path: root/arch/powerpc/Kconfig.debug
2008-04-29[POWERPC] Add IRQSTACKS support on ppc32Kumar Gala
This makes it possible to use separate stacks for hard and soft IRQs on 32-bit powerpc as well as on 64-bit. The code for 32-bit is just the 32-bit analog of the 64-bit code. * Added allocation and initialization of the irq stacks. We limit the stacks to be in lowmem for ppc32. * Implemented ppc32 versions of call_do_softirq() and call_handle_irq() to switch the stack pointers * Reworked how we do stack overflow detection. We now keep around the limit of the stack in the thread_struct and compare against the limit to see if we've overflowed. We can now use this on ppc64 if desired. [ paulus@samba.org: Fixed bug on 6xx where we need to reload r9 with the thread_info pointer. ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-27KVM: ppc: PowerPC 440 KVM implementationHollis Blanchard
This functionality is definitely experimental, but is capable of running unmodified PowerPC 440 Linux kernels as guests on a PowerPC 440 host. (Only tested with 440EP "Bamboo" guests so far, but with appropriate userspace support other SoC/board combinations should work.) See Documentation/powerpc/kvm_440.txt for technical details. [stephen: build fix] Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-17[POWERPC] cpm-serial: Relocate CPM buffer descriptors and SMC parameter ram.Laurent Pinchart
This patch relocates the buffer descriptors and the SMC parameter RAM at the end of the first CPM muram chunk, as described in the device tree. This allows device trees to stop excluding SMC parameter ram allocated by the boot loader from the CPM muram node. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-23[POWERPC] 4xx: Base support for 440GX Taishan eval boardHugh Blemings
This patch adds base support for the AMCC Taishan 440GX evaluation board. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-23[POWERPC] 4xx: Add early udbg support for 40x processorsBenjamin Herrenschmidt
This adds some basic real mode based early udbg support for 40x in order to debug things more easily Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-12-11[POWERPC] Early debug forces console log level to maxBenjamin Herrenschmidt
This makes the early debug option force the console loglevel to the max. The early debug option is meant to catch messages very early in the kernel boot process, in many cases, before the kernel has a chance to parse the "debug" command line argument. Thus it makes sense when CONFIG_PPC_EARLY_DEBUG is set, to force the console log level to the max at boot time. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-19[POWERPC] 4xx: Split early debug output and early boot console for 44xValentine Barshak
Currently there's no way to enable early boot console on PowerPC 44x not specifying uart's physical address in kernel config, which is used for very early debug messages. This patch splits very early debug output (which needs uart physical address in kernel config) and early boot console (which searches for uarts in the device tree using find_legacy_serial_ports). We enable early boot console for all 44x processors, while (dangerous) early debug is user-selectable. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2007-10-12kconfig: syntax cleanup - drop support for "depends/requires/def_boolean"Adrian Bunk
Remove the following redundant and never or rarely used kconfig syntax: - "def_boolean" (same as "def_bool") - "requires" (same as "depends on") - "depends" (same as "depends on") This patch contains the code changes and Kconfig updates. The shipped files are in next patch to let actual codechange stand out. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-04[POWERPC] cpm: Describe multi-user ram in its own device node.Scott Wood
The way the current CPM binding describes available multi-user (a.k.a. dual-ported) RAM doesn't work well when there are multiple free regions, and it doesn't work at all if the region doesn't begin at the start of the muram area (as the hardware needs to be programmed with offsets into this area). The latter situation can happen with SMC UARTs on CPM2, as its parameter RAM is relocatable, u-boot puts it at zero, and the kernel doesn't support moving it. It is now described with a muram node, similar to QE. The current CPM binding is sufficiently recent (i.e. never appeared in an official release) that compatibility with existing device trees is not an issue. The code supporting the new binding is shared between cpm1 and cpm2, rather than remain separated. QE should be able to use this code as well, once minor fixes are made to its device trees. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-03[POWERPC] Add early debug console for CPM serial ports.Scott Wood
This code assumes that the ports have been previously set up, with buffers in DPRAM. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-09-14[POWERPC] Export virq mapping via debugfsMichael Ellerman
This adds a debugfs file "powerpc/virq_mapping", which shows the virtual to real mapping of irq numbers. Enable it with CONFIG_VIRQ_DEBUG. Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Chen Gong <G.Chen@freescale.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-29Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATIONRafael J. Wysocki
Replace CONFIG_SOFTWARE_SUSPEND with CONFIG_HIBERNATION to avoid confusion (among other things, with CONFIG_SUSPEND introduced in the next patch). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26[POWERPC] Only allow building of BootX text support on PPC_MULTIPLATFORMKumar Gala
BootX text code is only supported on systems with real OF at this point which is PPC_OF && PPC_MULTIPLATFORM. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-09Fix trivial typos in Kconfig* filesDavid Sterba
Fix several typos in help text in Kconfig* files. Signed-off-by: David Sterba <dave@jikos.cz> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08[POWERPC] Early serial debug support for PPC44xDavid Gibson
This adds support for early serial debugging via the built in port on IBM/AMCC PowerPC 44x CPUs. It uses a bolted TLB entry in address space 1 for the UART's mapping, allowing robust debugging both before and after the initialization of the MMU. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] DEBUG_PAGEALLOC for 64-bitBenjamin Herrenschmidt
Here's an implementation of DEBUG_PAGEALLOC for 64 bits powerpc. It applies on top of the 32 bits patch. Unlike Anton's previous attempt, I'm not using updatepp. I'm removing the hash entries from the bolted mapping (using a map in RAM of all the slots). Expensive but it doesn't really matter, does it ? :-) Memory hot-added doesn't benefit from this unless it's added at an address that is below end_of_DRAM() as calculated at boot time. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> arch/powerpc/Kconfig.debug | 2 arch/powerpc/mm/hash_utils_64.c | 84 ++++++++++++++++++++++++++++++++++++++-- 2 files changed, 82 insertions(+), 4 deletions(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] DEBUG_PAGEALLOC for 32-bitBenjamin Herrenschmidt
Here's an implementation of DEBUG_PAGEALLOC for ppc32. It disables BAT mapping and is only tested with Hash table based processor though it shouldn't be too hard to adapt it to others. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> arch/powerpc/Kconfig.debug | 9 ++++++ arch/powerpc/mm/init_32.c | 4 +++ arch/powerpc/mm/pgtable_32.c | 52 +++++++++++++++++++++++++++++++++++++++ arch/powerpc/mm/ppc_mmu_32.c | 4 ++- include/asm-powerpc/cacheflush.h | 6 ++++ 5 files changed, 74 insertions(+), 1 deletion(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-22[POWERPC] Removed config options that we don't support in embedded6xxKumar Gala
When we started arch/powerpc we duplicated a number of config options from arch/ppc for various platforms that are supported. Now that we actually support a few platforms, remove all the ones that haven't been moved over. Additionally, this cleanup moved the 82xx/PQ2 options over into arch/powerpc/platforms/82xx/Kconfig where they belong. It also killed GEN550 which doesn't exist in arch/powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-02-07[POWERPC] pasemi: UART udbg supportOlof Johansson
Early debug output for PA Semi UART. Uses the 2.05 CI real mode ops. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-07[POWERPC] Celleb: basic supportIshizaki Kou
This patch adds base support for Celleb platform. Signed-off-by: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-01-30[POWERPC] Enable stack debug features on ppc32Kumar Gala
Enable stack overflow checking (DEBUG_STACKOVERFLOW) and stack usage (DEBUG_STACK_USAGE) on ppc32. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-12-04[POWERPC] Allow CONFIG_BOOTX_TEXT on iSeriesStephen Rothwell
and therefore combined builds. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Allow xmon to build on legacy iSeriesStephen Rothwell
xmon still does not run on iSeries, but this allows us to build a combined kernel that includes it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Make xmon disassembly optionalMichael Ellerman
While adding spu disassembly support it struck me that we're actually carrying quite a lot of code around, just to do disassembly in the case of a crash. While on large systems it's not an issue, on smaller ones it might be nice to have xmon - but without the weight of the disassembly support. For a Cell build this saves ~230KB (!), and for pSeries ~195KB. We still support the 'di' and 'sdi' commands, however they just dump the instruction in hex. Move the definitions into a header to clean xmon.c just a tiny bit. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
2006-09-13[POWERPC] print backtrace when entering xmonOlaf Hering
xmon does not print a backtrace per default. This is bad on systems with USB keyboard, the most needed info about the crash is lost. print a backtrace during the very first xmon entry. Booting with xmon=nobt disables the autobacktrace functionality. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] powerpc: Instrument Hypervisor CallsMike Kravetz
Add instrumentation for hypervisor calls on pseries. Call statistics include number of calls, wall time and cpu cycles (if available) and are made available via debugfs. Instrumentation code is behind the HCALL_STATS config option and has no impact if not enabled. Signed-off-by: Mike Kravetz <kravetz@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[POWERPC] Add udbg support for RTAS consoleMichael Ellerman
Add udbg hooks for the RTAS console, based on the RTAS put-term-char and get-term-char calls. Along with my previous patches, this should enable debugging as soon as early_init_dt_scan_rtas() is called. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-19[PATCH] powerpc: Make early debugging options behave with oldconfigMichael Ellerman
If you undefine all the early debugging options and then run make oldconfig, you don't get prompted to see if you want to enable any of them. This is annoying. AFAICT we can't do this just with a choice, because the choice is either optional, in which case we don't get prompted, or not in which case we _must_ select early debugging. So add a bool which controls whether we have early debugging at all, and then if that's enabled provide the choice. The extra bool will actually be useful in another patch I have lying around, so this is a win-win. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-27powerpc: remove OCP referencesKumar Gala
OCP isn't used in arch/powerpc and hopefully will never be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-01-11[PATCH] powerpc: Make early debugging configurable via KconfigMichael Ellerman
This patch adds Kconfig entries to control the early debugging options, currently in setup_64.c. Doing this via Kconfig rather than #defines means you can have one source tree, which is buildable for multiple platforms - and you can enable the correct early debug option for each platform via .config. I made udbg_early_init() a static inline because otherwise GCC is to daft to optimise it away when debugging is off. Now that we have udbg_init_rtas() we can make call_rtas_display_status* static. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-07[PATCH] Move Kprobes and Oprofile to "Instrumentation Support" menuPrasanna S Panchamukhi
Andrew Morton suggested to move kprobes from kernel hacking menu, since kernel hacking menu is in-appropriate for the Kprobes. This patch moves Kprobes and Oprofile under instrumentation menu. (akpm: it's not a natural fit, but things like djprobes and the s390 guys' statistics library need a home) Signed-of-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: John Levon <levon@movementarian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-10powerpc: Merge Kconfig.debugPaul Mackerras
This merges in the ppc64 bits into arch/powerpc/Kconfig.debug Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-01powerpc: make iSeries bootStephen Rothwell
Now that we use the device tree, it helps to build it in. It helps to links the kernel at the correct address. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2005-09-26powerpc: Merge enough to start building in arch/powerpc.Paul Mackerras
This creates the directory structure under arch/powerpc and a bunch of Kconfig files. It does a first-cut merge of arch/powerpc/mm, arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough to build a 32-bit powermac kernel with ARCH=powerpc. For now we are getting some unmerged files from arch/ppc/kernel and arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes to files in those directories and files outside arch/powerpc. The boot directory is still not merged. That's going to be interesting. Signed-off-by: Paul Mackerras <paulus@samba.org>
