path: root/arch/powerpc/boot/Makefile
2011-05-19powerpc: Use the deterministic mode of arMichal Marek
Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-20powerpc/boot: Add an ePAPR compliant boot wrapperDavid Gibson
This is a first cut at making bootwrapper code which will produce a zImage compliant with the requirements set down by ePAPR. This is a very simple bootwrapper, taking the device tree blob supplied by the ePAPR boot program and passing it on to the kernel. It builds on the earlier patch to build a relocatable ET_DYN zImage to meet the other ePAPR image requirements. For good measure we have some paranoid checks which will generate warnings if some of the ePAPR entry condition guarantees are not met. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-21powerpc/boot/dts: Install dts from the right directoryBen Hutchings
The dts-installed variable is initialised using a wildcard path that will be expanded relative to the build directory. Use the existing variable dtstree to generate an absolute wildcard path that will work when building in a separate directory. Reported-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Tested-by: Gerhard Pircher <gerhard_pircher@gmx.net> [against 2.6.32] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-12-23of/powerpc: Use generic rule to build dtb'sDirk Brandewie
Modify arch/powerpc/boot/Makefile to use dtc command in scripts/Makefile.lib Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-15powerpc/boot: Remove addRamdisk.c since it is now unusedPaul Mackerras
It was used in the dim distant past for adding initrds to images for legacy iSeries, but it's not even used for that now that we have initramfs. So remove it. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-05powerpc/4xx: Simple platform for the ISS 4xx simulatorTorez Smith
This is a trivial 4xx plaform that uses the new simple bsp from Josh and is handy to use in simulators such as ISS or even Mambo who don't properly implement most of the actual devices in the SoC but really only the core. Signed-off-by: Torez Smith <lnxtorez@linux.vnet.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2010-04-07powerpc: Add a new zImage for maple using a different link addressCorey Minyard
The maple platform failed to load because it's firmware could not take a link address of 0x4000000. A new platform type with a link address of 0x400000 had to be created for the maple. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-01-13zlib: Fix build of powerpc boot wrapperBenjamin Herrenschmidt
Commit ac4c2a3bbe5db5fc570b1d0ee1e474db7cb22585 broke the build of all powerpc boot wrappers. It attempts to add an include of autoconf.h but used the wrong path for it. It also adds -D__KERNEL__ to our boot wrapper, both things that we pretty much didn't do on purpose so far. We want our boot wrapper to remain independent enough of the kernel for various reasons, one of them being that you can "wrap" an existing kernel at distro install time which allows to ship one kernel image and a set of boot wrappers for different platforms, the wrappers don't have to be built out of the same kernel build tree. It's also incorrect to do what the patch does in our boot environment since we may not have a proper alignment exception handler which means we may not be able to fixup the few cases where an unaligned access will need SW emulation (depends on the core variant, could be when crossing page or segment boundaries for example). This patch fixes it by putting the old code back in and using the new "fancy" variant only when CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS is set, which happens not to be set on powerpc since we don't include autoconf.h. It also reverts the changes to our boot wrapper Makefile. This means that x86 should, afaik, keep the optimisations since its boot wrapper does include autoconf.h and define __KERNEL__ (though I doubt they make that much different outside of slow embedded processors). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-11zlib: optimize inffast when copying direct from outputJoakim Tjernlund
JFFS2 uses lesser compression ratio and inflate always ends up in "copy direct from output" case. This patch tries to optimize the direct copy procedure. Uses get_unaligned() but only in one place. The copy loop just above this one can also use this optimization, but I havn't done so as I have not tested if it is a win there too. On my MPC8321 this is about 17% faster on my JFFS2 root FS than the original. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-12powerpc: wii: bootwrapper bitsAlbert Herranz
Add support for the Nintendo Wii video game console to the powerpc bootwrapper. dtbImage.wii is a wrapped image that contains a flat device tree, an entry point compatible with the Homebrew Channel and BootMii, and an optional initrd. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-12powerpc: gamecube: bootwrapper bitsAlbert Herranz
Add support for the Nintendo GameCube video game console to the powerpc bootwrapper. dtbImage.gamecube is a wrapped image that contains a flat device tree, an entry point compatible with SDload, and an optional initrd. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-12powerpc: gamecube/wii: usbgecko bootwrapper console supportAlbert Herranz
Add support for using the USB Gecko adapter as a bootwrapper console on the Nintendo GameCube and Wii video game consoles. The USB Gecko is a 3rd party memory card interface adapter that provides a EXI (External Interface) to USB serial converter. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Acked-by: Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-08-31powerpc/405ex: support cuImage via included dtbTiejun Chen
To support cuImage, we need to initialize the required sections and ensure that it is built. Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-08-31powerpc/40x: Add support for the ESTeem 195E (PPC405EP) SBCSolomon Peachy
This patch adds support for the ESTeem 195E Hotfoot SBC. There are several variants of the SBC deployed, single/dual ethernet+serial, and also 4MB/8MB flash variations. In the interest of having a single kernel image boot on all boards, the cuboot shim detects the differences and mangles the DTS tree appropriately. With the exception of the CF interface that was never populated on production boards, this code/DTS supports all boardpop options. Signed-off-by: Solomon Peachy <solomon@linux-wlan.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-05-15Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix PCI ROM access powerpc/pseries: Really fix the oprofile CPU type on pseries serial/nwpserial: Fix wrong register read address and add interrupt acknowledge. powerpc/cell: Make ptcal more reliable powerpc: Allow mem=x cmdline to work with 4G+ powerpc/mpic: Fix incorrect allocation of interrupt rev-map powerpc: Fix oprofile sampling of marked events on POWER7 powerpc/iseries: Fix pci breakage due to bad dma_data initialization powerpc: Fix mktree build error on Mac OS X host powerpc/virtex: Fix duplicate level irq events. powerpc/virtex: Add uImage to the default images list powerpc/boot: add simpleImage.* to clean-files list powerpc/8xx: Update defconfigs powerpc/embedded6xx: Update defconfigs powerpc/86xx: Update defconfigs powerpc/85xx: Update defconfigs powerpc/83xx: Update defconfigs powerpc/fsl_soc: Remove mpc83xx_wdt_init, again
2009-05-14powerpc/boot: add simpleImage.* to clean-files listGrant Likely
2009-05-02Move dtc and libfdt sources from arch/powerpc/boot to scripts/dtcDavid Gibson
The powerpc kernel always requires an Open Firmware like device tree to supply device information. On systems without OF, this comes from a flattened device tree blob. This blob is usually generated by dtc, a tool which compiles a text description of the device tree into the flattened format used by the kernel. Sometimes, the bootwrapper makes small changes to the pre-compiled device tree blob (e.g. filling in the size of RAM). To do this it uses the libfdt library. Because these are only used on powerpc, the code for both these tools is included under arch/powerpc/boot (these were imported and are periodically updated from the upstream dtc tree). However, the microblaze architecture, currently being prepared for merging to mainline also uses dtc to produce device tree blobs. A few other archs have also mentioned some interest in using dtc. Therefore, this patch moves dtc and libfdt from arch/powerpc into scripts, where it can be used by any architecture. The vast bulk of this patch is a literal move, the rest is adjusting the various Makefiles to use dtc and libfdt correctly from their new locations. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11powerpc/amigaone: Bootwrapper and serial console support for AmigaOneGerhard Pircher
This adds the bootwrapper for the cuImage target and a compatible property check for "pnpPNP,501" to the generic serial console support code. The default link address for the cuImage target is set to 0x800000. This allows to boot the kernel with AmigaOS4's second level bootloader, which always loads a uImage at 0x500000. Signed-off-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-04powerpc/5200: Add support for the Media5200 board from FreescaleGrant Likely
This patch adds board support for the Media5200 platform. Changes are: - add the media5200 device tree - add the media5200 platform support code and cascaded interrupt controller - add media5200 to the build targets. Note: this patch also includes a minor tweak to the lite5200(b) target images list to add the .dtb files to the image list. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-01-08powerpc: Copy bootable images in the default install scriptGrant Likely
This patch makes the default install script (arch/powerpc/boot/install.sh) copy the bootable image files into the install directory. Before this patch only the vmlinux image file was copied. This patch makes the default 'make install' command useful for embedded development when $(INSTALL_PATH) is set in the environment. As a side effect, this patch changes the calling convention of the install.sh script. Instead of a single 5th parameter, the script is now passed a list of all the target images stored in the $(image-y) Makefile variable. This should be backwards compatible with existing install scripts since it just adds additional arguments and does not change existing ones. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-06trivial: Fix misspelling of "firmware" in powerpc MakefileNick Andrew
Fix misspelling of "firmware" in powerpc Makefile It's spelled "firmware". Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-12-22powerpc/cell: add QPACE as a separate Cell platformBenjamin Krill
Since the QPACE (Chromodynamics Parallel Computing on the Cell Broadband Engine) platform doesn't use a iommu, doesn't have PCI devices and a MPIC much lesser setup and configurations are needed. So far all devices are detected as OF device. A notifier function is used to set the dma_ops for the of_platform bus. Further this patch splits the PPC_CELL_NATIVE into PPC_CELL_COMMON which are parts that are shared with the QPACE platform and the rest. Signed-off-by: Benjamin Krill <ben@codiert.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2008-12-11powerpc/40x: Add proper BOOTCFLAGS for cuboot-acadiaJosh Boyer
The cuboot-acadia.c wrapper can cause assembler errors on some toolchains due to the lack of the proper BOOTCFLAGS. This adds the proper flags for the file. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-10-21powerpc: Add missing cuImage.initrd.% targetGrant Likely
This target is needed to build cuImages with an embedded ramdisk image. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-10-17powerpc/40x: Add cuboot wrapper for Acadia boardJosh Boyer
This adds a cuboot wrapper for the AMCC PowerPC 405EZ Acadia board. The clocking code is derived from U-Boot, originally written by Stefan Roese. Signed-off-by: Josh Boyer <jwboyer@linux.ibm.com>
2008-10-15Merge commit 'origin'Benjamin Herrenschmidt
Manual fixup of conflicts on: arch/powerpc/include/asm/dcr-regs.h drivers/net/ibm_newemac/core.h
2008-09-17powerpc: Holly board needs dtbImage targetJosh Boyer
One of the changes in the bootwrapper makefile introduced the dtbImage targets for boards that need a simple zImage with a DTB embedded in them (595be948cce574ff2d5dde5d0426a636a4363c70, "[POWERPC] bootwrapper: Build multiple cuImages"). When this was done, it broke booting on the Holly board as the zImage.holly wrapper did not get the DTB embedded properly. This changes the target for the Holly board to a dtbImage so that the wrapper includes the vmlinux, wrapper bits, and DTB. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-15powerpc: Make the 64-bit kernel as a position-independent executablePaul Mackerras
This implements CONFIG_RELOCATABLE for 64-bit by making the kernel as a position-independent executable (PIE) when it is set. This involves processing the dynamic relocations in the image in the early stages of booting, even if the kernel is being run at the address it is linked at, since the linker does not necessarily fill in words in the image for which there are dynamic relocations. (In fact the linker does fill in such words for 64-bit executables, though not for 32-bit executables, so in principle we could avoid calling relocate() entirely when we're running a 64-bit kernel at the linked address.) The dynamic relocations are processed by a new function relocate(addr), where the addr parameter is the virtual address where the image will be run. In fact we call it twice; once before calling prom_init, and again when starting the main kernel. This means that reloc_offset() returns 0 in prom_init (since it has been relocated to the address it is running at), which necessitated a few adjustments. This also changes __va and __pa to use an equivalent definition that is simpler. With the relocatable kernel, PAGE_OFFSET and MEMORY_START are constants (for 64-bit) whereas PHYSICAL_START is a variable (and KERNELBASE ideally should be too, but isn't yet). With this, relocatable kernels still copy themselves down to physical address 0 and run there. Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-08powerpc: Fix rare boot build breakageHugh Dickins
A make -j20 powerpc kernel build broke a couple of months ago saying: In file included from arch/powerpc/boot/gunzip_util.h:13, from arch/powerpc/boot/prpmc2800.c:21: arch/powerpc/boot/zlib.h:85: error: expected ‘:’, ‘,’, ‘;’, ‘}’ or ‘__attribute__’ before ‘*’ token arch/powerpc/boot/zlib.h:630: warning: type defaults to ‘int’ in declaration of ‘Byte’ arch/powerpc/boot/zlib.h:630: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token It happened again yesterday: too rare for me to confirm the fix, but it looks like the list of dependants on gunzip_util.h was incomplete. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-22powerpc/boot: Change spaces to tabsAdrian Bunk
For C code spaces versus tabs is just a religious issue, but for Makefiles it actually matters. This patch fixes he following errors: /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/Makefile:166: *** missing separator. Stop. /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/Makefile:171: *** missing separator. Stop. Since this was inside an ifdef DTC_GENPARSER it was not a problem unless someone wanted to regenerate the shipped generated files. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-15Merge commit 'jwb/jwb-next'Benjamin Herrenschmidt
2008-07-14Merge commit 'origin/HEAD' into test-mergeBenjamin Herrenschmidt
Manual fixup of include/asm-powerpc/pgtable-ppc64.h
2008-07-09powerpc/bootwrapper: Allow user to specify additional default targetsGrant Likely
It is inconvenient to add additional default targets to the bootwrapper Makefile for each new board supported which just needs a different dts file. This change allows the defconfig to specify additional build targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-07-04powerpc/virtex: Fix booting of Xilinx FPGAs with 16550 for 405 and 440John Linn
The following changes add processing to initialize the Xilinx 16550 UART in the boot wrapper for Virtex targets without firmware. Normally the boot wrapper assumes that the serial port has already been initialized by firmware. The wrapper was also modified to add the 440 build. Signed-off-by: John Linn <john.linn@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-01powerpc/bootwrapper: update for initrd with simpleImageJohn Linn
This change to the makefile corrects the build of a simpleImage with initrd. Signed-off-by: John Linn <john.linn@xilinx> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-01powerpc/bootwrapper: Pad .dtb by defaultKumar Gala
Since most bootloaders or wrappers tend to update or add some information to the .dtb they a handled they need some working space to do that in. By default add 1K of padding via a default setting of DTS_FLAGS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-30Merge branch 'linux-2.6'Paul Mackerras
2008-06-30Merge branch 'next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx
2008-06-16[POWERPC] Fix bootwrapper builds with newer gcc versionsKumar Gala
GCC 4.4.x looks to be adding support for generating out-of-line register saves/restores based on: http://gcc.gnu.org/ml/gcc-patches/2008-04/msg01678.html This breaks the bootwrapper as we'd need to link with libgcc to get the implementation of the register save/restores. To workaround this issue, we just stole the save/restore code from gcc and simplified it down for our needs (integer only). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-11powerpc/4xx: Sam440ep supportGiuseppe Coviello
The Sam440ep is an high customizable general purpose mini-itx board, based on the AMCC 440EP and with a LatticeXP FPGA onboard. It's poduced by ACube Systems Srl (Bassano del Grappa, Italy), http://www.acube-systems.biz. Signed-off-by: Giuseppe Coviello <gicoviello@gmail.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-06-10powerpc/85xx: add board support for the TQM8548 modulesWolfgang Grandegger
This patch adds support for the TQM8548 modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-09powerpc: Boot code for the C2KRemi Machet
Support for the C2K cPCI Single Board Computer from GEFanuc (PowerPC MPC7448 with a Marvell MV64460 chipset). All features of the board are not supported yet, but the board boots, flash works, all Ethernet ports are working and PCI devices are all found (USB and SATA on PCI1 do not work yet). Part 2 of 5: support for the board in arch/powerpc/boot. Signed-off-by: Remi Machet <rmachet@slac.stanford.edu> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-09Merge branch 'merge'Paul Mackerras
Conflicts: arch/powerpc/sysdev/fsl_soc.c
2008-06-09[POWERPC] boot/Makefile CONFIG_ variable fixesAdrian Bunk
This corrects the names of two CONFIG_ variables. Note that the CONFIG_MPC86XADS fix uncovers another bug (with mpc866_ads_defconfig) that will require fixing: <-- snip --> ... arch/powerpc/boot/dtc -O dtb -o arch/powerpc/boot/mpc866ads.dtb -b 0 /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/dts/mpc866ads.dts DTC: dts->dtb on file "/home/bunk/linux/kernel-2.6/git/linux-2.6/arch/powerpc/boot/dts/mpc866ads.dts" WRAP arch/powerpc/boot/cuImage.mpc866ads powerpc64-linux-ld: arch/powerpc/boot/cuboot-mpc866ads.o: No such file: No such file or directory make[2]: *** [arch/powerpc/boot/cuImage.mpc866ads] Error 1 <-- snip --> Reported-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-06-02[POWERPC] 83xx: Add support for Analogue & Micro ASP837E boardBryan O'Donoghue
The following adds support for the Analogue & Micro ASP 8347E, running Redboot. http://www.analogue-micro.com/ASP8347.html Signed-off-by: Bryan O'Donoghue <bodonoghue@codehermit.ie> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-05-20[POWERPC] Remove generated files on make cleanKumar Gala
dtbImage.* and several zImage. targets get created but never cleaned up. Also, moved zImage to the clean-files line associated with all other image results (was previously duplicated). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-24[POWERPC] bootwrapper: fix build error on virtex405-head.SGrant Likely
virtex405-head.S is an assembler file, not a C file; therefore BOOTAFLAGS is the correct place to set the needed -mcpu=405 flag. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-15[POWERPC] prpmc2800 needs a dtbImageDale Farnsworth
The prpmc2800 platform requires a zImage formatted file with an embedded dtb file. Rename the requested boot image file to dtbImage.prpmc2800. Signed-off-by: Dale Farnsworth <dale@farnsworth.org> Acked-by: Mark A. Greer <mgreer@mvista.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-02[POWERPC] bootwrapper: Add a firmware-independent simpleboot target.Grant Likely
This target produces a flat binary rather than an ELF file, fixes the entry point at the beginning of the image, and takes a complete device tree with no fixups needed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2008-04-02[POWERPC] add target for building .dtb filesGrant Likely
Call dtc from the Makefile instead of the wrapper script so that the dt blobs can be generated with a simple make invocation. Using this patch allows board ports to trigger automatic building of .dtb files by adding them to the image-y target list. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
