path: root/arch/powerpc/Kconfig
2010-05-24powerpc/kexec: Add support for FSL-BookESebastian Andrzej Siewior
This adds support kexec on FSL-BookE where the MMU can not be simply switched off. The code borrows the initial MMU-setup code to create the identical mapping mapping. The only difference to the original boot code is the size of the mapping(s) and the executeable address. The kexec code maps the first 2 GiB of memory in 256 MiB steps. This should work also on e500v1 boxes. SMP support is still not available. (Kumar: Added minor change to build to ifdef CONFIG_PPC_STD_MMU_64 some code that was PPC64 specific) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07powerpc: Add kprobe-based event tracerMahesh Salgaonkar
This patch ports the kprobe-based event tracer to powerpc. This patch is based on x86 port. This brings powerpc on par with x86. Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-03-19powerpc: Remove IOMMU_VMERGE config optionFUJITA Tomonori
The description says: Cause IO segments sent to a device for DMA to be merged virtually by the IOMMU when they happen to have been allocated contiguously. This doesn't add pressure to the IOMMU allocator. However, some drivers don't support getting large merged segments coming back from *_map_sg(). Most drivers don't have this problem; it is safe to say Y here. It's out of date. Long ago, drivers didn't have a way to tell IOMMUs about their segment length limit (that is, the maximum segment length that they can handle). So IOMMUs merged as many segments as possible and gave too large segments to drivers. dma_get_max_seg_size() was introduced to solve the above problem. Device drives can use the API to tell IOMMU about the maximum segment length that they can handle. In addition, the default limit (64K) should be safe for everyone. So this config option seems to be unnecessary. Note that this config option just enables users to disable the virtual merging by default. Users can still disable the virtual merging by the boot parameter. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-03-12pci-dma: powerpc: use include/linux/pci-dma.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Manual merge of: drivers/char/hvc_console.c drivers/char/hvc_console.h
2010-02-17powerpc/booke: Introduce new CONFIG options for advanced debug registersDave Kleikamp
powerpc/booke: Introduce new CONFIG options for advanced debug registers From: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Introduce new config options to simplify the ifdefs pertaining to the advanced debug registers for booke and 40x processors: CONFIG_PPC_ADV_DEBUG_REGS - boolean: true for dac-based processors CONFIG_PPC_ADV_DEBUG_IACS - number of IAC registers CONFIG_PPC_ADV_DEBUG_DACS - number of DAC registers CONFIG_PPC_ADV_DEBUG_DVCS - number of DVC registers CONFIG_PPC_ADV_DEBUG_DAC_RANGE - DAC ranges supported Beginning conservatively, since I only have the facilities to test 440 hardware. I believe all 40x and booke platforms support at least 2 IAC and 2 DAC registers. For 440, 4 IAC and 2 DVC registers are enabled, as well as the DAC ranges. Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-02-03powerpc: Increase NR_IRQS Kconfig maximum to 32768Anton Blanchard
With dynamic irq descriptors the overhead of a large NR_IRQS is much lower than it used to be. With more MSI-X capable adapters and drivers exploiting multiple vectors we may as well allow the user to increase it beyond the current maximum of 512. 32768 seems large enough that we'd never have to bump it again (although I bet my prediction is horribly wrong). It boot tests OK and the vmlinux footprint increase is only around 500kB due to: struct irq_map_entry irq_map[NR_IRQS]; We format /proc/interrupts correctly with the previous changes: CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 286: 0 0 0 0 0 0 516: 0 0 0 0 0 0 16689: 1833 0 0 0 0 0 17157: 0 0 0 0 0 0 17158: 319 0 0 0 0 0 25092: 0 0 0 0 0 0 Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-01-28Merge commit 'v2.6.33-rc5' into secretlab/test-devicetreeGrant Likely
2009-12-16Merge branch 'next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next' of git://git.secretlab.ca/git/linux-2.6: (23 commits) powerpc: fix up for mmu_mapin_ram api change powerpc: wii: allow ioremap within the memory hole powerpc: allow ioremap within reserved memory regions wii: use both mem1 and mem2 as ram wii: bootwrapper: add fixup to calc useable mem2 powerpc: gamecube/wii: early debugging using usbgecko powerpc: reserve fixmap entries for early debug powerpc: wii: default config powerpc: wii: platform support powerpc: wii: hollywood interrupt controller support powerpc: broadway processor support powerpc: wii: bootwrapper bits powerpc: wii: device tree powerpc: gamecube: default config powerpc: gamecube: platform support powerpc: gamecube/wii: flipper interrupt controller support powerpc: gamecube/wii: udbg support for usbgecko powerpc: gamecube/wii: do not include PCI support powerpc: gamecube/wii: declare as non-coherent platforms powerpc: gamecube/wii: introduce GAMECUBE_COMMON ... Fix up conflicts in arch/powerpc/mm/fsl_booke_mmu.c. Hopefully even close to correctly.
2009-12-12powerpc: gamecube/wii: do not include PCI supportAlbert Herranz
The Nintendo GameCube and Wii video game consoles do not have PCI hardware. Avoid wasting their scarce memory by not including PCI support into the kernel. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-09sysfs/cpu: Add probe/release filesNathan Fontenot
Version 3 of this patch is updated with documentation added to Documentation/ABI. There are no changes to any of the C code from v2 of the patch. In order to support kernel DLPAR of CPU resources we need to provide an interface to add (probe) and remove (release) the resource from the system. This patch Creates new generic probe and release sysfs files to facilitate cpu probe/release. The probe/release interface provides for allowing each arch to supply their own routines for implementing the backend of adding and removing cpus to/from the system. This also creates the powerpc specific stubs to handle the arch callouts from writes to the sysfs files. The creation and use of these files is regulated by the CONFIG_ARCH_CPU_PROBE_RELEASE option so that only architectures that need the capability will have the files created. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-11-23of/flattree: merge find_flat_dt_string and initial_boot_paramsGrant Likely
Merge common code between Microblaze and PowerPC. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Tested-by: Michal Simek <monstr@monstr.eu>
2009-11-11powerpc/85xx/86xx: Add suspend/resume supportAnton Vorontsov
This patch adds suspend/resume support for MPC8540 and MPC8641D- compatible CPUs. To reach sleep state, we just write the SLP bit into the PM control and status register. So far we don't support Deep Sleep mode as found in newer MPC85xx CPUs (i.e. MPC8536). It can be relatively easy implemented though, and for it we reserve 'mem' suspend type. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-30powerpc: Enable sparse irq_descs on powerpcMichael Ellerman
Defining CONFIG_SPARSE_IRQ enables generic code that gets rid of the static irq_desc array, and replaces it with an array of pointers to irq_descs. It also allows node local allocation of irq_descs, however we currently don't have the information available to do that, so we just allocate them on all on node 0. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-30powerpc: Make NR_IRQS a CONFIG optionMichael Ellerman
The irq_desc array consumes quite a lot of space, and for systems that don't need or can't have 512 irqs it's just wasted space. The first 16 are reserved for ISA, so the minimum of 32 is really 16 - and no one has asked for more than 512 so leave that as the maximum. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-30powerpc: Make it possible to select hibernation on all PowerPCsAnton Vorontsov
Just as with kexec, hibernation may fail even on well-tested platforms: some PCI device, a driver of which doesn't play well with hibernation, is enough to break resuming. Hibernation code is not much platform dependent, and hiding features only because these were not verified on a particular hardware is counterproductive: we just prevent the features from being widely tested. For example, with this patch I just tested hibernation on a MPC83xx board, and it works quite well, modulo a few drivers that need some fixing. So, let's make it possible to select hibernation support for all PowerPCs, then let's wait for any possible bug reports, and actually fix (or just collect ;-) the bugs instead of hiding them. If some platforms really can't stand hibernation, we can make a blacklist, with proper comments why exactly hibernation doesn't work, whether it is possible to fix, and what needs to be done to fix it. CONFIG_HIBERNATION is still =n by default, so the commit doesn't change anything apart from ability to set it to =y. I'm not sure if EXPERIMENTAL dependency is needed, I'd rather not add it for a few reasons: 1) It doesn't matter much, for distro kernels user has no clue that some feature is experimental. Majority of defconfigs enable EXPERIMENTAL anyway (90 vs. 4, which, btw, means that EXPERIMENTAL is overused in Kconfigs); 2) EXPERIMENTAL is a good thing for features that change default behaviour of a kernel, while for hibernation user has to explicitly issue 'echo disk > /sys/power/state' to trigger any hibernation bugs; 3) Per init/Kconfig, EXPERIMENTAL is a good thing to scare and discourage users from 'widespread use of a feature', while we want to encourage that use. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-30powerpc: Cleanup Kconfig selection of hugetlbfs supportBenjamin Herrenschmidt
2009-09-24powerpc: Increase NODES_SHIFT on 64bit from 4 to 8Anton Blanchard
Some System p configurations can already have more than 16 nodes so we need to increase NODES_SHIFT. I chose 256 to give us some room to grow in the future, although we can look at something smaller if the memory bloat is considered too much. Unless we clamp MAX_ACTIVE_REGIONS we end up with 300kB of extra bloat in early_node_map in mm/page_alloc.c: < 6144 early_node_map > 307200 early_node_map due to: #if MAX_NUMNODES >= 32 /* If there can be many nodes, allow up to 50 holes per node */ #define MAX_ACTIVE_REGIONS (MAX_NUMNODES*50) #else /* By default, allow up to 256 distinct regions */ #define MAX_ACTIVE_REGIONS 256 Since our memory is mostly contiguous it seems reasonable to keep this at 256 for now. I also set 32bit to 32 to save space (is there any chance a 32bit system will have more than 32 discontiguous memory ranges?). Even with that fixed we have a few data structures that grow: < 896 bootmem_node_data > 14336 bootmem_node_data < 1280 node_devices > 20480 node_devices < 25088 kmalloc_caches > 59648 kmalloc_caches < 1632 hstates > 21792 hstates Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-15Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (134 commits) powerpc/nvram: Enable use Generic NVRAM driver for different size chips powerpc/iseries: Fix oops reading from /proc/iSeries/mf/*/cmdline powerpc/ps3: Workaround for flash memory I/O error powerpc/booke: Don't set DABR on 64-bit BookE, use DAC1 instead powerpc/perf_counters: Reduce stack usage of power_check_constraints powerpc: Fix bug where perf_counters breaks oprofile powerpc/85xx: Fix SMP compile error and allow NULL for smp_ops powerpc/irq: Improve nanodoc powerpc: Fix some late PowerMac G5 with PCIe ATI graphics powerpc/fsl-booke: Use HW PTE format if CONFIG_PTE_64BIT powerpc/book3e: Add missing page sizes powerpc/pseries: Fix to handle slb resize across migration powerpc/powermac: Thermal control turns system off too eagerly powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan() powerpc/405ex: support cuImage via included dtb powerpc/405ex: provide necessary fixup function to support cuImage powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBC powerpc/44x: Add Eiger AMCC (AppliedMicro) PPC460SX evaluation board support. powerpc/44x: Update Arches defconfig powerpc/44x: Update Arches dts ... Fix up conflicts in drivers/char/agp/uninorth-agp.c
2009-08-28powerpc: Add CONFIG_DMA_API_DEBUG supportFUJITA Tomonori
2009-08-28powerpc: Use asm-generic/dma-mapping-common.hFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc: Remaining 64-bit Book3E supportBenjamin Herrenschmidt
This contains all the bits that didn't fit in previous patches :-) This includes the actual exception handlers assembly, the changes to the kernel entry, other misc bits and wiring it all up in Kconfig. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-20powerpc/mm: Fix definitions of FORCE_MAX_ZONEORDER in KconfigBenjamin Herrenschmidt
The current definitions set ranges and defaults for 32 and 64-bit only using "PPC_STD_MMU" which means hash based MMU. This uselessly restrict the usefulness for the upcoming 64-bit BookE port, but more than that, it's broken on 32-bit since the only 32-bit platform supporting multiple page sizes currently is 44x which does -not- have PPC_STD_MMU_32 set. This fixes it by using PPC64 and PPC32 instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-14powerpc64: convert to dynamic percpu allocatorTejun Heo
Now that percpu allows arbitrary embedding of the first chunk, powerpc64 can easily be converted to dynamic percpu allocator. Convert it. powerpc supports several large page sizes. Cap atom_size at 1M. There isn't much to gain by going above that anyway. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-07-04Merge branch 'master' into for-nextTejun Heo
Pull linus#master to merge PER_CPU_DEF_ATTRIBUTES and alpha build fix changes. As alpha in percpu tree uses 'weak' attribute instead of inline assembly, there's no need for __used attribute. Conflicts: arch/alpha/include/asm/percpu.h arch/mn10300/kernel/vmlinux.lds.S include/linux/percpu-defs.h
2009-06-26powerpc: Add irqtrace support for 32-bit powerpcBenjamin Herrenschmidt
Based on initial work from: Dale Farnsworth <dale@farnsworth.org> Add the low level irq tracing hooks for 32-bit powerpc needed to enable full lockdep functionality. The approach taken to deal with the code in entry_32.S is that we don't trace all the transitions of MSR:EE when we just turn it off to peek at TI_FLAGS without races. Only when we are calling into C code or returning from exceptions with a state that have changed from what lockdep thinks. There's a little bugger though: If we take an exception that keeps interrupts enabled (such as an alignment exception) while interrupts are enabled, we will call trace_hardirqs_on() on the way back spurriously. Not a big deal, but to get rid of it would require remembering in pt_regs that the exception was one of the type that kept interrupts enabled which we don't know at this stage. (Well, we could test all cases for regs->trap but that sucks too much). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Tested-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-24percpu: use dynamic percpu allocator as the default percpu allocatorTejun Heo
This patch makes most !CONFIG_HAVE_SETUP_PER_CPU_AREA archs use dynamic percpu allocator. The first chunk is allocated using embedding helper and 8k is reserved for modules. This ensures that the new allocator behaves almost identically to the original allocator as long as static percpu variables are concerned, so it shouldn't introduce much breakage. s390 and alpha use custom SHIFT_PERCPU_PTR() to work around addressing range limit the addressing model imposes. Unfortunately, this breaks if the address is specified using a variable, so for now, the two archs aren't converted. The following architectures are affected by this change. * sh * arm * cris * mips * sparc(32) * blackfin * avr32 * parisc (broken, under investigation) * m32r * powerpc(32) As this change makes the dynamic allocator the default one, CONFIG_HAVE_DYNAMIC_PER_CPU_AREA is replaced with its invert - CONFIG_HAVE_LEGACY_PER_CPU_AREA, which is added to yet-to-be converted archs. These archs implement their own setup_per_cpu_areas() and the conversion is not trivial. * powerpc(64) * sparc(64) * ia64 * alpha * s390 Boot and batch alloc/free tests on x86_32 with debug code (x86_32 doesn't use default first chunk initialization). Compile tested on sparc(32), powerpc(32), arm and alpha. Kyle McMartin reported that this change breaks parisc. The problem is still under investigation and he is okay with pushing this patch forward and fixing parisc later. [ Impact: use dynamic allocator for most archs w/o custom percpu setup ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Reviewed-by: Christoph Lameter <cl@linux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Bryan Wu <cooloney@kernel.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-18perf_counter: powerpc: Enable use of software counters on 32-bit powerpcPaul Mackerras
This enables the perf_counter subsystem on 32-bit powerpc. Since we don't have any support for hardware counters on 32-bit powerpc yet, only software counters can be used. Besides selecting HAVE_PERF_COUNTERS for 32-bit powerpc as well as 64-bit, the main thing this does is add an implementation of set_perf_counter_pending(). This needs to arrange for perf_counter_do_pending() to be called when interrupts are enabled. Rather than add code to local_irq_restore as 64-bit does, the 32-bit set_perf_counter_pending() generates an interrupt by setting the decrementer to 1 so that a decrementer interrupt will become pending in 1 or 2 timebase ticks (if a decrementer interrupt isn't already pending). When interrupts are enabled, timer_interrupt() will be called, and some new code in there calls perf_counter_do_pending(). We use a per-cpu array of flags to indicate whether we need to call perf_counter_do_pending() or not. This introduces a couple of new Kconfig symbols: PPC_HAVE_PMU_SUPPORT, which is selected by processor families for which we have hardware PMU support (currently only PPC64), and PPC_PERF_CTRS, which enables the powerpc-specific perf_counter back-end. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linuxppc-dev@ozlabs.org Cc: benh@kernel.crashing.org LKML-Reference: <19000.55404.103840.393470@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-15powerpc: Use generic atomic64_t implementation on 32-bit processorsPaul Mackerras
This makes 32-bit powerpc use the generic atomic64_t implementation. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-15powerpc: Don't do generic calibrate_delay()Benjamin Herrenschmidt
Currently we are wasting time calling the generic calibrate_delay() function. We don't need it since our implementation of __delay() is based on the CPU timebase. So instead, we use our own small implementation that initializes loops_per_jiffy to something sensible to make the few users like spinlock debug be happy Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-09powerpc: Add support for swiotlb on 32-bitBecky Bruce
This patch includes the basic infrastructure to use swiotlb bounce buffering on 32-bit powerpc. It is not yet enabled on any platforms. Probably the most interesting bit is the addition of addr_needs_map to dma_ops - we need this as a dma_op because the decision of whether or not an addr can be mapped by a device is device-specific. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-29Merge branch 'merge' into nextBenjamin Herrenschmidt
2009-05-27powerpc: Fix up dma_alloc_coherent() on platforms without cache coherency.Benjamin Herrenschmidt
The implementation we just revived has issues, such as using a Kconfig-defined virtual address area in kernel space that nothing actually carves out (and thus will overlap whatever is there), or having some dependencies on being self contained in a single PTE page which adds unnecessary constraints on the kernel virtual address space. This fixes it by using more classic PTE accessors and automatically locating the area for consistent memory, carving an appropriate hole in the kernel virtual address space, leaving only the size of that area as a Kconfig option. It also brings some dma-mask related fixes from the ARM implementation which was almost identical initially but grew its own fixes. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-27Revert "powerpc: Rework dma-noncoherent to use generic vmalloc layer"Benjamin Herrenschmidt
This reverts commit 33f00dcedb0e22cdb156a23632814fc580fcfcf8. While it was a good idea to try to use the mm/vmalloc.c allocator instead of our own (in fact, ours is itself a dup on an old variant of the vmalloc one), unfortunately, the approach is terminally busted since dma_alloc_coherent() can be called at interrupt time or in atomic contexts and there's little chances we'll make the code in mm/vmalloc.c cope with\ that :-( Until we can get the generic code to forbid that idiocy and fix all drivers abusing it, we pretty much have no choice but revert to our custom virtual space allocator. There's also a problem with SMP safety since freeing such mapping would require an IPI which cannot be done at interrupt time. However, right now, I don't think we support any platform that is both SMP and has non-coherent DMA (don't laugh, I know such things do exist !) so we can sort that out later. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-21powerpc/irq: We don't need __do_IRQ() anymoreMichael Ellerman
So select GENERIC_HARDIRQS_NO__DO_IRQ to disable it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-15powerpc: Allow 256kB pages with SHMEMHugh Dickins
Now that shmem's divisions by zero and SHMEM_MAX_BYTES are fixed, let powerpc 256kB pages coexist with CONFIG_SHMEM again. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc: Correct dependency of KEXECGeert Uytterhoeven
commit 28794d34ecb6815a3fa0a4256027c9b081a17c5f ("powerpc/kconfig: Kill PPC_MULTIPLATFORM") broke KEXEC, by making it dependent on BOOK3S, while it should be PPC_BOOK3S. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07Merge branch 'next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2009-04-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (28 commits) trivial: Update my email address trivial: NULL noise: drivers/mtd/tests/mtd_*test.c trivial: NULL noise: drivers/media/dvb/frontends/drx397xD_fw.h trivial: Fix misspelling of "Celsius". trivial: remove unused variable 'path' in alloc_file() trivial: fix a pdlfush -> pdflush typo in comment trivial: jbd header comment typo fix for JBD_PARANOID_IOFAIL trivial: wusb: Storage class should be before const qualifier trivial: drivers/char/bsr.c: Storage class should be before const qualifier trivial: h8300: Storage class should be before const qualifier trivial: fix where cgroup documentation is not correctly referred to trivial: Give the right path in Documentation example trivial: MTD: remove EOL from MODULE_DESCRIPTION trivial: Fix typo in bio_split()'s documentation trivial: PWM: fix of #endif comment trivial: fix typos/grammar errors in Kconfig texts trivial: Fix misspelling of firmware trivial: cgroups: documentation typo and spelling corrections trivial: Update contact info for Jochen Hein trivial: fix typo "resgister" -> "register" ...
2009-04-01generic debug pageallocAkinobu Mita
CONFIG_DEBUG_PAGEALLOC is now supported by x86, powerpc, sparc64, and s390. This patch implements it for the rest of the architectures by filling the pages with poison byte patterns after free_pages() and verifying the poison patterns before alloc_pages(). This generic one cannot detect invalid page accesses immediately but invalid read access may cause invalid dereference by poisoned memory and invalid write access can be detected after a long delay. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31powerpc: Make LOWMEM_CAM_NUM depend on FSL_BOOKEJosh Boyer
The recent addition of CONFIG_LOWMEM_CAM_BOOL and CONFIG_LOWMEM_CAM_NUM cause the latter to show up in configs that do not need it during 'make oldconfig'. Make LOWMEM_CAM_NUM depend on FSL_BOOKE. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-11powerpc/kconfig: Kill PPC_MULTIPLATFORMBenjamin Herrenschmidt
CONFIG_PPC_MULTIPLATFORM is a remain of the pre-powerpc days and isn't really meaningful anymore. It was basically equivalent to PPC64 || 6xx. This removes it along with the following changes: - 32-bit platforms that relied on PPC32 && PPC_MULTIPLATFORM now rely on 6xx which is what they want anyway. - A new symbol, PPC_BOOK3S, is defined that represent compliance with the "Server" variant of the architecture. This is set when either 6xx or PPC64 is set and open the door for future BOOK3E 64-bit. - 64-bit platforms that relied on PPC64 && PPC_MULTIPLATFORM now use PPC64 && PPC_BOOK3S - A separate and selectable CONFIG_PPC_OF_BOOT_TRAMPOLINE option is now used to control the use of prom_init.c Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-03Merge commit 'jwb/next' into nextBenjamin Herrenschmidt
2009-02-23powerpc: Rework dma-noncoherent to use generic vmalloc layerIlya Yanok
This patch rewrites consistent dma allocations support to use vmalloc layer to allocate virtual memory space from vmalloc pool and get rid of CONFIG_CONSISTENT_{START,SIZE}. This greatly simplifies the code by effectively removing a custom allocator we had for virtual space. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc32, ftrace: dynamic function graph tracerSteven Rostedt
This patch gets function graph tracing working with dynamic function tracer on PowerPC32. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc32, ftrace: port function graph tracer to ppc32, static onlySteven Rostedt
This patch ports the function graph tracer for PowerPC, but only for static function tracing. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-23powerpc64, tracing: add function graph tracer with dynamic tracingSteven Rostedt
This is the port of the function graph tracer to PowerPC with dynamic tracing. Geoff Lavand tested on PS3. Tested-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
