[ Upstream commit f0b22d1bb2a37a665a969e95785c75a4f49d1499 ]
Do not load one entry beyond the end of the syscall table when the
syscall number of a traced process equals to __NR_Linux_syscalls.
Similar bug with regular processes was fixed by commit 3bb457af4fa8
("[PARISC] Fix bug when syscall nr is __NR_Linux_syscalls").
This bug was found by strace test suite.
Cc: stable@vger.kernel.org
Signed-off-by: Dmitry V. Levin <ldv@altlinux.org>
Acked-by: Helge Deller <deller@gmx.de>
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit 2ef4dfd9d9f288943e249b78365a69e3ea3ec072 ]
Handling exceptions from modules never worked on parisc.
It was just masked by the fact that exceptions from modules
don't happen during normal use.
When a module triggers an exception in get_user() we need to load the
main kernel dp value before accessing the exception_data structure, and
afterwards restore the original dp value of the module on exit.
Noticed-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit ef72f3110d8b19f4c098a0bff7ed7d11945e70c6 ]
The kernel module testcase (lib/test_user_copy.c) exhibited a kernel
crash on parisc if the parameters for copy_from_user were reversed
("illegal reversed copy_to_user" testcase).
Fix this potential crash by checking the fault handler if the faulting
address is in the exception table.
[ Upstream commit e3893027a300927049efc1572f852201eb785142 ]
We want to avoid the kernel module loader to create function pointers
for the kernel fixup routines of get_user() and put_user(). Changing
the external reference from function type to int type fixes this.
This unbreaks exception handling for get_user() and put_user() when
called from a kernel module.
[ Upstream commit 98e8b6c9ac9d1b1e9d1122dfa6783d5d566bb8f7 ]
Mike Frysinger reported that his ptrace testcase showed strange
behaviour on parisc: It was not possible to avoid a syscall and the
return value of a syscall couldn't be changed.
To modify a syscall number, we were missing to save the new syscall
number to gr20 which is then picked up later in assembly again.
The effect that the return value couldn't be changed is a side-effect of
another bug in the assembly code. When a process is ptraced, userspace
expects each syscall to report entrance and exit of a syscall. If a
syscall number was given which doesn't exist, we jumped to the normal
syscall exit code instead of informing userspace that the (non-existant)
syscall exits. This unexpected behaviour confuses userspace and thus the
bug was misinterpreted as if we can't change the return value.
This patch fixes both problems and was tested on 64bit kernel with
32bit userspace.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: stable@vger.kernel.org # v4.0+
Tested-by: Mike Frysinger <vapier@gentoo.org>
[ Upstream commit e60fc5aa608eb38b47ba4ee058f306f739eb70a0 ]
On a 64bit kernel build the compiler aligns the _sifields union in the
struct siginfo_t on a 64bit address. The __ARCH_SI_PREAMBLE_SIZE define
compensates for this alignment and thus fixes the wait testcase of the
strace package.
The symptoms of a wrong __ARCH_SI_PREAMBLE_SIZE value is that
_sigchld.si_stime variable is missed to be copied and thus after a
copy_siginfo() will have uninitialized values.
commit b1b4e435e4ef7de77f07bf2a42c8380b960c2d44 upstream.
When detecting a serial port on newer PA-RISC machines (with iosapic) we have a
long way to go to find the right IRQ line, registering it, then registering the
serial port and the irq handler for the serial port. During this phase spurious
interrupts for the serial port may happen which then crashes the kernel because
the action handler might not have been set up yet.
So, basically it's a race condition between the serial port hardware and the
CPU which sets up the necessary fields in the irq sructs. The main reason for
this race is, that we unmask the serial port irqs too early without having set
up everything properly before (which isn't easily possible because we need the
IRQ number to register the serial ports).
This patch is a work-around for this problem. It adds checks to the CPU irq
handler to verify if the IRQ action field has been initialized already. If not,
we just skip this interrupt (which isn't critical for a serial port at bootup).
The real fix would probably involve rewriting all PA-RISC specific IRQ code
(for CPU, IOSAPIC, GSC and EISA) to use IRQ domains with proper parenting of
the irq chips and proper irq enabling along this line.
This bug has been in the PA-RISC port since the beginning, but the crashes
happened very rarely with currently used hardware. But on the latest machine
which I bought (a C8000 workstation), which uses the fastest CPUs (4 x PA8900,
1GHz) and which has the largest possible L1 cache size (64MB each), the kernel
crashed at every boot because of this race. So, without this patch the machine
would currently be unuseable.
For the record, here is the flow logic:
1. serial_init_chip() in 8250_gsc.c calls iosapic_serial_irq().
2. iosapic_serial_irq() calls txn_alloc_irq() to find the irq.
3. iosapic_serial_irq() calls cpu_claim_irq() to register the CPU irq
4. cpu_claim_irq() unmasks the CPU irq (which it shouldn't!)
5. serial_init_chip() then registers the 8250 port.
Problems:
- In step 4 the CPU irq shouldn't have been registered yet, but after step 5
- If serial irq happens between 4 and 5 have finished, the kernel will crash
commit 1b59ddfcf1678de38a1f8ca9fb8ea5eebeff1843 upstream.
The attached change fixes the condition used in the "sub" instruction.
A double word comparison is needed. This fixes the 64-bit LWS CAS
operation on 64-bit kernels.
I can now enable 64-bit atomic support in GCC.
Signed-off-by: John David Anglin <dave.anglin>
commit 4c4ac9a48ac512c6b5a6cca06cfad2ad96e8caaa upstream.
Commit 0e0da48dee8d ("parisc: mm: don't count preallocated pmds")
introduced a memory leak.
After this commit, the 'return' statement in pmd_free is executed in all
cases. Even for pmd that are not attached to the pgd. So 'free_pages'
can never be called anymore, leading to a memory leak.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Acked-by: Mikulas Patocka <mpatocka@redhat.com>
based on timing results
commit 01ab60570427caa24b9debc369e452e86cd9beb4 upstream.
The increased use of pdtlb/pitlb instructions seemed to increase the
frequency of random segmentation faults building packages. Further, we
had a number of cases where TLB inserts would repeatedly fail and all
forward progress would stop. The Haskell ghc package caused a lot of
trouble in this area. The final indication of a race in pte handling was
this syslog entry on sibaris (C8000):
swap_free: Unused swap offset entry 00000004
BUG: Bad page map in process mysqld pte:00000100 pmd:019bbec5
addr:00000000ec464000 vm_flags:00100073 anon_vma:0000000221023828 mapping: (null) index:ec464
CPU: 1 PID: 9176 Comm: mysqld Not tainted 4.0.0-2-parisc64-smp #1 Debian 4.0.5-1
Backtrace:
[<0000000040173eb0>] show_stack+0x20/0x38
[<0000000040444424>] dump_stack+0x9c/0x110
[<00000000402a0d38>] print_bad_pte+0x1a8/0x278
[<00000000402a28b8>] unmap_single_vma+0x3d8/0x770
[<00000000402a4090>] zap_page_range+0xf0/0x198
[<00000000402ba2a4>] SyS_madvise+0x404/0x8c0
Note that the pte value is 0 except for the accessed bit 0x100. This bit
shouldn't be set without the present bit.
It should be noted that the madvise system call is probably a trigger for many
of the random segmentation faults.
In looking at the kernel code, I found the following problems:
1) The pte_clear define didn't take TLB lock when clearing a pte.
2) We didn't test pte present bit inside lock in exception support.
3) The pte and tlb locks needed to merged in order to ensure consistency
between page table and TLB. This also has the effect of serializing TLB
broadcasts on SMP systems.
The attached change implements the above and a few other tweaks to try
to improve performance. Based on the timing code, TLB purges are very
slow (e.g., ~ 209 cycles per page on rp3440). Thus, I think it
beneficial to test the split_tlb variable to avoid duplicate purges.
Probably, all PA 2.0 machines have combined TLBs.
I dropped using __flush_tlb_range in flush_tlb_mm as I realized all
applications and most threads have a stack size that is too large to
make this useful. I added some comments to this effect.
Since implementing 1 through 3, I haven't had any random segmentation
faults on mx3210 (rp3440) in about one week of building code and running
as a Debian buildd.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
architectures
On architectures where the stack grows upwards (CONFIG_STACK_GROWSUP=y,
currently parisc and metag only) stack randomization sometimes leads to crashes
when the stack ulimit is set to lower values than STACK_RND_MASK (which is 8 MB
by default if not defined in arch-specific headers).
The problem is, that when the stack vm_area_struct is set up in fs/exec.c, the
additional space needed for the stack randomization (as defined by the value of
STACK_RND_MASK) was not taken into account yet and as such, when the stack
randomization code added a random offset to the stack start, the stack
effectively got smaller than what the user defined via rlimit_max(RLIMIT_STACK)
which then sometimes leads to out-of-stack situations and crashes.
This patch fixes it by adding the maximum possible amount of memory (based on
STACK_RND_MASK) which theoretically could be added by the stack randomization
code to the initial stack size. That way, the user-defined stack size is always
guaranteed to be at minimum what is defined via rlimit_max(RLIMIT_STACK).
This bug is currently not visible on the metag architecture, because on metag
STACK_RND_MASK is defined to 0 which effectively disables stack randomization.
The changes to fs/exec.c are inside an "#ifdef CONFIG_STACK_GROWSUP"
section, so it does not affect other platformws beside those where the
stack grows upwards (parisc and metag).
Cc: linux-parisc@vger.kernel.org
Cc: James Hogan <james.hogan@imgtec.com>
Cc: linux-metag@vger.kernel.org
Cc: stable@vger.kernel.org # v3.16+
The 'arg' argument to copy_thread() is only ever used when forking a new
kernel thread. Hence, rename it to 'kthread_arg' for clarity (and
consistency with do_fork() and other arch-specific implementations of
copy_thread()).
Signed-off-by: Alex Dowad <alexinbeijing@gmail.com>
The following warning is seen when compiling parisc images
./arch/parisc/include/asm/pgalloc.h: In function 'pgd_alloc':
./arch/parisc/include/asm/pgalloc.h:29:5: warning: "PT_NLEVELS" is not defined
Some definitions of PT_NLEVELS were missed with the conversion to
CONFIG_PGTABLE_LEVELS.
Fixes: f24ffde43237 ("parisc: expose number of page table levels
on Kconfig level")
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
The only reason to keep parisc's private asm/scatterlist.h was that it
had the macro sg_virt_addr(). Convert all callers to use something else
(sometimes just sg->offset was enough, others should use sg_virt()), and
we can just use the asm-generic scatterlist.h instead.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Dave Anglin <dave.anglin@bell.net>
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
Switch to using the newly created asm-generic/seccomp.h for the seccomp
strict mode syscall definitions. Definitions were identical.
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull exec domain removal from Richard Weinberger:
"This series removes execution domain support from Linux.
The idea behind exec domains was to support different ABIs. The
feature was never complete nor stable. Let's rip it out and make the
kernel signal handling code less complicated"
* 'exec_domain_rip_v2' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (27 commits)
arm64: Removed unused variable
sparc: Fix execution domain removal
Remove rest of exec domains.
arch: Remove exec_domain from remaining archs
arc: Remove signal translation and exec_domain
xtensa: Remove signal translation and exec_domain
xtensa: Autogenerate offsets in struct thread_info
x86: Remove signal translation and exec_domain
unicore32: Remove signal translation and exec_domain
um: Remove signal translation and exec_domain
tile: Remove signal translation and exec_domain
sparc: Remove signal translation and exec_domain
sh: Remove signal translation and exec_domain
s390: Remove signal translation and exec_domain
mn10300: Remove signal translation and exec_domain
microblaze: Remove signal translation and exec_domain
m68k: Remove signal translation and exec_domain
m32r: Remove signal translation and exec_domain
m32r: Autogenerate offsets in struct thread_info
frv: Remove signal translation and exec_domain
We would want to use number of page table level to define mm_struct.
Let's expose it as CONFIG_PGTABLE_LEVELS.
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Richard Weinberger <richard@nod.at>
Make the code which sets up the pmd depend on PT_NLEVELS == 3, not on
CONFIG_64BIT. The reason is, that a 64bit kernel with a page size
greater than 4k doesn't need the pmd and thus has PT_NLEVELS = 2.
The patch dc6c9a35b66b520cf67e05d8ca60ebecad3b0479 that counts pmds
allocated for a process introduced a bug on 64-bit PA-RISC kernels.
The PA-RISC architecture preallocates one pmd with each pgd. This
preallocated pmd can never be freed - pmd_free does nothing when it is
called with this pmd. When the kernel attempts to free this preallocated
pmd, it decreases the count of allocated pmds. The result is that the
counter underflows and this error is reported.
This patch fixes the bug by artifically incrementing the counter in
pmd_free when the kernel tries to free the preallocated pmd.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Thanks to spatch.
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded. Usually, these defines are provided by
<asm-generic/pgtable-nopmd.h> and <asm-generic/pgtable-nopud.h>.
But some architectures fold page table levels in a custom way. They
need to define these macros themself. This patch adds missing defines.
The patch fixes mm->nr_pmds underflow and eliminates dead __pmd_alloc()
and __pud_alloc() on architectures without these page table levels.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- several cleanups in kbuild
- serialize multiple *config targets so that 'make defconfig kvmconfig'
works
- The cc-ifversion macro got support for an else-branch
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild,gcov: simplify kernel/gcov/Makefile more
kbuild: allow cc-ifversion to have the argument for false condition
kbuild,gcov: remove unnecessary workaround
kbuild: do not add $(call ...) to invoke cc-version or cc-fullversion
kbuild: fix cc-ifversion macro
kbuild: drop $(version_h) from MRPROPER_FILES
kbuild: use mixed-targets when two or more config targets are given
kbuild: remove redundant line from bounds.h/asm-offsets.h
kbuild: merge bounds.h and asm-offsets.h rules
kbuild: Drop support for clean-rule
Remove the function smp_send_start() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
While working on arch/parisc/include/asm/uaccess.h, I noticed that some
macros within this header are made harder to read because they violate a
coding style rule: space is missing after comma.
Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
Fix that up using __force.
Drop code to create HP-UX gateway page and syscall entry code.
This patch series drops the support for 32bit HP-UX binaries.
The HP-UX compat layer has always been incomplete and it's unlikely that
someone will ever implement it.
Furthermore those two commits which enhance the compatibility of Linux on parisc
to other architectures:
f5a408d: parisc: Make EWOULDBLOCK be equal to EAGAIN on parisc
1f25df2: parisc: Reduce SIGRTMIN from 37 to 32 to behave like other Linux architectures
basically make it impossible to implement the HP-UX support correctly.
Add checks if the userspace trampoline code was correctly generated by the
signal trampoline generation code. In addition only flush caches as needed and
fix the old flushing code which didn't flushed all generated instructions.
For instrumenting global variables KASan will shadow memory backing memory
for modules. So on module loading we will need to allocate memory for
shadow and map it at address in shadow that corresponds to the address
allocated in module_alloc().
__vmalloc_node_range() could be used for this purpose, except it puts a
guard hole after allocated area. Guard hole in shadow memory should be a
problem because at some future point we might need to have a shadow memory
at address occupied by guard hole. So we could fail to allocate shadow
for module_alloc().
Now we have VM_NO_GUARD flag disabling guard page, so we need to pass into
__vmalloc_node_range(). Add new parameter 'vm_flags' to
__vmalloc_node_range() function.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Signed-off-by: Andrey Konovalov <adech.fo@gmail.com>
Cc: Yuri Gribov <tetra2005@gmail.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Pekka Enberg <penberg@kernel.org>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
LKP has triggered a compiler warning after my recent patch "mm: account
pmd page tables to the process":
mm/mmap.c: In function 'exit_mmap':
>> mm/mmap.c:2857:2: warning: right shift count >= width of type [enabled by default]
The code:
> 2857 WARN_ON(mm_nr_pmds(mm) >
2858 round_up(FIRST_USER_ADDRESS, PUD_SIZE) >> PUD_SHIFT);
In this, on tile, we have FIRST_USER_ADDRESS defined as 0. round_up() has
the same type -- int. PUD_SHIFT.
I think the best way to fix it is to define FIRST_USER_ADDRESS as unsigned
long. On every arch for consistency.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
We've replaced remap_file_pages(2) implementation with emulation. Nobody
creates non-linear mapping anymore.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Pull module and param fixes from Rusty Russell:
"Surprising number of fixes this merge window :(
The first two are minor fallout from the param rework which went in
this merge window.
The next three are a series which fixes a longstanding (but never
previously reported and unlikely , so no CC stable) race between
kallsyms and freeing the init section.
Finally, a minor cleanup as our module refcount will now be -1 during
unload"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: make module_refcount() a signed integer.
module: fix race in kallsyms resolution during module load success.
module: remove mod arg from module_free, rename module_memfree().
module_arch_freeing_init(): new hook for archs before module->module_init freed.
param: fix uninitialized read with CONFIG_DEBUG_LOCK_ALLOC
param: initialize store function to NULL if not available.
Archs have been abusing module_free() to clean up their arch-specific
allocations. Since module_free() is also (ab)used by BPF and trace code,
let's keep it to simple allocations, and provide a hook called before
that.
This means that avr32, ia64, parisc and s390 no longer need to implement
their own module_free() at all. avr32 doesn't need module_finalize()
either.
Cc: linux-ia64@vger.kernel.org
Cc: linux-s390@vger.kernel.org
The macros cc-version, cc-fullversion and ld-version take no argument.
It is not necessary to add $(call ...) to invoke them.
Acked-by: Helge Deller <deller@gmx.de> [parisc]
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc build fix from Helge Deller:
"This unbreaks the kernel compilation on parisc with gcc-4.9"
* 'parisc-3.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: fix out-of-register compiler error in ldcw inline assembler function
The __ldcw macro has a problem when its argument needs to be reloaded from
memory. The output memory operand and the input register operand both need to
be reloaded using a register in class R1_REGS when generating 64-bit code.
This fails because there's only a single register in the class. Instead, use a
memory clobber. This also makes the __ldcw macro a compiler memory barrier.
Cc: <stable@vger.kernel.org> [3.13+]
__get_cpu_var was removed. Update comments to refer to
this_cpu_ptr() instead.
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Tejun Heo <tj@kernel.org>
Pull networking updates from David Miller:
1) New offloading infrastructure and example 'rocker' driver for
offloading of switching and routing to hardware.
This work was done by a large group of dedicated individuals, not
limited to: Scott Feldman, Jiri Pirko, Thomas Graf, John Fastabend,
Jamal Hadi Salim, Andy Gospodarek, Florian Fainelli, Roopa Prabhu
2) Start making the networking operate on IOV iterators instead of
modifying iov objects in-situ during transfers. Thanks to Al Viro
and Herbert Xu.
3) A set of new netlink interfaces for the TIPC stack, from Richard
Alpe.
4) Remove unnecessary looping during ipv6 routing lookups, from Martin
KaFai Lau.
5) Add PAUSE frame generation support to gianfar driver, from Matei
Pavaluca.
6) Allow for larger reordering levels in TCP, which are easily
achievable in the real world right now, from Eric Dumazet.
7) Add a variable of napi_schedule that doesn't need to disable cpu
interrupts, from Eric Dumazet.
8) Use a doubly linked list to optimize neigh_parms_release(), from
Nicolas Dichtel.
9) Various enhancements to the kernel BPF verifier, and allow eBPF
programs to actually be attached to sockets. From Alexei
Starovoitov.
10) Support TSO/LSO in sunvnet driver, from David L Stevens.
11) Allow controlling ECN usage via routing metrics, from Florian
Westphal.
12) Remote checksum offload, from Tom Herbert.
13) Add split-header receive, BQL, and xmit_more support to amd-xgbe
driver, from Thomas Lendacky.
14) Add MPLS support to openvswitch, from Simon Horman.
15) Support wildcard tunnel endpoints in ipv6 tunnels, from Steffen
Klassert.
16) Do gro flushes on a per-device basis using a timer, from Eric
Dumazet. This tries to resolve the conflicting goals between the
desired handling of bulk vs. RPC-like traffic.
17) Allow userspace to ask for the CPU upon what a packet was
received/steered, via SO_INCOMING_CPU. From Eric Dumazet.
18) Limit GSO packets to half the current congestion window, from Eric
Dumazet.
19) Add a generic helper so that all drivers set their RSS keys in a
consistent way, from Eric Dumazet.
20) Add xmit_more support to enic driver, from Govindarajulu
Varadarajan.
21) Add VLAN packet scheduler action, from Jiri Pirko.
22) Support configurable RSS hash functions via ethtool, from Eyal
Perry.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1820 commits)
Fix race condition between vxlan_sock_add and vxlan_sock_release
net/macb: fix compilation warning for print_hex_dump() called with skb->mac_header
net/mlx4: Add support for A0 steering
net/mlx4: Refactor QUERY_PORT
net/mlx4_core: Add explicit error message when rule doesn't meet configuration
net/mlx4: Add A0 hybrid steering
net/mlx4: Add mlx4_bitmap zone allocator
net/mlx4: Add a check if there are too many reserved QPs
net/mlx4: Change QP allocation scheme
net/mlx4_core: Use tasklet for user-space CQ completion events
net/mlx4_core: Mask out host side virtualization features for guests
net/mlx4_en: Set csum level for encapsulated packets
be2net: Export tunnel offloads only when a VxLAN tunnel is created
gianfar: Fix dma check map error when DMA_API_DEBUG is enabled
cxgb4/csiostor: Don't use MASTER_MUST for fw_hello call
net: fec: only enable mdio interrupt before phy device link up
net: fec: clear all interrupt events to support i.MX6SX
net: fec: reset fep link status in suspend function
net: sock: fix access via invalid file descriptor
net: introduce helper macro for_each_cmsghdr
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
As there are now no remaining users of arch_fast_hash(), lets kill
it entirely.
This basically reverts commit 71ae8aac3e19 ("lib: introduce arch
optimized hash library") and follow-up work, that is f.e., commit
237217546d44 ("lib: hash: follow-up fixups for arch hash"),
commit e3fec2f74f7f ("lib: Add missing arch generic-y entries for
asm-generic/hash.h") and last but not least commit 6a02652df511
("perf tools: Fix include for non x86 architectures").
Cc: Francesco Fusco <fusco@ntop.org>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull asm-generic asm/io.h rewrite from Arnd Bergmann:
"While there normally is no reason to have a pull request for
asm-generic but have all changes get merged through whichever tree
needs them, I do have a series for 3.19.
There are two sets of patches that change significant portions of
asm/io.h, and this branch contains both in order to resolve the
conflicts:
- Will Deacon has done a set of patches to ensure that all
architectures define {read,write}{b,w,l,q}_relaxed() functions or
get them by including asm-generic/io.h.
These functions are commonly used on ARM specific drivers to avoid
expensive L2 cache synchronization implied by the normal
{read,write}{b,w,l,q}, but we need to define them on all
architectures in order to share the drivers across architectures
and to enable CONFIG_COMPILE_TEST configurations for them
- Thierry Reding has done an unrelated set of patches that extends
the asm-generic/io.h file to the degree necessary to make it useful
on ARM64 and potentially other architectures"
* tag 'asm-generic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: (29 commits)
ARM64: use GENERIC_PCI_IOMAP
sparc: io: remove duplicate relaxed accessors on sparc32
ARM: sa11x0: Use void __iomem * in MMIO accessors
arm64: Use include/asm-generic/io.h
ARM: Use include/asm-generic/io.h
asm-generic/io.h: Implement generic {read,write}s*()
asm-generic/io.h: Reconcile I/O accessor overrides
/dev/mem: Use more consistent data types
Change xlate_dev_{kmem,mem}_ptr() prototypes
ARM: ixp4xx: Properly override I/O accessors
ARM: ixp4xx: Fix build with IXP4XX_INDIRECT_PCI
ARM: ebsa110: Properly override I/O accessors
ARC: Remove redundant PCI_IOBASE declaration
documentation: memory-barriers: clarify relaxed io accessor semantics
x86: io: implement dummy relaxed accessor macros for writes
tile: io: implement dummy relaxed accessor macros for writes
sparc: io: implement dummy relaxed accessor macros for writes
powerpc: io: implement dummy relaxed accessor macros for writes
parisc: io: implement dummy relaxed accessor macros for writes
mn10300: io: implement dummy relaxed accessor macros for writes
