440. It is now possible for example to do kernel builds with "-j64" on four way systems. On systems using XFS file systems, the patch recently posted by Mikulas Patocka to "fix crash using XFS on loopback" is needed to avoid a hang caused by an uninitialized lock passed to flush_dcache_page() in the page struct. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11parisc: fix mmap(MAP_FIXED|MAP_SHARED) to already mmapped addressHelge Deller
commit 0576da2c08e3d332f1b0653030d28ab804585ab6 upstream. locale-gen on Debian showed a strange problem on parisc: mmap2(NULL, 536870912, PROT_NONE, MAP_SHARED, 3, 0) = 0x42a54000 mmap2(0x42a54000, 103860, PROT_READ|PROT_WRITE, MAP_SHARED|MAP_FIXED, 3, 0) = -1 EINVAL (Invalid argument) Basically it was just trying to re-mmap() a file at the same address which it was given by a previous mmap() call. But this remapping failed with EINVAL. The problem is, that when MAP_FIXED and MAP_SHARED flags were used, we didn't included the mapping-based offset when we verified the alignment of the given fixed address against the offset which we calculated it in the previous call. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04parisc: break out SOCK_NONBLOCK define to own asm header fileHelge Deller
commit 38c7937379276a5ea8c54481205003af2f2b5694 upstream. Break SOCK_NONBLOCK out to its own asm-file as other arches do. This fixes build errors with auditd and probably other packages. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-13parisc: Do not crash 64bit SMP kernels on machines with >= 4GB RAMHelge Deller
commit 54e181e073fc1415e41917d725ebdbd7de956455 upstream. Since the beginning of the parisc-linux port, sometimes 64bit SMP kernels were not able to bring up other CPUs than the monarch CPU and instead crashed the kernel. The reason was unclear, esp. since it involved various machines (e.g. J5600, J6750 and SuperDome). Testing showed, that those crashes didn't happened when less than 4GB were installed, or if a 32bit Linux kernel was booted. In the end, the fix for those SMP problems is trivial: During the early phase of the initialization of the CPUs, including the monarch CPU, the PDC_PSW firmware function to enable WIDE (=64bit) mode is called. It's documented that this firmware function may clobber various registers, and one one of those possibly clobbered registers is %cr30 which holds the task thread info pointer. Now, if %cr30 would always have been clobbered, then this bug would have been detected much earlier. But lots of testing finally showed, that - at least for %cr30 - on some machines only the upper 32bits of the 64bit register suddenly turned zero after the firmware call. So, after finding the root cause, the explanation for the various crashes became clear: - On 32bit SMP Linux kernels all upper 32bit were zero, so we didn't faced this problem. - Monarch CPUs in 64bit mode always booted sucessfully, because the inital task thread info pointer was below 4GB. - Secondary CPUs booted sucessfully on machines with less than 4GB RAM because the upper 32bit were zero anyay. - Secondary CPus failed to boot if we had more than 4GB RAM and the task thread info pointer was located above the 4GB boundary. Finally, the patch to fix this problem is trivial by saving the %cr30 register before the firmware call and restoring it afterwards. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18parisc: fix interruption handler to respect pagefault_disable()Helge Deller
commit 59b33f148cc08fb33cbe823fca1e34f7f023765e upstream. Running an "echo t > /proc/sysrq-trigger" crashes the parisc kernel. The problem is, that in print_worker_info() we try to read the workqueue info via the probe_kernel_read() functions which use pagefault_disable() to avoid crashes like this: probe_kernel_read(&pwq, &worker->current_pwq, sizeof(pwq)); probe_kernel_read(&wq, &pwq->wq, sizeof(wq)); probe_kernel_read(name, wq->name, sizeof(name) - 1); The problem here is, that the first probe_kernel_read(&pwq) might return zero in pwq and as such the following probe_kernel_reads() try to access contents of the page zero which is read protected and generate a kernel segfault. With this patch we fix the interruption handler to call parisc_terminate() directly only if pagefault_disable() was not called (in which case preempt_count()==0). Otherwise we hand over to the pagefault handler which will try to look up the faulting address in the fixup tables. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11parisc: Fix interrupt routing for C8000 serial portsThomas Bogendoerfer
commit dd5e6d6a3db09b16b7c222943977865eead88cc3 upstream. We can't use dev->mod_index for selecting the interrupt routing entry, because it's not an index into interrupt routing table. It will be even wrong on a machine with 2 CPUs (4 cores). But all needed information is contained in the PAT entries for the serial ports. mod[0] contains the iosapic address and mod_info has some indications for the interrupt input (at least it looks like it). This patch implements the searching for the right iosapic and uses this interrupt input information. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11parisc: Fix cache routines to ignore vma's with an invalid pfnJohn David Anglin
commit 50861f5a02dbf939c27d35a26c472885e2844188 upstream. The parisc architecture does not have a pte special bit. As a result, special mappings are handled with the VM_PFNMAP and VM_MIXEDMAP flags. VM_MIXEDMAP mappings may or may not have a "struct page" backing. When pfn_valid() is false, there is no "struct page" backing. Otherwise, they are treated as normal pages. The FireGL driver uses the VM_MIXEDMAP without a backing "struct page". This treatment caused a panic due to a TLB data miss in update_mmu_cache. This appeared to be in the code generated for page_address(). We were in fact using a very circular bit of code to determine the physical address of the PFN in various cache routines. This wasn't valid when there was no "struct page" backing. The needed address can in fact be determined simply from the PFN itself without using the "struct page". The attached patch updates update_mmu_cache(), flush_cache_mm(), flush_cache_range() and flush_cache_page() to check pfn_valid() and to directly compute the PFN physical and virtual addresses. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21parisc: optimize mtsp(0,sr) inline assemblyHelge Deller
commit 92b59929825d67db575043a76651865d16873b36 upstream. If the value which should be moved into a space register is zero, we can optimize the inline assembly to become "mtsp %r0,%srX". Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21parisc: Ensure volatile space register %sr1 is not clobberedJohn David Anglin
commit e8d8fc219f9a0e63e7fb927881e6f4db8e7d34df upstream. I still see the occasional random segv on rp3440. Looking at one of these (a code 15), it appeared the problem must be with the cache handling of anonymous pages. Reviewing this, I noticed that the space register %sr1 might be being clobbered when we flush an anonymous page. Register %sr1 is used for TLB purges in a couple of places. These purges are needed on PA8800 and PA8900 processors to ensure cache consistency of flushed cache lines. The solution here is simply to move the %sr1 load into the TLB lock region needed to ensure that one purge executes at a time on SMP systems. This was already the case for one use. After a few days of operation, I haven't had a random segv on my rp3440. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-21parisc: Fix gcc miscompilation in pa_memcpy()Helge Deller
commit 5b879d78bc0818aa710f5d4d9abbfc2aca075cc3 upstream. When running the LTP testsuite one may hit this kernel BUG() with the write06 testcase: kernel BUG at mm/filemap.c:2023! CPU: 1 PID: 8614 Comm: writev01 Not tainted 3.10.0-rc7-64bit-c3000+ #6 IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000401e6e84 00000000401e6e88 IIR: 03ffe01f ISR: 0000000010340000 IOR: 000001fbe0380820 CPU: 1 CR30: 00000000bef80000 CR31: ffffffffffffffff ORIG_R28: 00000000bdc192c0 IAOQ[0]: iov_iter_advance+0x3c/0xc0 IAOQ[1]: iov_iter_advance+0x40/0xc0 RP(r2): generic_file_buffered_write+0x204/0x3f0 Backtrace: [<00000000401e764c>] generic_file_buffered_write+0x204/0x3f0 [<00000000401eab24>] __generic_file_aio_write+0x244/0x448 [<00000000401eadc0>] generic_file_aio_write+0x98/0x150 [<000000004024f460>] do_sync_readv_writev+0xc0/0x130 [<000000004025037c>] compat_do_readv_writev+0x12c/0x340 [<00000000402505f8>] compat_writev+0x68/0xa0 [<0000000040251d88>] compat_SyS_writev+0x98/0xf8 Reason for this crash is a gcc miscompilation in the fault handlers of pa_memcpy() which return the fault address instead of the copied bytes. Since this seems to be a generic problem with gcc-4.7.x (and below), it's better to simplify the fault handlers in pa_memcpy to avoid this problem. Here is a simple reproducer for the problem: int main(int argc, char **argv) { int fd, nbytes; struct iovec wr_iovec[] = { { "TEST STRING ",32}, { (char*)0x40005000,32} }; // random memory. fd = open(DATA_FILE, O_RDWR | O_CREAT, 0666); nbytes = writev(fd, wr_iovec, 2); printf("return value = %d, errno %d (%s)\n", nbytes, errno, strerror(errno)); return 0; } In addition, John David Anglin wrote: There is no gcc PR as pa_memcpy is not legitimate C code. There is an implicit assumption that certain variables will contain correct values when an exception occurs and the code randomly jumps to one of the exception blocks. There is no guarantee of this. If a PR was filed, it would likely be marked as invalid. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-18parisc: Use unshadowed index register for flush instructions in ↵John David Anglin
flush_dcache_page_asm and flush_icache_page_asm The comment at the start of pacache.S states that the base and index registers used for fdc,fic, and pdc instructions should not use shadowed registers. Although this is probably unnecessary for tmpalias flushes, there is also no reason not to comply. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-18parisc: provide pci_mmap_page_range() for pariscThomas Bogendoerfer
pci_mmap_page_range() is needed for X11-server support on C8000 with ATI FireGL card. Signed-off-by Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-18parisc: fix serial ports on C8000 workstationThomas Bogendoerfer
The C8000 workstation (64 bit kernel only) has a somewhat different serial port configuration than other models. Thomas Bogendoerfer sent a patch to fix this in September 2010, which was now minimally modified by me. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-18parisc: fix kernel BUG at arch/parisc/include/asm/mmzone.h:50 (part 2)Helge Deller
Make sure that we really return -1 (instead of 0x00ff) as node id for page frame numbers which are not physically available. This finally fixes the kernel panic when running cat /proc/kpageflags /proc/kpagecount. Theoretically this patch now limits the number of physical memory ranges to 127 instead of 254, but currently we have MAX_PHYSMEM_RANGES hardcoded to 8 which is sufficient for all existing parisc machines. Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parisc: kernel: using strlcpy() instead of strcpy()Chen Gang
'boot_args' is an input args, and 'boot_command_line' has a fix length. So use strlcpy() instead of strcpy() to avoid memory overflow. Signed-off-by: Chen Gang <gang.chen@asianux.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parisc: rename "CONFIG_PA7100" to "CONFIG_PA7000"Paul Bolle
There's a Makefile line setting cflags for CONFIG_PA7100. But that Kconfig macro doesn't exist. There is a Kconfig symbol PA7000, which covers both PA7000 and PA7100 processors. So let's use the corresponding Kconfig macro. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parisc: fix kernel BUG at arch/parisc/include/asm/mmzone.h:50Helge Deller
With CONFIG_DISCONTIGMEM=y and multiple physical memory areas, cat /proc/kpageflags triggers this kernel bug: kernel BUG at arch/parisc/include/asm/mmzone.h:50! CPU: 2 PID: 7848 Comm: cat Tainted: G D W 3.10.0-rc3-64bit #44 IAOQ[0]: kpageflags_read0x128/0x238 IAOQ[1]: kpageflags_read0x12c/0x238 RP(r2): proc_reg_read0xbc/0x130 Backtrace: [<00000000402ca2d4>] proc_reg_read0xbc/0x130 [<0000000040235bcc>] vfs_read0xc4/0x1d0 [<0000000040235f0c>] SyS_read0x94/0xf0 [<0000000040105fc0>] syscall_exit0x0/0x14 kpageflags_read() walks through the whole memory, even if some memory areas are physically not available. So, we should better not BUG on an unavailable pfn in pfn_to_nid() but just return the expected value -1 or 0. Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parisc: memory overflow, 'name' length is too short for usingChen Gang
'path.bc[i]' can be asigned by PCI_SLOT() which can '> 10', so sizeof(6 * "%u:" + "%u" + '\0') may be 21. Since 'name' length is 20, it may be memory overflow. And 'path.bc[i]' is 'unsigned char' for printing, we can be sure the max length of 'name' must be less than 28. So simplify thinking, we can use 28 instead of 20 directly, and do not think of whether 'patchc.bc[i]' can '> 100'. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc: fix irq stack on UP and SMPHelge Deller
The logic to detect if the irq stack was already in use with raw_spin_trylock() is wrong, because it will generate a "trylock failure on UP" error message with CONFIG_SMP=n and CONFIG_DEBUG_SPINLOCK=y. arch_spin_trylock() can't be used either since in the CONFIG_SMP=n case no atomic protection is given and we are reentrant here. A mutex didn't worked either and brings more overhead by turning off interrupts. So, let's use the fastest path for parisc which is the ldcw instruction. Counting how often the irq stack was used is pretty useless, so just drop this piece of code. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc: make interrupt and interruption stack allocation reentrantJohn David Anglin
The get_stack_use_cr30 and get_stack_use_r30 macros allocate a stack frame for external interrupts and interruptions requiring a stack frame. They are currently not reentrant in that they save register context before the stack is set or adjusted. I have observed a number of system crashes where there was clear evidence of stack corruption during interrupt processing, and as a result register corruption. Some interruptions can still occur during interruption processing, however external interrupts are disabled and data TLB misses don't occur for absolute accesses. So, it's not entirely clear what triggers this issue. Also, if an interruption occurs when Q=0, it is generally not possible to recover as the shadowed registers are not copied. The attached patch reworks the get_stack_use_cr30 and get_stack_use_r30 macros to allocate stack before doing register saves. The new code is a couple of instructions shorter than the old implementation. Thus, it's an improvement even if it doesn't fully resolve the stack corruption issue. Based on limited testing, it improves SMP system stability. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc: show number of FPE and unaligned access handler calls in ↵Helge Deller
/proc/interrupts Show number of floating point assistant and unaligned access fixup handler in /proc/interrupts file. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc: use PAGE_SHIFT instead of hardcoded value 12 in pacache.SHelge Deller
additionally clean up some whitespaces & tabs. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc: add rp5470 entry to machine databaseHelge Deller
2013-05-13parisc: make default cross compiler search more robust (v3)Helge Deller
People/distros vary how they prefix the toolchain name for 64bit builds. Rather than enforce one convention over another, add a for loop which does a search for all the general prefixes. For 64bit builds, we now search for (in order): hppa64-unknown-linux-gnu hppa64-linux-gnu hppa64-linux For 32bit builds, we look for: hppa-unknown-linux-gnu hppa-linux-gnu hppa-linux hppa2.0-unknown-linux-gnu hppa2.0-linux-gnu hppa2.0-linux hppa1.1-unknown-linux-gnu hppa1.1-linux-gnu hppa1.1-linux This patch was initiated by Mike Frysinger, with feedback from Jeroen Roovers, John David Anglin and Helge Deller. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Jeroen Roovers <jer@gentoo.org> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-11parisc: fix SMP races when updating PTE and TLB entries in entry.SJohn David Anglin
Currently, race conditions exist in the handling of TLB interruptions in entry.S. In particular, dirty bit updates can be lost if an accessed interruption occurs just after the dirty bit interruption on a different cpu. Lost dirty bit updates result in user pages not being flushed and general system instability. This change adds lock and unlock macros to synchronize all PTE and TLB updates done in entry.S. As a result, userspace stability is significantly improved. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-11parisc: implement irq stacks - part 2 (v2)Helge Deller
This patch fixes few build issues which were introduced with the last irq stack patch, e.g. the combination of stack overflow check and irq stack. Furthermore we now do proper locking and change the irq bh handler to use the irq stack as well. In /proc/interrupts one now can monitor how huge the irq stack has grown and how often it was preferred over the kernel stack. IRQ stacks are now enabled by default just to make sure that we not overflow the kernel stack by accident. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull stray syscall bits from Al Viro: "Several syscall-related commits that were missing from the original" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: switch compat_sys_sysctl to COMPAT_SYSCALL_DEFINE unicore32: just use mmap_pgoff()... unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINE x86, vm86: fix VM86 syscalls: use SYSCALL_DEFINEx(...)
2013-05-09unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINEAl Viro
2013-05-07parisc: tlb flush counting fix for SMP and UPHelge Deller
Fix up build error on UP and show correctly number of function call (ipi) irqs. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-07parisc: more irq statistics in /proc/interruptsHelge Deller
Add framework and initial values for more fine grained statistics in /proc/interrupts. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-07parisc: implement irq stacksHelge Deller
Default kernel stack size on parisc is 16k. During tests we found that the kernel stack can easily grow beyond 13k, which leaves 3k left for irq processing. This patch adds the possibility to activate an additional stack of 16k per CPU which is being used during irq processing. This implementation does not yet uses this irq stack for the irq bh handler. The assembler code for call_on_stack was heavily cleaned up by John David Anglin. CC: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-07parisc: add kernel stack overflow checkHelge Deller
Add the CONFIG_DEBUG_STACKOVERFLOW config option to enable checks to detect kernel stack overflows. Stack overflows can not be detected reliable since we do not want to introduce too much overhead. Instead, during irq processing in do_cpu_irq_mask() we check kernel stack usage of the interrupted kernel process. Kernel threads can be easily detected by checking the value of space register 7 (sr7) which is zero when running inside the kernel. Since THREAD_SIZE is 16k and PAGE_SIZE is 4k, reduce the alignment of the init thread to the lower value (PAGE_SIZE) in the kernel vmlinux.ld.S linker script. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-07parisc: only re-enable interrupts if we need to schedule or deliver signals ↵John David Anglin
when returning to userspace Helge and I have found that we have a kernel stack overflow problem which causes a variety of random failures. Currently, we re-enable interrupts when returning from an external interrupt incase we need to schedule or delivery signals. As a result, a potentially unlimited number of interrupts can occur while we are running on the kernel stack. It is very limited in space (currently, 16k). This change defers enabling interrupts until we have actually decided to schedule or delivery signals. This only occurs when we about to return to userspace. This limits the number of interrupts on the kernel stack to one. In other cases, interrupts remain disabled until the final return from interrupt (rfi). Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: implement atomic64_dec_if_positive()Helge Deller
2013-05-06parisc: use long branch in fork_like macroJohn David Anglin
The "b" branch instruction used in the fork_like macro only can handle 17-bit pc-relative offsets. This fails with an out of range offset with some .config files. Rewrite to use the "be" instruction which can branch to any address in a space. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: fix NATIVE set up in buildMike Frysinger
The ifeq operator does not accept globs, so this little bit of code will never match (unless uname literally prints out "parsic*"). Rewrite to use a pattern matching operator so that NATIVE is set to 1 on parisc. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: document the parisc gateway pageHelge Deller
Include some documentation about how the parisc gateway page technically works and how it is used from userspace. James Bottomley is the original author of this description and it was copied here out of an email thread from Apr 12 2013 titled: man2 : syscall.2 : document syscall calling conventions CC: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: fix partly 16/64k PAGE_SIZE bootHelge Deller
This patch fixes partly PAGE_SIZEs of 16K or 64K by adjusting the assembler PTE lookup code and the assembler TEMPALIAS code. Furthermore some data alignments for PAGE_SIZE have been limited to 4K (or less) to not waste too much memory with greater page sizes. As a side note, the palo loader can (currently) only handle up to 10 ELF segments which is fixed with tighter aligning as well. My testings indicated that the ldci command in the sba iommu coding needed adjustment by the PAGE_SHIFT value and that the I/O PDIR Page size was only set to 4K for my machine (C3000). All this fixes partly the boot, but there are still quite some caching problems left. Examples are e.g. the symbios logic driver which is failing: sym0: <896> rev 0x7 at pci 0000:00:0f.0 irq 69 sym0: PA-RISC Firmware, ID 7, Fast-40, SE, parity checking CACHE TEST FAILED: DMA error (dstat=0x81).sym0: CACHE INCORRECTLY CONFIGURED. and the tulip network driver which doesn't seem to work correctly either: Sending BOOTP requests .net eth0: Setting full-duplex based on MII#1 link partner capability of 05e1 ..... timed out! Beside those kernel fixes glibc will need fixes too to be able to handle >4K page sizes. Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: Provide default implementation for dma_{alloc, free}_attrsDamian Hobson-Garcia
Most architectures that define CONFIG_HAVE_DMA, have implementations for both dma_alloc_attrs() and dma_free_attrs(). All achitectures that do not define CONFIG_HAVE_DMA also have both of these definitions provided by dma-mapping-broken.h. Add default implementations for these functions on parisc. Signed-off-by: Damian Hobson-Garcia <dhobsong@igel.co.jp> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: fix whitespace errors in arch/parisc/kernel/traps.cRolf Eike Beer
Things like " \t" and whitespace at end of line. I'm leaving all the other coding style errors here alone. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: remove the second argument of kmap_atomicZhao Hongjiang
kmap_atomic allows only one argument now, just move the second. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-05parisc: single_open() leaksAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKSStephen Boyd
The help text for this config is duplicated across the x86, parisc, and s390 Kconfig.debug files. Arnd Bergman noted that the help text was slightly misleading and should be fixed to state that enabling this option isn't a problem when using pre 4.4 gcc. To simplify the rewording, consolidate the text into lib/Kconfig.debug and modify it there to be more explicit about when you should say N to this config. Also, make the text a bit more generic by stating that this option enables compile time checks so we can cover architectures which emit warnings vs. ones which emit errors. The details of how an architecture decided to implement the checks isn't as important as the concept of compile time checking of copy_from_user() calls. While we're doing this, remove all the copy_from_user_overflow() code that's duplicated many times and place it into lib/ so that any architecture supporting this option can get the function for free. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Helge Deller <deller@gmx.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
